  4. Iobroker startet nach Stromausfall nicht mehr
    5.5k
55 Beiträge 9 Kommentatoren 7.1k Aufrufe 4 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    @hardy-0 Laut log startet er ja noch.
    Logfiles bitte als text in Code Tags </> Posten
    Was steht im iobroker log?
    Hardy 0H 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      Hardy 0H Offline
      Hardy 0H Offline
      Hardy 0
      @wendy2702
      Das ist der Log.
      -----                  Step 1 of 5: Preparing container                   -----
      This is not the first run of this container. Skipping first run preparation.
      Installing additional packages is set by ENV.
      Checking the following Packages: ...
      Reading package lists...
      Building dependency tree...
      Reading state information...
      0 upgraded, 0 newly installed, 0 to remove and 33 not upgraded.
      Done.
      -----             Step 2 of 5: Detecting ioBroker installation             -----
      Existing installation of ioBroker detected in /opt/iobroker.
      -----             Step 3 of 5: Checking ioBroker installation              -----
      (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
      Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
      -----                Step 4 of 5: Applying special settings                -----
      Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
      Usb-device-support is activated by ENV.
      chown: cannot access '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0': No such file or directory
      chmod: cannot access '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0': No such file or directory
      Setting permissions for /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0... Done.
      -----                    Step 5 of 5: ioBroker startup                     -----
      Starting ioBroker...
      host.b8818f500ddc check instance "system.adapter.admin.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.javascript.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.pushover.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.pushover.1" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.influxdb.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.influxdb.1" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.zigbee.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.alexa2.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.hm-rega.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.hm-rpc.1" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.sonoff.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.mqtt.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.ping.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.hm-rpc.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.ical.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.discovery.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.wled.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.accuweather.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.daswetter.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.device-reminder.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.device-reminder.1" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.easee.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.echarts.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.iot.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.text2command.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.unifi.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.web.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.vis.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.vis-bars.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.vis-canvas-gauges.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.vis-hqwidgets.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.vis-google-fonts.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.vis-material-advanced.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.vis-timeandweather.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.vis-inventwo.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.vis-lcars.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.trashschedule.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.gotify.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.gotify.1" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.habpanel.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.bluelink.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.youtube.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.kodi.0" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.gotify.2" for host "b8818f500ddc"
      host.b8818f500ddc check instance "system.adapter.gotify.3" for host "b8818f500ddc"
      Send diag info: {"uuid":"1bfd457b-36fe-4c7b-ae7e-c539150694f2","language":"de","country":"Germany","hosts":[{"version":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.17.1","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.8.10","platform":"Javascript/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"wled":{"version":"0.6.7","platform":"Javascript/Node.js"},"accuweather":{"version":"1.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"daswetter":{"version":"3.1.7","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.15.16","platform":"Javascript/Node.js"},"hm-rega":{"version":"3.0.44","platform":"Javascript/Node.js"},"pushover":{"version":"3.0.3","platform":"Javascript/Node.js"},"sonoff":{"version":"2.5.1","platform":"Javascript/Node.js"},"device-reminder":{"version":"1.2.9","platform":"Javascript/Node.js"},"easee":{"version":"1.0.7","platform":"Javascript/Node.js"},"echarts":{"version":"1.0.12","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javascript/Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/Node.js"},"trashschedule":{"version":"2.2.0","platform":"Javascript/Node.js"},"unifi":{"version":"0.5.10","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-canvas-gauges":{"version":"1.0.1","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-google-fonts":{"version":"1.0.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.2.2","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-lcars":{"version":"1.0.4","platform":"Javascript/Node.js"},"mqtt":{"version":"4.0.7","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"gotify":{"version":"0.0.1","platform":"Javascript/Node.js"},"habpanel":{"version":"0.5.0","platform":"Javascript/Node.js"},"devices":{"version":"1.1.2","platform":"Javascript/Node.js"},"bluelink":{"version":"2.2.5","platform":"Javascript/Node.js"},"chromecast":{"version":"2.3.1","platform":"Javascript/Node.js"},"youtube":{"version":"4.1.0","platform":"Javascript/Node.js"},"kodi":{"version":"2.0.8","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":47,"compactMode":false,"noCompactInstances":0,"model":"Common KVM processor","cpus":4,"mem":8343470080,"ostype":"Linux","city":"Teltow","vis":22}
      ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
      MOD EDIT: CODE TAGS KORRIGIERT
      • Hardy 0H Hardy 0
        @wendy2702
        Das ist der Log.
        Done.
        Hardy 0H Offline
        Hardy 0H Offline
        Hardy 0
        schrieb am zuletzt editiert von Hardy 0
        @wendy2702 OK Danke - kann man da was erkennen?
        • wendy2702W Online
          wendy2702W Online
          @hardy-0 Sehe da erstmal nichts negatives, betreibe selber IOB auch nicht im Docker.
          Ist das der Inhalt des IOB logs?
          /opt/iobroker/log/....
            Hardy 0H Offline
            Hardy 0H Offline
            Hardy 0
            @wendy2702 leider gibt es den Ordner nicht auf der VM....
            Gibt nur /opt/ mit z.b. nextcloud aber ibroker nicht...
            Oder muss ich woanders suchen?
            • Hardy 0H Hardy 0
              wendy2702W Online
              wendy2702W Online
              @hardy-0 Ja, du musst im Container suchen.
                Hardy 0H Offline
                Hardy 0H Offline
                Hardy 0
                @wendy2702 Also daten sind im Ordner: /var/lib/docker/volumes/iobroker/_data vorhanden.
                wendy2702W Hardy 0H 2 Antworten Letzte Antwort
                • Hardy 0H Hardy 0
                  wendy2702W Online
                  wendy2702W Online
                  @hardy-0 Dann gibt es bestimmt auch ein Logfile im iobroker log ordner
                  • Hardy 0H Hardy 0
                    Hardy 0H Offline
                    Hardy 0H Offline
                    Hardy 0
                    • Hardy 0H Hardy 0
                      wendy2702W Online
                      wendy2702W Online
                      @hardy-0 Vielleicht im ersten Ordner von oben....
                      der "log" heisst
                        Hardy 0H Offline
                        Hardy 0H Offline
                        Hardy 0
                        @wendy2702
                        2023-03-12 00:00:00.069  - info: host.b8818f500ddc instance system.adapter.daswetter.0 started with pid 24301
                        2023-03-12 00:00:01.365  - info: daswetter.0 (24301) starting. Version 3.1.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.17.1, js-controller: 4.0.24
                        2023-03-12 00:00:01.390  - info: daswetter.0 (24301) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                        2023-03-12 00:00:01.952  - info: daswetter.0 (24301) cleaned everything up...
                        2023-03-12 00:00:02.022  - info: host.b8818f500ddc instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-03-12 00:00:02.360  - info: easee.0 (781) undefined is not a valid state value for id "easee.0.EH5ZAXPD.status.latestFirmware"
                        2023-03-12 00:00:04.131  - info: host.b8818f500ddc instance system.adapter.ical.0 started with pid 24330
                        2023-03-12 00:00:05.959  - info: ical.0 (24330) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.17.1, js-controller: 4.0.24
                        2023-03-12 00:00:07.475  - info: ical.0 (24330) processing URL: abfall https://apm.wastebox.gemos-management.de/Gemos/WasteBox/Frontend/TourSchedule/Raw/Name/2023/List/156279/1427,1429,1431,1433,1434,1435,1436,1437/180/Print/ics/Default/Abfuhrtermine.ics
                        2023-03-12 00:00:08.164  - info: host.b8818f500ddc instance system.adapter.youtube.0 started with pid 24345
                        2023-03-12 00:00:10.056  - info: youtube.0 (24345) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.youtube, node: v16.17.1, js-controller: 4.0.24
                        2023-03-12 00:00:10.720  - info: youtube.0 (24345) Terminated (NO_ERROR): Without reason
                        2023-03-12 00:00:11.259  - info: host.b8818f500ddc instance system.adapter.youtube.0 terminated with code 0 (NO_ERROR)
                        2023-03-12 00:00:12.792  - info: ical.0 (24330) Terminated (NO_ERROR): Without reason
                        2023-03-12 00:00:13.334  - info: host.b8818f500ddc instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                        • Hardy 0H Hardy 0
                          @wendy2702
                          wendy2702W Online
                          wendy2702W Online
                          @hardy-0 sagte in Iobroker startet nach Stromausfall nicht mehr:
                          2023-03-12
                          das ist alt oder deine Time settings stimmen nicht
                            2023-03-12
                            Hardy 0H Offline
                            Hardy 0H Offline
                            Hardy 0
                            @wendy2702 Habe die VM zurückgesetzt, ist vom 12.3.23...
                            • Hardy 0H Hardy 0
                              wendy2702W Online
                              wendy2702W Online
                              @hardy-0 Wenn du die neu startest, sollte es ein log mit aktuellem Datum geben wenn das in der VM und im Container korrekt ist.
                              Ein Fehler ist in dem Schnipsel nicht zu sehen.
                                Hardy 0H Offline
                                Hardy 0H Offline
                                Hardy 0
                                @wendy2702 Alles klar. Vielen dank für Deine Mühe... kann mir das überhaupt nicht erklären. Aber ich gebe nicht auf und suche weiter nach einer Lösung. LG Hardy
                                  Hardy 0H Offline
                                  Hardy 0H Offline
                                  Hardy 0
                                  @wendy2702 Ich nochmal - habe mal portainer beendet, dann iob mit docker start iobroker versucht - Fehlermeldung war diese:
                                  "root@docker:~# docker start iobroker
                                  Error response from daemon: error gathering device information while adding custom device "/dev/serial/by-id/usb-ITead_Sonoff_Zigb ee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0": no such file or directory
                                  Error: failed to start containers: iobroker
                                  Hab dann in Portainer den Stick entfernt - den Container neu bauen lassen und was soll ich sagen... er läuft!
                                  Lag also am durchgereichten zigbee-stick.
                                  Hätte ich auch früher drauf kommen können...
                                  • Hardy 0H Hardy 0
                                    wendy2702W Online
                                    wendy2702W Online
                                    @hardy-0 Sehr gut das es wieder funktioniert.
                                    Etwas mit den Sticks oder dem Stick stand sogar im Log, wusste aber nicht das Docker dann nicht startet.
                                    Ich würde mir an deiner Stelle aber mal Grundsätzlich gedanken über das Setup machen.
                                    Proxmox --> VM --> Portainer --> Docker Container macht das handling unnötig aufwendig und kompliziert.
                                    Warum nutzt du Proxmox wenn du eh darin alles in extra Docker Container verpackst?
