  4. Iobroker startet nach Stromausfall nicht mehr
    5.5k
55 Beiträge 9 Kommentatoren 7.1k Aufrufe 4 Beobachtet
  • wendy2702W wendy2702
    @hardy-0 Naja, leicht kompliziert aber jedem das seine.
    Läuft denn nur iobroker nicht mehr oder der ganze Container nicht?
    Mal ins log geschaut?
    Hardy 0H Offline
    Hardy 0H Offline
    Hardy 0
    @wendy2702 Alle anderen Container laufen, wie nextcloud, wordpress, unifi, usw. nur der IOB nicht. _iobroker_logs.txt
    • wendy2702W Online
      wendy2702W Online
      @hardy-0 Laut log startet er ja noch.
      Logfiles bitte als text in Code Tags </> Posten
      Was steht im iobroker log?
      Hardy 0H 1 Antwort Letzte Antwort
        Hardy 0H Offline
        Hardy 0H Offline
        Hardy 0
        @wendy2702
        Das ist der Log.
        -----                  Step 1 of 5: Preparing container                   -----
        This is not the first run of this container. Skipping first run preparation.
        Installing additional packages is set by ENV.
        Checking the following Packages: ...
        Reading package lists...
        Building dependency tree...
        Reading state information...
        0 upgraded, 0 newly installed, 0 to remove and 33 not upgraded.
        Done.
        -----             Step 2 of 5: Detecting ioBroker installation             -----
        Existing installation of ioBroker detected in /opt/iobroker.
        -----             Step 3 of 5: Checking ioBroker installation              -----
        (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
        Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
        -----                Step 4 of 5: Applying special settings                -----
        Some adapters have special requirements/ settings which can be activated by the use of environment variables.
        For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
        Usb-device-support is activated by ENV.
        chown: cannot access '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0': No such file or directory
        chmod: cannot access '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0': No such file or directory
        Setting permissions for /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0... Done.
        -----                    Step 5 of 5: ioBroker startup                     -----
        Starting ioBroker...
        host.b8818f500ddc check instance "system.adapter.admin.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.javascript.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.pushover.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.pushover.1" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.influxdb.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.influxdb.1" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.zigbee.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.alexa2.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.hm-rega.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.hm-rpc.1" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.sonoff.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.mqtt.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.ping.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.hm-rpc.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.ical.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.discovery.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.wled.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.accuweather.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.daswetter.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.device-reminder.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.device-reminder.1" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.easee.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.echarts.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.iot.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.text2command.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.unifi.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.web.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.vis.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.vis-bars.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.vis-canvas-gauges.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.vis-hqwidgets.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.vis-google-fonts.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.vis-material-advanced.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.vis-timeandweather.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.vis-inventwo.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.vis-lcars.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.trashschedule.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.gotify.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.gotify.1" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.habpanel.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.bluelink.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.youtube.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.kodi.0" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.gotify.2" for host "b8818f500ddc"
        host.b8818f500ddc check instance "system.adapter.gotify.3" for host "b8818f500ddc"
        Send diag info: {"uuid":"1bfd457b-36fe-4c7b-ae7e-c539150694f2","language":"de","country":"Germany","hosts":[{"version":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.17.1","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.8.10","platform":"Javascript/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"wled":{"version":"0.6.7","platform":"Javascript/Node.js"},"accuweather":{"version":"1.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"daswetter":{"version":"3.1.7","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.15.16","platform":"Javascript/Node.js"},"hm-rega":{"version":"3.0.44","platform":"Javascript/Node.js"},"pushover":{"version":"3.0.3","platform":"Javascript/Node.js"},"sonoff":{"version":"2.5.1","platform":"Javascript/Node.js"},"device-reminder":{"version":"1.2.9","platform":"Javascript/Node.js"},"easee":{"version":"1.0.7","platform":"Javascript/Node.js"},"echarts":{"version":"1.0.12","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javascript/Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/Node.js"},"trashschedule":{"version":"2.2.0","platform":"Javascript/Node.js"},"unifi":{"version":"0.5.10","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-canvas-gauges":{"version":"1.0.1","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-google-fonts":{"version":"1.0.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.2.2","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-lcars":{"version":"1.0.4","platform":"Javascript/Node.js"},"mqtt":{"version":"4.0.7","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"gotify":{"version":"0.0.1","platform":"Javascript/Node.js"},"habpanel":{"version":"0.5.0","platform":"Javascript/Node.js"},"devices":{"version":"1.1.2","platform":"Javascript/Node.js"},"bluelink":{"version":"2.2.5","platform":"Javascript/Node.js"},"chromecast":{"version":"2.3.1","platform":"Javascript/Node.js"},"youtube":{"version":"4.1.0","platform":"Javascript/Node.js"},"kodi":{"version":"2.0.8","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":47,"compactMode":false,"noCompactInstances":0,"model":"Common KVM processor","cpus":4,"mem":8343470080,"ostype":"Linux","city":"Teltow","vis":22}
        ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
        MOD EDIT: CODE TAGS KORRIGIERT
        • Hardy 0H Hardy 0
          @wendy2702
          Das ist der Log.
          Done.
          Hardy 0H Offline
          Hardy 0H Offline
          Hardy 0
          schrieb am zuletzt editiert von Hardy 0
          @wendy2702 OK Danke - kann man da was erkennen?
          • wendy2702W Online
            wendy2702W Online
            @hardy-0 Sehe da erstmal nichts negatives, betreibe selber IOB auch nicht im Docker.
            Ist das der Inhalt des IOB logs?
            /opt/iobroker/log/....
              Hardy 0H Offline
              Hardy 0H Offline
              Hardy 0
              @wendy2702 leider gibt es den Ordner nicht auf der VM....
              Gibt nur /opt/ mit z.b. nextcloud aber ibroker nicht...
              Oder muss ich woanders suchen?
              • Hardy 0H Hardy 0
                wendy2702W Online
                wendy2702W Online
                @hardy-0 Ja, du musst im Container suchen.
                  Hardy 0H Offline
                  Hardy 0H Offline
                  Hardy 0
                  @wendy2702 Also daten sind im Ordner: /var/lib/docker/volumes/iobroker/_data vorhanden.
                  wendy2702W Hardy 0H 2 Antworten Letzte Antwort
                  • Hardy 0H Hardy 0
                    wendy2702W Online
                    wendy2702W Online
                    @hardy-0 Dann gibt es bestimmt auch ein Logfile im iobroker log ordner
                    • Hardy 0H Hardy 0
                      Hardy 0H Offline
                      Hardy 0H Offline
                      Hardy 0
                      • Hardy 0H Hardy 0
                        wendy2702W Online
                        wendy2702W Online
                        @hardy-0 Vielleicht im ersten Ordner von oben....
                        der "log" heisst
                          Hardy 0H Offline
                          Hardy 0H Offline
                          Hardy 0
                          @wendy2702
                          2023-03-12 00:00:00.069  - info: host.b8818f500ddc instance system.adapter.daswetter.0 started with pid 24301
                          2023-03-12 00:00:01.365  - info: daswetter.0 (24301) starting. Version 3.1.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.17.1, js-controller: 4.0.24
                          2023-03-12 00:00:01.390  - info: daswetter.0 (24301) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                          2023-03-12 00:00:01.952  - info: daswetter.0 (24301) cleaned everything up...
                          2023-03-12 00:00:02.022  - info: host.b8818f500ddc instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-03-12 00:00:02.360  - info: easee.0 (781) undefined is not a valid state value for id "easee.0.EH5ZAXPD.status.latestFirmware"
                          2023-03-12 00:00:04.131  - info: host.b8818f500ddc instance system.adapter.ical.0 started with pid 24330
                          2023-03-12 00:00:05.959  - info: ical.0 (24330) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.17.1, js-controller: 4.0.24
                          2023-03-12 00:00:07.475  - info: ical.0 (24330) processing URL: abfall https://apm.wastebox.gemos-management.de/Gemos/WasteBox/Frontend/TourSchedule/Raw/Name/2023/List/156279/1427,1429,1431,1433,1434,1435,1436,1437/180/Print/ics/Default/Abfuhrtermine.ics
                          2023-03-12 00:00:08.164  - info: host.b8818f500ddc instance system.adapter.youtube.0 started with pid 24345
                          2023-03-12 00:00:10.056  - info: youtube.0 (24345) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.youtube, node: v16.17.1, js-controller: 4.0.24
                          2023-03-12 00:00:10.720  - info: youtube.0 (24345) Terminated (NO_ERROR): Without reason
                          2023-03-12 00:00:11.259  - info: host.b8818f500ddc instance system.adapter.youtube.0 terminated with code 0 (NO_ERROR)
                          2023-03-12 00:00:12.792  - info: ical.0 (24330) Terminated (NO_ERROR): Without reason
                          2023-03-12 00:00:13.334  - info: host.b8818f500ddc instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                          • Hardy 0H Hardy 0
                            @wendy2702
                            wendy2702W Online
                            wendy2702W Online
                            @hardy-0 sagte in Iobroker startet nach Stromausfall nicht mehr:
                            2023-03-12
                            das ist alt oder deine Time settings stimmen nicht
                              2023-03-12
                              Hardy 0H Offline
                              Hardy 0H Offline
                              Hardy 0
                              @wendy2702 Habe die VM zurückgesetzt, ist vom 12.3.23...
                              • Hardy 0H Hardy 0
                                wendy2702W Online
                                wendy2702W Online
                                @hardy-0 Wenn du die neu startest, sollte es ein log mit aktuellem Datum geben wenn das in der VM und im Container korrekt ist.
                                Ein Fehler ist in dem Schnipsel nicht zu sehen.
                                  Hardy 0H Offline
                                  Hardy 0H Offline
                                  Hardy 0
                                  @wendy2702 Alles klar. Vielen dank für Deine Mühe... kann mir das überhaupt nicht erklären. Aber ich gebe nicht auf und suche weiter nach einer Lösung. LG Hardy
                                    Hardy 0H Offline
                                    Hardy 0H Offline
                                    Hardy 0
                                    @wendy2702 Ich nochmal - habe mal portainer beendet, dann iob mit docker start iobroker versucht - Fehlermeldung war diese:
                                    "root@docker:~# docker start iobroker
                                    Error response from daemon: error gathering device information while adding custom device "/dev/serial/by-id/usb-ITead_Sonoff_Zigb ee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0": no such file or directory
                                    Error: failed to start containers: iobroker
                                    Hab dann in Portainer den Stick entfernt - den Container neu bauen lassen und was soll ich sagen... er läuft!
                                    Lag also am durchgereichten zigbee-stick.
                                    Hätte ich auch früher drauf kommen können...
                                    • Hardy 0H Hardy 0
                                      wendy2702W Online
                                      wendy2702W Online
                                      @hardy-0 Sehr gut das es wieder funktioniert.
                                      Etwas mit den Sticks oder dem Stick stand sogar im Log, wusste aber nicht das Docker dann nicht startet.
                                      Ich würde mir an deiner Stelle aber mal Grundsätzlich gedanken über das Setup machen.
                                      Proxmox --> VM --> Portainer --> Docker Container macht das handling unnötig aufwendig und kompliziert.
                                      Warum nutzt du Proxmox wenn du eh darin alles in extra Docker Container verpackst?
