  4. Zigbee: Resource temporarily unavailable Cannot lock port
29 Beiträge 4 Kommentatoren 5.8k Aufrufe 4 Beobachtet
    roughestboy
    Hallo, seit kurzem habe ich obigen Fehler.
    Log, wenn ich die Instanz stoppe und starte:
    zigbee.0
    2023-02-26 12:05:46.625 error Error herdsman start
    zigbee.0
    2023-02-26 12:05:46.623 error Failed to start Zigbee
    zigbee.0
    2023-02-26 12:05:46.622 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2023-02-26 12:05:46.328 info Installed Version: iobroker.zigbee@1.7.6
    zigbee.0
    2023-02-26 12:05:46.275 info Starting Zigbee npm ...
    zigbee.0
    2023-02-26 12:05:46.273 info Try to reconnect. 1 attempts left
    zigbee.0
    2023-02-26 12:05:36.268 error Error herdsman start
    zigbee.0
    2023-02-26 12:05:36.267 error Failed to start Zigbee
    zigbee.0
    2023-02-26 12:05:36.266 error Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2023-02-26 12:05:36.121 error Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2023-02-26 12:05:36.121 error If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2023-02-26 12:05:36.120 error Please update configuration to prevent further issues.
    zigbee.0
    2023-02-26 12:05:36.119 error - Channel List: configured=15, adapter=15
    zigbee.0
    2023-02-26 12:05:36.118 error - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    2023-02-26 12:05:36.118 error - Extended PAN ID: configured=00124b00194af3c5, adapter=00124b00194af3c5
    zigbee.0
    2023-02-26 12:05:36.117 error - PAN ID: configured=6754, adapter=6754
    zigbee.0
    2023-02-26 12:05:36.117 error Configuration is not consistent with adapter state/backup!
    zigbee.0
    2023-02-26 12:05:36.013 info Installed Version: iobroker.zigbee@1.7.6
    zigbee.0
    2023-02-26 12:05:35.472 info Starting Zigbee npm ...
    zigbee.0
    2023-02-26 12:05:35.469 info delete old Backup files. keep only last 10
    zigbee.0
    2023-02-26 12:05:35.350 info starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.0, js-controller: 4.0.23
    Anhand dem, was vor der obigen Meldung los ist, kann ich keinen Fehler erkennen, zumindest, was die 4 Einstellungen nach
    betrifft. Ich würde jetzt sowas machen wollen, das sagt mir aber nichts:
    "Please update configuration to prevent further issues."
    und natürlich ein Recommissioning vermeiden wollen.
    Was kann man da tun ?
    • R roughestboy
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      crunchipC Offline
      crunchipC Offline
      @roughestboy sagte in Zigbee: Resource temporarily unavailable Cannot lock port:
      R 2 Antworten Letzte Antwort
        roughestboy
        @crunchip und das bedeutet dann
        ich muss alle Geräte neu pairen ?
          roughestboy
          @crunchip sagte in Zigbee: Resource temporarily unavailable Cannot lock port:
          Nun, habe ich mal nvbackup.json umbenannt.
          Neues Log ab start der Instanz:
          zigbee.0
          2023-02-26 12:40:55.549 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
          zigbee.0
          2023-02-26 12:40:55.546 info terminating
          zigbee.0
          2023-02-26 12:40:55.069 error Cannot read properties of undefined (reading 'mapped')
          zigbee.0
          2023-02-26 12:40:55.068 error TypeError: Cannot read properties of undefined (reading 'mapped') at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:501:36) at runNextTicks (node:internal/process/task_queues:61:5) at processImmediate (node:internal/timers:437:9)
          zigbee.0
          2023-02-26 12:40:55.066 error unhandled promise rejection: Cannot read properties of undefined (reading 'mapped')
          zigbee.0
          2023-02-26 12:40:55.065 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0
          2023-02-26 12:40:55.047 info Zigbee: disabling joining new devices.
          zigbee.0
          2023-02-26 12:40:55.045 info cleaned everything up...
          zigbee.0
          2023-02-26 12:40:55.029 error Cannot read properties of undefined (reading 'mapped')
          zigbee.0
          2023-02-26 12:40:55.027 error TypeError: Cannot read properties of undefined (reading 'mapped') at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:501:36)
          zigbee.0
          2023-02-26 12:40:55.026 error unhandled promise rejection: Cannot read properties of undefined (reading 'mapped')
          zigbee.0
          2023-02-26 12:40:55.025 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0
          2023-02-26 12:40:53.224 info debug devices set to []
          zigbee.0
          2023-02-26 12:40:53.148 info Zigbee started
          zigbee.0
          2023-02-26 12:40:53.147 info Currently no devices.
          zigbee.0
          2023-02-26 12:40:53.140 info --> transmitPower : high
          zigbee.0
          2023-02-26 12:40:53.121 info Unable to disable LED, unsupported function.
          zigbee.0
          2023-02-26 12:40:53.120 info Disable LED
          zigbee.0
          2023-02-26 12:40:53.115 info Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200327}}
          zigbee.0
          2023-02-26 12:40:52.917 info Installed Version: iobroker.zigbee@1.7.6
          zigbee.0
          2023-02-26 12:40:52.279 info Starting Zigbee npm ...
          zigbee.0
          2023-02-26 12:40:52.276 info delete old Backup files. keep only last 10
          zigbee.0
          2023-02-26 12:40:52.167 info starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.0, js-controller: 4.0.23
          Nun gehts um "Unhandled promise rejection". Was kann ich jetzt tun ?
          • R roughestboy
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            @roughestboy Zunächst würde ich mal deine Software auf Stand bringen. Betriebssystem, NodeJS, Adapter usw.
            Welche Hardware zigbeet denn da herum? So'n oller CC2531?
            Und dann bitte Auszüge aus dem LogFile in CodeTags setzen statt Spoiler.
            R 1 Antwort Letzte Antwort
              roughestboy
              Zigbee Adapter ist ein CC2538 von Arteck. Update folgt.
              • R roughestboy
                CC2538
                Ich dachte da sei vielleicht der Firmware-Stack falsch. Aber 3.0.x passt da.
                  CC2538
                  roughestboy
                  System ist up2date, js-controller 4.0.24. npm 8.19.2 und node.js 16.18.0 nahezu.
                  Log mit Start der Zigbee Instanz sieht nun so aus:
                  zigbee.0
                  2023-02-26 16:03:00.572	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  zigbee.0
                  2023-02-26 16:03:00.570	info	terminating
                  zigbee.0
                  2023-02-26 16:03:00.071	info	Zigbee: disabling joining new devices.
                  zigbee.0
                  2023-02-26 16:03:00.067	info	cleaned everything up...
                  zigbee.0
                  2023-02-26 16:03:00.040	error	Cannot read properties of undefined (reading 'mapped')
                  zigbee.0
                  2023-02-26 16:03:00.037	error	TypeError: Cannot read properties of undefined (reading 'mapped') at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:571:36)
                  zigbee.0
                  2023-02-26 16:03:00.035	error	unhandled promise rejection: Cannot read properties of undefined (reading 'mapped')
                  zigbee.0
                  2023-02-26 16:03:00.031	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  zigbee.0
                  2023-02-26 16:02:58.359	info	debug devices set to []
                  zigbee.0
                  2023-02-26 16:02:58.280	info	Zigbee started
                  zigbee.0
                  2023-02-26 16:02:58.278	info	Currently no devices.
                  zigbee.0
                  2023-02-26 16:02:58.263	info	--> transmitPower : high
                  zigbee.0
                  2023-02-26 16:02:58.245	info	Unable to disable LED, unsupported function.
                  zigbee.0
                  2023-02-26 16:02:58.244	info	Disable LED
                  zigbee.0
                  2023-02-26 16:02:58.237	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200327}}
                  zigbee.0
                  2023-02-26 16:02:57.965	info	Installed Version: iobroker.zigbee@1.8.10
                  zigbee.0
                  2023-02-26 16:02:57.340	info	Starting Zigbee npm ...
                  zigbee.0
                  2023-02-26 16:02:57.337	info	delete old Backup files. keep only last 10
                  zigbee.0
                  2023-02-26 16:02:57.212	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.0, js-controller: 4.0.24
                  Kann es ein Hardware Prob sein ? Verkabelung habe ich neu gesteckt, allerdings siehen
                  lsusb
                  Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                  Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
                  Bus 001 Device 003: ID 0451:16c8 Texas Instruments, Inc. CC2538 USB CDC
                  Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                  und ls -l /dev/serial/by-id
                  lrwxrwxrwx 1 root root 13 26. Feb 15:44 usb-EnOcean_GmbH_EnOcean_USB_300_DB_FT3FUSTH-if00-port0 -> ../../ttyUSB0
                  lrwxrwxrwx 1 root root 13 26. Feb 15:44 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
                  nicht verkehrt aus.
                  • R roughestboy
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    lsusb
                    nicht verkehrt aus.
                    nahezu
                    Dann mach es vollständig.
                      roughestboy
                      Ich habe jetzt ein völlig aktuelles System. Bzgl. dem Zigbee Prob bringt das nichts.
                      Testweise einen anderen USB Anschluss verwendet und eine 2. Instanz erzeugt, Instanz läuft trotzdem auf rot.
                      crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                      • R roughestboy
                        crunchipC Offline
                        crunchipC Offline
                        @roughestboy wenn du die nvbackup.json wieder einfügst?
                        • R roughestboy
                          @roughestboy
                          Dann erzähl uns mal mehr zu deinem System.
                          Z.B. per Ausgabe von
                          iob diag
                            roughestboy
                            schrieb am zuletzt editiert von roughestboy
                            @crunchip
                            Ja, die alte nvbackup.json is ja auch noch da. Wenn ich die wieder einsetze, sehen die Fehlermeldungen anders aus, Instanz bleibt aber auf gelb:
                            zigbee.0
                            2023-02-26 18:00:06.605	error	Error herdsman start
                            zigbee.0
                            2023-02-26 18:00:06.604	error	Failed to start Zigbee
                            zigbee.0
                            2023-02-26 18:00:06.598	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                            zigbee.0
                            2023-02-26 18:00:06.199	info	Installed Version: iobroker.zigbee@1.8.10
                            zigbee.0
                            2023-02-26 18:00:06.131	info	Starting Zigbee npm ...
                            zigbee.0
                            2023-02-26 18:00:06.128	info	Try to reconnect. 1 attempts left
                            zigbee.0
                            2023-02-26 17:59:56.121	error	Error herdsman start
                            zigbee.0
                            2023-02-26 17:59:56.120	error	Failed to start Zigbee
                            zigbee.0
                            2023-02-26 17:59:56.117	error	Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
                            zigbee.0
                            2023-02-26 17:59:46.937	info	Installed Version: iobroker.zigbee@1.8.10
                            zigbee.0
                            2023-02-26 17:59:46.246	info	Starting Zigbee npm ...
                            zigbee.0
                            2023-02-26 17:59:46.242	info	delete old Backup files. keep only last 10
                            zigbee.0
                            2023-02-26 17:59:46.102	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
                              @roughestboy
                              iob diag
                              roughestboy
                                                   v.2023-01-02
                              Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                              Installation:           Native
                              Timezone:               Europe/Berlin
                              User-ID:                1000
                              X-Server:               false
                              Boot Target:            multi-user.target
                              Pending OS-Updates:     54
                              Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                                      /usr/bin/node           v16.19.1
                                                      /usr/bin/npm            8.19.3
                                                      /usr/bin/npx            8.19.3
                              ioBroker Core:          js-controller           4.0.24
                                                      admin                   6.3.6
                              Objects type: jsonl
                              States  type: redis
                              Status admin:
                              + system.adapter.admin.0                  : admin                 : pi4iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              Pending iob updates:    0
                              Active repo(s): beta
                              Objects:                4090
                              States:                 2820
                              Size of iob-Database:
                              25M     /opt/iobroker/iobroker-data/objects.jsonl
                              552K    /opt/iobroker/iobroker-data/states.jsonl
                              • R roughestboy
                                                     v.2023-01-02
                                User-ID:                1000
                                X-Server:               false
                                                        /usr/bin/npm            8.19.3
                                                        /usr/bin/npx            8.19.3
                                                        admin                   6.3.6
                                Objects type: jsonl
                                States  type: redis
                                Status admin:
                                Objects:                4090
                                States:                 2820
                                @roughestboy
                                Updaten...
                                • R roughestboy
                                  @crunchip
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  crunchipC Offline
                                  crunchipC Offline
                                  @roughestboy und wenn du den Stick mal kurz absteckst?
                                    roughestboy
                                    @crunchip ändert nichts.
                                      @roughestboy
                                      Updaten...
                                      roughestboy
                                      Habe jetzt Pending OS-Updates auf Null. Zwischendurch Kabel zum Stick getauscht, den Stick gegen einen identischen gewechselt, und ein Backitup vom 2.2. eingespielt, da war das Problem noch nicht. Auch noch eine neue, 2te Instanz angelegt. Es bleibt immer bei einem 'zigbee-herdsman Problem,' "Cannot read properties of undefined (reading 'payload')" und "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'". Letztes log:
                                      zigbee.0
                                      	2023-03-04 11:48:47.327	error	Error herdsman start
                                      zigbee.0
                                      	2023-03-04 11:48:47.325	error	Failed to start Zigbee
                                      zigbee.0
                                      	2023-03-04 11:48:47.324	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                      zigbee.0
                                      	2023-03-04 11:48:47.127	info	Installed Version: iobroker.zigbee@1.8.10
                                      zigbee.0
                                      	2023-03-04 11:48:47.103	info	Starting Zigbee npm ...
                                      zigbee.0
                                      	2023-03-04 11:48:47.102	info	Try to reconnect. 1 attempts left
                                      zigbee.0
                                      	2023-03-04 11:48:37.083	error	Error herdsman start
                                      zigbee.0
                                      	2023-03-04 11:48:37.083	error	Failed to start Zigbee
                                      zigbee.0
                                      	2023-03-04 11:48:37.081	error	Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
                                      zigbee.0
                                      	2023-03-04 11:48:28.346	info	Installed Version: iobroker.zigbee@1.8.10
                                      zigbee.0
                                      	2023-03-04 11:48:27.652	info	Starting Zigbee npm ...
                                      zigbee.0
                                      	2023-03-04 11:48:27.483	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
                                        roughestboy
                                        Frage: gibts in iobroker irgendetwas oder einen anderen Adapter, der sich den Zigbee Stick schnappt, in etwa sowas wie hier:
                                        502 - Bad Gateway =>TypeError: Cannot read property 'payload' of undefined
                                          roughestboy
                                          So, um das hier noch abzuschließen. Habe mich wegen eines anderen 'Großprojekts' lange nicht kümmern können und erstmal ohne Zigbee leben müssen.
                                          Nun ist raus, es war ein 'schlechtes' udev-Paket. Siehe auch
                                          zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev
                                          Für mich war es dann die Möglichkeit 2.
