  4. „Cannot update rating: certificate has expired“ admin.0
57 Beiträge 14 Kommentatoren 9.2k Aufrufe 13 Beobachtet
    skorpil
    Was will mir dieser Warnhinweis sagen? Irgendwelche Handlungen meinerseits erforderlich?
    • S skorpil
      @skorpil
      Bei welcher Aktion erscheint der denn?
        @skorpil
        skorpil
        @thomas-braun der Hinweis erschien zunächst nur in den Fehlermeldungen. Ich habe den Admin daraufhin neu gestartet, und der Warnhinweis kam erneut.
        host.LinuxNeu
        2023-01-28 12:03:21.662	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        admin.0
        2023-01-28 12:03:21.514	warn	Cannot update rating: certificate has expired
        host.LinuxNeu
        2023-01-28 12:03:17.647	info	instance system.adapter.admin.0 started with pid 14760
        host.LinuxNeu
        2023-01-28 12:03:14.991	info	instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.LinuxNeu
        2023-01-28 12:03:14.470	info	stopInstance system.adapter.admin.0 send kill signal
        host.LinuxNeu
        2023-01-28 12:03:14.400	info	stopInstance system.adapter.admin.0 (force=false, process=true)
        • S skorpil
          host.LinuxNeu
          admin.0
          host.LinuxNeu
          host.LinuxNeu
          host.LinuxNeu
          host.LinuxNeu
          @skorpil
          iob update
          sudo apt update
          sagen jeweils?
            @skorpil
            iob update
            sudo apt update
            sagen jeweils?
            skorpil
            iob update:
            Used repository: stable
            Adapter    "admin"        : 6.3.5    , installed 6.3.5
            Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
            Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
            Adapter    "denon"        : 1.13.4   , installed 1.13.4
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
            Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
            Adapter    "ical"         : 1.13.2   , installed 1.13.2
            Adapter    "iot"          : 1.14.2   , installed 1.14.2
            Adapter    "javascript"   : 6.1.4    , installed 6.1.4
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
            Adapter    "pushover"     : 3.0.3    , installed 3.0.3
            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
            Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "yr"           : 5.3.0    , installed 5.3.0
            sudo apt update
            OK:1 http://deb.debian.org/debian buster InRelease
            OK:2 http://security.debian.org/debian-security buster/updates InRelease
            OK:3 http://deb.debian.org/debian buster-updates InRelease
            OK:4 https://deb.nodesource.com/node_16.x buster InRelease
            Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
            PS: schonmal Danke, dass Du Dich meines Problems animmst
            DJMarc75D OstfrieseUnterwegsO Thomas BraunT 3 Antworten Letzte Antwort
            • S skorpil
              iob update:
              sudo apt update
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @skorpil bitte komplett zeigen (Inkl. Eingabe)
              Lehrling seit 1975 !!!
              • S skorpil
                iob update:
                sudo apt update
                OstfrieseUnterwegsO Offline
                OstfrieseUnterwegs
                @skorpil Meine Glaskugel sagt, dass @Thomas-Braun gleich sagt: Mach mal ein update auf Bullseye. Buster ist tot ;-)
                • S skorpil
                  iob update:
                  sudo apt update
                  @skorpil
                  Hau das Update noch rein.
                  Zum Problem: Da wird vermutlich bei den certs was klemmen. Ich sehe jetzt nicht ob das auf deiner oder auf Seiten des Servers liegt.
                  Die Alternativen iob-Repos hast du ausprobiert?
                  • OstfrieseUnterwegsO OstfrieseUnterwegs
                    @ostfrieseunterwegs sagte in „Cannot update rating: certificate has expired“ admin.0:
                    Danke für den Hinweis, hatte ich übersehen.
                    Ja, Buster hat das End of Life erreicht, installier da ein lebendiges Release.
                    S 2 Antworten Letzte Antwort
                      @skorpil
                      skorpil
                      @thomas-braun sagte in „Cannot update rating: certificate has expired“ admin.0:
                      Da bin ich nicht tief genug im Thema drinnen! Wie geht das?
                        skorpil
                        Auch hier reichen meine Linux Kenntnisse nicht! Wo gibt es eine Anleitung, speziell bei iob?
                        • S skorpil
                          @skorpil
                          Ja, hab ich mal irgendwann als es aktuell war was zu geschrieben. Schau durch meine alten Themen durch.
                            @skorpil
                            skorpil
                            @thomas-braun diese?
                            Link Text
                            • S skorpil
                              Link Text
                              @skorpil
                              Ja
                                @skorpil
                                Ja
                                MartyBr
                                Bei mir erscheint die Meldung auch. Meine Systeme sind auf Bullseye und ich fahre Stable.
                                Ist das vielleicht ein Serverproblem?
                                Martin
                                Intel NUCs mit Proxmox / Iobroker als VM unter Debian
                                Raspeberry mit USB Leseköpfen für Smartmeter
                                Homematic und Homematic IP
                                • Thomas BraunT Online
                                  @martybr
                                  Ja.
                                  Trotzdem ist das Grundsystem hier pflegebedürftig.
                                  Michael SchmittM 1 Antwort Letzte Antwort
                                    MartyBr
                                    schrieb am zuletzt editiert von MartyBr
                                    Das ist bei dem Thread Eröffnet richtig. Mein System ist aktuell bei gleicher Warnmeldung:
                                    Plattform: linux
                                    Betriebssystem: linux
                                    Architektur: x64
                                    CPUs: 4
                                    Geschwindigkeit: 2304 MHz
                                    Modell: Common KVM processor
                                    RAM: 9.4 GB
                                    System-Betriebszeit: 03:43:54
                                    Node.js: v16.19.0
                                    time: 1674914865803
                                    timeOffset: -60
                                    Adapter-Anzahl: 457
                                    NPM: 8.19.3
                                    Datenträgergröße: 27.2 GB
                                    Freier Festplattenspeicher: 17.2 GB
                                    Betriebszeit: 03:43:51
                                    Aktive Instanzen: 42
                                    Pfad: /opt/iobroker/
                                    aktiv:
                                    martin@iobroker:/opt/iobroker$ iobroker update
                                    Adapter    "alarm"        : 3.3.9    , installed 3.3.9
                                    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
                                    Adapter    "bring"        : 1.8.1    , installed 1.8.1
                                    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                                    Adapter    "email"        : 1.1.4    , installed 1.1.4
                                    Adapter    "epson_ecotank_et_2750": 0.0.12, installed 0.0.12
                                    Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
                                    Adapter    "fb-checkpresence": 1.1.20, installed 1.1.25
                                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                                    Adapter    "homekit-controller": 0.5.1, installed 0.5.1
                                    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
                                    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                                    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                    Adapter    "kostal-piko-ba": 2.1.0   , installed 2.1.0
                                    Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                                    Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                    Adapter    "nuki-extended": 2.3.1    , installed 2.6.5
                                    Adapter    "nut"          : 1.5.1    , installed 1.5.1
                                    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                                    Adapter    "rest-api"     : 1.0.4    , installed 1.0.4
                                    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                                    Adapter    "shuttercontrol": 1.4.18  , installed 1.4.19
                                    Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
                                    Adapter    "snmp"         : 2.2.1    , installed 2.2.1
                                    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                                    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                                    Adapter    "text2command" : 2.3.0    , installed 2.3.0
                                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
                                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                    Adapter    "viessmann"    : 1.4.2    , installed 1.4.2
                                    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                                    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                                    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                                    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
                                    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
                                    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                    Adapter    "web"          : 4.3.0    , installed 4.3.0
                                    Adapter    "worx"         : 2.0.3    , installed 2.0.3
                                    Adapter    "ws"           : 1.3.0    , installed 1.3.0
                                    Adapter    "yahka"        : 0.13.1   , installed 0.17.0
                                    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                                    martin@iobroker:/opt/iobroker$ sudo apt update
                                    [sudo] Passwort für martin:
                                    Holen:1 http://security.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                                    OK:2 http://deb.debian.org/debian bullseye InRelease
                                    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    Es wurden 48,4 kB in 1 s geholt (81,9 kB/s).
                                    Alle Pakete sind aktuell.
                                    Martin
                                      @martybr
                                      Ja.
                                      Michael SchmittM Online
                                      Michael Schmitt
                                      schrieb am zuletzt editiert von Michael Schmitt
                                      bei mir kommt die Meldung auch, dachte eigentlich es wäre alles aktuell.
                                      pi@raspberrypi:~ $ iob update
                                      Adapter    "backitup"     : 2.5.10   , installed 2.5.10
                                      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                                      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                      Adapter    "devices"      : 1.1.2    , installed 1.1.2
                                      Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
                                      Adapter    "history"      : 2.2.4    , installed 2.2.4
                                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                                      Adapter    "material"     : 1.1.2    , installed 0.13.9 [Updatable]
                                      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                                      pi@raspberrypi:~ $ sudo apt update
                                      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      OK:4 https://phoscon.de/apt/deconz bullseye InRelease
                                      pi@raspberrypi:~ $
                                      hier ist lediglich deconz nicht aktuell, da ich mit der neuesten Version und einigen Geräten Verbindungsprobleme habe
                                        Stormbringer
                                        schrieb am zuletzt editiert von Stormbringer
                                        Habe das Problem auch. Beim Produktivsystem ist minimum alles auf Stable, VM Proxmox Ubuntu 22.04.... Habe testweise einen neuen Container angelegt und io frisch installiert da kommt es auch gleich. Die Fehlermeldung an und für sich wäre mir ja egal aber irgendwie sind anscheinend auch viele Adapter betroffen die Daten von einer Cloud (wie tado, vesync, bring...) holen. Habt ihr das auch oder ist das ein anderes Problem und es tritt nur durch Zufall gleichzeitig auf?
                                        Ganze LOG voll mit:
                                        tado.0
                                        	2023-01-28 17:40:47.156	error	Disconnected from Tado cloud service ..., retry in 30 seconds !
                                        tado.0
                                        	2023-01-28 17:40:47.156	error	Error in data refresh at step DoZones: Error: connect ETIMEDOUT 53.17.152.58:443
                                        tado.0
                                        	2023-01-28 17:40:47.155	error	Error: connect ETIMEDOUT 53.17.152.58:443
                                        vesync.0
                                        	2023-01-28 17:41:24.020	error	Error: connect ETIMEDOUT 53.7.152.56:443
                                        vesync.0
                                        	2023-01-28 17:41:24.019	error	https://smartapi.vesync.com/cloud/v2/deviceManaged/bypassV2
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	instance system.adapter.tado.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at TLSSocket.emit (node:events:513:28)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at ClientRequest.emit (node:domain:489:12)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at RedirectableRequest.emit (node:events:513:28)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.tado/node_modules/axios/lib/core/AxiosError.js:89:14)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[1]: }
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[1]: address: '54.76.203.76',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[1]: code: 'ETIMEDOUT',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16) {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[1]: },
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: [Symbol(kCapture)]: false
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: },
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: [Symbol(kOutHeaders)]: [Object: null prototype],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: [Symbol(kNeedDrain)]: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: [Symbol(kBytesWritten)]: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: _redirectable: [Circular *1],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: host: 'my.tado.com',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: maxHeadersCount: null,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: upgradeOrConnect: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: aborted: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: _ended: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: insecureHTTPParser: undefined,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[1]: cause: Error: connect ETIMEDOUT 54.75.202.73:443
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[1]: errno: -110,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[1]: syscall: 'connect',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[1]: port: 443
                                        host.io-frost-prox
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: Error: connect ETIMEDOUT 54.75.202.73:443
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.tado/node_modules/axios/lib/adapters/http.js:526:25)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at RedirectableRequest.emit (node:domain:489:12)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at ClientRequest.emit (node:events:525:35)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at TLSSocket.socketErrorListener (node:_http_client:494:9)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	error	Caught by controller[2]: at TLSSocket.emit (node:domain:489:12)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.870	info	Restart adapter system.adapter.tado.0 because enabled
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: maxHeaderSize: undefined,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: socketPath: undefined,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: _onPendingData: [Function: nop],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: '\r\n',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: 'Host: my.tado.com\r\n' +
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: 'Content-Length: 2\r\n' +
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: 'Content-Type: application/json\r\n' +
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: 'Accept: application/json, text/plain, */*\r\n' +
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: socket: [TLSSocket],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: _headerSent: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: _trailer: '',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: path: '/api/v2/devices/SU1340286464/temperatureOffset',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: res: null,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: timeoutCb: null,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: parser: null,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: reusedSocket: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: protocol: 'https:',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: [Symbol(kCapture)]: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: [Symbol(kEndCalled)]: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: [Symbol(corked)]: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: [Symbol(kUniqueHeaders)]: null
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.869	error	Caught by controller[1]: _currentUrl: 'https://my.tado.com/api/v2/devices/SU1340286464/temperatureOffset',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: _hasBody: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: strictContentLength: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _removedContLen: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: sendDate: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _defaultKeepAlive: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: shouldKeepAlive: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _last: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: writable: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: outputData: [],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _eventsCount: 7,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _currentRequest: ClientRequest {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _requestBodyBuffers: [ [Object] ],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _redirects: [],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _ending: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: },
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: nativeProtocols: [Object],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: finished: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: _closed: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: _header: 'GET /api/v2/devices/SU1340286464/temperatureOffset HTTP/1.1\r\n' +
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: 'Authorization: Bearer +
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: 'User-Agent: axios/1.2.1\r\n' +
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: 'Accept-Encoding: gzip, compress, deflate, br\r\n' +
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: 'Connection: close\r\n' +
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: _keepAliveTimeout: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: agent: [Agent],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.868	error	Caught by controller[1]: method: 'GET',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: agent: undefined,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: hostname: 'my.tado.com',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: beforeRedirect: [Function: dispatchBeforeRedirect],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: agents: [Object],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: method: 'GET',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: pathname: '/api/v2/devices/SU1340286464/temperatureOffset'
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _ended: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _redirectCount: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _requestBodyLength: 2,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _onNativeResponse: [Function (anonymous)],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _events: [Object: null prototype],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _maxListeners: 100,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: outputSize: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: destroyed: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: chunkedEncoding: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: maxRequestsOnConnectionReached: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: useChunkedEncodingByDefault: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _removedConnection: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _removedTE: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.867	error	Caught by controller[1]: _contentLength: '2',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: path: '/api/v2/devices/SU1340286464/temperatureOffset',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: headers: [Object: null prototype],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: auth: undefined,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: beforeRedirects: [Object],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: port: '',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.866	error	Caught by controller[1]: protocol: 'https:',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: maxBodyLength: Infinity,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: _options: {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: _eventsCount: 3,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: socket: [Function: handleRequestSocket]
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: response: [Function: handleResponse],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: },
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: closeEmitted: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: errored: null,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: autoDestroy: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: errorEmitted: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: constructed: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: allNoop: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: bufferedIndex: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: afterWriteTickInfo: null,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: writecb: null,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: bufferProcessing: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: corked: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: length: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: decodeStrings: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: finished: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: ending: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: finalCalled: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: objectMode: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: request: <ref *1> Writable {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: data: '{}'
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: closed: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: [Symbol(kOnFinished)]: []
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: _events: [Object: null prototype] {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: error: [Function: handleRequestError],
                                        host.io-frost-prox
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: _maxListeners: 100,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.863	error	Caught by controller[1]: maxRedirects: 21,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: method: 'get',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: },
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: 'Content-Length': '2',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: 'Content-Type': 'application/json',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: Accept: 'application/json, text/plain, */*',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: validateStatus: [Function: validateStatus],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: maxBodyLength: -1,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: xsrfHeaderName: 'X-XSRF-TOKEN',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: timeout: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: transformRequest: [ [Function: transformRequest] ],
                                        host.io-frost-prox
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: forcedJSONParsing: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: transitional: {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: errno: -110,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: syscall: 'connect',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: port: 443,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: },
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: _writableState: WritableState {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: highWaterMark: 16384,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: needDrain: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: ended: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: destroyed: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: defaultEncoding: 'utf8',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: writing: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: sync: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: onwrite: [Function: bound onwrite],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: writelen: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: buffered: [],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: allBuffers: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: pendingcb: 0,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: prefinished: false,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.862	error	Caught by controller[1]: emitClose: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.860	error	Caught by controller[1]: at TLSSocket.emit (node:domain:489:12) {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.860	error	Caught by controller[1]: at TLSSocket.socketErrorListener (node:_http_client:494:9)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.860	error	Caught by controller[1]: at ClientRequest.emit (node:events:525:35)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.860	error	Caught by controller[1]: at RedirectableRequest.emit (node:domain:489:12)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: address: '54.75.202.73',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: code: 'ETIMEDOUT',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: config: {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: silentJSONParsing: true,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: clarifyTimeoutError: false
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: adapter: [ 'xhr', 'http' ],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: transformResponse: [ [Function: transformResponse] ],
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: xsrfCookieName: 'XSRF-TOKEN',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: maxContentLength: -1,
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: env: { FormData: [Function], Blob: null },
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: headers: AxiosHeaders {
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: Authorization: 'Bearer c8CGUg',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: 'User-Agent': 'axios/1.2.1',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: 'Accept-Encoding': 'gzip, compress, deflate, br'
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.861	error	Caught by controller[1]: url: 'https://my.tado.com/api/v2/devices/SU1340286464/temperatureOffset',
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.860	error	Caught by controller[1]: at RedirectableRequest.emit (node:events:513:28)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.860	error	Caught by controller[1]: at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.860	error	Caught by controller[1]: at ClientRequest.emit (node:domain:489:12)
                                        host.io-frost-prox
                                           2023-01-28 17:55:03.860	error	Caught by controller[1]: at TLSSocket.emit (node:events:513:28)
                                        Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
                                        • S Stormbringer
                                          Ganze LOG voll mit:
                                          tado.0
                                          tado.0
                                          tado.0
                                          vesync.0
                                          vesync.0
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          host.io-frost-prox
                                          Da stimmt was mit dem Routing nicht, würde ich sagen.
                                          echad@chet:~ $ ping 53.17.152.58
                                          PING 53.17.152.58 (53.17.152.58) 56(84) bytes of data.
                                          --- 53.17.152.58 ping statistics ---
                                          13 packets transmitted, 0 received, 100% packet loss, time 12269ms
                                          echad@chet:~ $ traceroute 53.17.152.58
                                          traceroute to 53.17.152.58 (53.17.152.58), 30 hops max, 60 byte packets
                                           1  fritz.box (192.168.178.1)  1.218 ms  1.140 ms  9.438 ms
                                           2  * * *
                                           3  de-dus23e-rc1-ae23.dus.unity-media.net (81.210.141.25)  28.275 ms  29.957 ms  29.874 ms
                                           4  de-fra01b-rc2-ae-21-0.aorta.net (84.116.138.202)  32.040 ms  33.290 ms  33.234 ms
                                           5  de-bfe18a-rt01-lag-1.aorta.net (84.116.190.34)  31.771 ms  31.733 ms  31.617 ms
                                           6  ae32-100-pcr1.fnt.cw.net (195.2.18.217)  24.261 ms ae8-100-tcr1.fnt.cw.net (195.2.26.93)  24.660 ms  26.200 ms
                                           7  telia-gw.fnt.cw.net (195.2.22.238)  28.908 ms  18.342 ms ae34-pcr1.fnt.cw.net (195.2.31.38)  20.242 ms
                                           8  ffm-bb1-link.ip.twelve99.net (62.115.124.116)  28.383 ms telia-gw.fnt.cw.net (195.2.22.238)  28.267 ms  24.401 ms
                                           9  ffm-b10-link.ip.twelve99.net (62.115.137.211)  21.119 ms ffm-bb1-link.ip.twelve99.net (62.115.124.116)  25.984 ms ffm-b1-link.ip.twelve99.net (62.115.121.1)  29.601 ms
                                          10  kddi-ic319844-ffm-b1.ip.twelve99-cust.net (62.115.32.106)  28.393 ms ffm-b1-link.ip.twelve99.net (62.115.121.1)  31.634 ms kddi-ic301630-ffm-b10.ip.twelve99-cust.net (62.115.32.110)  28.311 ms
                                          11  195.82.60.158 (195.82.60.158)  25.131 ms  22.316 ms kddi-ic301630-ffm-b10.ip.twelve99-cust.net (62.115.32.110)  23.491 ms
                                          12  * * *
                                          13  * * *
                                          14  * * *
                                          15  * * *
                                          16  * * *
                                          17  * * *
                                          18  * * *
                                          19  * * *
                                          20  * * *
                                          21  * * *
                                          22  * * *
                                          23  * * *
                                          24  * * *
                                          25  * * *
                                          26  * * *
                                          27  * * *
                                          28  * * *
                                          29  * * *
                                          30  * * *
                                          echad@chet:~ $
                                          Die IP kommt aus einem IP-Pool von Daimler-Benz?
                                          echad@chet:~ $ whois 53.17.152.58
                                          # ARIN WHOIS data and services are subject to the Terms of Use
                                          # available at: https://www.arin.net/resources/registry/whois/tou/
                                          # If you see inaccuracies in the results, please report at
                                          # https://www.arin.net/resources/registry/whois/inaccuracy_reporting/
                                          # Copyright 1997-2023, American Registry for Internet Numbers, Ltd.
                                          NetRange:       53.0.0.0 - 53.255.255.255
                                          CIDR:           53.0.0.0/8
                                          NetName:        RIPE-ERX-53
                                          NetHandle:      NET-53-0-0-0-1
                                          Parent:          ()
                                          NetType:        Early Registrations, Maintained by RIPE NCC
                                          OriginAS:
                                          Organization:   RIPE Network Coordination Centre (RIPE)
                                          RegDate:        1992-03-17
                                          Updated:        2014-10-14
                                          Comment:        These addresses have been further assigned to users in the RIPE NCC region. Contact information can be found in the RIPE database at http://www.ripe.net/whois
                                          Ref:            https://rdap.arin.net/registry/ip/53.0.0.0
                                          ResourceLink:  https://apps.db.ripe.net/search/query.html
                                          ResourceLink:  whois.ripe.net
                                          OrgName:        RIPE Network Coordination Centre
                                          OrgId:          RIPE
                                          Address:        P.O. Box 10096
                                          City:           Amsterdam
                                          StateProv:
                                          PostalCode:     1001EB
                                          Country:        NL
                                          RegDate:
                                          Updated:        2013-07-29
                                          Ref:            https://rdap.arin.net/registry/entity/RIPE
                                          ReferralServer:  whois://whois.ripe.net
                                          OrgTechHandle: RNO29-ARIN
                                          OrgTechName:   RIPE NCC Operations
                                          OrgTechPhone:  +31 20 535 4444
                                          OrgTechEmail:  hostmaster@ripe.net
                                          OrgTechRef:    https://rdap.arin.net/registry/entity/RNO29-ARIN
                                          OrgAbuseHandle: ABUSE3850-ARIN
                                          OrgAbuseName:   Abuse Contact
                                          OrgAbusePhone:  +31205354444
                                          OrgAbuseEmail:  abuse@ripe.net
                                          OrgAbuseRef:    https://rdap.arin.net/registry/entity/ABUSE3850-ARIN
                                          Found a referral to whois.ripe.net.
                                          % This is the RIPE Database query service.
                                          % The objects are in RPSL format.
                                          % The RIPE Database is subject to Terms and Conditions.
                                          % See http://www.ripe.net/db/support/db-terms-conditions.pdf
                                          % Note: this output has been filtered.
                                          %       To receive output for a database update, use the "-B" flag.
                                          % Information related to '53.0.0.0 - 53.255.255.255'
                                          % Abuse contact for '53.0.0.0 - 53.255.255.255' is 'ipadmin@daimler.com'
                                          inetnum:        53.0.0.0 - 53.255.255.255
                                          netname:        MERCEDES-BENZ-NET1
                                          org:            ORG-DA474-RIPE
                                          descr:          Mercedes-Benz Group AG
                                          country:        DE
                                          admin-c:        EH4384-RIPE
                                          tech-c:         EH4384-RIPE
                                          status:         LEGACY
                                          mnt-by:         RIPE-NCC-LEGACY-MNT
                                          mnt-by:         DAIMLER-MNT
                                          created:        1970-01-01T00:00:00Z
                                          last-modified:  2022-04-12T08:04:16Z
                                          source:         RIPE
                                          organisation:   ORG-DA474-RIPE
                                          org-name:       Mercedes-Benz Group AG
                                          country:        DE
                                          org-type:       LIR
                                          address:        ITT/TN HPC L525
                                          address:        70546
                                          address:        Stuttgart
                                          address:        GERMANY
                                          phone:          +497111760844
                                          fax-no:         +497111779060844
                                          abuse-c:        AR13603-RIPE
                                          mnt-ref:        RIPE-NCC-HM-MNT
                                          mnt-ref:        DAIMLER-MNT
                                          mnt-by:         RIPE-NCC-HM-MNT
                                          mnt-by:         DAIMLER-MNT
                                          created:        2012-12-11T14:21:36Z
                                          last-modified:  2022-02-02T07:09:15Z
                                          source:         RIPE # Filtered
                                          person:         Edda Hoppe
                                          address:        Daimler AG
                                          address:        HPC L525
                                          address:        D-70546 Stuttgart
                                          address:        Germany
                                          phone:          +49 711 17 56394
                                          fax-no:         +49 711 17 79087921
                                          nic-hdl:        EH4384-RIPE
                                          created:        2022-01-13T13:28:17Z
                                          last-modified:  2022-01-13T13:37:14Z
                                          mnt-by:         DAIMLER-MNT
                                          % Information related to '53.0.0.0/8AS31399'
                                          route:          53.0.0.0/8
                                          descr:          MERCEDES-BENZ-NET1
                                          origin:         AS31399
                                          mnt-by:         DAIMLER-MNT
                                          created:        2006-03-14T10:05:37Z
                                          last-modified:  2022-04-12T08:05:43Z
                                          source:         RIPE
                                          % This query was served by the RIPE Database Query Service version 1.105 (ABERDEEN)
