  4. VIS lädt Projekt nicht mehr
35 Beiträge 4 Kommentatoren 3.6k Aufrufe 3 Beobachtet
    MP_Trixi
    schrieb am zuletzt editiert von MP_Trixi
    ich habe gestern an meiner VIS weitergearbeitet (Einbindung eines Menu (Material Design Top Bar Widget)). Öffnet man den VIS Editor über die Admin Konsole kommt das Demo Projekt. Will ich mein Projekt öffnen, bleibt es bei Loading Values hängen. Die Console zeigt folgenden Fehler:
    Version vis-google-fonts: 0.0.1
    edit.html?PFH-Vis:6581 Version vis-map: 1.0.3
    lib.min.js:43 Download the Vue Devtools extension for a better development experience:
    https://github.com/vuejs/vue-devtools
    lib.min.js:43 You are running Vue in development mode.
    Make sure to turn on production mode when deploying for production.
    See more tips at https://vuejs.org/guide/deployment.html
    edit.html?PFH-Vis:8765 Metro version: "1.2.0"
    edit.html?PFH-Vis:10097 Version vis-plumb: 1.0.0
    trashschedule.js:152 Version trashschedule: 2.0.3
    vis-material-advanced.js:184 Version vis-material-advanced: 1.6.0
    edit.html?PFH-Vis:19283 Version vis-weather: 2.5.6
    DevTools failed to load source map: Could not load content for http://192.168.1.112:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://192.168.1.112:8082/vis/widgets/material-webfont/css/materialdesignicons.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    conn.js:305 2023-01-28T09:15:49.819Z Connected => authenticate
    :8082/vis/edit.html?PFH-Vis#BMW-Karte:1 Unchecked runtime.lastError: The message port closed before a response was received.
    conn.js:326 2023-01-28T09:15:49.965Z Authenticated: true
    materialdesign.js:33 Version vis-materialdesign: 0.5.9
    visUtils.js:455 Uncaught TypeError: Cannot read properties of undefined (reading 'data')
        at getUsedObjectIDs (visUtils.js:455:97)
        at Object.getUsedObjectIDs (vis.js:519:22)
        at vis.js:2055:34
        at conn.js:580:25
    getUsedObjectIDs @ visUtils.js:455
    getUsedObjectIDs @ vis.js:519
    (anonymous) @ vis.js:2055
    (anonymous) @ conn.js:580
    setTimeout (async)
    (anonymous) @ conn.js:579
    r.onack @ socket.io.js:8
    r.onpacket @ socket.io.js:8
    (anonymous) @ socket.io.js:8
    r.emit @ socket.io.js:6
    r.ondecoded @ socket.io.js:6
    a.add @ socket.io.js:6
    r.ondata @ socket.io.js:6
    r.onPacket @ socket.io.js:6
    (anonymous) @ socket.io.js:6
    r.onPacket @ socket.io.js:7
    r.onData @ socket.io.js:7
    ws.onmessage @ socket.io.js:8
    instrument.ts:129 sentry initialized for vis-materialdesign
    lässt sich da noch was retten?
    Zur Info. Das zeigt iobroker update an:
    pi@smarthome:/opt/iobroker $ iobroker update
    Used repository: stable
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
    Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.5.10   , installed 2.5.10
    Adapter    "bmw"          : 2.5.7    , installed 2.5.7
    Adapter    "devices"      : 1.1.2    , installed 1.1.1  [Updatable]
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "heatingcontrol": 2.9.3   , installed 2.9.3
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.2   , installed 1.13.2
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "logparser"    : 1.1.0    , installed 1.1.0
    Adapter    "meross"       : 1.14.0   , installed 1.14.0
    Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
    Adapter    "modbus"       : 5.0.11   , installed 5.0.5  [Updatable]
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
    Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
    Adapter    "selverf"      : 0.6.2    , installed 0.6.2
    Adapter    "shelly"       : 6.3.1    , installed 6.0.0  [Updatable]
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "trashschedule": 2.2.0    , installed 2.0.3  [Updatable]
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "vw-connect"   : 0.0.56   , installed 0.0.56
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Und die Info zum System:
    Node.js: v18.2.0
    NPM: 8.9.0
    js-controller: 4.0.24
    bahnuhrB GlasfaserG 2 Antworten Letzte Antwort
    • M MP_Trixi
          at vis.js:2055:34
          at conn.js:580:25
      setTimeout (async)
      Node.js: v18.2.0
      NPM: 8.9.0
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @mp_trixi sagte in VIS lädt Projekt nicht mehr:
      Node.js: v18.2.0
      warum ?
      Danke.
        MP_Trixi
        @bahnuhr
        gute Frage - kanns Dir gar nicht mehr sagen wie ich auf 18 gekommen bin. Würde fast behaupten, dass die seit Anfang an installiert war. Habe den ioBroker noch nicht so lange im Einsatz. Gibts ne Möglichkeit auf eine supportete Version downzugraden?
        bahnuhrB 2 Antworten Letzte Antwort
        • M MP_Trixi
          @bahnuhr
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          Nein, mit Sicherheit nicht.
          stable ist 16.
          Da musst du manuell was gemacht haben.
          Danke.
          • M MP_Trixi
            @bahnuhr
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            suche mal nach Beiträgen von @Thomas-Braun . Er hat in seiner Signatur Anleitungen wie man sowas macht.
            Danke.
            • bahnuhrB bahnuhr
              stable ist 16.
              MP_Trixi
              @bahnuhr
              ok - danke - und du meinst es liegt daran?
              • M MP_Trixi
                @bahnuhr
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @bahnuhr
                kann ich dir nicht sagen; weil ich "Material Design" nicht nutze.
                Aber dein System ist krumm; und dies solltest du auf jeden Fall richtig stellen.
                Danke.
                • bahnuhrB bahnuhr
                  @bahnuhr
                  MP_Trixi
                  @bahnuhr
                  so, das mit den Versionen sollte nun so stimmen (mein Problem habe ich allerdings immernoch :( )
                  pi@smarthome:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  aarch64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v16.19.0
                  v16.19.0
                  8.19.3
                  8.19.3
                  4.0.24
                  pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  tty
                  /home/pi
                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:5 https://repos.influxdata.com/debian stretch InRelease
                  Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                  Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Hit:8 https://deb.nodesource.com/node_18.x bullseye InRelease
                  Reading package lists... Done
                  Building dependency tree... Done
                  1 package can be upgraded. Run 'apt list --upgradable' to see it.
                  nodejs:
                    Installed: 16.19.0-deb-1nodesource1
                    Candidate: 18.13.0-deb-1nodesource1
                    Version table:
                       18.13.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                   *** 16.19.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                          100 /var/lib/dpkg/status
                       12.22.12~dfsg-1~deb11u3 500
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                       12.22.5~dfsg-2~11u1 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  • M MP_Trixi
                    @bahnuhr
                    aarch64
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    /usr/bin/npx
                    v16.19.0
                    v16.19.0
                    8.19.3
                    8.19.3
                    4.0.24
                    pi
                    tty
                    /home/pi
                    nodejs:
                      Version table:
                    @mp_trixi
                    Die Quelle für nodejs18 solltest du deaktivieren.
                    Und die Quellen für influx sowie Grafana sind auch falsch. Korrigieren!
                      @mp_trixi
                      MP_Trixi
                      @Thomas-Braun
                      hab ich noch gemacht:
                      aarch64
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      v16.19.0
                      v16.19.0
                      8.19.3
                      8.19.3
                      4.0.24
                      pi
                      tty
                      /home/pi
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Hit:6 https://repos.influxdata.com/debian stretch InRelease
                      Hit:7 https://packages.grafana.com/oss/deb stable InRelease
                      All packages are up to date.
                      nodejs:
                        Candidate: 16.19.0-deb-1nodesource1
                        Version table:
                      • M MP_Trixi
                        @Thomas-Braun
                        aarch64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        /usr/bin/npx
                        v16.19.0
                        v16.19.0
                        8.19.3
                        8.19.3
                        4.0.24
                        pi
                        tty
                        /home/pi
                        nodejs:
                          Version table:
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        Das kann doch auch nicht stimmen.
                        Danke.
                        • bahnuhrB bahnuhr
                          MP_Trixi
                          @bahnuhr
                          wie ihr schon gemerkt habt habe keine Ahnung von Linux - was ist das falsch?
                          • M MP_Trixi
                            @bahnuhr
                            @mp_trixi
                            Am besten beide .list Files löschen und grafana und influx nochmal neu einrichten.
                              @mp_trixi
                              MP_Trixi
                              verstehe grad nicht was da nicht passen soll. Mit grafana und influxdb hatte ich bis jetzt noch keine Probleme (zumindest keine denen ich mir bewusst bin). Was ist das Problem bei den beiden?
                              meinst du die beiden Listen?
                               GNU nano 5.4        /etc/apt/sources.list
                              deb http://deb.debian.org/debian bullseye main contrib non-free
                              deb http://security.debian.org/debian-security bullseye-security main contrib non-free
                              deb http://deb.debian.org/debian bullseye-updates main contrib non-free
                              # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
                              #deb-src http://deb.debian.org/debian bullseye main contrib non-free
                              #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
                              #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
                              #node 16
                              deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                              und
                              GNU nano 5.4        /etc/apt/sources.list.d/nodesource.list
                              #node 18
                              #deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
                              #deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
                              • M MP_Trixi
                                #node 16
                                und
                                #node 18
                                @mp_trixi
                                Man trägt Fremdrepos nicht in die sources.list ein, dafür gibt es ja extra eigene Dateien, wie z.B. die nodesource.list.
                                Lösch die Zeilen zu node16 aus der sources.list raus und änder in der nodesource.list die 18 auf 16 ab.
                                Die Repos zu Influx und Grafana werden/wurden gerade umgestellt.
                                Du hast aber da noch einen alten Stand drin, der Eintrag mit 'stretch' bei influx ist darüber hinaus auch für das falsche Release.
                                • M MP_Trixi
                                  #node 16
                                  und
                                  #node 18
                                  @mp_trixi
                                  So sehen die Dateien bei mir aus.
                                  echad@chet:~ $ cat /etc/apt/sources.list.d/grafana.list
                                  deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
                                  echad@chet:~ $ cat /etc/apt/sources.list.d/influxdata.list
                                  deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
                                  Ich würde die an deiner Stelle nochmal inkl. Key neu reinziehen.
                                  Siehe auch:
                                  https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                                  M 3 Antworten Letzte Antwort
                                    @mp_trixi
                                    Siehe auch:
                                    MP_Trixi
                                    danke für die Deine Hilfe - bin da wirklich absoluter DAU der ausführt und nicht wirklich weiß was er tut. In den Files habe ich bisher nichts händisch gemacht (bis auf heute).
                                    Das sieht jetzt so aus:
                                    pi@smarthome:~ $ cat /etc/apt/sources.list
                                    und
                                    pi@smarthome:~ $ cat /etc/apt/sources.list.d/nodesource.list
                                    #node 16
                                    damit sieht es jetzt so aus:
                                    aarch64
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/bin/npx
                                    v16.19.0
                                    v16.19.0
                                    8.19.3
                                    8.19.3
                                    4.0.24
                                    pi
                                    tty
                                    /home/pi
                                    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    nodejs:
                                      Version table:
                                    grafana:
                                    pi@smarthome:~ $ cat /etc/apt/sources.list.d/grafana.list
                                    deb https://packages.grafana.com/oss/deb stable main
                                    influx gibt es nicht
                                    pi@smarthome:~ $ cat /etc/apt/sources.list.d/influxdata.list
                                    cat: /etc/apt/sources.list.d/influxdata.list: No such file or directory
                                    Was müsste ich jetzt genau tun? grafana und influx löschen (wie?) und komplett neu installieren? Was ist dann mit den Einstellungen und Daten?
                                      @mp_trixi
                                      Siehe auch:
                                      MP_Trixi
                                      habe mir den Link angeschaut.
                                      Stimmt. Beim der Anleitung zum downgrade kamen bei sudo apt update fehler zu keys. Da habe ich auch nach Hilfe gesucht und folgendes gefunden zum Beheben (das habe ich auch gemacht):
                                      sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9E439B102CF3C0C6
                                      sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys D8FF8E1F7DF8B07E
                                      einer war influx, einer grafana. Danach lief sudo apt update durch
                                      pi@smarthome:~ $ apt-key list | grep -i grafana | wc -l
                                      Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                      die Keys jetzt löschen?
                                      pub   rsa4096 2015-09-28 [SC]
                                            05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
                                      uid           [ unknown] InfluxDB Packaging Service <support@influxdb.com>
                                      sub   rsa4096 2015-09-28 [E]
                                      pub   rsa2048 2017-01-24 [SC]
                                            4E40 DDF6 D76E 284A 4A67  80E4 8C8C 34C5 2409 8CB6
                                      uid           [ unknown] Grafana <info@grafana.com>
                                      sub   rsa2048 2017-01-24 [E]
                                      pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                                            9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
                                      uid           [ unknown] InfluxData Package Signing Key <support@influxdata.com>
                                      pub   rsa3072 2023-01-06 [SC] [expires: 2025-01-05]
                                            0E22 EB88 E39E 1227 7A77  60AE 9E43 9B10 2CF3 C0C6
                                      uid           [ unknown] Grafana Labs <engineering@grafana.com>
                                      sub   rsa3072 2023-01-06 [E] [expires: 2025-01-05]
                                      • M MP_Trixi
                                        @mp_trixi
                                        Ja, steht auch so im entsprechenden Thread drin.
                                          @mp_trixi
                                          Siehe auch:
                                          MP_Trixi
                                          habs für grafana nach Deiner Anleitung gemacht. Die Keys für influx analog gelöscht
                                          wie sind die folgenden zwei Befehle für influx?
                                          sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                                          echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
