  4. Neuling benötigt Hilfe beim Projekt import und Anpassung
109 Beiträge 7 Kommentatoren 15.2k Aufrufe 4 Beobachtet
  • wendy2702W wendy2702
    Sieht man den fehlenden Router jetzt?
    Was kommt bei
    iob update
    iob list instances
    Und schalte die Grafische Oberfläche aus. Ein Server kommt ohne aus.
    Thoninho7T Offline
    Thoninho7T Offline
    Thoninho7
    #101
    @wendy2702
    * Documentation:  https://help.ubuntu.com
    * Management:     https://landscape.canonical.com
    * Support:        https://ubuntu.com/advantage
    Last login: Thu Feb  9 19:00:35 2023 from 10.0.0.46
    gerald@ioBroker:~$ iob update
    Used repository: stable
    Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.5.12   , installed 2.5.10 [Updatable]
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "fronius"      : 1.1.3    , installed 1.1.3
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "fuelpricemonitor": 0.3.3 , installed 0.3.3
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.2   , installed 1.13.2
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
    Adapter    "onvif"        : 0.4.4    , installed 0.4.4
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
    Adapter    "tapo"         : 0.0.8    , installed 0.0.8
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    gerald@ioBroker:~$ iob list instance
    Unknown type: instance
    gerald@ioBroker:~$ iob instances
    iobroker [command]
    Commands:
     iobroker setup                                               Setup ioBroker
     iobroker start [all|<adapter>.<instance>]                    Starts the js-con        troller or a specified adapter instance
     iobroker stop [<adapter>.<instance>]                         stops the js-cont        roller or a specified adapter instance
     iobroker restart [<adapter>.<instance>]                      Restarts js-contr        oller or a specified adapter instance  [aliases: r]
     iobroker debug <adapter>[.<instance>]                        Starts a Node.js        debugging session for the adapter instance
     iobroker info                                                Shows the host in        fo
     iobroker logs [<adapter>]                                    Monitor log
     iobroker add <adapter> [desiredNumber]                       Add instance of a        dapter  [aliases: a]
     iobroker install <adapter>                                   Installs a specif        ied adapter  [aliases: i]
     iobroker rebuild [<module>]                                  Rebuild all nativ        e modules or path
     iobroker url <url> [<name>]                                  Install adapter f        rom specified url, e.g. GitHub
     iobroker del <adapter>                                       Remove adapter an        d all instances from this host  [aliases: delete]
     iobroker del <adapter>.<instance>                            Remove adapter in        stance  [aliases: delete]
     iobroker update [<repositoryUrl>]                            Update repository        and list adapters
     iobroker upgrade                                             Upgrade managemen        t
     iobroker upload [all|<adapter>]                              Upload management        [aliases: u]
     iobroker object                                              Object management        [aliases: o]
     iobroker state                                               State management        [aliases: s]
     iobroker message <adapter>[.instance] <command> [<message>]  Send message to a        dapter instance/s
     iobroker list <type> [<filter>]                              List all entries,        like objects
     iobroker chmod <mode> <file>                                 Change file right        s
     iobroker chown <user> <group> <file>                         Change file owner        ship
     iobroker touch <file>                                        Touch file
     iobroker rm <file>                                           Remove file
     iobroker file                                                File management
     iobroker user                                                User commands
     iobroker group                                               group management
     iobroker host <hostname>                                     Set host to given        hostname
     iobroker set <adapter>.<instance>                            Change settings o        f adapter config
     iobroker license <license.file or license.text>              Update license by        given file
     iobroker cert                                                Certificate manag        ement
     iobroker clean <yes>                                         Clears all object        s and states
     iobroker backup                                              Create backup
     iobroker restore <backup name or path>                       Restore a specifi        ed backup
     iobroker validate <backup name or path>                      Validate a specif        ied backup
     iobroker status [all|<adapter>.<instance>]                   Status of ioBroke        r or adapter instance  [aliases: isrun]
     iobroker repo [<name>]                                       Show repo informa        tion
     iobroker uuid                                                Show uuid of the        installation  [aliases: id]
     iobroker unsetup                                             Reset license, in        stallation secret and language
     iobroker fix                                                 Execute the insta        llation fixer script, this updates your ioBroker installation
     iobroker multihost                                           Multihost managem        ent
     iobroker compact                                             compact group man        agement
     iobroker plugin                                              Plugin management
     iobroker version [<adapter>]                                 Show version of j        s-controller or specified adapter  [aliases: v]
    Options:
     --help  Show help  [boolean]
    gerald@ioBroker:~$ er instance/s
    Options:
    gerald@ioBroker:~$
    ^Crald@ioBroker:~$p  [boolean]ter  [aliases: v]                Show version of j
    gerald@ioBroker:~$ login as: gerald
    gerald@10.0.0.54's password:
    Welcome to Ubuntu 22.04 LTS (GNU/Linux 5.15.35-2-pve x86_64)
    gerald@ioBroker:~$p  [boolean]ter  [aliases: v]                Show version of j
    gerald@ioBroker:~$
    Das ist alles, was mir aufgeführt wird.
    Huawei konnte ich jetzt nirgenswo lesen
    Ist es möglich, dass der Router unter einem anderen Name läuft??
    Ich habe ja die View vom Sigi234 downgeloadet.
    Thoninho7T 1 Antwort Letzte Antwort
    • Thoninho7T Thoninho7
      @wendy2702
      iobroker [command]
      Commands:
      Options:
      Options:
      gerald@ioBroker:~$
      gerald@ioBroker:~$
      Thoninho7T Offline
      Thoninho7T Offline
      Thoninho7
      #102
      @thoninho7
      Backitup habe ich schon Upgedatet
      Nur zur Info
        @thoninho7
        Nur zur Info
        #103
        @thoninho7
        Pending OS-Updates: 184
        Wie schaut es da aus?
        Dringendst!
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
          @thoninho7
          Dringendst!
          iob stop
          sudo apt update
          sudo reboot
          Thoninho7T Offline
          Thoninho7T Offline
          Thoninho7
          #104
          Danke dir auch für deine Hilfe..
          Hab alles erledigt...
          Nochmals posten??
            Nochmals posten??
            #105
            @thoninho7
            Ich seh gerade erst... lxc...
            Da wirst du wohl den Container neuziehen müssen.
            Kann ich dir aber nicht erklären, ich setze kein Dosenfutter ein.
              @thoninho7
              Thoninho7T Offline
              Thoninho7T Offline
              Thoninho7
              #106
              Verzeih mir, aber ich verstehe das nicht
              Was meinst du damit genau...🤔
                #107
                @thoninho7
                Die Dinger wollen anders unterhalten werden.
                Hab ich aber keinen Plan von.
                • wendy2702W Offline
                  wendy2702W Offline
                  wendy2702
                  #108
                  Alles gut.
                  Im Proxmox CT / LXC geht das Upgrade innerhalb des CT/LXCs eigentlich genau wie eine Native Installation.
                  Im Docker sieht es anders aus. Hast du aber nicht.
                  Aber, zu deiner Liste. Da sieht man nichts von Huawei, das ist auch richtig.
                  Wenn könntest du eventuell was unter den Objecten sehen.
                  Ping Adapter und UPNP, letzteres nur wenn der Huawei das Unterstützt und aktiviert hat.
                    Alles gut.
                    #109
                    @wendy2702 sagte in Neuling benötigt Hilfe beim Projekt import und Anpassung:
                    Ah, stimmt... Aber dieses Dosenfutter...
