  5. Roborock Adapter tester gesucht
    5.8k
766 Beiträge 51 Kommentatoren 310.9k Aufrufe 52 Beobachtet
    DonToben
    #561
    @copystring
    Mit dem letzten dev branch habe ich ständig folgende Meldungen.
    2023-04-16 00:00:11.387 - warn: roborock.0 (31163) MQTT connection close.
    2023-04-16 00:00:11.396 - warn: roborock.0 (31163) MQTT connection reconnect.
    2023-04-16 00:00:11.471 - info: roborock.0 (31163) State value to set for "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.updateStatus.updatable" has to be type "string" but received type "boolean"
    2023-04-16 00:00:21.899 - error: roborock.0 (31163) Failed to execute get_room_mapping. Error: Error: Request with id 6866 timed out after 10 seconds for response.102
    2023-04-16 00:08:21.905 - error: roborock.0 (31163) Failed to execute get_water_box_custom_mode. Error: Error: Request with id 5048 timed out after 10 seconds for response.102
    2023-04-16 00:17:21.905 - error: roborock.0 (31163) Failed to execute get_consumable. Error: Error: Request with id 8491 timed out after 10 seconds for response.102
    2023-04-16 00:17:21.906 - error: roborock.0 (31163) Failed to execute get_carpet_clean_mode. Error: Error: Request with id 2782 timed out after 10 seconds for response.102
    2023-04-16 00:21:21.907 - error: roborock.0 (31163) Failed to execute get_room_mapping. Error: Error: Request with id 2447 timed out after 10 seconds for response.102
    2023-04-16 00:22:21.906 - error: roborock.0 (31163) Failed to execute get_room_mapping. Error: Error: Request with id 6434 timed out after 10 seconds for response.102
    2023-04-16 00:24:21.906 - error: roborock.0 (31163) Failed to execute get_status. Error: Error: Request with id 9671 timed out after 10 seconds for response.102
    2023-04-16 00:24:21.908 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 4780 timed out after 10 seconds for response.102
    2023-04-16 00:44:21.914 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 7326 timed out after 10 seconds for response.102
    2023-04-16 00:54:21.916 - error: roborock.0 (31163) Failed to execute get_status. Error: Error: Request with id 8849 timed out after 10 seconds for response.102
    2023-04-16 01:02:21.924 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 2613 timed out after 10 seconds for response.102
    2023-04-16 01:04:21.924 - error: roborock.0 (31163) Failed to execute get_water_box_custom_mode. Error: Error: Request with id 9896 timed out after 10 seconds for response.102
    2023-04-16 01:24:21.935 - error: roborock.0 (31163) Failed to execute get_network_info. Error: Error: Request with id 2610 timed out after 10 seconds for response.102
    2023-04-16 01:39:21.945 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 4178 timed out after 10 seconds for response.102
    2023-04-16 02:26:25.831 - info: host.raspberrypi Delete log file iobroker.2023-04-08.log.gz
    2023-04-16 02:29:21.967 - error: roborock.0 (31163) Failed to execute get_network_info. Error: Error: Request with id 9757 timed out after 10 seconds for response.102
    2023-04-16 02:29:21.968 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 9992 timed out after 10 seconds for response.102
    2023-04-16 02:31:21.970 - error: roborock.0 (31163) Failed to execute get_room_mapping. Error: Error: Request with id 5967 timed out after 10 seconds for response.102
    2023-04-16 02:45:21.976 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 6739 timed out after 10 seconds for response.102
    2023-04-16 03:00:11.388 - warn: roborock.0 (31163) MQTT connection close.
    2023-04-16 03:00:11.389 - warn: roborock.0 (31163) MQTT connection reconnect.
    2023-04-16 03:00:11.611 - info: roborock.0 (31163) State value to set for "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.updateStatus.updatable" has to be type "string" but received type "boolean"
    2023-04-16 03:02:21.981 - error: roborock.0 (31163) Failed to execute get_network_info. Error: Error: Request with id 7462 timed out after 10 seconds for response.102
    2023-04-16 03:02:21.983 - error: roborock.0 (31163) Failed to execute get_water_box_custom_mode. Error: Error: Request with id 9020 timed out after 10 seconds for response.102
    2023-04-16 03:05:21.983 - error: roborock.0 (31163) Failed to execute get_status. Error: Error: Request with id 9954 timed out after 10 seconds for response.102
    2023-04-16 03:05:21.984 - error: roborock.0 (31163) Failed to execute get_consumable. Error: Error: Request with id 3501 timed out after 10 seconds for response.102
    2023-04-16 03:05:21.984 - error: roborock.0 (31163) Failed to execute get_network_info. Error: Error: Request with id 6613 timed out after 10 seconds for response.102
    2023-04-16 03:05:21.985 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 3573 timed out after 10 seconds for response.102
    2023-04-16 03:05:21.986 - error: roborock.0 (31163) Failed to execute get_carpet_clean_mode. Error: Error: Request with id 4264 timed out after 10 seconds for response.102
    2023-04-16 03:05:21.986 - error: roborock.0 (31163) Failed to execute get_water_box_custom_mode. Error: Error: Request with id 6112 timed out after 10 seconds for response.102
    2023-04-16 03:05:21.987 - error: roborock.0 (31163) Failed to execute get_room_mapping. Error: Error: Request with id 9996 timed out after 10 seconds for response.102
    2023-04-16 03:36:21.998 - error: roborock.0 (31163) Failed to execute get_consumable. Error: Error: Request with id 8101 timed out after 10 seconds for response.102
    2023-04-16 03:36:21.999 - error: roborock.0 (31163) Failed to execute get_carpet_clean_mode. Error: Error: Request with id 1292 timed out after 10 seconds for response.102
    2023-04-16 03:40:22.002 - error: roborock.0 (31163) Failed to execute get_status. Error: Error: Request with id 5963 timed out after 10 seconds for response.102
    2023-04-16 03:51:22.009 - error: roborock.0 (31163) Failed to execute get_consumable. Error: Error: Request with id 4946 timed out after 10 seconds for response.102
    2023-04-16 03:54:22.010 - error: roborock.0 (31163) Failed to execute get_consumable. Error: Error: Request with id 1316 timed out after 10 seconds for response.102
    2023-04-16 03:54:22.011 - error: roborock.0 (31163) Failed to execute get_carpet_clean_mode. Error: Error: Request with id 1181 timed out after 10 seconds for response.102
    2023-04-16 03:55:22.011 - error: roborock.0 (31163) Failed to execute get_consumable. Error: Error: Request with id 2767 timed out after 10 seconds for response.102
    2023-04-16 03:58:22.015 - error: roborock.0 (31163) Failed to execute get_status. Error: Error: Request with id 2554 timed out after 10 seconds for response.102
    2023-04-16 03:58:22.016 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 2289 timed out after 10 seconds for response.102
    2023-04-16 03:58:22.018 - error: roborock.0 (31163) Failed to execute get_room_mapping. Error: Error: Request with id 4789 timed out after 10 seconds for response.102
    2023-04-16 04:03:22.022 - error: roborock.0 (31163) Failed to execute get_room_mapping. Error: Error: Request with id 9611 timed out after 10 seconds for response.102
    2023-04-16 04:25:22.038 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 2463 timed out after 10 seconds for response.102
    2023-04-16 04:34:22.040 - error: roborock.0 (31163) Failed to execute get_status. Error: Error: Request with id 5493 timed out after 10 seconds for response.102
    2023-04-16 04:57:22.053 - error: roborock.0 (31163) Failed to execute get_status. Error: Error: Request with id 1654 timed out after 10 seconds for response.102
    2023-04-16 05:06:22.063 - error: roborock.0 (31163) Failed to execute get_carpet_clean_mode. Error: Error: Request with id 3276 timed out after 10 seconds for response.102
    2023-04-16 05:25:22.074 - error: roborock.0 (31163) Failed to execute get_status. Error: Error: Request with id 1712 timed out after 10 seconds for response.102
    2023-04-16 05:25:22.074 - error: roborock.0 (31163) Failed to execute get_carpet_mode. Error: Error: Request with id 6715 timed out after 10 seconds for response.102
    2023-04-16 06:00:00.070 - info: alexa2.0 (31244) Scheduled restart.
    2023-04-16 06:00:00.092 - info: roborock.0 (31163) Scheduled restart.
    2023-04-16 06:00:00.101 - info: alexa2.0 (31244) terminating
    copystringC 1 Antwort Letzte Antwort
    • A ArnoD
      @copystring ist es eigentlich möglich einen Timer zu integrieren so wie im Adapter mihome-vacuum ?
      Dort konnte man bei den Adaptereinstellungen für die Reinigung eine Startzeit und Tag eingeben, sodass die Reinigung auch gestartet wurde, wenn mal keine Internetverbindung vorhanden war.
      copystringC Offline
      copystringC Offline
      copystring
      #562
      @arnod said in Roborock Adapter tester gesucht:
      Das kann man auch direkt über blockly oder über den Smartcontrol Adapter machen. Sowas baue ich nicht extra nochmal ein.
      @dontoben said in Roborock Adapter tester gesucht:
      @copystring
      Hast du deinen RPi mal neu gestartet? Das liegt wahrscheinlich nicht an meinem Adapter, sondern an irgendwas anderen.
      Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
      https://paypal.me/copystring
      copystringC D 2 Antworten Letzte Antwort
      • copystringC copystring
        @copystring
        copystringC Offline
        copystringC Offline
        copystring
        #563
        @copystring said in Roborock Adapter tester gesucht:
        Oder meinst du, dass speichern der Zeiten direkt im Roboter? Ja, dann kann ich mir das angucken.
        A 1 Antwort Letzte Antwort
          @copystring
          DonToben
          schrieb am zuletzt editiert von DonToben
          #564
          @copystring
          Probiere ich aus. Aber obwohl die Meldungen kommen, lässt sich der Roborock einwandfrei über den Adapter steuern.
            ArnoD
            #565
            @copystring sagte in Roborock Adapter tester gesucht:
            Ja, um sicherzustellen, dass die Reinigung auch ohne eine Verbindung zum Internet bzw. W-LAN startet.
            • D DonToben
              @copystring
              DonToben
              #566
              @copystring
              Habe ein issue auf GitHub erstellt. Neustart des RPi brachte keine Besserung.
              P 1 Antwort Letzte Antwort
              • D DonToben
                @copystring
                pad
                #567
                Guten Tag!
                endlich gibt es ein solches Plugin, erstmal vielen Dank dafür.
                Ich habe den S7 MaxV Ultra und ich vermisse aktuelle eigentlich Hauptsächlich eine Funktion:
                Ich haber in der IOS Roborock App ein Programm erstellt, welche mir Automatisch eine Zone reinigt, wenn ich darauf tipper. Ist irgendwie geplant diese bereits angelegten Zonen ueber iobroker nutzen zu koennen? Konkret reinigt die Zone immer den Bereich vom Esstisch, wo die kleine gesessen hat.
                Mfg
                pad
                • O Online
                  O Online
                  oxident
                  #568
                  Hier gleiches Problem wie bei @DonToben
                  Bei mir jedoch in einer "potenten" VM auf einem x86.
                  • O oxident
                    David G.D Offline
                    David G.D Offline
                    David G.
                    #569
                    @oxident
                    Glaube auch nicht im Ansatz, dass sich derartige Fehler mit einer potenten vm von selber lösen ^^.
                    O 1 Antwort Letzte Antwort
                    • David G.D David G.
                      @oxident
                      O Online
                      O Online
                      oxident
                      #570
                      @david-g Naja, mehr RAM hilft ja auch gegen Memory-Leaks. Zumindest eine Weile 😁
                      Wollte damit auch nur sagen, scheint kein Raspi-Problem zu sein
                      • D DonToben
                        @copystring
                        copystringC Offline
                        copystringC Offline
                        copystring
                        #571
                        @copystring
                        Der Server von Roborock antwortet halt nicht immer. Das kann ja verschiedene Gründe haben. Der Adapter erkennt eben, dass der Server nicht antwortete. Das musste ich einbauen, weil es sonst Nachrichten gab, die durcheinandergekommen sind.
                          @copystring
                          socke85
                          #572
                          Ich habe den Adapter installiert und habe nur einen leeren Ordner in den Objekten unter Instanzen taucht er nicht auf. Installiert mit der URL: https://github.com/copystring/ioBroker.roborock.git
                          js 4.0.24 NPM:
                          v8.19.2
                          Habt ihr einen Tipp für mich?
                            RandyAndy
                            schrieb am zuletzt editiert von RandyAndy
                            #573
                            Eigentlich finde ich den Adapter als solches ja interessant. Ich habe Ihn auch mehrfach installiert/geupdated. Inzwischen habe ich Ihn aber wieder gelöscht. Plötzlich war der Plan der Wohnung verdoppelt. Das Roboter hat sich dann auch komisch verhalten. Ich kann natürlich nicht sagen ob dies der Adpter ist oder nicht. Nach der Deinstallation (ist nun auch schon 2-3 Wochen her) ist wieder alles normal.
                            Da man die Cloud immer noch braucht ist mir dann die App doch lieber, da man ja eigentlich mit dem Adpater nicht mehr machen kann. Der Adpater wäre erst dann interessant wenn er den Cloud-Zwang aufhebt, dann würde ich mich wieder damit beschäftigen.
                            copystringC O 2 Antworten Letzte Antwort
                            • R RandyAndy
                              copystringC Offline
                              copystringC Offline
                              copystring
                              #574
                              @randyandy said in Roborock Adapter tester gesucht:
                              Klar. Der Adapter kann nicht jedem gefallen. Das ist auch OK so. Wenn du allerdings eine Lösung möchtest, welche ohne Cloud klarkommt, dann musst du dir Valetudo auf dem Roboter installieren. Eine custom Firmware, welche die Cloudanbindung auflöst und ausschließlich lokal funktioniert. Damit wird allerdings kein Multilevel Reinigen unterstützt. Man kann also nur eine Karte haben, welche man dann entsprechend tauschen muss, wenn man das Stockwerk wechselt.
                              • R RandyAndy
                                O Online
                                O Online
                                oxident
                                schrieb am zuletzt editiert von oxident
                                #575
                                @randyandy Ich denke, man sollte den Adapter auch nicht als Konkurrenz zur App sehen. Eher als Ergänzung: Wer will, der kann z. B. mit dem Wandschalter die Reinigung starten, beim Aufschließen der Haustür den Roboter die Reinigung abbrechen lassen usw.
                                Diese ganzen Möglichkeiten sind doch eigentlich das, was ein -Smart- home ausmachen.
                                copystringC David G.D 2 Antworten Letzte Antwort
                                • O oxident
                                  copystringC Offline
                                  copystringC Offline
                                  copystring
                                  schrieb am zuletzt editiert von copystring
                                  #576
                                  @oxident said in Roborock Adapter tester gesucht:
                                  Dem kann ich mich nur anschließen. Bei uns lasse ich den Roboter automatisch reinigen sobald alle das Haus verlassen. Das Haus weiß immer wann jemand zu Hause ist.
                                  • O oxident
                                    David G.D Offline
                                    David G.D Offline
                                    David G.
                                    #577
                                    @oxident sagte in Roborock Adapter tester gesucht:
                                    Das finde ich nicht.
                                    Meine Frau nutzt die App, ich ausnahmslos den Adapter.
                                    Ich behaupte, über meine Visualisierung bestimmt 95% dessen was die App kann ab abzubilden.
                                    Mir fehlt nur die Zonenreinigung (nutze ich auch nicht), da diese am Raspi nicht klappt.
                                      @copystring
                                      Ok, hier das LOG file:
                                      LOG.txt
                                      Irgendwas stimmt mit deinen Räumen nicht. Es gibt einen Raum ohne ID. In diesem Fall der Raum mit der Nummer 21. Sowas habe ich bisher aber noch nicht gesehen. Irgendwie merkwürdig, aber die Daten kommen so direkt von Roborock.
                                      All mapped rooms: [[16,"10523949",13],[17,"10737469",6],[18,"10523966",12],[19,"10523989",12],[20,"10523984",8],[21,"NaN",13]]
                                      Kannst du das mal in deiner App kontrollieren?
                                      @david-g said in Roborock Adapter tester gesucht:
                                      Mit ist eben beim dock_error_status etwas aufgefallen.
                                      Denke aber, da kann man nichts machen.
                                      Während der Reinigung ist der Roboter zur Station gefahren um den Mop zu waschen. Dabei ist das Wasser ausgegangen und es gab den Errorcode
                                      38.
                                      Danach hat der Roboter seine Reinigung fortgesetzt und ist am Ende wieder zur Basis zurück.
                                      Dabei ist der dock_error_status wieder auf 0 gesprungen obwohl das Wasser noch leer ist.
                                      Ja, ich glaube, da kann ich nichts machen. Du kannst mir aber gerne ein Log anhängen, damit ich das prüfen kann.
                                      @spampunk said in Roborock Adapter tester gesucht:
                                      Hallo @copystring ,
                                      Ich verfolge schon seit einiger Zeit diesen Thread und kann es kaum erwarten, dass der Adapter in stable Status geht.
                                      An dieser Stelle vielen herzlichen Dank, dass Du Dich der Sache angenommen hast und viel Zeit und know how in dieses Projekt hinein steckst.
                                      Wenn ich das richtig verstehe, scheinen die grundsätzlichen Funktionen ja implementiert zu sein. Wäre es dann möglich, den Adapter mit den Grundfunktionen (Saugen & Karte) ins stable repository zu packen und die weniger relevanten Punkte nachzuliefern?
                                      Viele Grüße,
                                      Timo
                                      Hallo Timo,
                                      danke für das Feedback. Die Anfrage für das Aufnehmen in die offizielle Repo habe ich bereits am 28. Februar gestellt und ist noch offen.
                                      Spampunk
                                      #578
                                      @copystring Ich warte ja wie auf Weihnachten, dass Dein Adapter im ioBroker Repository aufgenommen wird.
                                      Bis dahin: gibt es auf GitHub eine Version, die als stable betrachtet werden kann? Dann würde ich die gerne installieren.
                                      Ich bin halt ein wenig vorsichtig, da mein S5Max zurzeit noch mit Xiaomi unterwegs ist und der Wechsel zu Roborock bedeutet, sowohl den Sauger, als auch meine (umfangreiche) Visualisierung umzustellen.
                                      LG,
                                      Timo
                                      • S Spampunk
                                        LG,
                                        Timo
                                        David G.D Offline
                                        David G.D Offline
                                        David G.
                                        #579
                                        @spampunk sagte in Roborock Adapter tester gesucht:
                                        Ist von @copystring ja schon beantragt.
                                        Aus seiner Sicht ist der Adapter also schon stable.
                                        Wenn du das "Wagnis" eingehen möchtest, kannst du es eigentlich auch jetzt schon machen.
                                        Bei mir läuft der Adapter absolut rund (bis auf Systembedingt die Zonenreinigung und warum auch immer die Kamera).
                                          bernhaddl
                                          schrieb am zuletzt editiert von bernhaddl
                                          #580
                                          Hallo zusammen, bei mir werden einige Räume immer in beiden Geschossen angelegt. Nach dem Löschen der Ordner und Adapterneustart passt alles, aber sobald ich in der App die Geschosse einmal gewechselt habe herrscht wieder komplettes durcheinander.
                                          Hat noch jemand das Problem?
                                          Die Karten werden bei mir auch nicht angezeigt:
