  4. Viessmann-Adapter mit vcontrol
    1.0k
    6.1k
354 Beiträge 18 Kommentatoren 133.4k Aufrufe 17 Beobachtet
  • M MartyBr
    @issr4k
    Ich habe hier mal die Vorgängerversion ohne meine Änderungen eingestellt. Meine Version stürzt nach 2 Stunden ab und reisst der Adapter auch runter.
    vcontrol.xml
    <?xml version="1.0"?>
    <V-Control xmlns:vcontrol="http://www.openv.de/vcontrol">
      <unix>
         <config>
    	<serial>
    		<tty>/dev/ttyUSB0</tty>
    	</serial>
    	<net>
    		<port>3002</port>
    		<allow ip='127.0.0.1'/>
    		<allow ip='192.168.178.0/24'/>
    	</net>
    	<logging>
    		<file>/var/log/vcontrold.log</file>
    		<syslog>n</syslog>
    		<debug>y</debug>
    	</logging>
    	<device ID="204D"/>
         </config>
      </unix>
      <units>
    	<unit name='Temperatur'>
    	   <abbrev>UT</abbrev>
    	   <calc get='V/10' set='V*10'/>
    	   <type>short</type>
    	   <entity>Degrees Celsius</entity>
    	</unit>
    	<unit name='Neigung'>
    	   <abbrev>UN</abbrev>
    	   <type>short</type>
    	   <entity></entity>
    	</unit>
    	<unit name='Temperatur 1Byte'>
              <abbrev>UT1</abbrev>
              <calc get='V/2' set='V*2'/>
              <type>char</type>
            </unit>
    	<unit name='Temperatur 1Byte unsigned'>
              <abbrev>UT1U</abbrev>
              <type>uchar</type>
            </unit>
    	<unit name='Temperatur 1Byte ganzzahlig'>
              <abbrev>UTI</abbrev>
              <calc get='V' set='V'/>
              <type>uchar</type>
            </unit>
    	<unit name='Status'>
    	   <abbrev>ST</abbrev>
    	   <type>char</type>
    	   <entity></entity>
    	</unit>
    	<unit name='Counter'>
    	   <abbrev>CO</abbrev>
    	   <type>int</type>
    	   <entity></entity>
    	</unit>
    	<unit name='Prozent'>
    	   <abbrev>PR</abbrev>
    	   <type>short</type>
    	   <entity>%</entity>
    	</unit>
    	<unit name='Prozent 1 Byte ganzzahlig'>
    	   <abbrev>PR1</abbrev>
    	   <type>uchar</type>
    	   <entity>%</entity>
    	</unit>
    	<unit name='CounterS'>
    	   <abbrev>CS</abbrev>
    	   <calc get='V/3600' set='V*3600'/>
    	   <type>uint</type>
    	   <entity>Stunden</entity>
    	</unit>
    	<unit name='CycleTime'>
    	   <abbrev>CT</abbrev>
    	   <type>cycletime</type>
    	</unit>
    	<unit name='ReturnStatus'>
    	   <abbrev>RT</abbrev>
    	   <type>enum</type>
    	   <enum bytes='00' text='0'/>
    	   <enum bytes='01' text='1'/>
               <enum bytes='02' text='EIN'/>
    	   <enum text='NOT OK'/>
    	</unit>
    	<unit name='BetriebsArt'>
    	   <abbrev>BA</abbrev>
    	   <type>enum</type>
    	   <enum bytes='00' text='Abschaltbetrieb'/>
    	   <enum bytes='01' text='Warmwasser'/>
    	   <enum bytes='02' text='Heizen und Warmwasser'/>
    	   <enum bytes='03' text='3'/>
    	   <enum bytes='04' text='dauernd reduziert'/>
    	   <enum bytes='05' text='dauernd normal'/>
    	   <enum bytes='06' text='normal Abschalt'/>
     	   <enum bytes='07' text='nur Kuehlen'/>
    	   <enum text='UNKNOWN'/>
    	</unit>
    	 <unit name='SetReturnStatus'>
               <abbrev>SR</abbrev>
               <type>enum</type>
               <enum bytes='00' text='OK'/>
               <enum bytes='05' text='SYNC (NOT OK)'/>
            </unit>
            <unit name='SystemTime'>
    	   <abbrev>TI</abbrev>
    	   <type>systime</type>
    	</unit>
    	<unit name='ErrorState'>
    	   <abbrev>ES</abbrev>
    	   <type>errstate</type>
    	   <enum bytes='00' text='Control mode (no error)'/>
    	   <enum bytes='0F' text='Maintenance (reset coding for 24 to 0)'/>
    	   <enum bytes='10' text='Outside temperature sensor short circuit'/>
    	   <enum bytes='18' text='Lead break outside temperature sensor'/>
    	   <enum bytes='20' text='Short-circuit flow temperature sensor'/>
    	   <enum bytes='21' text='Short-circuit temperature sensor rewind'/>
    	   <enum bytes='28' text='Interruption outside temperature sensor'/>
    	   <enum bytes='29' text='Interruption rewind temperature sensor'/>
    	   <enum bytes='30' text='Burner blocked check boiler water temp sensor'/>
    	   <enum bytes='38' text='Burner blocked lead break temperature sensor'/>
    	   <enum bytes='40' text='Short-circuit flow temperature sensor M2'/>
    	   <enum bytes='42' text='Interruption flow temperature sensor M2'/>
    	   <enum bytes='50' text='No DHW heating, check cylinder temperature sensor'/>
         <enum bytes='51' text='No DHW heating, short circuit outlet temperature sensor'/>
         <enum bytes='52' text='Burner blocked, short circuit flow sensor'/>
         <enum bytes='58' text='No DHW heating, lead break outlet temperature sensor'/>
    	   <enum bytes='92' text='Solar: Kurzschluss Kollektortemperatursensor'/>
    	   <enum bytes='93' text='Solar: Kurzschluss Sensor S3'/>
    	   <enum bytes='94' text='Solar: Kurzschluss Speichertemperatursensor'/>
    	   <enum bytes='9A' text='Solar: Unterbrechung Kollektortemperatursensor'/>
    	   <enum bytes='9B' text='Solar: Unterbrechung Sensor S3'/>
    	   <enum bytes='9C' text='Solar: Unterbrechung Speichertemperatursensor'/>
    	   <enum bytes='9F' text='Solar: Fehlermeldung Solarteil (siehe Solarregler)'/>
    	   <enum bytes='A7' text='Control unit faulty'/>
    	   <enum bytes='B0' text='Burner blocked, Short exhaust temperature sensor'/>
    	   <enum bytes='B1' text='Communication error Control Unit'/>
    	   <enum bytes='B4' text='Internal error (Electronics)'/>
    	   <enum bytes='B5' text='Internal error (Electronics)'/>
    	   <enum bytes='B6' text='Invalid hardware ID (Electronics)'/>
    	   <enum bytes='B7' text='Internal error (boiler encodable connector)'/>
    	   <enum bytes='B8' text='Burner blocked, lead break exhaust temperature sensor'/>
    	   <enum bytes='B9' text='Repeat internal error (data input)'/>
    	   <enum bytes='BA' text='Communication error extension kit for mixer circuit M2'/>
    	   <enum bytes='BC' text='Remote communication error Vitorol, heating M1'/>
    	   <enum bytes='BD' text='Remote communication error Vitorol, heating M2'/>
    	   <enum bytes='BE' text='Incorrect coding remote control Vitorol'/>
    	   <enum bytes='C1' text='External safety device (boiler cools off)'/>
    	   <enum bytes='C2' text='Kommunikationsfehler Solarregelung'/>
    	   <enum bytes='C5' text='Communication error variable speed heating circuit pump, heating circuit M1'/>
    	   <enum bytes='C6' text='Communication error variable speed heating circuit pump, heating circuit M2'/>
    	   <enum bytes='C7' text='Incorrect coding of the heating circuit pump'/>
    	   <enum bytes='C9' text='Fault message on the control module V active'/>
    	   <enum bytes='CD' text='communication error Vitocom 100 (KM-BUS)'/>
    	   <enum bytes='CE' text='communication error Schaltmodul-V'/>
    	   <enum bytes='CF' text='communication error LON Modul'/>
    	   <enum bytes='D1' text='Burner Fault'/>
    	   <enum bytes='D4' text='Safety breaker tripped or fault message is not inserted properly'/>
    	   <enum bytes='DA' text='Short circuit temperature sensor, heating circuit M1'/>
    	   <enum bytes='DB' text='Short circuit temperature sensor, heating circuit M2'/>
    	   <enum bytes='DD' text='Interruption temperature sensor, heating circuit M1'/>
    	   <enum bytes='DE' text='Interruption temperature sensor, heating circuit M2'/>
         <enum bytes='E3' text='Burner in fault state, fault in safety chain'/>
         <enum bytes='E4' text='Error supply voltage'/>
    	   <enum bytes='E5' text='Internal error (check ionization electrode)'/>
    	   <enum bytes='E6' text='Exhaust / supply air clogged'/>
    	   <enum bytes='F0' text='(Exchange control) internal error'/>
    	   <enum bytes='F1' text='Max exhaust gas temperature exceeded'/>
    	   <enum bytes='F2' text='Triggered temperature limiter'/>
    	   <enum bytes='F3' text='Burner fault, flame signal present at burner start'/>
    	   <enum bytes='F4' text='No Flame signal'/>
    	   <enum bytes='F7' text='Differenzdrucksensor defekt'/>
    	   <enum bytes='F8' text='Fuel valve closes too late'/>
    	   <enum bytes='F9' text='Fan speed too low during burner start'/>
    	   <enum bytes='FA' text='Fan not at stand-still'/>
         <enum bytes='FC' text='Electric Fan control unit faulty'/>
         <enum bytes='FD' text='Burner blocked, burner control unit faulty'/>
    	   <enum bytes='FE' text='Starkes Stoerfeld (EMV) in der Naehe oder Elektronik defekt'/>
    	   <enum bytes='FF' text='Strong interference (EMC) field exists'/>
    	</unit>
    	<unit name='DeviceType'>
               <abbrev>DT</abbrev>
               <type>enum</type>
    		       <enum bytes='20 4D' text='V200-S ID=204D Protokoll:P300'/>
    	</unit>
    	<unit name='Brenner Stunden'>
               <abbrev>BH</abbrev>
               <type>uchar</type>
    	   <calc get='(B1 * 100)+B0'/>
    	   <entity>h</entity>
    	</unit>
    	<unit name='Bitstatus'>
               <abbrev>BST</abbrev>
               <type>uchar</type>
               <icalc get="(B0 &amp; (0x01&lt;&lt;BP))&gt;&gt; BP"/>
            </unit>
    	<unit name='HKP Pumpentyp'>
               <abbrev>HKT</abbrev>
               <type>uchar</type>
               <enum bytes='00' text='stufig'/>
               <enum bytes='01' text='drehzahlgeregelt'/>
            </unit>
      </units>
      <protocols>
          <protocol name='P300'>
              <pid>41</pid>
              <macros>
                    <macro name='GETADDR'>
                        <command>SEND 00 01</command>
                    </macro>
              </macros>
              <commands>
                    <command name="getaddr">
                         <send>GETADDR $addr $hexlen;RECV $len $unit</send>
                    </command>
                    <command name="setaddr">
                         <send>SEND 00 02 $addr $hexlen BYTES;RECV 1 SR</send>
                    </command>
                    <command name="setaddr0">
                         <send>SEND 00 02 $addr $hexlen 00;RECV 1 SR</send>
                    </command>
                    <command name="setaddr1">
                         <send>SEND 00 02 $addr $hexlen 01;RECV 1 SR</send>
                    </command>
                    <command name="setaddr2">
                         <send>SEND 00 02 $addr $hexlen 02;RECV 1 SR</send>
                    </command>
                    <command name="setaddr16">
                         <send>SEND 00 02 $addr $hexlen A0 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr17">
                         <send>SEND 00 02 $addr $hexlen AA 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr18">
                         <send>SEND 00 02 $addr $hexlen B4 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr19">
                         <send>SEND 00 02 $addr $hexlen BE 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr20">
                         <send>SEND 00 02 $addr $hexlen C8 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr21">
                         <send>SEND 00 02 $addr $hexlen D2 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr22">
                         <send>SEND 00 02 $addr $hexlen DC 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr23">
                         <send>SEND 00 02 $addr $hexlen E6 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr24">
                         <send>SEND 00 02 $addr $hexlen F0 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr25">
                         <send>SEND 00 02 $addr $hexlen FA 00;RECV 2 SR</send>
                    </command>
                    <command name="setaddr45">
                         <send>SEND 00 02 $addr $hexlen C2 01;RECV 2 SR</send>
                    </command>
                    <command name="setaddr55">
                         <send>SEND 00 02 $addr $hexlen 26 02;RECV 2 SR</send>
                    </command>
                </commands>
          </protocol>
        </protocols>
      <extern xmlns:xi="http://www.w3.org/2003/XInclude">
         <xi:include href="vito.xml" parse="xml"/>
      </extern>
    </V-Control>
    vito.xml
    <vito>
            <devices>
                    <device ID="204D" name="V200-S" protocol="P300"/>
            </devices>
            <commands>
    <command name="getDevType" protocmd="getaddr">
             <addr>00F8</addr>
             <len>2</len>
             <unit>UN</unit>
             <description>Information - Allgemein: Anlagentyp (204D)</description>
         </command>
         <command name="getTempA" protocmd="getaddr">
             <addr>0101</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Allgemein: Aussentemperatur (-40..70)</description>
         </command>
         <command name="getTempSekVL" protocmd="getaddr">
             <addr>0105</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK1: Vorlauftemperatur Sekundaer 1 (0..95)</description>
         </command>
         <command name="getTempSekRL" protocmd="getaddr">
             <addr>0106</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Diagnose - Anlagenuebersicht: Ruecklauftemperatur Sekundaer 1 (0..95)</description>
         </command>
         <command name="getTempWWIstOben" protocmd="getaddr">
             <addr>010d</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Warmwasser: Warmwassertemperatur oben (0..95)</description>
         </command>
         <command name="getTempPriVL" protocmd="getaddr">
             <addr>0103</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Diagnose - Anlagenuebersicht: Vorlauftemperatur Primaerquelle (-20..95)</description>
         </command>
         <command name="getTempPriRL" protocmd="getaddr">
             <addr>0104</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Diagnose - Anlagenuebersicht: Ruecklauftemperatur Primaerquelle (-20..95)</description>
         </command>
         <command name="getTempSek2RL" protocmd="getaddr">
             <addr>0107</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Diagnose - Anlagenuebersicht: Ruecklauftemperatur Sekundaer 2 (0..95)</description>
         </command>
         <command name="getTempAnlVL" protocmd="getaddr">
             <addr>010A</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Allgemein: Anlagenvorlauftemperatur (0..95)</description>
         </command>
         <command name="getTempPufferIst" protocmd="getaddr">
             <addr>010B</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Allgemein: Pufferspeichertemperatur (0..95)</description>
         </command>
         <command name="getTempWWIstUnten" protocmd="getaddr">
             <addr>010f</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Warmwasser: Warmwassertemperatur unten (0..95)</description>
         </command>
         <command name="getTempSolKoll" protocmd="getaddr">
             <addr>0111</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Solar: Solar Kollektortemperatur (-20..190)</description>
         </command>
         <command name="getTempSolRL" protocmd="getaddr">
             <addr>0112</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Solar: Solar Ruecklauftemperatur (0..95)</description>
         </command>
         <command name="getTempSolSp" protocmd="getaddr">
             <addr>0113</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Solar: Solar Speichertemperatur (0..95)</description>
         </command>
         <command name="getTempSek2VL" protocmd="getaddr">
             <addr>0114</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK2: Vorlauftemperatur Sekundaer 2 (0..95)</description>
         </command>
         <command name="getTempSek3VL" protocmd="getaddr">
             <addr>0115</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK3: Vorlauftemperatur Sekundaer 3 (0..95)</description>
         </command>
         <command name="getTempRaumIst" protocmd="getaddr">
             <addr>0116</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK1: Raumtemperatur HK1 (0..40)</description>
         </command>
         <command name="getTempRaumIst2" protocmd="getaddr">
             <addr>0117</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK2: Raumtemperatur HK2 (0..40)</description>
         </command>
         <command name="getTempRaumIst3" protocmd="getaddr">
             <addr>0118</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK3: Raumtemperatur HK3 (0..40)</description>
         </command>
         <command name="getTempKuehlVL" protocmd="getaddr">
             <addr>0119</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK1: Vorlauftemperatur Kuehlkreis 1 (0..95)</description>
         </command>
         <command name="getTempKuehlVL2" protocmd="getaddr">
             <addr>0119</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK1: Vorlauftemperatur Kuehlkreis 2 (0..95)</description>
         </command>
         <command name="getTempKuehlVL3" protocmd="getaddr">
             <addr>0119</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK1: Vorlauftemperatur Kuehlkreis 3 (0..95)</description>
         </command>
         <command name="getTempRaumSoll" protocmd="getaddr">
             <addr>011B</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK1: Raumsolltemperatur HK1 von FB (10..30)</description>
         </command>
         <command name="getTempRaumSoll2" protocmd="getaddr">
             <addr>011C</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK2: Raumsolltemperatur HK2 von FB (10..30)</description>
         </command>
         <command name="getTempRaumSoll3" protocmd="getaddr">
             <addr>011D</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Information - Heizkreis HK3: Raumsolltemperatur HK3 von FB (10..30)</description>
         </command>
         <command name="getStatusV1" protocmd="getaddr">
             <addr>0480</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Diagnose - Anlagenuebersicht: Verdichter 1 (Schuetz) (0..1)</description>
         </command>
         <command name="getStatusV2" protocmd="getaddr">
             <addr>0481</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Diagnose - Anlagenuebersicht: Verdichter 2 (Schuetz) (0..1)</description>
         </command>
         <command name="getStatusQuellePri1" protocmd="getaddr">
             <addr>0482</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Diagnose - Anlagenuebersicht: Primaerquelle 1 (Vent. oder Primaerpumpe (0..1)</description>
         </command>
         <command name="getStatusQuellePri2" protocmd="getaddr">
             <addr>0483</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Diagnose - Anlagenuebersicht: Primaerquelle 2 (Primaerpumpe) (0..1)</description>
         </command>
         <command name="getStatusSekP" protocmd="getaddr">
             <addr>0484</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Diagnose - Anlagenuebersicht: Sekundaerpumpe 1 (0..1)</description>
         </command>
         <command name="getStatusExtW" protocmd="getaddr">
             <addr>048B</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Diagnose - Allgemein: Relais Ansteuerung ext. Waermeerzeuge (0..1)</description>
         </command>
         <command name="getStatusPumpe" protocmd="getaddr">
             <addr>048D</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Information - Heizkreis HK1: Heizkreispumpe (0..1)</description>
         </command>
         <command name="getStatusPumpe2" protocmd="getaddr">
             <addr>048E</addr>
             <len>1-Bit</len>
             <unit>RT</unit>
             <description>Information - Heizkreis HK2: Heizkreispumpe (0..1)</description>
         </command>
         <command name="getStatusPumpeZirk" protocmd="getaddr">
             <addr>0490</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Information - Warmwasser: Zirkulationspumpe (0..1)</description>
         </command>
         <command name="getStatusVentilWW" protocmd="getaddr">
             <addr>0494</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Diagnose - Waermepumpe: 3-W-Ventil Heizen WW1 (0 (Heizen)..1 (WW))</description>
         </command>
         <command name="getStatusVentilWW2" protocmd="getaddr">
             <addr>0495</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Diagnose - Waermepumpe: 3-W-Ventil Heizen WW2 (0 (Heizen)..1 (WW))</description>
         </command>
         <command name="getStatusSpeicherPumpe" protocmd="getaddr">
             <addr>0496</addr>
             <len>1-Bit</len>
             <unit>RT</unit>
             <description>Information - Warmwasser: Speicherladepumpe (0..1)</description>
         </command>
         <command name="getAnzQuelleSek" protocmd="getaddr">
             <addr>0504</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Schaltzyklen Anlage: Einschaltungen Sekundaerquelle (?)</description>
         </command>
         <command name="getAnzHeizstabSt1" protocmd="getaddr">
             <addr>0508</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Schaltzyklen Anlage: Einschaltungen Heizstab Stufe 1 (?)</description>
         </command>
         <command name="getAnzHeizstabSt2" protocmd="getaddr">
             <addr>0509</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Schaltzyklen Anlage: Einschaltungen Heizstab Stufe 2 (?)</description>
         </command>
         <command name="getAnzHK" protocmd="getaddr">
             <addr>050D</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Schaltzyklen Anlage: Einschaltungen Heizkreis (?)</description>
         </command>
         <command name="getLZPumpeSek" protocmd="getaddr">
             <addr>0584</addr>
             <len>4</len>
             <unit>CS</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Sekundaerpumpe (?)</description>
         </command>
         <command name="getLZHeizstabSt1" protocmd="getaddr">
             <addr>0588</addr>
             <len>4</len>
             <unit>CS</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Heizstab Stufe 1 (?)</description>
         </command>
         <command name="getLZHeizstabSt2" protocmd="getaddr">
             <addr>0589</addr>
             <len>4</len>
             <unit>CS</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Heizstab Stufe 2 (?)</description>
         </command>
         <command name="getLZSNH" protocmd="getaddr">
             <addr>058A</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Speichernachheizung (0..1150000)</description>
         </command>
         <command name="getLZAC" protocmd="getaddr">
             <addr>058C</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Active Cooling (0..1150000)</description>
         </command>
         <command name="getLZPumpe" protocmd="getaddr">
             <addr>058D</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Pumpe HK1 (0..1150000)</description>
         </command>
         <command name="getLZPumpe2" protocmd="getaddr">
             <addr>058E</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Pumpe HK2 (0..1150000)</description>
         </command>
         <command name="getLZPumpe3" protocmd="getaddr">
             <addr>058F</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Pumpe HK3 (0..1150000)</description>
         </command>
         <command name="getLZUPumpe" protocmd="getaddr">
             <addr>0590</addr>
             <len>4</len>
             <unit>CS</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Umwaelzpumpe (?)</description>
         </command>
         <command name="getLZVentilWW" protocmd="getaddr">
             <addr>0594</addr>
             <len>4</len>
             <unit>CS</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Warmwasserventil (?)</description>
         </command>
         <command name="getLZSpeicherPumpe" protocmd="getaddr">
             <addr>0596</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Speicherladepumpe (0..1150000)</description>
         </command>
         <command name="getStatusAC" protocmd="getaddr">
             <addr>096C</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Information - Heizkreis HK1: Kuehlung fuer HK1 (0..1)</description>
         </command>
         <command name="getStatusAC2" protocmd="getaddr">
             <addr>096D</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Information - Heizkreis HK2: Kuehlung fuer HK2 (0..1)</description>
         </command>
         <command name="getStatusAC3" protocmd="getaddr">
             <addr>096E</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Information - Heizkreis HK3: Kuehlung fuer HK3 (0..1)</description>
         </command>
         <command name="getLZVerdSt1" protocmd="getaddr">
             <addr>1620</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Verdichter auf Stufe 1 (?)</description>
         </command>
         <command name="getLZVerdSt2" protocmd="getaddr">
             <addr>1622</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Verdichter auf Stufe 2 (?)</description>
         </command>
         <command name="getLZVerdSt3" protocmd="getaddr">
             <addr>1624</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Verdichter auf Stufe 3 (?)</description>
         </command>
         <command name="getLZVerdSt4" protocmd="getaddr">
             <addr>1626</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Verdichter auf Stufe 4 (?)</description>
         </command>
         <command name="getLZVerdSt5" protocmd="getaddr">
             <addr>1628</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Verdichter auf Stufe 5 (?)</description>
         </command>
         <command name="getEnergiePV" protocmd="getaddr">
             <addr>1678</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: ElektroenergiePV (0..1150000)</description>
         </command>
         <command name="getEnergieFaktor" protocmd="getaddr">
             <addr>163F</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Faktor Energiebilanz (1 = 0.1 kWh, 10 = 1 kWh, 100 = 10 kWh)</description>
         </command>
         <command name="getEnergieHeizwaerme" protocmd="getaddr">
             <addr>1640</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Heizwärme "Heizbetrieb", Verdichter 1</description>
         </command>
         <command name="getEnergieHeizwaerme2" protocmd="getaddr">
             <addr>1641</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Heizwärme "Heizbetrieb", Verdichter 2</description>
         </command>
         <command name="getEnergieHeizwaermeWW" protocmd="getaddr">
             <addr>1650</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Heizwärme "WW-Betrieb", Verdichter 1</description>
         </command>
         <command name="getEnergieHeizwaermeWW2" protocmd="getaddr">
             <addr>1651</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Heizwärme "WW-Betrieb", Verdichter 2</description>
         </command>
         <command name="getEnergieHeizelektro" protocmd="getaddr">
             <addr>1660</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Elektroenergie "Heizbetrieb", Verdichter 1</description>
         </command>
         <command name="getEnergieHeizelektro2" protocmd="getaddr">
             <addr>1661</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Elektroenergie "Heizbetrieb", Verdichter 2</description>
         </command>
         <command name="getEnergieWWelektro" protocmd="getaddr">
             <addr>1670</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Elektroenergie "WW-Betrieb", Verdichter 1</description>
         </command>
         <command name="getEnergieWWelektro2" protocmd="getaddr">
             <addr>1671</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Elektroenergie "WW-Betrieb", Verdichter 2</description>
         </command>
         <command name="getJAZ" protocmd="getaddr">
             <addr>1680</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Jahresarbeitszahl (0..10)</description>
         </command>
         <command name="getJAZHeiz" protocmd="getaddr">
             <addr>1681</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Jahresarbeitszahl Heizen (0..10)</description>
         </command>
         <command name="getJAZWW" protocmd="getaddr">
             <addr>1682</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: Jahresarbeitszahl WW (0..10)</description>
         </command>
         <command name="getCOPHeiz" protocmd="getaddr">
             <addr>1690</addr>
             <len>2</len>
             <unit>CO</unit>
             <description>Statistik - Energiebilanz: COP Heizbetrieb (0..10)</description>
         </command>
         <command name="getTempSekVLMittel" protocmd="getaddr">
             <addr>16B2</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Statistik - Energiebilanz: mittlere sek. Vorlauftemperatur (0..95)</description>
         </command>
         <command name="getTempSekRLMittel" protocmd="getaddr">
             <addr>16B3</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Statistik - Energiebilanz: mittlere sek.Temperatur RL1 (0..95)</description>
         </command>
         <command name="getTempSekRLMittel2" protocmd="getaddr">
             <addr>16B4</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Statistik - Energiebilanz: mittlere sek.Temperatur RL2 (0..95)</description>
         </command>
         <command name="getTempVLSoll" protocmd="getaddr">
             <addr>1800</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Diagnose - Heizkreis HK1: Vorlaufsolltemperatur HK1 (0..95)</description>
         </command>
         <command name="getTempVLSoll2" protocmd="getaddr">
             <addr>1801</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Diagnose - Heizkreis HK2: Vorlaufsolltemperatur HK2 (0..95)</description>
         </command>
         <command name="getTempVLSoll3" protocmd="getaddr">
             <addr>1802</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Diagnose - Heizkreis HK3: Vorlaufsolltemperatur HK3 (0..95)</description>
         </command>
         <command name="getSolarRegler" protocmd="getaddr">
             <addr>190A</addr>
             <len>4</len>
             <unit>UT</unit>
             <description>Diagnose - Solar: Solarertrag Reglermethoden (0..1150000)</description>
         </command>
         <command name="getSpdFanOut" protocmd="getaddr">
             <addr>1A52</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Outdoor Fanspeed</description>
         </command>
         <command name="getSpdFan" protocmd="getaddr">
             <addr>1A53</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Geschwindigkeit Luefter</description>
         </command>
         <command name="getSpdKomp" protocmd="getaddr">
             <addr>1A54</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Compressor Frequency</description>
         </command>
         <command name="getTempOAT" protocmd="getaddr">
             <addr>1A5C</addr>
             <len>1</len>
             <unit>UTI</unit>
             <description>OAT Temperature</description>
         </command>
         <command name="getTempICT" protocmd="getaddr">
             <addr>1A5D</addr>
             <len>1</len>
             <unit>UTI</unit>
             <description>OCT Temperature</description>
         </command>
         <command name="getTempCCT" protocmd="getaddr">
             <addr>1A5E</addr>
             <len>1</len>
             <unit>UTI</unit>
             <description>CCT Temperature</description>
         </command>
         <command name="getTempHST" protocmd="getaddr">
             <addr>1A5F</addr>
             <len>1</len>
             <unit>UTI</unit>
             <description>HST Temperature</description>
         </command>
         <command name="getTempOMT" protocmd="getaddr">
             <addr>1A60</addr>
             <len>1</len>
             <unit>UTI</unit>
             <description>OMT Temperature</description>
         </command>
         <command name="getLastVerdichter" protocmd="getaddr">
             <addr>1AC3</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Last am Verdichter</description>
         </command>
         <command name="getTempRaumSollNormal" protocmd="getaddr">
             <addr>2000</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung HK1 - Heizkreis 1: Raumsolltemperatur normal (10..30)</description>
         </command>
         <command name="getTempRaumSollRed" protocmd="getaddr">
             <addr>2001</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung HK1 - Heizkreis 1: Raumsolltemperatur reduzierter Betrieb (10..30)</description>
         </command>
         <command name="getHKLNiveau" protocmd="getaddr">
             <addr>2006</addr>
             <len>2</len>
             <unit>UN</unit>
             <description>Bedienung HK1 - Heizkreis 1: Niveau der Heizkennlinie (-15..40)</description>
         </command>
         <command name="getHKLNeigung" protocmd="getaddr">
             <addr>2007</addr>
             <len>2</len>
             <unit>UN</unit>
             <description>Bedienung HK1 - Heizkreis 1: Neigung der Heizkennlinie (0..35)</description>
         </command>
         <command name="getTempRaumSollParty" protocmd="getaddr">
             <addr>2022</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung HK1 - Heizkreis 1: Party Solltemperatur (10..30)</description>
         </command>
         <command name="getTempRaumSollNormal2" protocmd="getaddr">
             <addr>3000</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung HK2 - Heizkreis 2: Raumsolltemperatur normal (10..30)</description>
         </command>
         <command name="getTempRaumSollRed2" protocmd="getaddr">
             <addr>3001</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung HK2 - Heizkreis 2: Raumsolltemperatur reduzierter Betrieb (10..30)</description>
         </command>
         <command name="getHKLNiveau2" protocmd="getaddr">
             <addr>3006</addr>
             <len>2</len>
             <unit>UN</unit>
             <description>Bedienung HK2 - Heizkreis 2: Niveau der Heizkennlinie (-15..40)</description>
         </command>
         <command name="getHKLNeigung2" protocmd="getaddr">
             <addr>3007</addr>
             <len>2</len>
             <unit>UN</unit>
             <description>Bedienung HK2 - Heizkreis 2: Neigung der Heizkennlinie (0..35)</description>
         </command>
         <command name="getTempRaumSollParty2" protocmd="getaddr">
             <addr>3022</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung HK2 - Heizkreis 2: Party Solltemperatur (10..30)</description>
         </command>
         <command name="getTempRaumSollNormal3" protocmd="getaddr">
             <addr>4000</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung HK3 - Heizkreis 3: Raumsolltemperatur normal (10..30)</description>
         </command>
         <command name="getTempRaumSollRed3" protocmd="getaddr">
             <addr>4001</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung HK3 - Heizkreis 3: Raumsolltemperatur reduzierter Betrieb (10..30)</description>
         </command>
         <command name="getHKLNiveau3" protocmd="getaddr">
             <addr>4006</addr>
             <len>2</len>
             <unit>UN</unit>
             <description>Bedienung HK3 - Heizkreis 3: Niveau der Heizkennlinie (-15..40)</description>
         </command>
         <command name="getHKLNeigung3" protocmd="getaddr">
             <addr>4007</addr>
             <len>2</len>
             <unit>UN</unit>
             <description>Bedienung HK3 - Heizkreis 3: Neigung der Heizkennlinie (0..35)</description>
         </command>
         <command name="getTempRaumSollParty3" protocmd="getaddr">
             <addr>4022</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung HK3 - Heizkreis 3: Party Solltemperatur (10..30)</description>
         </command>
         <command name="getLZWP" protocmd="getaddr">
             <addr>5005</addr>
             <len>4</len>
             <unit>CO</unit>
             <description>Statistik - Betriebsstunden Anlage: Betriebsstunden Waermepumpe  (0..1150000)</description>
         </command>
         <command name="getPwrSollVerdichter" protocmd="getaddr">
             <addr>5030</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Diagnose - Anlagenuebersicht: Soll-Leistung Verdichter 1 (0..100)</description>
         </command>
         <command name="getPwrSollVerdichter2" protocmd="getaddr">
             <addr>5130</addr>
             <len>1</len>
             <unit>CO</unit>
             <description>Diagnose - Anlagenuebersicht: Soll-Leistung Verdichter 2 (0..100)</description>
         </command>
         <command name="getTempWWSoll" protocmd="getaddr">
             <addr>6000</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung WW - Betriebsdaten WW: Warmwassersolltemperatur (10..60 (95))</description>
         </command>
         <command name="getTempWWSoll2" protocmd="getaddr">
             <addr>600C</addr>
             <len>2</len>
             <unit>UT</unit>
             <description>Bedienung WW - Betriebsdaten WW: Zweiter Sollwert (10..60 (95))</description>
         </command>
         <command name="setTempWWSoll2_55" protocmd="setaddr55">
             <addr>600C</addr>
             <len>2</len>
             <unit>UT</unit>
         </command>
         <command name="setTempWWSoll2_45" protocmd="setaddr45">
             <addr>600C</addr>
             <len>2</len>
             <unit>UT</unit>
         </command>
         <command name="getKKLNiveau" protocmd="getaddr">
             <addr>7110</addr>
             <len>2</len>
             <unit>UN</unit>
             <description>Bedienung HK1 - Heizkreis 1: Niveau Kuehlkennlinie (-15..40)</description>
         </command>
         <command name="getKKLNeigung" protocmd="getaddr">
             <addr>7111</addr>
             <len>2</len>
             <unit>UN</unit>
             <description>Bedienung HK1 - Heizkreis 1: Neigung Kuehlkennlinie (0..35)</description>
         </command>
         <command name="getBetriebsart" protocmd="getaddr">
             <addr>B000</addr>
             <len>1</len>
             <unit>BA</unit>
             <description>Bedienung HK1 - Heizkreis 1: Betriebsart (0..4)</description>
         </command>
         <command name="getWWEinmal" protocmd="getaddr">
             <addr>B020</addr>
             <len>1</len>
             <unit>RT</unit>
             <description>Bedienung WW - Betriebsdaten WW: 1x WW-Bereitung (0..1)</description>
         </command>
                    <command name="set1xWWein" protocmd="setaddr2">
                            <addr>B020</addr>
                            <len>1</len>
                            <unit>RT</unit>
                            <description>1 malige Warmwasserbereitung</description>
                    </command>
                    <command name="get1xWW" protocmd="getaddr">
                            <addr>B020</addr>
                            <len>1</len>
                            <unit>RT</unit>
                    </command>
    		<command name="set1xWWaus" protocmd="setaddr0">
                            <addr>B020</addr>
                            <len>1</len>
                            <unit>RT</unit>
                    </command>
                    <command name="Betriebsart" protocmd="getaddr">
                            <addr>B000</addr>
                            <len>1</len>
                            <unit>BA</unit>
                            <description>Bedienung HK1 Heizkreis 1 Wertebereich 0 - 4</description>
                    </command>
                    <command name="Betriebsart0" protocmd="setaddr0">
                            <addr>B000</addr>
                            <len>1</len>
                            <unit>BA</unit>
                            <description>Abschaltbetrieb</description>
                    </command>
                    <command name="Betriebsart1" protocmd="setaddr1">
                            <addr>B000</addr>
                            <len>1</len>
                            <unit>BA</unit>
                            <description>Warmwasser</description>
                    </command>
                    <command name="Betriebsart2" protocmd="setaddr2">
                            <addr>B000</addr>
                            <len>1</len>
                            <unit>BA</unit>
                            <description>Heizen und Warmwasser</description>
                    </command>
                    <command name="getRT" protocmd="getaddr">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>Bedienung HK1 Heizkreis 1 Wertebereich 10 - 30</description>
                    </command>
    		<command name="setRT16" protocmd="setaddr16">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 16C</description>
                    </command>
    		<command name="setRT17" protocmd="setaddr17">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 17C</description>
                    </command>
                    <command name="setRT18" protocmd="setaddr18">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 18C</description>
                    </command>
                    <command name="setRT19" protocmd="setaddr19">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 19C</description>
                    </command>
                    <command name="setRT20" protocmd="setaddr20">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 20C</description>
                    </command>
                    <command name="setRT21" protocmd="setaddr21">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 21C</description>
                    </command>
                    <command name="setRT22" protocmd="setaddr22">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 22C</description>
                    </command>
                    <command name="setRT23" protocmd="setaddr23">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 23C</description>
                    </command>
                    <command name="setRT24" protocmd="setaddr24">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 24C</description>
                    </command>
                    <command name="setRT25" protocmd="setaddr25">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf 25C</description>
                    </command>
                    <command name="setRT" protocmd="setaddr">
                            <addr>2000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>RT auf xxC</description>
                    </command>
                    <command name="RaumsolltemperaturreduzierterBetrieb" protocmd="getaddr">
                            <addr>2001</addr>
                            <len>2</len>
                            <unit>UT</unit>
                    </command>
                    <command name="Warmwassersolltemperatur" protocmd="getaddr">
                            <addr>6000</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>Bedienung WW Betriebsdaten WW Wertebereich 10 - 60 (95)</description>
                    </command>
                    <command name="Aussentemperatur" protocmd="getaddr">
                            <addr>0101</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>Information Allgemein Wertebereich -40 - 70</description>
                    </command>
                    <command name="Heizkreispumpe" protocmd="getaddr">
                            <addr>048D</addr>
                            <len>1</len>
                            <unit>RT</unit>
                            <description>Information Heizkreis HK1 Wertebereich 0 - 1</description>
                    </command>
                    <command name="Warmwassertemperaturoben" protocmd="getaddr">
                            <addr>010D</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>Information Warmwasser Wertebereich 0 - 95</description>
                    </command>
                    <command name="VorlaufsolltemperaturHK1" protocmd="getaddr">
                            <addr>1800</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>Diagnose Heizkreis HK1 Wertebereich 0 - 95</description>
                    </command>
                    <command name="VorlauftemperaturSekundaer1" protocmd="getaddr">
                            <addr>0105</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>Diagnose Anlagenuebersicht Wertebereich 0 - 95</description>
                    </command>
                    <command name="RuecklauftemperaturSekundaer1" protocmd="getaddr">
                            <addr>0106</addr>
                            <len>2</len>
                            <unit>UT</unit>
                    </command>
                    <command name="Sekundaerpumpe1" protocmd="getaddr">
                            <addr>0484</addr>
                            <len>1</len>
                            <unit>RT</unit>
                            <description>Diagnose Anlagenuebersicht Wertebereich 0 - 1</description>
                    </command>
                    <command name="Soll-LeistungVerdichter1" protocmd="getaddr">
                            <addr>5030</addr>
                            <len>1</len>
                            <unit>CO</unit>
                            <description>Diagnose Anlagenuebersicht Wertebereich 0 - 100</description>
                    </command>
                    <command name="BetriebsstundenPumpeHK1" protocmd="getaddr">
                            <addr>058D</addr>
                            <len>4</len>
                            <unit>CO</unit>
                            <description>Statistik Betriebsstunden Anlage Wertebereich 0 - 1150000</description>
                    </command>
                    <command name="mittleresekVL" protocmd="getaddr">
                            <addr>16B2</addr>
                            <len>2</len>
                            <unit>UT</unit>
                            <description>Statistik Energiebilanz Wertebereich 0 - 95</description>
                    </command>
                    <command name="mittleresekRL" protocmd="getaddr">
                            <addr>16B3</addr>
                            <len>2</len>
                            <unit>UT</unit>
                    </command>
            </commands>
    </vito>
    Edit:
    Log-Meldungen
    	2023-02-17 19:07:01.885	info	State value to set for "viessmann.0.get.StatusVentilWW" has to be type "string" but received type "number"
    viessmann.0
    2023-02-17 19:07:01.819	info	State value to set for "viessmann.0.get.StatusPumpeZirk" has to be type "string" but received type "number"
    viessmann.0
    2023-02-17 19:07:01.760	info	State value to set for "viessmann.0.get.StatusPumpe" has to be type "string" but received type "number"
    Wie kann ich den Type des Datenpunktes umstellen?
    Issr4kI Offline
    Issr4kI Offline
    Issr4k
    @martybr
    Mal versucht die Datenpunkte wo er wegen String und Number meckert, manuell im Objektbtowser direkt in ioBroker auf den gewünschten Datentyp zu ändern?
    Des weiteren würde ich dir raten die Dateien mal radikal zu verschlanken, vorallem die vito.xml… mehr wie 70% davon sind doch völlig überflüssig. Wozu sollte man die unbedingt in ioBroker haben wollen…
    • Issr4kI Issr4k
      @martybr
      MartyBr
      schrieb am zuletzt editiert von MartyBr
      @issr4k
      Ich habe gedacht, dass der Typ in der XML bestimmt wird, z.B. hier:
               <addr>0101</addr>
               <len>2</len>
               <unit>UT</unit>
      <unit> sieht mir danach aus, ich habe aber noch keinen Hinweis auf die verschiedenen Units in der Vito.xml gefunden. Ich muss da noch ein bisschen suchen.
      DT scheint Text su sein, UT gleich Zahl. Ich suche weiter....
      Edit: Ich habe eine Tabelle mit den Infos gefunden:
      Name ()	Datentyp	Bytes	Berechnung	Beschreibung
      UT	signed short	2	* 0.1	Temperatur mit einer Nachkommastelle
      PR	short	2	* 1	Prozentwert 0..100%
      ST	(unsigned) char	1	* 1	Status Boolean 0 oder 1
      CO	(unsinged) int	4	* 1	Counter (Zähler)
      CS	(unsigned) int	4	/ 3600	Sekundenzähler (/3600 in h)
      CT	cycletime	n*2		CycleTime, Schaltzeiten
      (h <<3 + Min DIV 10)
      An / Aus jeweils ein Byte
      BA	enum	1		Betriebsart
      SR	enum	1		Return Status beim Setzen
      TI	systime	8		WT, TT.MM.JJJJ HH:MM:SS
      ES	errstate	9		1 Byte Fehler + sysdate
      RT	enum	1		Return Status Umwandlung enum
      Martin
      Intel NUCs mit Proxmox / Iobroker als VM unter Debian
      Raspeberry mit USB Leseköpfen für Smartmeter
      Homematic und Homematic IP
      Issr4kI 1 Antwort Letzte Antwort
      • M MartyBr
        @issr4k
                 <addr>0101</addr>
                 <len>2</len>
                 <unit>UT</unit>
        Issr4kI Offline
        Issr4kI Offline
        Issr4k
        @martybr
        Oke, demnach nal die Datenpunkte aus dem Log von UT auf ST ändern in der xml…
        • Issr4kI Issr4k
          @martybr
          MartyBr
          @issr4k
          Die angemeckerten Werte haben alle ein RT in unit == Return Status Umwandlung.
          Also doch vielleicht in ioBroker den DP ändern????
          Edit:
          Ich habe das mal für einen DP in ioBroker geändert, mal schauen....
          Martin
          • M MartyBr
            @issr4k
            Edit:
            MartyBr
            @martybr
            Sieht nun gut aus. Ich setze die anderen Date nun auch auf "number" in iobroker.
            Martin
            • M MartyBr
              @martybr
              Issr4kI Offline
              Issr4kI Offline
              Issr4k
              @martybr
              Dann hoffen dass die Verbindung jetzt länger als zwei Stunden durchhält.
              Mein vcontrold läuft jetzt seit ein paar Wochen
              • Issr4kI Issr4k
                @martybr
                MartyBr
                @issr4k
                Ich lasse ihn nun mal laufen. Ich habe noch einige Datenpunkte freigeschaltet.
                Morgen schmeisse ich mal die Solarwerte aus dem System. Die PV läuft separat. Ich hätte nur gerne den Heizstab im System mit der Option, ihn bei hoher Einspeisung der PV zu aktivieren.
                Das ist die nächste Herausforderung.
                Martin
                • M MartyBr
                  @issr4k
                  Issr4kI Offline
                  Issr4kI Offline
                  Issr4k
                  @martybr ja genau, das möchte ich auch machen.
                  Dazu müssen wir mal das Handbuch zu rate ziehen
                  • Issr4kI Issr4k
                    MartyBr
                    @issr4k
                    Erst mal muss das System in ein paar Tage stabil laufen. Morgen werde ich mal einige Datenpunkte löschen, also alles was mit HK2 und HK3 und die Solar. Die benötige ich nicht.
                    Und dann geht es an den Heizstab 💪
                    Martin
                    • M MartyBr
                      @issr4k
                      Issr4kI Offline
                      Issr4kI Offline
                      Issr4k
                      schrieb am zuletzt editiert von Issr4k
                      @martybr hier siehe die ersten beiden Einträge!
                      Viessmann Forum
                      Ein Anfang … :)
                      • Issr4kI Issr4k
                        Viessmann Forum
                        Ein Anfang … :)
                        MartyBr
                        @issr4k
                        Mein Viessmann-Adapter und der VControld laufen nun stabil. Ich habe noch einige Datenpunkte rausgeworfen.
                        Ich kann nun einige Werte interpretieren, z.B. die verschiedenen Temperaturwerte WW, Heizkreis und die Temperaturen der Primärleitung == Erdwärme. Nun habe ich den Verdichter/Kompressor gefunden.
                        Martin
                        • M MartyBr
                          @issr4k
                          Issr4kI Offline
                          Issr4kI Offline
                          Issr4k
                          @martybr Ich bin auch gerade dran.... Allerdings habe ich meine Verbindung gecrasht... Und bekomme sie jetzt nicht mehr zum laufen :D
                          Wollte mit Adresse 7907 die Leistung des Heizstabes anpassen, seitdem geht nichts mehr.
                          Lädst du die getesteten Adressen hier hoch?
                          • Issr4kI Issr4k
                            MartyBr
                            @issr4k
                            ja, gerne. Hier meine aktuelle und laufende Vito.xml:
                            vito.xml
                            Martin
                            • M MartyBr
                              @issr4k
                              vito.xml
                              Issr4kI Offline
                              Issr4kI Offline
                              Issr4k
                              @martybr Danke!
                              Du sag mal funzt "getDevType" bei dir?
                              ist deine vcontrold.xml noch unverändert? Bzw hängst du Sie auch nochmal an?
                              • Issr4kI Issr4k
                                @martybr Danke!
                                MartyBr
                                @issr4k
                                Ja zu beiden Fragen. Ich kann mit dem Wert nichts anfangen.
                                viessmann.0.get.DevType     1923,2
                                Hier die vcontrold.xml:
                                vcontrold.xml
                                Martin
                                • M MartyBr
                                  @issr4k
                                  vcontrold.xml
                                  Issr4kI Offline
                                  Issr4kI Offline
                                  Issr4k
                                  @martybr die 1923,2 bekomme ich auch darauf... Versuche mein Protokoll auf das 300er umzustellen und reite mich dadurch als weiter rein xD
                                  • Issr4kI Issr4k
                                    MartyBr
                                    @issr4k Gib mir bitte eine Info zum Heizstab, wenn du da weitergekommen bist.
                                    Ich habe bisher noch keine Einstellungen zum setzen von DPs getestet. Das ist ja auch noch eine Baustelle.
                                    Du kannst ja mal meine XML testen. Die liefern schon eine Menge an Datenpunkten.
                                    Martin
                                    • Issr4kI Offline
                                      Issr4kI Offline
                                      Issr4k
                                      @martybr
                                            <addr>B020</addr>
                                            <len>1</len>
                                            <unit>SR</unit>
                                            <description>Abfrage WW 1xWW Bereitung</description>
                                          </command>
                                        <command name="set1xWW" protocmd="setaddr">
                                            <addr>B020</addr>
                                            <len>1</len>
                                            <unit>SR</unit>
                                            <description>Bedienung WW 1xWW Bereitung</description>
                                          </command>
                                      Kannst du B020 bei dir mal testen. Bei mir passiert leider nichts.
                                      Zumindest bei "get" müsste doch etwas feststellbar sein, man kann über das Display der Vitocal Menü > Warmwasser > 1x Warmwasserbereitung anwählen (dahinter ist ein Viereck welches einen Haken bekommt wenn aktiv.
                                      EDIT:
                                      Es klappt aber nur hiermit <unit>RT</unit>
                                      Es tut sich was. jag es bei dir auch mal durch.
                                      Im Kontext dazu Github die letzten beiden Beiträge
                                      • Issr4kI Issr4k
                                        @martybr
                                              <addr>B020</addr>
                                              <len>1</len>
                                              <unit>SR</unit>
                                            </command>
                                              <addr>B020</addr>
                                              <len>1</len>
                                              <unit>SR</unit>
                                            </command>
                                        EDIT:
                                        MartyBr
                                        @issr4k
                                        Teste ich morgen. In meiner Vito.xml steht ja als unit "RT".
                                        Martin
                                        • M MartyBr
                                          @issr4k
                                          Issr4kI Offline
                                          Issr4kI Offline
                                          Issr4k
                                          @martybr
                                          spreche ich "set1xWW" mit 2 an, steht auf dem Display der Vitocal dick und fett Manueller Modbus..
                                          EDIT: Wo genau hast du denn die Tabelle mit den Datentypen her?
                                          EDIT 2: So klappt es jetzt... B020 ist wohl nicht der Richtige...
                                                <addr>B0D0</addr>
                                                <len>1</len>
                                                <unit>RT</unit>
                                              </command>
                                          Bei "2" wird das Häkchen auf der Vitocal gesetzt und bei "0" entfernt... Bei der "1" passiert gar nichts, soweit ich sehen kann...
