  4. Update von Adapter funktionieren nicht
    5.6k
3 Beiträge 3 Kommentatoren 500 Aufrufe 3 Beobachtet
  • L Offline
    LJ-Mic
    Seit kurzem kann ich meine Adapter nicht Aktualisieren.
    Leider bin ich mit meine Problem nicht fündig geworden, darum hier noch mal der Hilfeschrei.
    Das sollte helfen:
    pi@pi01:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v16.18.1
    /usr/local/bin/node
    v16.17.0
    /usr/local/bin/npm
    9.1.3
    nodejs:
      Installiert:           16.18.1-deb-1nodesource1
      Installationskandidat: 16.18.1-deb-1nodesource1
      Versionstabelle:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u1 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    pi@pi01:~ $ iobroker update
    Used repository: stable
    Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
    Adapter    "alexa2"       : 3.23.2   , installed 3.19.9 [Updatable]
    Adapter    "backitup"     : 2.5.4    , installed 2.4.10 [Updatable]
    Adapter    "cloud"        : 4.2.2    , installed 4.2.2
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "haier"        : 1.0.4    , installed 1.0.4
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hoover"       : 0.0.4    , installed 0.0.2  [Updatable]
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.0    , installed 4.0.0
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "plex"         : 0.9.1    , installed 0.9.1
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "sayit"        : 1.12.3   , installed 1.12.3
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "terminal"     : 0.2.6    , installed 0.2.6
    Adapter    "text2command" : 2.2.2    , installed 2.2.2
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "xterm"        : 0.3.2    , installed 0.3.2
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Adapter    "zigbee"       : 1.7.6    , installed 1.7.5  [Updatable]
    pi@pi01:~ $ iobroker upgrade
    This upgrade of "alexa2" will introduce the following changes:
    -> 3.23.2:
    Prioritize real devices higher than app devices when serialnumbers overlap
    -> 3.23.1:
    Enhance checks when changing smart device values
    Try to prevent Amazon rate limiting (again)
    -> 3.21.0:
    IMPORTANT: Because of rate limits by Amazon I decided to remove the update of smart home device values in intervals because it seems to produce too much load in Skills and Amazon systems.
    Optimizes loading of smart home device states
    Fixed issue with enabling/disabling of Alarms in combination with non-default music for the alarm
    Prevented that Timers or Alarms that are long in the future to trigger their trigger state too early
    Fixed deleting own user Messages state
    Already request Notification updates when history registered a Notification action and do not wait for Push info to come in
    -> 3.20.1:
    make sure caching works correctly with multiple instances of the adapter
    -> 3.20.0:
    Increase minimum interval for requesting smart home device data to 15 minutes (900s) because of Amazon rate limits. Please do not try to work around it!
    Cache Smart home device list and data to prevent too many requests when restarting adapter in short intervals and to prevent deleted smart home devices also on further rate limit issues
    -> 3.19.10:
    Fix issue in retry handling when rate limit exceeded is returned by Amazon
    Do not clean up Smart Home Device objects for now - delete manually if you remove a device
    Would you like to upgrade alexa2 from @3.19.9 to @3.23.2 now? [(y)es, (n)o]: y
    Update alexa2 from @3.19.9 to @3.23.2
    NPM version: 9.1.3
    Installing iobroker.alexa2@3.23.2... (System call)
    host.pi01 Cannot install iobroker.alexa2@3.23.2: 217
    Mach ich das Update per Browser/Admin kommt folgendes zum Beispiel bei Alexa:
    $ iobroker upgrade alexa2@3.23.2 --debug
    NPM version: 9.1.3Installing iobroker.alexa2@3.23.2... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/addressparsernpm ERR! dest /opt/iobroker/node_modules/.addressparser-qF9vtHFgnpm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/addressparser' -> '/opt/iobroker/node_modules/.addressparser-qF9vtHFg'
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-12-05T23_02_53_757Z-debug-0.log
    ERROR: Process exited with code 25
    • L LJ-Mic
      Das sollte helfen:
      /usr/bin/nodejs
      v16.18.1
      /usr/local/bin/node
      v16.17.0
      /usr/local/bin/npm
      9.1.3
      nodejs:
        Versionstabelle:
      -> 3.23.2:
      -> 3.23.1:
      -> 3.21.0:
      -> 3.20.1:
      -> 3.20.0:
      -> 3.19.10:
      NPM version: 9.1.3
      crunchipC Abwesend
      crunchipC Abwesend
      @lj-mic sagte in Update von Adapter funktionieren nicht:
      man kann es schon gar nicht mehr zählen wie oft dieses Problem hier im Forum behandelt wurde
      zum einen ist dein nodejs falsch installiert und zum anderen, steht code25 sogar angepinnt ganz oben im Forum, da muss man nicht mal suchen.
      https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
        CodierknechtC Online
        Codierknecht
        @crunchip sagte in Update von Adapter funktionieren nicht:
        Und NPM ausnahmsweise mal zu neu statt zu alt ;-)
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
