  4. Node-Red
  5. Sonos Lautstärke regeln
    6.5k
60 Beiträge 2 Kommentatoren 6.1k Aufrufe 2 Beobachtet
  • mickymM mickym
    @saranger OK . ja ich habe eins nicht bedacht, da die KNX ja nur eine Node ist. da muss nich der Switch davor. Mache ich gleich. 3 ist gedrückt? und 4 losgelassen?
    Saranger
    @mickym ja genau,
    • S Saranger
      @mickym ja genau,
      mickymM Offline
      mickymM Offline
      mickym
      @saranger sagte in Sonos Lautstärke regeln:
      @mickym ja genau,
      Hatte ich vorher umgekehrt verstanden:
      Sollte so passen. Ansonsten musst Du die trigger Node ändern. Jetzt wird sie bei 4 zurückgesetzt.
             "id": "e016af2ca1bcd4ab",
             "type": "ioBroker in",
             "z": "289f539dcc33814e",
             "name": "",
             "topic": "0_userdata.0.sonos",
             "payloadType": "value",
             "onlyack": "update",
             "func": "all",
             "gap": "",
             "fireOnStart": "true",
             "outFormat": "MQTT",
             "x": 3970,
             "y": 1460,
             "wires": [
                     "2c6be8f77f8d6af8"
             "id": "2c6be8f77f8d6af8",
             "type": "ui_slider",
             "name": "",
             "label": "slider",
             "tooltip": "",
             "group": "0eab8134c3a0274f",
             "order": 0,
             "width": 0,
             "height": 0,
             "passthru": true,
             "outs": "all",
             "topic": "topic",
             "topicType": "msg",
             "min": "-50",
             "max": "50",
             "step": 1,
             "className": "",
             "x": 4170,
             "y": 1540,
             "wires": [
                     "b67100af74cb26a3"
             "id": "088a4eac83b92384",
             "type": "ioBroker out",
             "d": true,
             "name": "",
             "ack": "false",
             "autoCreate": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 4590,
             "y": 1460,
             "wires": []
             "id": "73f491b996915df3",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "3",
             "payloadType": "num",
             "x": 2970,
             "y": 1520,
             "wires": [
                     "b3f9267a0167714f"
             "id": "8316e3d57694f5d9",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "4",
             "x": 2970,
             "y": 1560,
             "wires": [
                     "b3f9267a0167714f"
             "id": "90158baa4ebc8746",
             "type": "trigger",
             "name": "",
             "op1": "true",
             "op2": "0",
             "op1type": "bool",
             "op2type": "str",
             "duration": "-250",
             "extend": false,
             "overrideDelay": false,
             "units": "ms",
             "reset": "4",
             "bytopic": "all",
             "topic": "topic",
             "outputs": 1,
             "x": 3430,
             "y": 1540,
             "wires": [
                     "52d93ccac45ceb5e"
             "id": "52d93ccac45ceb5e",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "volume",
                     "tot": "flow"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 3670,
             "y": 1540,
             "wires": [
                     "255a96714e4a8404"
             "id": "b67100af74cb26a3",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "volume",
                     "pt": "flow",
                     "to": "payload",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4350,
             "y": 1540,
             "wires": [
                     "7091ed465e491ae9",
                     "088a4eac83b92384"
             "id": "a1c2a16d5f94f96a",
             "type": "change",
             "name": "lauter",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload + 1",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4010,
             "y": 1520,
             "wires": [
                     "2c6be8f77f8d6af8"
             "id": "cd995dd8d3e0a86d",
             "type": "change",
             "name": "leiser",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload - 1",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4010,
             "y": 1560,
             "wires": [
                     "2c6be8f77f8d6af8"
             "id": "255a96714e4a8404",
             "type": "switch",
             "name": "",
             "property": "toggle",
             "propertyType": "flow",
             "rules": [
                     "t": "true"
                     "t": "false"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 3850,
             "y": 1540,
             "wires": [
                     "a1c2a16d5f94f96a"
                     "cd995dd8d3e0a86d"
             "outputLabels": [
                 "lauter",
                 "leiser"
             "id": "7091ed465e491ae9",
             "type": "debug",
             "name": "Volume",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 4420,
             "y": 1620,
             "wires": []
             "id": "6b61b68392c028df",
             "type": "change",
             "name": "toggle",
             "rules": [
                     "t": "set",
                     "p": "toggle",
                     "pt": "flow",
                     "to": "$exists($flowContext(\"toggle\")) ? $not($flowContext(\"toggle\")) : false\t\t",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 3370,
             "y": 1600,
             "wires": [
             "id": "b3f9267a0167714f",
             "type": "switch",
             "name": "KNX Taster Analyse",
             "property": "payload",
             "propertyType": "msg",
             "rules": [
                     "t": "eq",
                     "v": "3",
                     "vt": "num"
                     "t": "eq",
                     "v": "4",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 3170,
             "y": 1540,
             "wires": [
                     "90158baa4ebc8746"
                     "6b61b68392c028df",
                     "90158baa4ebc8746"
             "outputLabels": [
                 "gedrückt",
                 "losgelassen"
             "id": "0eab8134c3a0274f",
             "type": "ui_group",
             "name": "Lautstärke",
             "tab": "20b3095113f94d70",
             "order": 2,
             "disp": true,
             "width": "6",
             "collapse": false,
             "className": ""
             "id": "20b3095113f94d70",
             "type": "ui_tab",
             "name": "Home",
             "icon": "dashboard",
             "order": 1,
             "disabled": false,
             "hidden": false
      Deine KNX Node nun an die switch Node am Anfang.
      Ich hab die Ausgänge auch beschriftet, sodass Du da die Debug NOdes hinmachen kannst und überprüfen kannst, ob es am richtigen Ausgang rauskommt.
      Hier konfigurierst Du, bei welcher payload die trigger Node aufhören soll zu senden.
      • mickymM mickym
        @mickym ja genau,
               "name": "",
               "func": "all",
               "gap": "",
               "x": 3970,
               "y": 1460,
               "wires": [
                       "2c6be8f77f8d6af8"
               "name": "",
               "label": "slider",
               "tooltip": "",
               "order": 0,
               "width": 0,
               "height": 0,
               "passthru": true,
               "outs": "all",
               "topic": "topic",
               "topicType": "msg",
               "min": "-50",
               "max": "50",
               "step": 1,
               "className": "",
               "x": 4170,
               "y": 1540,
               "wires": [
                       "b67100af74cb26a3"
               "d": true,
               "name": "",
               "ack": "false",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 4590,
               "y": 1460,
               "wires": []
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "3",
               "x": 2970,
               "y": 1520,
               "wires": [
                       "b3f9267a0167714f"
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "4",
               "x": 2970,
               "y": 1560,
               "wires": [
                       "b3f9267a0167714f"
               "type": "trigger",
               "name": "",
               "op1": "true",
               "op2": "0",
               "op1type": "bool",
               "op2type": "str",
               "duration": "-250",
               "extend": false,
               "units": "ms",
               "reset": "4",
               "bytopic": "all",
               "topic": "topic",
               "outputs": 1,
               "x": 3430,
               "y": 1540,
               "wires": [
                       "52d93ccac45ceb5e"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "volume",
                       "tot": "flow"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 3670,
               "y": 1540,
               "wires": [
                       "255a96714e4a8404"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "volume",
                       "pt": "flow",
                       "to": "payload",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 4350,
               "y": 1540,
               "wires": [
                       "7091ed465e491ae9",
                       "088a4eac83b92384"
               "type": "change",
               "name": "lauter",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 4010,
               "y": 1520,
               "wires": [
                       "2c6be8f77f8d6af8"
               "type": "change",
               "name": "leiser",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 4010,
               "y": 1560,
               "wires": [
                       "2c6be8f77f8d6af8"
               "type": "switch",
               "name": "",
               "rules": [
                       "t": "true"
                       "t": "false"
               "checkall": "true",
               "repair": false,
               "outputs": 2,
               "x": 3850,
               "y": 1540,
               "wires": [
                       "a1c2a16d5f94f96a"
                       "cd995dd8d3e0a86d"
               "outputLabels": [
                   "lauter",
                   "leiser"
               "type": "debug",
               "name": "Volume",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 4420,
               "y": 1620,
               "wires": []
               "type": "change",
               "name": "toggle",
               "rules": [
                       "t": "set",
                       "p": "toggle",
                       "pt": "flow",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 3370,
               "y": 1600,
               "wires": [
               "type": "switch",
               "rules": [
                       "t": "eq",
                       "v": "3",
                       "vt": "num"
                       "t": "eq",
                       "v": "4",
                       "vt": "num"
               "checkall": "true",
               "repair": false,
               "outputs": 2,
               "x": 3170,
               "y": 1540,
               "wires": [
                       "90158baa4ebc8746"
                       "6b61b68392c028df",
                       "90158baa4ebc8746"
               "outputLabels": [
                   "gedrückt",
                   "losgelassen"
               "type": "ui_group",
               "order": 2,
               "disp": true,
               "width": "6",
               "collapse": false,
               "className": ""
               "type": "ui_tab",
               "name": "Home",
               "order": 1,
               "disabled": false,
               "hidden": false
        Saranger
        @mickym also es ist jetzt so halte ich gedrückt macht er zwei Schritte vor und bleibt dann stehe. ich lasse los und drücke wieder lang und es passiert nix. Ich lasse wieder los und drücke erneut lang dann macht zwei Punkte zurück. Hatte den Trigger auf 3 geändert. Aber kein Stress ich schau mir das am We noch mal an und antworte dir noch mal :-)
        • S Saranger
          mickymM Offline
          mickymM Offline
          mickym
          @saranger
          Jetzt sollten auch andere Werte wie ggf. 1 und 2 nicht mehr stören. Ich bin mir auch nicht sicher, ob das zwischen 3 und 4 dauernd wechselt - weil Du Dimmer eingestellt hast. Vielleicht solltest Du die KNX Node lieber auf Taster und nicht Dimmer einschaltest.
          Vielleicht ist auch 3 höher regeln und 4 tiefer und hat nichts mit dem langen Tastendruck zu tun. Dann ist es natürlich so, dass man den ganzen Flow anders machen muss. Schau erst mal ob Du das was aus der KNX Node nicht eindeutiger machen kannst. Ich glaube, dass der KNX Dimmer ggf. selber toggelt und das wäre schlecht weil das dann fehlerbehafteter wird.
          Aber kann natürlich sein, dass nur der Dimmermodus den langen Tastendruck simuliert. Ausserdem wenn er dann stehen bleibt - schau mal ob der selbstständig eine Nachricht schickt, auch wenn Du den Taster gedrückt hälst.
          Aber auch mit dem Verhalten habe ich noch eine Idee. ;) Wichtig wäre halt zu wissen, ob der Taster selbstständig die Gegennachricht sendet.
          • mickymM mickym
            @saranger
            Saranger
            @mickym Wenn ich nicht auf dimmer stelle habe ich nur 1x Schalten und dann kann ich nicht differenzieren zwischen langen und kurzen druck. 4 und 3 passt zum "hochdimmen". Ich denke man müsste noch einen zweiten Pfadfür Leise machen wo man auf 0 reagiert. Dummerweise sendet er beim betätigen die 0 und beim los lassen ebenfalls die 0 aber vielleicht geht da trotzdem was.
            • mickymM Offline
              mickymM Offline
              mickym
              das wäre jetzt ein Flow, wo der Taster selbst mit wechselndem 3 oder 4 signalisiert, dass die Werte erhöht bzw. erniedrigt werden sollen. Ich habe jetzt mal 3 für leiser werdend und 4 für lauter werden verwendet. Wird der entgegen gesetzte Wert gesendet, dann stoppt der Flow.
              Sprich es geht jetzt mit der Dimmereinstellung so. (das erste Mal muss man ggf. 2 mal drücken).
              Der Taster sendet 3 - der Flow erniedrigt die Werte solange, bis 4 kommt. Das gilt nun als Stopp-Signal.
              Dies erwartet also immer das gegenläufige Signal zum Stoppen. Nimmt nun aber 3 und 4 als leiser oder lauter.
                     "name": "",
                     "func": "all",
                     "gap": "",
                     "x": 3950,
                     "y": 1440,
                     "wires": [
                             "2c6be8f77f8d6af8"
                     "name": "",
                     "label": "slider",
                     "tooltip": "",
                     "order": 0,
                     "width": 0,
                     "height": 0,
                     "passthru": true,
                     "outs": "all",
                     "topic": "topic",
                     "topicType": "msg",
                     "min": "-50",
                     "max": "50",
                     "step": 1,
                     "className": "",
                     "x": 4170,
                     "y": 1540,
                     "wires": [
                             "b67100af74cb26a3"
                     "d": true,
                     "name": "",
                     "ack": "false",
                     "stateName": "",
                     "role": "",
                     "payloadType": "",
                     "readonly": "",
                     "stateUnit": "",
                     "stateMin": "",
                     "stateMax": "",
                     "x": 4590,
                     "y": 1460,
                     "wires": []
                     "type": "inject",
                     "name": "",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "3",
                     "x": 3110,
                     "y": 1580,
                     "wires": [
                             "90158baa4ebc8746"
                     "type": "inject",
                     "name": "",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "4",
                     "x": 3110,
                     "y": 1540,
                     "wires": [
                             "90158baa4ebc8746"
                     "type": "trigger",
                     "name": "",
                     "op1": "",
                     "op2": "0",
                     "op1type": "pay",
                     "op2type": "str",
                     "duration": "-500",
                     "extend": false,
                     "units": "ms",
                     "reset": "",
                     "bytopic": "all",
                     "topic": "topic",
                     "outputs": 1,
                     "x": 3350,
                     "y": 1560,
                     "wires": [
                             "ae6a83948dc6f287",
                             "ffa3cb8c2bfd0147"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "volume",
                             "pt": "flow",
                             "to": "payload",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 4350,
                     "y": 1540,
                     "wires": [
                             "7091ed465e491ae9",
                             "088a4eac83b92384"
                     "type": "debug",
                     "name": "Volume",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 4420,
                     "y": 1620,
                     "wires": []
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "volume",
                             "tot": "flow"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 3830,
                     "y": 1520,
                     "wires": [
                             "cd995dd8d3e0a86d"
                     "id": "ae6a83948dc6f287",
                     "type": "switch",
                     "name": "3=leiser, 4= lauter",
                     "rules": [
                             "t": "eq",
                             "v": "3",
                             "vt": "num"
                             "t": "eq",
                             "v": "4",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 3590,
                     "y": 1540,
                     "wires": [
                             "52d93ccac45ceb5e"
                             "d3221876d8430845"
                     "id": "d3221876d8430845",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "volume",
                             "tot": "flow"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 3830,
                     "y": 1560,
                     "wires": [
                             "a1c2a16d5f94f96a"
                     "type": "change",
                     "name": "lauter",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 4010,
                     "y": 1560,
                     "wires": [
                             "2c6be8f77f8d6af8"
                     "type": "change",
                     "name": "leiser",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 4010,
                     "y": 1520,
                     "wires": [
                             "2c6be8f77f8d6af8"
                     "id": "1ceb99c8e35107ef",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "reset",
                             "pt": "msg",
                             "to": "true",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 3340,
                     "y": 1680,
                     "wires": [
                             "90158baa4ebc8746"
                     "id": "ffa3cb8c2bfd0147",
                     "type": "rbe",
                     "name": "",
                     "func": "rbe",
                     "gap": "",
                     "start": "",
                     "inout": "out",
                     "septopics": false,
                     "topi": "topic",
                     "x": 3570,
                     "y": 1600,
                     "wires": [
                             "1ceb99c8e35107ef"
                     "type": "ui_group",
                     "order": 2,
                     "disp": true,
                     "width": "6",
                     "collapse": false,
                     "className": ""
                     "type": "ui_tab",
                     "name": "Home",
                     "order": 1,
                     "disabled": false,
                     "hidden": false
              • mickymM mickym
                       "name": "",
                       "func": "all",
                       "gap": "",
                       "x": 3950,
                       "y": 1440,
                       "wires": [
                               "2c6be8f77f8d6af8"
                       "name": "",
                       "label": "slider",
                       "tooltip": "",
                       "order": 0,
                       "width": 0,
                       "height": 0,
                       "passthru": true,
                       "outs": "all",
                       "topic": "topic",
                       "topicType": "msg",
                       "min": "-50",
                       "max": "50",
                       "step": 1,
                       "className": "",
                       "x": 4170,
                       "y": 1540,
                       "wires": [
                               "b67100af74cb26a3"
                       "d": true,
                       "name": "",
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 4590,
                       "y": 1460,
                       "wires": []
                       "type": "inject",
                       "name": "",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "3",
                       "x": 3110,
                       "y": 1580,
                       "wires": [
                               "90158baa4ebc8746"
                       "type": "inject",
                       "name": "",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "4",
                       "x": 3110,
                       "y": 1540,
                       "wires": [
                               "90158baa4ebc8746"
                       "type": "trigger",
                       "name": "",
                       "op1": "",
                       "op2": "0",
                       "op1type": "pay",
                       "op2type": "str",
                       "duration": "-500",
                       "extend": false,
                       "units": "ms",
                       "reset": "",
                       "bytopic": "all",
                       "topic": "topic",
                       "outputs": 1,
                       "x": 3350,
                       "y": 1560,
                       "wires": [
                               "ae6a83948dc6f287",
                               "ffa3cb8c2bfd0147"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "volume",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 4350,
                       "y": 1540,
                       "wires": [
                               "7091ed465e491ae9",
                               "088a4eac83b92384"
                       "type": "debug",
                       "name": "Volume",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 4420,
                       "y": 1620,
                       "wires": []
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "volume",
                               "tot": "flow"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 3830,
                       "y": 1520,
                       "wires": [
                               "cd995dd8d3e0a86d"
                       "type": "switch",
                       "rules": [
                               "t": "eq",
                               "v": "3",
                               "vt": "num"
                               "t": "eq",
                               "v": "4",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 3590,
                       "y": 1540,
                       "wires": [
                               "52d93ccac45ceb5e"
                               "d3221876d8430845"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "volume",
                               "tot": "flow"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 3830,
                       "y": 1560,
                       "wires": [
                               "a1c2a16d5f94f96a"
                       "type": "change",
                       "name": "lauter",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 4010,
                       "y": 1560,
                       "wires": [
                               "2c6be8f77f8d6af8"
                       "type": "change",
                       "name": "leiser",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 4010,
                       "y": 1520,
                       "wires": [
                               "2c6be8f77f8d6af8"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "reset",
                               "pt": "msg",
                               "to": "true",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 3340,
                       "y": 1680,
                       "wires": [
                               "90158baa4ebc8746"
                       "type": "rbe",
                       "name": "",
                       "func": "rbe",
                       "gap": "",
                       "start": "",
                       "inout": "out",
                       "septopics": false,
                       "topi": "topic",
                       "x": 3570,
                       "y": 1600,
                       "wires": [
                               "1ceb99c8e35107ef"
                       "type": "ui_group",
                       "order": 2,
                       "disp": true,
                       "width": "6",
                       "collapse": false,
                       "className": ""
                       "type": "ui_tab",
                       "name": "Home",
                       "order": 1,
                       "disabled": false,
                       "hidden": false
                Saranger
                @mickym
                ich versuch das mal mit Worten meine denkweise darzulegen :-).
                Ich halte gedrückt -> 4 -> es geht die Latustärke hoch -> ich lasse los -> es kommt die 3 -> Lautstärke bleibt stehen
                Ich halte erneut gedrückt -> 0 -> es geht die Lautstärke runter -> ich lasse los -> es kommt die 0 -> Lautstärke bleibt stehen
                die zwei mal 0 ist halt doof aber das kann man nicht ändern.
                mickymM 2 Antworten Letzte Antwort
                • S Saranger
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @mickym
                  Bist Du Dir sicher? Also er sendet bei langem Drücken am Anfang nicht mal 3 und mal 4? Und beim Loslassen das jeweilg andere?
                  • S Saranger
                    @mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    Wird denn bei Lautstärke runter 3 oder wieder 4 gesendet?
                    • mickymM mickym
                      @mickym
                      Saranger
                      schrieb am zuletzt editiert von Saranger
                      @mickym es kommt immer 4 beim drücken dann 3 beim los lassen, dann 0 beim drücken und 0 beim los lassen. Dann wieder 4 beim drücken und 3 beim los lassen usw.
                      • S Saranger
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @mickym es kommt immer 4 beim drücken dann 3 beim los lassen, dann = beim drücken und 0 beim los lassen. Dann wieder 4 beim drücken und 3 beim los lassen usw.
                        Also wenn IMMER 4 und 3 bei loslassen kommt, wann kommen dann die 2 mal 0?
                        Jetzt verstehe ich es so:
                        4:3 dann 0:0 dann 4:3 dann 0:0 - sprich 2mal 0 würden man nutzen, um die Richtung zu wechseln?
                        • mickymM mickym
                          Saranger
                          @mickym ja hast du recht sorry. hab es grad noch mal geprüft immer die 4 und beim loslassen die 3
                          • S Saranger
                            mickymM Offline
                            mickymM Offline
                            mickym
                            4:3 dann 0:0 dann 4:3 dann 0:0 - sprich 2mal 0 würden man nutzen, um die Richtung zu wechseln? Oder ist das 0:4:3:0, um eine Sequenz eines langen Tastendrucks abzuschliessen? Dann kann man die 0 aber ignorieren? Dann hätte der ursprüngliche Flow aber funktionieren müssen. Es ist für mich langsam schwierig zu helfen, wenn ich das nicht sehe.
                            • mickymM mickym
                              Saranger
                              @mickym
                              wenn man das auf zwei Taster (Wippe) aufteilen würde und Linke Taste der Wippe für laut und rechte Taste der Wippe für leise sehen würde wäre es so.
                              Linke Taste für laut: 4 beim drücken und 3 beim los lassen
                              rechte Taste für leise: 0 beim drücken und 0 beim los lassen
                              Ich habe diese beiden Funktionen auf einer Taste als Umschalt Funktion, der wechselt quasi nach jedem langen drücken von 4:3 zu 0:0, dann wieder 4:3.
                              Ist irgendwie schwer zu erklären^^
                              mickymM S 2 Antworten Letzte Antwort
                              • S Saranger
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @saranger Mach halt mal einen Screenshot Deiner Debug Ausgabe.
                                Drücke den Taster jeweils für 10s - dann 10s nichts machen und wieder für 10s halten- dann 10s nichts machen und wieder für 10s halten und dann immer loslassen.
                                Dann kann ich mir vielleicht selbst ein Bild machen. Sonst wird das nichts. Du hast doch keine 2 Tasten oder schon? Oder willst Du es mit 2 Tasten machen.
                                Nein das ist Käse - mit Deiner Switch Node. Eine payload = 0 und dann kommt es immer am gleichen Ausgang raus.
                                Bitte wie gesagt die Debugausgabe von der KNX Node - mit 1 oder 2 Tasten musst Du mir halt sagen. Ich weiß doch nicht mal wie Dein physischer Taster aussieht?
                                • S Saranger
                                  @mickym
                                  Saranger
                                  so kann man da nix machen?
                                  • S Saranger
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @saranger s- letzter Post von mir.
                                    • mickymM mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      Ist komisch, hast Du nun 2 Taster einen mit 4:3 und einen mit 0:0 und das kommt aus der gleichen Node raus? Kann man da nicht 2 Nodes verwenden?
                                      Wenn das so ist, dass man bei dem 2. Taster zwischen drücken und loslassen nicht unterscheiden kann, dann ist mir das egal, sondern dann nehme ich einfach größer 0 für einen Taster (lauter) und =0 (leiser). Die erste Nachricht triggert, die zweite Nachricht stoppt.
                                      Das müsste dann ja OK sein. Zur Sicherheit macht man noch einen Timer ggf. dass der Trigger nicht unendlich lange läuft.
                                      • mickymM mickym
                                        Saranger
                                        so passiert es jetzt wenn ich so drücke wie du geschrieben hast. Ich habe eine Gira TastSensor 4. dieser hat 4 WIppen oder aber 8 Tasten jenachdem wie man ihn konfiguriert. Ich möchte es aber eigentlich über eine Taste machen mit Umschaltfunktion)
                                        Das kommt aus einer Node Aufteilen würde nur funktionieren wenn ich es als Wippe mache. Da ich aber eigentlich die zweite Taste mache um dann die Playlist auszuwählen ist das eher ungünstig.
                                        Ich hau mich erstmal hin, ich schau morgen früh noch mal rein :-). Danke schon mal.
                                        • mickymM Offline
                                          mickymM Offline
                                          mickym
                                          So ich hab es mir einfach gemacht. 4 erhöht Lautstärke, 0 die erniedrigt die Lautstärke. Die jeweils 2. Nachricht - also Taste wird losgelassen, stoppt (egal ob da 3 oder 0 geliefert wird).
                                                 "id": "38121ce9eef37c18",
                                                 "type": "split",
                                                 "name": "",
                                                 "splt": "2",
                                                 "spltType": "len",
                                                 "arraySplt": 1,
                                                 "arraySpltType": "len",
                                                 "stream": true,
                                                 "addname": "",
                                                 "x": 3550,
                                                 "y": 1680,
                                                 "wires": [
                                                         "45916a4633788c3f"
                                                 "id": "c19fdd314570a755",
                                                 "type": "inject",
                                                 "name": "",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "3",
                                                 "x": 3130,
                                                 "y": 1580,
                                                 "wires": [
                                                         "1635f537c1a920f6"
                                                 "id": "91a99d986fec4fa8",
                                                 "type": "inject",
                                                 "name": "",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "4",
                                                 "x": 3130,
                                                 "y": 1620,
                                                 "wires": [
                                                         "1635f537c1a920f6"
                                                 "id": "a03281db9d76c9cd",
                                                 "type": "inject",
                                                 "name": "",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "0",
                                                 "x": 3130,
                                                 "y": 1660,
                                                 "wires": [
                                                         "1635f537c1a920f6"
                                                 "id": "c6caf4b699a942ee",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "$string(payload)\t",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 3390,
                                                 "y": 1680,
                                                 "wires": [
                                                         "38121ce9eef37c18"
                                                 "id": "a96f8ba34653b03f",
                                                 "type": "switch",
                                                 "name": "lauter/leiser",
                                                 "rules": [
                                                         "t": "eq",
                                                         "v": "4",
                                                         "vt": "num"
                                                         "t": "eq",
                                                         "v": "0",
                                                         "vt": "num"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 3370,
                                                 "y": 1580,
                                                 "wires": [
                                                         "a539365bb50f57d7"
                                                         "7834aeaa084b335f"
                                                 "outputLabels": [
                                                     "lauter",
                                                     "leiser"
                                                 "id": "a539365bb50f57d7",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "lauter",
                                                         "pt": "msg",
                                                         "to": "true",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 3560,
                                                 "y": 1560,
                                                 "wires": [
                                                         "c378fa28c6c2fe3a"
                                                 "id": "7834aeaa084b335f",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "lauter",
                                                         "pt": "msg",
                                                         "to": "false",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 3560,
                                                 "y": 1600,
                                                 "wires": [
                                                         "c378fa28c6c2fe3a"
                                                 "id": "0cabae77cf2ddd9f",
                                                 "name": "",
                                                 "label": "slider",
                                                 "tooltip": "",
                                                 "order": 0,
                                                 "width": 0,
                                                 "height": 0,
                                                 "passthru": true,
                                                 "outs": "all",
                                                 "topic": "topic",
                                                 "topicType": "msg",
                                                 "min": "-50",
                                                 "max": "50",
                                                 "step": 1,
                                                 "className": "",
                                                 "x": 4510,
                                                 "y": 1580,
                                                 "wires": [
                                                         "ddad0944ee424de0"
                                                 "id": "b0b3b36c5fd27a27",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "volume",
                                                         "tot": "flow"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 4050,
                                                 "y": 1580,
                                                 "wires": [
                                                         "5d74e58ba9d9bb9a"
                                                 "id": "ddad0944ee424de0",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "volume",
                                                         "pt": "flow",
                                                         "to": "payload",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 4690,
                                                 "y": 1580,
                                                 "wires": [
                                                         "2b9410c867dfa8fd"
                                                 "id": "e1abe46632c327f7",
                                                 "type": "change",
                                                 "name": "lauter",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 4370,
                                                 "y": 1560,
                                                 "wires": [
                                                         "0cabae77cf2ddd9f"
                                                 "id": "454b87edeacb479a",
                                                 "type": "change",
                                                 "name": "leiser",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 4370,
                                                 "y": 1600,
                                                 "wires": [
                                                         "0cabae77cf2ddd9f"
                                                 "id": "5d74e58ba9d9bb9a",
                                                 "type": "switch",
                                                 "name": "",
                                                 "property": "lauter",
                                                 "rules": [
                                                         "t": "true"
                                                         "t": "false"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 4230,
                                                 "y": 1580,
                                                 "wires": [
                                                         "e1abe46632c327f7"
                                                         "454b87edeacb479a"
                                                 "outputLabels": [
                                                     "lauter",
                                                     "leiser"
                                                 "id": "2b9410c867dfa8fd",
                                                 "type": "debug",
                                                 "name": "Volume",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 4880,
                                                 "y": 1580,
                                                 "wires": []
                                                 "id": "c378fa28c6c2fe3a",
                                                 "type": "trigger",
                                                 "name": "",
                                                 "op1": "",
                                                 "op2": "0",
                                                 "op1type": "pay",
                                                 "op2type": "str",
                                                 "duration": "-250",
                                                 "extend": false,
                                                 "units": "ms",
                                                 "reset": "",
                                                 "bytopic": "all",
                                                 "topic": "topic",
                                                 "outputs": 1,
                                                 "x": 3810,
                                                 "y": 1580,
                                                 "wires": [
                                                         "b0b3b36c5fd27a27"
                                                 "id": "45916a4633788c3f",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "reset",
                                                         "pt": "msg",
                                                         "to": "true",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 3700,
                                                 "y": 1680,
                                                 "wires": [
                                                         "c378fa28c6c2fe3a"
                                                 "id": "1635f537c1a920f6",
                                                 "type": "junction",
                                                 "x": 3240,
                                                 "y": 1620,
                                                 "wires": [
                                                         "c6caf4b699a942ee",
                                                         "a96f8ba34653b03f"
                                                 "type": "ui_group",
                                                 "order": 2,
                                                 "disp": true,
                                                 "width": "6",
                                                 "collapse": false,
                                                 "className": ""
                                                 "type": "ui_tab",
                                                 "name": "Home",
                                                 "order": 1,
                                                 "disabled": false,
                                                 "hidden": false
