  4. Node-Red
  5. Sonos Lautstärke regeln
    6.5k
60 Beiträge 2 Kommentatoren 6.1k Aufrufe 2 Beobachtet
  • mickymM mickym
    @saranger Ich mach Dir noch einen Flow mit togglen und da muss man dann halt den Adapter noch anbinden. Kannst Dir ja dann am WE anschauen. Aber Du siehst es ist Einiges möglich.
    Saranger
    @mickym ok das teste ich noch :-)
    • S Saranger
      mickymM Offline
      mickymM Offline
      mickym
      @saranger sagte in Sonos Lautstärke regeln:
      So ich hab mal das Schreiben mit der iobroker out rausgelassen - Du kannst im Debug Fenster sehen, ob sich die Werte erhöhen oder erniedrigen:
             "id": "e016af2ca1bcd4ab",
             "type": "ioBroker in",
             "z": "289f539dcc33814e",
             "name": "",
             "topic": "0_userdata.0.sonos",
             "payloadType": "value",
             "onlyack": "update",
             "func": "all",
             "gap": "",
             "fireOnStart": "true",
             "outFormat": "MQTT",
             "x": 3970,
             "y": 1460,
             "wires": [
                     "2c6be8f77f8d6af8"
             "id": "2c6be8f77f8d6af8",
             "type": "ui_slider",
             "name": "",
             "label": "slider",
             "tooltip": "",
             "group": "0eab8134c3a0274f",
             "order": 0,
             "width": 0,
             "height": 0,
             "passthru": true,
             "outs": "all",
             "topic": "topic",
             "topicType": "msg",
             "min": "-50",
             "max": "50",
             "step": 1,
             "className": "",
             "x": 4170,
             "y": 1540,
             "wires": [
                     "b67100af74cb26a3"
             "id": "088a4eac83b92384",
             "type": "ioBroker out",
             "d": true,
             "name": "",
             "ack": "false",
             "autoCreate": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 4590,
             "y": 1460,
             "wires": []
             "id": "73f491b996915df3",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "3",
             "payloadType": "num",
             "x": 3210,
             "y": 1520,
             "wires": [
                     "90158baa4ebc8746",
                     "6b61b68392c028df"
             "id": "8316e3d57694f5d9",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "4",
             "x": 3210,
             "y": 1560,
             "wires": [
                     "90158baa4ebc8746"
             "id": "90158baa4ebc8746",
             "type": "trigger",
             "name": "",
             "op1": "true",
             "op2": "0",
             "op1type": "bool",
             "op2type": "str",
             "duration": "-250",
             "extend": false,
             "overrideDelay": false,
             "units": "ms",
             "reset": "3",
             "bytopic": "all",
             "topic": "topic",
             "outputs": 1,
             "x": 3430,
             "y": 1540,
             "wires": [
                     "52d93ccac45ceb5e"
             "id": "52d93ccac45ceb5e",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "volume",
                     "tot": "flow"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 3670,
             "y": 1540,
             "wires": [
                     "255a96714e4a8404"
             "id": "b67100af74cb26a3",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "volume",
                     "pt": "flow",
                     "to": "payload",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4350,
             "y": 1540,
             "wires": [
                     "7091ed465e491ae9",
                     "088a4eac83b92384"
             "id": "a1c2a16d5f94f96a",
             "type": "change",
             "name": "lauter",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload + 1",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4010,
             "y": 1520,
             "wires": [
                     "2c6be8f77f8d6af8"
             "id": "cd995dd8d3e0a86d",
             "type": "change",
             "name": "leiser",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload - 1",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4010,
             "y": 1560,
             "wires": [
                     "2c6be8f77f8d6af8"
             "id": "255a96714e4a8404",
             "type": "switch",
             "name": "",
             "property": "toggle",
             "propertyType": "flow",
             "rules": [
                     "t": "true"
                     "t": "false"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 3850,
             "y": 1540,
             "wires": [
                     "a1c2a16d5f94f96a"
                     "cd995dd8d3e0a86d"
             "outputLabels": [
                 "lauter",
                 "leiser"
             "id": "7091ed465e491ae9",
             "type": "debug",
             "name": "Volume",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 4420,
             "y": 1620,
             "wires": []
             "id": "6b61b68392c028df",
             "type": "change",
             "name": "toggle",
             "rules": [
                     "t": "set",
                     "p": "toggle",
                     "pt": "flow",
                     "to": "$exists($flowContext(\"toggle\")) ? $not($flowContext(\"toggle\")) : false\t\t",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 3370,
             "y": 1480,
             "wires": [
             "id": "0eab8134c3a0274f",
             "type": "ui_group",
             "name": "Lautstärke",
             "tab": "20b3095113f94d70",
             "order": 2,
             "disp": true,
             "width": "6",
             "collapse": false,
             "className": ""
             "id": "20b3095113f94d70",
             "type": "ui_tab",
             "name": "Home",
             "icon": "dashboard",
             "order": 1,
             "disabled": false,
             "hidden": false
      Das Loslassen der Taste ist der Trigger zum Umschalten.
      EDIT: so die überflüssige Node noch eliminiert.
      Grün ist wenn es leiser wird, als Werte kleiner werden, rot mit erneutem Tastendruck
      Wie gesagt - der Rest muss man sehen, was der sonos Adapter verträgt, aber du siehst das alleine an der Debug Node der Flow mit dem Taster kleiner oder größere werdende Werte liefert.
      Achso ich habe mit leiser werden angefangen, wenn Du es umgekehrt willst, dann musst halt hinten in der toggle node, das letzte false gegen true ersetzen.
      • mickymM mickym
               "name": "",
               "func": "all",
               "gap": "",
               "x": 3970,
               "y": 1460,
               "wires": [
                       "2c6be8f77f8d6af8"
               "name": "",
               "label": "slider",
               "tooltip": "",
               "order": 0,
               "width": 0,
               "height": 0,
               "passthru": true,
               "outs": "all",
               "topic": "topic",
               "topicType": "msg",
               "min": "-50",
               "max": "50",
               "step": 1,
               "className": "",
               "x": 4170,
               "y": 1540,
               "wires": [
                       "b67100af74cb26a3"
               "d": true,
               "name": "",
               "ack": "false",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 4590,
               "y": 1460,
               "wires": []
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "3",
               "x": 3210,
               "y": 1520,
               "wires": [
                       "90158baa4ebc8746",
                       "6b61b68392c028df"
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "4",
               "x": 3210,
               "y": 1560,
               "wires": [
                       "90158baa4ebc8746"
               "type": "trigger",
               "name": "",
               "op1": "true",
               "op2": "0",
               "op1type": "bool",
               "op2type": "str",
               "duration": "-250",
               "extend": false,
               "units": "ms",
               "reset": "3",
               "bytopic": "all",
               "topic": "topic",
               "outputs": 1,
               "x": 3430,
               "y": 1540,
               "wires": [
                       "52d93ccac45ceb5e"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "volume",
                       "tot": "flow"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 3670,
               "y": 1540,
               "wires": [
                       "255a96714e4a8404"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "volume",
                       "pt": "flow",
                       "to": "payload",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 4350,
               "y": 1540,
               "wires": [
                       "7091ed465e491ae9",
                       "088a4eac83b92384"
               "type": "change",
               "name": "lauter",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 4010,
               "y": 1520,
               "wires": [
                       "2c6be8f77f8d6af8"
               "type": "change",
               "name": "leiser",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 4010,
               "y": 1560,
               "wires": [
                       "2c6be8f77f8d6af8"
               "type": "switch",
               "name": "",
               "rules": [
                       "t": "true"
                       "t": "false"
               "checkall": "true",
               "repair": false,
               "outputs": 2,
               "x": 3850,
               "y": 1540,
               "wires": [
                       "a1c2a16d5f94f96a"
                       "cd995dd8d3e0a86d"
               "outputLabels": [
                   "lauter",
                   "leiser"
               "type": "debug",
               "name": "Volume",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 4420,
               "y": 1620,
               "wires": []
               "type": "change",
               "name": "toggle",
               "rules": [
                       "t": "set",
                       "p": "toggle",
                       "pt": "flow",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 3370,
               "y": 1480,
               "wires": [
               "type": "ui_group",
               "order": 2,
               "disp": true,
               "width": "6",
               "collapse": false,
               "className": ""
               "type": "ui_tab",
               "name": "Home",
               "order": 1,
               "disabled": false,
               "hidden": false
        Saranger
        @mickym also so richtig mag es noch nicht. Wenn ich den Taster gedrückt halte kommt die 3 aber es verändert sich nix und beim los lassen kommt die 4 Aber da passiert auch nix. Wenn ich dann erneut gedrückt halte (Toggle auf verringern) kommt die 0 beim gedrückt halten und beim los lassen auch die 0.
        • S Saranger
          mickymM Offline
          mickymM Offline
          mickym
          @saranger OK . ja ich habe eins nicht bedacht, da die KNX ja nur eine Node ist. da muss nich der Switch davor. Mache ich gleich. 3 ist gedrückt? und 4 losgelassen?
          • mickymM mickym
            Saranger
            @mickym ja genau,
            • S Saranger
              @mickym ja genau,
              mickymM Offline
              mickymM Offline
              mickym
              @mickym ja genau,
              Hatte ich vorher umgekehrt verstanden:
              Sollte so passen. Ansonsten musst Du die trigger Node ändern. Jetzt wird sie bei 4 zurückgesetzt.
                     "name": "",
                     "func": "all",
                     "gap": "",
                     "x": 3970,
                     "y": 1460,
                     "wires": [
                             "2c6be8f77f8d6af8"
                     "name": "",
                     "label": "slider",
                     "tooltip": "",
                     "order": 0,
                     "width": 0,
                     "height": 0,
                     "passthru": true,
                     "outs": "all",
                     "topic": "topic",
                     "topicType": "msg",
                     "min": "-50",
                     "max": "50",
                     "step": 1,
                     "className": "",
                     "x": 4170,
                     "y": 1540,
                     "wires": [
                             "b67100af74cb26a3"
                     "d": true,
                     "name": "",
                     "ack": "false",
                     "stateName": "",
                     "role": "",
                     "payloadType": "",
                     "readonly": "",
                     "stateUnit": "",
                     "stateMin": "",
                     "stateMax": "",
                     "x": 4590,
                     "y": 1460,
                     "wires": []
                     "type": "inject",
                     "name": "",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "3",
                     "x": 2970,
                     "y": 1520,
                     "wires": [
                             "b3f9267a0167714f"
                     "type": "inject",
                     "name": "",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "4",
                     "x": 2970,
                     "y": 1560,
                     "wires": [
                             "b3f9267a0167714f"
                     "type": "trigger",
                     "name": "",
                     "op1": "true",
                     "op2": "0",
                     "op1type": "bool",
                     "op2type": "str",
                     "duration": "-250",
                     "extend": false,
                     "units": "ms",
                     "reset": "4",
                     "bytopic": "all",
                     "topic": "topic",
                     "outputs": 1,
                     "x": 3430,
                     "y": 1540,
                     "wires": [
                             "52d93ccac45ceb5e"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "volume",
                             "tot": "flow"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 3670,
                     "y": 1540,
                     "wires": [
                             "255a96714e4a8404"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "volume",
                             "pt": "flow",
                             "to": "payload",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 4350,
                     "y": 1540,
                     "wires": [
                             "7091ed465e491ae9",
                             "088a4eac83b92384"
                     "type": "change",
                     "name": "lauter",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 4010,
                     "y": 1520,
                     "wires": [
                             "2c6be8f77f8d6af8"
                     "type": "change",
                     "name": "leiser",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 4010,
                     "y": 1560,
                     "wires": [
                             "2c6be8f77f8d6af8"
                     "type": "switch",
                     "name": "",
                     "rules": [
                             "t": "true"
                             "t": "false"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 3850,
                     "y": 1540,
                     "wires": [
                             "a1c2a16d5f94f96a"
                             "cd995dd8d3e0a86d"
                     "outputLabels": [
                         "lauter",
                         "leiser"
                     "type": "debug",
                     "name": "Volume",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 4420,
                     "y": 1620,
                     "wires": []
                     "type": "change",
                     "name": "toggle",
                     "rules": [
                             "t": "set",
                             "p": "toggle",
                             "pt": "flow",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 3370,
                     "y": 1600,
                     "wires": [
                     "id": "b3f9267a0167714f",
                     "type": "switch",
                     "name": "KNX Taster Analyse",
                     "property": "payload",
                     "propertyType": "msg",
                     "rules": [
                             "t": "eq",
                             "v": "3",
                             "vt": "num"
                             "t": "eq",
                             "v": "4",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 3170,
                     "y": 1540,
                     "wires": [
                             "90158baa4ebc8746"
                             "6b61b68392c028df",
                             "90158baa4ebc8746"
                     "outputLabels": [
                         "gedrückt",
                         "losgelassen"
                     "type": "ui_group",
                     "order": 2,
                     "disp": true,
                     "width": "6",
                     "collapse": false,
                     "className": ""
                     "type": "ui_tab",
                     "name": "Home",
                     "order": 1,
                     "disabled": false,
                     "hidden": false
              Deine KNX Node nun an die switch Node am Anfang.
              Ich hab die Ausgänge auch beschriftet, sodass Du da die Debug NOdes hinmachen kannst und überprüfen kannst, ob es am richtigen Ausgang rauskommt.
              Hier konfigurierst Du, bei welcher payload die trigger Node aufhören soll zu senden.
              • mickymM mickym
                @mickym ja genau,
                       "name": "",
                       "func": "all",
                       "gap": "",
                       "x": 3970,
                       "y": 1460,
                       "wires": [
                               "2c6be8f77f8d6af8"
                       "name": "",
                       "label": "slider",
                       "tooltip": "",
                       "order": 0,
                       "width": 0,
                       "height": 0,
                       "passthru": true,
                       "outs": "all",
                       "topic": "topic",
                       "topicType": "msg",
                       "min": "-50",
                       "max": "50",
                       "step": 1,
                       "className": "",
                       "x": 4170,
                       "y": 1540,
                       "wires": [
                               "b67100af74cb26a3"
                       "d": true,
                       "name": "",
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 4590,
                       "y": 1460,
                       "wires": []
                       "type": "inject",
                       "name": "",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "3",
                       "x": 2970,
                       "y": 1520,
                       "wires": [
                               "b3f9267a0167714f"
                       "type": "inject",
                       "name": "",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "4",
                       "x": 2970,
                       "y": 1560,
                       "wires": [
                               "b3f9267a0167714f"
                       "type": "trigger",
                       "name": "",
                       "op1": "true",
                       "op2": "0",
                       "op1type": "bool",
                       "op2type": "str",
                       "duration": "-250",
                       "extend": false,
                       "units": "ms",
                       "reset": "4",
                       "bytopic": "all",
                       "topic": "topic",
                       "outputs": 1,
                       "x": 3430,
                       "y": 1540,
                       "wires": [
                               "52d93ccac45ceb5e"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "volume",
                               "tot": "flow"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 3670,
                       "y": 1540,
                       "wires": [
                               "255a96714e4a8404"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "volume",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 4350,
                       "y": 1540,
                       "wires": [
                               "7091ed465e491ae9",
                               "088a4eac83b92384"
                       "type": "change",
                       "name": "lauter",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 4010,
                       "y": 1520,
                       "wires": [
                               "2c6be8f77f8d6af8"
                       "type": "change",
                       "name": "leiser",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 4010,
                       "y": 1560,
                       "wires": [
                               "2c6be8f77f8d6af8"
                       "type": "switch",
                       "name": "",
                       "rules": [
                               "t": "true"
                               "t": "false"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 3850,
                       "y": 1540,
                       "wires": [
                               "a1c2a16d5f94f96a"
                               "cd995dd8d3e0a86d"
                       "outputLabels": [
                           "lauter",
                           "leiser"
                       "type": "debug",
                       "name": "Volume",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 4420,
                       "y": 1620,
                       "wires": []
                       "type": "change",
                       "name": "toggle",
                       "rules": [
                               "t": "set",
                               "p": "toggle",
                               "pt": "flow",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 3370,
                       "y": 1600,
                       "wires": [
                       "type": "switch",
                       "rules": [
                               "t": "eq",
                               "v": "3",
                               "vt": "num"
                               "t": "eq",
                               "v": "4",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 3170,
                       "y": 1540,
                       "wires": [
                               "90158baa4ebc8746"
                               "6b61b68392c028df",
                               "90158baa4ebc8746"
                       "outputLabels": [
                           "gedrückt",
                           "losgelassen"
                       "type": "ui_group",
                       "order": 2,
                       "disp": true,
                       "width": "6",
                       "collapse": false,
                       "className": ""
                       "type": "ui_tab",
                       "name": "Home",
                       "order": 1,
                       "disabled": false,
                       "hidden": false
                Saranger
                @mickym also es ist jetzt so halte ich gedrückt macht er zwei Schritte vor und bleibt dann stehe. ich lasse los und drücke wieder lang und es passiert nix. Ich lasse wieder los und drücke erneut lang dann macht zwei Punkte zurück. Hatte den Trigger auf 3 geändert. Aber kein Stress ich schau mir das am We noch mal an und antworte dir noch mal :-)
                • S Saranger
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @saranger
                  Jetzt sollten auch andere Werte wie ggf. 1 und 2 nicht mehr stören. Ich bin mir auch nicht sicher, ob das zwischen 3 und 4 dauernd wechselt - weil Du Dimmer eingestellt hast. Vielleicht solltest Du die KNX Node lieber auf Taster und nicht Dimmer einschaltest.
                  Vielleicht ist auch 3 höher regeln und 4 tiefer und hat nichts mit dem langen Tastendruck zu tun. Dann ist es natürlich so, dass man den ganzen Flow anders machen muss. Schau erst mal ob Du das was aus der KNX Node nicht eindeutiger machen kannst. Ich glaube, dass der KNX Dimmer ggf. selber toggelt und das wäre schlecht weil das dann fehlerbehafteter wird.
                  Aber kann natürlich sein, dass nur der Dimmermodus den langen Tastendruck simuliert. Ausserdem wenn er dann stehen bleibt - schau mal ob der selbstständig eine Nachricht schickt, auch wenn Du den Taster gedrückt hälst.
                  Aber auch mit dem Verhalten habe ich noch eine Idee. ;) Wichtig wäre halt zu wissen, ob der Taster selbstständig die Gegennachricht sendet.
                  • mickymM mickym
                    @saranger
                    Saranger
                    @mickym Wenn ich nicht auf dimmer stelle habe ich nur 1x Schalten und dann kann ich nicht differenzieren zwischen langen und kurzen druck. 4 und 3 passt zum "hochdimmen". Ich denke man müsste noch einen zweiten Pfadfür Leise machen wo man auf 0 reagiert. Dummerweise sendet er beim betätigen die 0 und beim los lassen ebenfalls die 0 aber vielleicht geht da trotzdem was.
                    • mickymM Offline
                      mickymM Offline
                      mickym
                      das wäre jetzt ein Flow, wo der Taster selbst mit wechselndem 3 oder 4 signalisiert, dass die Werte erhöht bzw. erniedrigt werden sollen. Ich habe jetzt mal 3 für leiser werdend und 4 für lauter werden verwendet. Wird der entgegen gesetzte Wert gesendet, dann stoppt der Flow.
                      Sprich es geht jetzt mit der Dimmereinstellung so. (das erste Mal muss man ggf. 2 mal drücken).
                      Der Taster sendet 3 - der Flow erniedrigt die Werte solange, bis 4 kommt. Das gilt nun als Stopp-Signal.
                      Dies erwartet also immer das gegenläufige Signal zum Stoppen. Nimmt nun aber 3 und 4 als leiser oder lauter.
                             "name": "",
                             "func": "all",
                             "gap": "",
                             "x": 3950,
                             "y": 1440,
                             "wires": [
                                     "2c6be8f77f8d6af8"
                             "name": "",
                             "label": "slider",
                             "tooltip": "",
                             "order": 0,
                             "width": 0,
                             "height": 0,
                             "passthru": true,
                             "outs": "all",
                             "topic": "topic",
                             "topicType": "msg",
                             "min": "-50",
                             "max": "50",
                             "step": 1,
                             "className": "",
                             "x": 4170,
                             "y": 1540,
                             "wires": [
                                     "b67100af74cb26a3"
                             "d": true,
                             "name": "",
                             "ack": "false",
                             "stateName": "",
                             "role": "",
                             "payloadType": "",
                             "readonly": "",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 4590,
                             "y": 1460,
                             "wires": []
                             "type": "inject",
                             "name": "",
                             "props": [
                                     "p": "payload"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "3",
                             "x": 3110,
                             "y": 1580,
                             "wires": [
                                     "90158baa4ebc8746"
                             "type": "inject",
                             "name": "",
                             "props": [
                                     "p": "payload"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "4",
                             "x": 3110,
                             "y": 1540,
                             "wires": [
                                     "90158baa4ebc8746"
                             "type": "trigger",
                             "name": "",
                             "op1": "",
                             "op2": "0",
                             "op1type": "pay",
                             "op2type": "str",
                             "duration": "-500",
                             "extend": false,
                             "units": "ms",
                             "reset": "",
                             "bytopic": "all",
                             "topic": "topic",
                             "outputs": 1,
                             "x": 3350,
                             "y": 1560,
                             "wires": [
                                     "ae6a83948dc6f287",
                                     "ffa3cb8c2bfd0147"
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "volume",
                                     "pt": "flow",
                                     "to": "payload",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 4350,
                             "y": 1540,
                             "wires": [
                                     "7091ed465e491ae9",
                                     "088a4eac83b92384"
                             "type": "debug",
                             "name": "Volume",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 4420,
                             "y": 1620,
                             "wires": []
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "volume",
                                     "tot": "flow"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 3830,
                             "y": 1520,
                             "wires": [
                                     "cd995dd8d3e0a86d"
                             "id": "ae6a83948dc6f287",
                             "type": "switch",
                             "name": "3=leiser, 4= lauter",
                             "rules": [
                                     "t": "eq",
                                     "v": "3",
                                     "vt": "num"
                                     "t": "eq",
                                     "v": "4",
                                     "vt": "num"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 3590,
                             "y": 1540,
                             "wires": [
                                     "52d93ccac45ceb5e"
                                     "d3221876d8430845"
                             "id": "d3221876d8430845",
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "volume",
                                     "tot": "flow"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 3830,
                             "y": 1560,
                             "wires": [
                                     "a1c2a16d5f94f96a"
                             "type": "change",
                             "name": "lauter",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 4010,
                             "y": 1560,
                             "wires": [
                                     "2c6be8f77f8d6af8"
                             "type": "change",
                             "name": "leiser",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "jsonata"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 4010,
                             "y": 1520,
                             "wires": [
                                     "2c6be8f77f8d6af8"
                             "id": "1ceb99c8e35107ef",
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "reset",
                                     "pt": "msg",
                                     "to": "true",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 3340,
                             "y": 1680,
                             "wires": [
                                     "90158baa4ebc8746"
                             "id": "ffa3cb8c2bfd0147",
                             "type": "rbe",
                             "name": "",
                             "func": "rbe",
                             "gap": "",
                             "start": "",
                             "inout": "out",
                             "septopics": false,
                             "topi": "topic",
                             "x": 3570,
                             "y": 1600,
                             "wires": [
                                     "1ceb99c8e35107ef"
                             "type": "ui_group",
                             "order": 2,
                             "disp": true,
                             "width": "6",
                             "collapse": false,
                             "className": ""
                             "type": "ui_tab",
                             "name": "Home",
                             "order": 1,
                             "disabled": false,
                             "hidden": false
                      • mickymM mickym
                               "name": "",
                               "func": "all",
                               "gap": "",
                               "x": 3950,
                               "y": 1440,
                               "wires": [
                                       "2c6be8f77f8d6af8"
                               "name": "",
                               "label": "slider",
                               "tooltip": "",
                               "order": 0,
                               "width": 0,
                               "height": 0,
                               "passthru": true,
                               "outs": "all",
                               "topic": "topic",
                               "topicType": "msg",
                               "min": "-50",
                               "max": "50",
                               "step": 1,
                               "className": "",
                               "x": 4170,
                               "y": 1540,
                               "wires": [
                                       "b67100af74cb26a3"
                               "d": true,
                               "name": "",
                               "ack": "false",
                               "stateName": "",
                               "role": "",
                               "payloadType": "",
                               "readonly": "",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 4590,
                               "y": 1460,
                               "wires": []
                               "type": "inject",
                               "name": "",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "3",
                               "x": 3110,
                               "y": 1580,
                               "wires": [
                                       "90158baa4ebc8746"
                               "type": "inject",
                               "name": "",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "4",
                               "x": 3110,
                               "y": 1540,
                               "wires": [
                                       "90158baa4ebc8746"
                               "type": "trigger",
                               "name": "",
                               "op1": "",
                               "op2": "0",
                               "op1type": "pay",
                               "op2type": "str",
                               "duration": "-500",
                               "extend": false,
                               "units": "ms",
                               "reset": "",
                               "bytopic": "all",
                               "topic": "topic",
                               "outputs": 1,
                               "x": 3350,
                               "y": 1560,
                               "wires": [
                                       "ae6a83948dc6f287",
                                       "ffa3cb8c2bfd0147"
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "volume",
                                       "pt": "flow",
                                       "to": "payload",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 4350,
                               "y": 1540,
                               "wires": [
                                       "7091ed465e491ae9",
                                       "088a4eac83b92384"
                               "type": "debug",
                               "name": "Volume",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 4420,
                               "y": 1620,
                               "wires": []
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "volume",
                                       "tot": "flow"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 3830,
                               "y": 1520,
                               "wires": [
                                       "cd995dd8d3e0a86d"
                               "type": "switch",
                               "rules": [
                                       "t": "eq",
                                       "v": "3",
                                       "vt": "num"
                                       "t": "eq",
                                       "v": "4",
                                       "vt": "num"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 3590,
                               "y": 1540,
                               "wires": [
                                       "52d93ccac45ceb5e"
                                       "d3221876d8430845"
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "volume",
                                       "tot": "flow"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 3830,
                               "y": 1560,
                               "wires": [
                                       "a1c2a16d5f94f96a"
                               "type": "change",
                               "name": "lauter",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 4010,
                               "y": 1560,
                               "wires": [
                                       "2c6be8f77f8d6af8"
                               "type": "change",
                               "name": "leiser",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 4010,
                               "y": 1520,
                               "wires": [
                                       "2c6be8f77f8d6af8"
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "reset",
                                       "pt": "msg",
                                       "to": "true",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 3340,
                               "y": 1680,
                               "wires": [
                                       "90158baa4ebc8746"
                               "type": "rbe",
                               "name": "",
                               "func": "rbe",
                               "gap": "",
                               "start": "",
                               "inout": "out",
                               "septopics": false,
                               "topi": "topic",
                               "x": 3570,
                               "y": 1600,
                               "wires": [
                                       "1ceb99c8e35107ef"
                               "type": "ui_group",
                               "order": 2,
                               "disp": true,
                               "width": "6",
                               "collapse": false,
                               "className": ""
                               "type": "ui_tab",
                               "name": "Home",
                               "order": 1,
                               "disabled": false,
                               "hidden": false
                        Saranger
                        @mickym
                        ich versuch das mal mit Worten meine denkweise darzulegen :-).
                        Ich halte gedrückt -> 4 -> es geht die Latustärke hoch -> ich lasse los -> es kommt die 3 -> Lautstärke bleibt stehen
                        Ich halte erneut gedrückt -> 0 -> es geht die Lautstärke runter -> ich lasse los -> es kommt die 0 -> Lautstärke bleibt stehen
                        die zwei mal 0 ist halt doof aber das kann man nicht ändern.
                        • S Saranger
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @mickym
                          Bist Du Dir sicher? Also er sendet bei langem Drücken am Anfang nicht mal 3 und mal 4? Und beim Loslassen das jeweilg andere?
                          • S Saranger
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            Wird denn bei Lautstärke runter 3 oder wieder 4 gesendet?
                            • mickymM mickym
                              @mickym
                              Saranger
                              schrieb am zuletzt editiert von Saranger
                              @mickym es kommt immer 4 beim drücken dann 3 beim los lassen, dann 0 beim drücken und 0 beim los lassen. Dann wieder 4 beim drücken und 3 beim los lassen usw.
                              • S Saranger
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @mickym es kommt immer 4 beim drücken dann 3 beim los lassen, dann = beim drücken und 0 beim los lassen. Dann wieder 4 beim drücken und 3 beim los lassen usw.
                                Also wenn IMMER 4 und 3 bei loslassen kommt, wann kommen dann die 2 mal 0?
                                Jetzt verstehe ich es so:
                                4:3 dann 0:0 dann 4:3 dann 0:0 - sprich 2mal 0 würden man nutzen, um die Richtung zu wechseln?
                                • mickymM mickym
                                  Saranger
                                  @mickym ja hast du recht sorry. hab es grad noch mal geprüft immer die 4 und beim loslassen die 3
                                  • S Saranger
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    4:3 dann 0:0 dann 4:3 dann 0:0 - sprich 2mal 0 würden man nutzen, um die Richtung zu wechseln? Oder ist das 0:4:3:0, um eine Sequenz eines langen Tastendrucks abzuschliessen? Dann kann man die 0 aber ignorieren? Dann hätte der ursprüngliche Flow aber funktionieren müssen. Es ist für mich langsam schwierig zu helfen, wenn ich das nicht sehe.
                                    • mickymM mickym
                                      Saranger
                                      @mickym
                                      wenn man das auf zwei Taster (Wippe) aufteilen würde und Linke Taste der Wippe für laut und rechte Taste der Wippe für leise sehen würde wäre es so.
                                      Linke Taste für laut: 4 beim drücken und 3 beim los lassen
                                      rechte Taste für leise: 0 beim drücken und 0 beim los lassen
                                      Ich habe diese beiden Funktionen auf einer Taste als Umschalt Funktion, der wechselt quasi nach jedem langen drücken von 4:3 zu 0:0, dann wieder 4:3.
                                      Ist irgendwie schwer zu erklären^^
                                      mickymM S 2 Antworten Letzte Antwort
                                      • S Saranger
                                        @mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @saranger Mach halt mal einen Screenshot Deiner Debug Ausgabe.
                                        Drücke den Taster jeweils für 10s - dann 10s nichts machen und wieder für 10s halten- dann 10s nichts machen und wieder für 10s halten und dann immer loslassen.
                                        Dann kann ich mir vielleicht selbst ein Bild machen. Sonst wird das nichts. Du hast doch keine 2 Tasten oder schon? Oder willst Du es mit 2 Tasten machen.
                                        Nein das ist Käse - mit Deiner Switch Node. Eine payload = 0 und dann kommt es immer am gleichen Ausgang raus.
                                        Bitte wie gesagt die Debugausgabe von der KNX Node - mit 1 oder 2 Tasten musst Du mir halt sagen. Ich weiß doch nicht mal wie Dein physischer Taster aussieht?
                                        • S Saranger
                                          @mickym
                                          Saranger
                                          so kann man da nix machen?
