  4. [gelöst] Canvas - compiled against a different Node.js vers,
    6.3k
103 Beiträge 4 Kommentatoren 22.2k Aufrufe 3 Beobachtet
    @diamand2k22
    Hau den Adapter mal komplett von der Kiste runter und dann wieder frisch drauf.
    Am besten mit --debug dann:
    iob add ecovacs-deebot --debug
    Diamand2k22
    #81
    $ iobroker url mrbungle64/ioBroker.ecovacs-deebot --host pi4b --debug
    install mrbungle64/ioBroker.ecovacs-deebot
    NPM version: 10.9.0
    Installing mrbungle64/ioBroker.ecovacs-deebot... (System call)
    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.npm warn deprecated gauge@3.0.2: This package is no longer supported.
    > canvas@2.10.2 install> node-pre-gyp install --fallback-to-build --update-binary
    node-pre-gyp info it worked if it ends with oknode-pre-gyp info using node-pre-gyp@1.0.11node-pre-gyp info using node@22.12.0 | linux | arm64
    (node:2806199) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.(Use `node --trace-deprecation ...` to show where the warning was created)node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz
    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@22.12.0 (node-v127 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v127-linux-glibc-arm64.tar.gz gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64
    gyp info ok gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64
    gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
    gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/canvas/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/22.12.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.12.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.12.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/canvas',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
    gyp info ok
    gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@22.12.0 | linux | arm64gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node COPY Release/canvas-postbuild.node CXX(target) Release/obj.target/canvas/src/backend/Backend.o
    In file included from ../src/backend/Backend.h:6, from ../src/backend/Backend.cc:1:../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, imp::Sig)’:../../nan/nan.h:2548:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’ 2548 | tpl->SetAccessor( | ~~~~~~~~~~~~~~~~^ 2549 | name | ~~~~ 2550 | , getter_ | ~~~~~~~~~ 2551 | , setter_ | ~~~~~~~~~ 2552 | , obj | ~~~~~ 2553 | , settings | ~~~~~~~~~~ 2554 | , attribute | ~~~~~~~~~~~ 2555 | #if (NODE_MODULE_VERSION < NODE_16_0_MODULE_VERSION) | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 2556 | , signature | ~~~~~~~~~~~ 2557 | #endif | ~~~~~~ 2558 | ); | ~ In file included from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-function.h:15, from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8.h:33, from /home/iobroker/.cache/node-gyp/22.12.0/include/node/node.h:73, from ../../nan/nan.h:62:/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1049:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1049 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1052:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1052 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1055:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1055 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1058:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1058 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute)’:../../nan/nan.h:2594:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’ 2594 | tpl->SetAccessor( | ~~~~~~~~~~~~~~~~^ 2595 | name | ~~~~ 2596 | , getter_ | ~~~~~~~~~ 2597 | , setter_ | ~~~~~~~~~ 2598 | , obj | ~~~~~ 2599 | , settings | ~~~~~~~~~~ 2600 | , attribute | ~~~~~~~~~~~ 2601 | ); | ~ /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1049:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1049 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1052:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1052 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1055:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ 1055 | void SetAccessor( | ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-template.h:1058:61: note: no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’ 1058 | Local<Value> data = Local<Value>(), PropertyAttribute attribute = None, | ~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~
    make: *** [canvas.target.mk:159: Release/obj.target/canvas/src/backend/Backend.o] Fehler 1make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:216:23)gyp ERR! System Linux 6.1.21-v8+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--update-binary" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v127"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v22.12.0gyp ERR! node-gyp -v v10.2.0gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v127' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)node-pre-gyp ERR! stack at ChildProcess.emit (node:events:524:28)node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1101:16)node-pre-gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:304:5)
    node-pre-gyp ERR! node -v v22.12.0node-pre-gyp ERR! node-pre-gyp -v v1.0.11node-pre-gyp ERR! not ok Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v127' (1)
    removed 2 packages, and changed 3 packages in 48s
    316 packages are looking for funding run `npm fund` for details
    upload [5] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/admin.d.ts admin.d.ts video/mp2t
    upload [4] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/ecovacs-deebot.png ecovacs-deebot.png image/png
    upload [3] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/index_m.html index_m.html text/html
    upload [2] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/style.css style.css text/css
    upload [0] ecovacs-deebot.admin /opt/iobroker/node_modules/iobroker.ecovacs-deebot/admin/words.js words.js application/javascript
    Updating objects from io-package.json for adapter "ecovacs-deebot" with version "1.4.16-alpha.4"
    Update "system.adapter.ecovacs-deebot.0"
    Update "system.adapter.ecovacs-deebot.1"
    Process exited with code 0
    irgendwie findet er das Package nicht.
    • D Diamand2k22
      NPM version: 10.9.0
      gyp info ok
      #82
      @diamand2k22 sagte in [gelöst] Canvas - compiled against a different Node.js vers,:
      Ja, das ist nicht schlimm, weil es dann aus den Quellen gebaut wird.
      Sieht dann so aus:
      echad@chet:/opt/iobroker $ iob add ecovacs-deebot --debug
      NPM version: 10.9.2
      Installing iobroker.ecovacs-deebot@1.4.15... (System call)
      npm warn deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
      npm warn deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
      npm warn deprecated @xmldom/xmldom@0.9.0-beta.11: this version has critical issues, please update to the latest version
      npm warn deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
      node-pre-gyp info using node@23.5.0 | linux | arm64
      (node:122704) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
      node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
      node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
      node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.2 and node@23.5.0 (node-v131 ABI, glibc) (falling back to source compile with node-gyp)
      node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.2/canvas-v2.10.2-node-v131-linux-glibc-arm64.tar.gz
      gyp info using node-gyp@11.0.0
      gyp info ok
      gyp info spawn args '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build/config.gypi',
      gyp info spawn args '/home/iobroker/.cache/node-gyp/23.5.0/include/node/common.gypi',
      gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.5.0',
      gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.5.0/<(target_arch)/node.lib',
      gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas',
      gyp info ok
      gyp info spawn make
      make: Entering directory '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build'
      In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-local-handle.h:13,
                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-array-buffer.h:12,
                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8.h:24,
                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/node.h:73,
                       from ../../../../nan/nan.h:62,
      In member function ‘bool v8::api_internal::IndirectHandleBase::IsEmpty() const’,
          inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:450:20,
          inlined from ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:463:8,
          inlined from ‘void Nan::Persistent<T, M>::Reset(const v8::Local<S>&) [with S = v8::Object; T = v8::Object; M = v8::NonCopyablePersistentTraits<v8::Object>]’ at ../../../../nan/nan_persistent_12_inl.h:29:33,
          inlined from ‘void Nan::ObjectWrap::Wrap(v8::Local<v8::Object>)’ at ../../../../nan/nan_object_wrap.h:56:23,
          inlined from ‘static void Backend::init(const Nan::FunctionCallbackInfo<v8::Value>&)’ at ../src/backend/Backend.cc:23:16:
      /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-handle-base.h:56:43: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
         56 |   V8_INLINE bool IsEmpty() const { return location_ == nullptr; }
      In member function ‘void v8::api_internal::IndirectHandleBase::Clear()’,
          inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:452:14,
      /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-handle-base.h:59:38: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
         59 |   V8_INLINE void Clear() { location_ = nullptr; }
      In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-object.h:11,
                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-array-buffer.h:13:
      In member function ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’,
      /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-persistent-handle.h:465:16: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
        465 |   this->slot() = New(isolate, *other);
        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
        CXX(target) Release/obj.target/canvas/src/Backends.o
        CXX(target) Release/obj.target/canvas/src/Canvas.o
      In file included from ../../../../nan/nan_callbacks.h:123,
                       from ../../../../nan/nan.h:182,
                       from ../src/Canvas.h:5,
                       from ../src/Canvas.cc:3:
      ../../../../nan/nan_callbacks_12_inl.h: In instantiation of ‘v8::Local<v8::Object> Nan::FunctionCallbackInfo<T>::Holder() const [with T = v8::Value]’:
      ../src/Canvas.cc:649:63:   required from here
      ../../../../nan/nan_callbacks_12_inl.h:112:68: warning: ‘v8::Local<v8::Object> v8::FunctionCallbackInfo<F>::Holder() const [with T = v8::Value]’ is deprecated: V8 will stop providing access to hidden prototype (i.e. JSGlobalObject). Use This() instead. \nDO NOT try to workaround this by accessing JSGlobalObject via v8::Object::GetPrototype() - it'll be deprecated soon too. \nSee http://crbug.com/333672197.  [-Wdeprecated-declarations]
        112 |   inline v8::Local<v8::Object> Holder() const { return info_.Holder(); }
      In file included from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-isolate.h:22,
                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-snapshot.h:9,
                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-context.h:15,
                       from /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8.h:26,
                       from ../../../../nan/nan.h:62:
      /home/iobroker/.cache/node-gyp/23.5.0/include/node/v8-function-callback.h:658:15: note: declared here
        658 | Local<Object> FunctionCallbackInfo<T>::Holder() const {
      • D Diamand2k22
        NPM version: 10.9.0
        gyp info ok
        #83
        @diamand2k22
        Bitte ein gescheites Terminal verwenden, dann ist der Output auch besser lesbar.
        Wie in meinem Beispiel.
          @diamand2k22
          Diamand2k22
          schrieb am zuletzt editiert von Diamand2k22
          #84
          diesen ganzen Errors beim build von canvas machen micht stutzig... ab Zeile 140....
          pi4b@pi4b:/opt/iobroker$ iob upgrade iobroker.ecovacs-deebot@1.4.15 --debug
          Would you like to downgrade ecovacs-deebot from @1.4.16-alpha.4 to @1.4.15 now? [(y)es, (n)o]: y
          Update ecovacs-deebot from @1.4.16-alpha.4 to @1.4.15
          NPM version: 10.9.0
          (node:2806815) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
          gyp info ok
          gyp info ok
          gyp info spawn make
           2549 |       name
           2550 |     , getter_
           2551 |     , setter_
           2552 |     , obj
           2553 |     , settings
           2554 |     , attribute
           2556 |     , signature
           2557 | #endif
           2558 |   );
           2595 |       name
           2596 |     , getter_
           2597 |     , setter_
           2598 |     , obj
           2599 |     , settings
           2600 |     , attribute
           2601 |   );
          gyp ERR! not ok
          node-pre-gyp ERR! System Linux 6.1.21-v8+
          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
          added 2 packages, and changed 3 packages in 50s
          Updating objects from io-package.json for adapter "ecovacs-deebot" with version "1.4.15"
          • D Diamand2k22
            NPM version: 10.9.0
            gyp info ok
            gyp info ok
            gyp info spawn make
             2549 |       name
             2550 |     , getter_
             2551 |     , setter_
             2552 |     , obj
             2553 |     , settings
             2554 |     , attribute
             2556 |     , signature
             2557 | #endif
             2558 |   );
             2595 |       name
             2596 |     , getter_
             2597 |     , setter_
             2598 |     , obj
             2599 |     , settings
             2600 |     , attribute
             2601 |   );
            gyp ERR! not ok
            #85
            @diamand2k22
            Du solltest doch den Adapter komplett runterhauen und frisch neuinstallieren.
            • D Diamand2k22
              NPM version: 10.9.0
              gyp info ok
              gyp info ok
              gyp info spawn make
               2549 |       name
               2550 |     , getter_
               2551 |     , setter_
               2552 |     , obj
               2553 |     , settings
               2554 |     , attribute
               2556 |     , signature
               2557 | #endif
               2558 |   );
               2595 |       name
               2596 |     , getter_
               2597 |     , setter_
               2598 |     , obj
               2599 |     , settings
               2600 |     , attribute
               2601 |   );
              gyp ERR! not ok
              #86
              @diamand2k22
              Bullseye oder Bookworm?
              Und verwende nodejs@20.
                Diamand2k22
                #87
                bookworm und nodejs@22
                hab den Fehler mit dem canvas übrigens auch bei dem esphome Adapter...
                • D Diamand2k22
                  #88
                  @diamand2k22
                  Dann hast du aber mit Sicherheit einen Versuch unternommen, von einer Vorversion auf den 'Bookworm' zu springen.
                  Das geht aber regelmäßig in die Hose.
                  Installier das System komplett NEU.
                    @diamand2k22
                    Diamand2k22
                    #89
                    Bookworm hab ich schon lange drauf und auch bis jetzt nie ein Problem gehabt.
                    auch canvas hat bis dato funktioniert.
                    erst seid dem letzten sudo apt update && full-upgrade hab ich dieses Problem
                    ich sehe du hast da schon node@23.5.0 am laufen 😬
                    • D Diamand2k22
                      #90
                      Es ist aber trotzdem nicht richtig installiert. Da läuft mindestens noch der Bullseye-Kernel.
                      So komische Fehler zeigen sich immer erst nach einiger Zeit. Das System fängt an sich merkwürdig zu verhalten.
                      Ja, ist mein Bastelsystem. Das andere System läuft auf nodejs@20.
                      Bookworm-Kernel:
                      echad@chet:~ $ uname -a
                      Linux chet 6.6.62+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64 GNU/Linux
                        Bookworm-Kernel:
                        Diamand2k22
                        #91
                        ja sieht bei mir so aus:
                        pi4b@pi4b:~$ uname -a
                        Linux pi4b 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU
                        schau mal hier:
                        https://github.com/Automattic/node-canvas/issues/2377
                          @diamand2k22
                          #92
                          @thomas-braun sagte in [gelöst] Canvas - compiled against a different Node.js vers,:
                          Ich zitiere mich selbst:
                          • D Diamand2k22
                            schau mal hier:
                            #93
                            6.1.21-v8+
                            Ist wie gesagt der falsche Kernel.
                              6.1.21-v8+
                              Diamand2k22
                              #94
                              gibt es denn eine Möglichkeit, den Kernel zu tauschen ohne Neuinstallation? oder ist der Murks zu groß?
                              • D Diamand2k22
                                #95
                                @diamand2k22
                                Mit viel Gebastel und ggfls. zweifelhaftem Ergebnis:
                                Wer es entgegen aller Warnungen versuchen möchte:
                                https://www.heise.de/hintergrund/Raspberry-Pi-OS-InPlace-Upgrade-von-Bullseye-auf-Bookworm-wagen-9999516.html
                                  @diamand2k22
                                  Diamand2k22
                                  #96
                                  ok...dann werd ich die Neu-Installation mal in Angriff nehmen demnächst... d.h. jetzt konkret der veraltete Kernel in Kombination mit nodjs@22 führt zu dem Problem?
                                  • D Diamand2k22
                                    #97
                                    @diamand2k22
                                    Kann ich dir nicht sagen. Ich kann dir aber sagen, dass es auf meinem 'senkrechten' System auch mit nodejs@22 baut:
                                    echad@chet:/opt/iobroker $ nodejs -v
                                    v22.12.0
                                    NPM version: 10.9.0
                                    (node:129683) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                    gyp info ok
                                    gyp http GET https://nodejs.org/download/release/v22.12.0/node-v22.12.0-headers.tar.gz
                                    gyp http 200 https://nodejs.org/download/release/v22.12.0/node-v22.12.0-headers.tar.gz
                                    gyp http GET https://nodejs.org/download/release/v22.12.0/SHASUMS256.txt
                                    gyp http 200 https://nodejs.org/download/release/v22.12.0/SHASUMS256.txt
                                    gyp info ok
                                    gyp info spawn make
                                    In file included from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-local-handle.h:13,
                                                     from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-array-buffer.h:12,
                                                     from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8.h:24,
                                        inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-persistent-handle.h:469:20,
                                        inlined from ‘void v8::PersistentBase<T>::Reset(v8::Isolate*, const v8::Local<S>&) [with S = v8::Object; T = v8::Object]’ at /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-persistent-handle.h:482:8,
                                    /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-handle-base.h:56:43: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                                        inlined from ‘void v8::PersistentBase<T>::Reset() [with T = v8::Object]’ at /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-persistent-handle.h:471:14,
                                    /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-handle-base.h:59:38: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                                    In file included from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-object.h:10,
                                                     from /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-array-buffer.h:13:
                                    /home/iobroker/.cache/node-gyp/22.12.0/include/node/v8-persistent-handle.h:484:16: warning: array subscript 0 is outside array bounds of ‘Nan::Persistent<v8::Object> [0]’ [-Warray-bounds]
                                      484 |   this->slot() = New(isolate, *other);
                                      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                                      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                                      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                                    ../src/CanvasRenderingContext2d.cc: In member function ‘void Context2d::setTextPath(double, double)’:
                                    ../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_LEFT’ not handled in switch [-Wswitch]
                                     2494 |   switch (state->textAlignment) {
                                    ../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_START’ not handled in switch [-Wswitch]
                                      CXX(target) Release/obj.target/canvas/src/closure.o
                                      CXX(target) Release/obj.target/canvas/src/color.o
                                      CXX(target) Release/obj.target/canvas/src/Image.o
                                    ../src/Image.cc: In member function ‘cairo_status_t Image::loadSVGFromBuffer(uint8_t*, unsigned int)’:
                                    ../src/Image.cc:1196:29: warning: ‘void rsvg_handle_get_dimensions(RsvgHandle*, RsvgDimensionData*)’ is deprecated: Use 'rsvg_handle_get_intrinsic_size_in_pixels' instead [-Wdeprecated-declarations]
                                     1196 |   rsvg_handle_get_dimensions(_rsvg, dims);
                                    In file included from ../src/Image.h:28,
                                                     from ../src/Image.cc:3:
                                    /usr/include/librsvg-2.0/librsvg/rsvg.h:708:6: note: declared here
                                      708 | void rsvg_handle_get_dimensions (RsvgHandle *handle, RsvgDimensionData *dimension_data);
                                    ../src/Image.cc: In member function ‘cairo_status_t Image::renderSVGToSurface()’:
                                    ../src/Image.cc:1235:48: warning: ‘gboolean rsvg_handle_render_cairo(RsvgHandle*, cairo_t*)’ is deprecated: Use 'rsvg_handle_render_document' instead [-Wdeprecated-declarations]
                                     1235 |   gboolean render_ok = rsvg_handle_render_cairo(_rsvg, cr);
                                    In file included from /usr/include/librsvg-2.0/librsvg/rsvg.h:1452:
                                    /usr/include/librsvg-2.0/librsvg/rsvg-cairo.h:88:10: note: declared here
                                       88 | gboolean rsvg_handle_render_cairo (RsvgHandle *handle, cairo_t *cr);
                                      CXX(target) Release/obj.target/canvas/src/ImageData.o
                                      CXX(target) Release/obj.target/canvas/src/init.o
                                      CXX(target) Release/obj.target/canvas/src/register_font.o
                                      SOLINK_MODULE(target) Release/obj.target/canvas.node
                                      COPY Release/canvas.node
                                    make: Leaving directory '/opt/iobroker/node_modules/ecovacs-deebot/node_modules/canvas/build'
                                    gyp info ok
                                    node-pre-gyp info ok
                                    added 33 packages in 2m
                                    230 packages are looking for funding
                                    host.chet install adapter ecovacs-deebot
                                    host.chet object system.adapter.ecovacs-deebot created/updated
                                    host.chet create instance ecovacs-deebot
                                    host.chet object system.adapter.ecovacs-deebot.0.alive created
                                    host.chet object system.adapter.ecovacs-deebot.0.connected created
                                    host.chet object system.adapter.ecovacs-deebot.0.compactMode created
                                    host.chet object system.adapter.ecovacs-deebot.0.cpu created
                                    host.chet object system.adapter.ecovacs-deebot.0.cputime created
                                    host.chet object system.adapter.ecovacs-deebot.0.memHeapUsed created
                                    host.chet object system.adapter.ecovacs-deebot.0.memHeapTotal created
                                    host.chet object system.adapter.ecovacs-deebot.0.memRss created
                                    host.chet object system.adapter.ecovacs-deebot.0.uptime created
                                    host.chet object system.adapter.ecovacs-deebot.0.inputCount created
                                    host.chet object system.adapter.ecovacs-deebot.0.outputCount created
                                    host.chet object system.adapter.ecovacs-deebot.0.eventLoopLag created
                                    host.chet object system.adapter.ecovacs-deebot.0.sigKill created
                                    host.chet object system.adapter.ecovacs-deebot.0.logLevel created
                                    host.chet object ecovacs-deebot.0.info created
                                    host.chet object ecovacs-deebot.0.info.connection created
                                    host.chet object ecovacs-deebot.0 created
                                    host.chet Set default value of ecovacs-deebot.0.info.connection: false
                                    host.chet object system.adapter.ecovacs-deebot.0 created
                                    echad@chet:/opt/iobroker $ node -v
                                    v22.12.0
                                    echad@chet:/opt/iobroker $ cd /opt/iobroker/ && npm ls canvas
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    ├─┬ iobroker.echarts@1.9.5
                                    │ ├── canvas@2.11.2
                                    │ └─┬ jsdom@25.0.1
                                    │   └── canvas@2.11.2 deduped
                                    ├─┬ iobroker.ecovacs-deebot@1.4.15
                                    │ └─┬ ecovacs-deebot@0.9.6-beta.3
                                    │   └── canvas@2.10.2
                                    └─┬ iobroker.mihome-vacuum@4.2.0
                                      Diamand2k22
                                      #98
                                      @thomas-braun said in [gelöst] Canvas - compiled against a different Node.js vers,:
                                      wenn ich es manuell über die Konsole installiere, mit:
                                      npm install canvas@2.10.2
                                      dann gehts.
                                      pi4b@pi4b:/opt/iobroker$ npm ls canvas
                                      └─┬ iobroker.ecovacs-deebot@1.4.16-alpha.4 (git+ssh://git@github.com/mrbungle64/                            ioBroker.ecovacs-deebot.git#22db1e39d24c855f6ae4eb567e8e9cdaa4ac2524)
                                        ├── canvas@2.10.2
                                        └─┬ ecovacs-deebot@0.9.6-beta.7
                                          └── canvas@2.10.2 deduped
                                      • D Diamand2k22
                                        dann gehts.
                                          ├── canvas@2.10.2
                                        #99
                                        @diamand2k22
                                        Dann liegt es aber in der falschen Ebene.
                                        Und dein System ist immer noch ein 'Bullsworm'
                                          Diamand2k22
                                          #100
                                          Ich weiß, aber bis zur Neuinstallation noch soweit hinausgezögern. Ich hab den npm befehl unter npm-Modulen/iobroker.ecovacs-Deebot ausgeführt, sollte doch normal passen oder?
