  2. English
  4. Onvif
    1.0k
Onvif
3 Beiträge 2 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • VraanaaV Offline
    VraanaaV Offline
    Vraanaa
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: linux
    Node-Version: 14.18.3
    Nodejs-Version: 14.18.3
    NPM-Version: 6.14.15
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    I have a issue with OnVif adapter - ist disconnect from REOLINK kameras sporadic. When Connected - all is working well.
    Dont know what can be issue of the connection's
    Cameras: REOLINK
    Model
    RLC-810A
    Build No.
    build 22041503
    Hardware No.
    IPC_523128M8MP
    Config Version
    v3.1.0.0
    Firmware Version
    v3.1.0.956_22041503
    • VraanaaV Vraanaa
      Hardwaresystem: Pi4
      Image genutzt: Nein
      Cameras: REOLINK
      Model
      RLC-810A
      Build No.
      build 22041503
      Hardware No.
      IPC_523128M8MP
      Config Version
      v3.1.0.0
      Firmware Version
      v3.1.0.956_22041503
      arteckA Offline
      arteckA Offline
      arteck
      @vraanaa check you wifi.. in the moment when the cam is off
      VraanaaV 1 Antwort Letzte Antwort
      • arteckA arteck
        VraanaaV Offline
        VraanaaV Offline
        Vraanaa
        @arteck Thank you for reply - The cameras are Wired connected (PoE) - I use them also for Synology Surveillance and they recording all the time without some gap in recording.
        I performed Speed test during disconnection of Camera in Onvif adapter.
