  4. Hm-rpc: HM-MOD-EM-8Bit
1 Beiträge 1 Kommentatoren 675 Aufrufe
  • GoerschG Offline
    GoerschG Offline
    Goersch
    noch ein paar "Send this to developer"
    ! ` > 2017-05-03 13:03:04.945 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-MOD-EM-8Bit.MAINTENANCE.10"
    2017-05-03 13:03:04.945 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"AES_KEY":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATIONS":1,"TAB_ORDER":8,"TYPE":"INTEGER","UNIT":""},"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"DEVICE_IN_BOOTLOADER":{"DEFAULT":false,"FLAGS":9,"ID":"DEVICE_IN_BOOTLOADER","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":6,"TYPE":"BOOL","UNIT":""},"LOWBAT":{"DEFAULT":false,"FLAGS":9,"ID":"LOWBAT","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"RSSI_DEVICE":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"INTEGER","UNIT":""},"RSSI_PEER":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"STICKY_UNREACH":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"UNREACH":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"UPDATE_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"UPDATE_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":7,"TYPE":"BOOL","UNIT":""}}}
    2017-05-03 13:03:05.031 - [32minfo[39m: hm-rpc.0 binrpc -> getParamsetDescription ["NEQYYYYYYY:1","VALUES"]
    2017-05-03 13:03:05.074 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-MOD-EM-8Bit.KEY.10"
    2017-05-03 13:03:05.074 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":2,"TYPE":"ACTION","UNIT":""},"PRESS_CONT":{"DEFAULT":false,"FLAGS":3,"ID":"PRESS_CONT","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":3,"TYPE":"ACTION","UNIT":""},"PRESS_LONG":{"CONTROL":"BUTTON.LONG","DEFAULT":false,"FLAGS":1,"ID":"PRESS_LONG","MAX":true,"MIN":false,"OPERATIONS":6,"TAB_ORDER":1,"TYPE":"ACTION","UNIT":""},"PRESS_LONG_RELEASE":{"DEFAULT":false,"FLAGS":3,"ID":"PRESS_LONG_RELEASE","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":4,"TYPE":"ACTION","UNIT":""},"PRESS_SHORT":{"CONTROL":"BUTTON.SHORT","DEFAULT":false,"FLAGS":1,"ID":"PRESS_SHORT","MAX":true,"MIN":false,"OPERATIONS":6,"TAB_ORDER":0,"TYPE":"ACTION","UNIT":""}}}
    2017-05-03 13:03:05.165 - [32minfo[39m: hm-rpc.0 binrpc -> getParamsetDescription ["NEQYYYYYYY:3","VALUES"]
    2017-05-03 13:03:05.210 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-MOD-EM-8Bit.MOD_EM8BIT_TRANSMITTER.10"
    2017-05-03 13:03:05.211 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":2,"TYPE":"ACTION","UNIT":""},"LOWBAT":{"CONTROL":"BATTERIE.LOWBAT","DEFAULT":false,"FLAGS":1,"ID":"LOWBAT","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"STATE":{"CONTROL":"DIGITAL_STATE.STATE","DEFAULT":0,"FLAGS":1,"ID":"STATE","MAX":255,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"INTEGER","UNIT":""}}} `
