  4. Fehler beim Host js-controller Update (Slave)
    5.7k
23 Beiträge 3 Kommentatoren 2.6k Aufrufe 1 Beobachtet
    @porty
    Da hängt noch zigbee-herdsman in der Pipeline.
    sudo -H -u iobroker npm cache clear --force
    portyP Offline
    portyP Offline
    porty
    schrieb am zuletzt editiert von porty
    nächste Versuch, erneut mit Fehlschlag.
    (Zeitzone wurde inzwischen angepasst ;) )
    Das ganze hat wieder gut 3 Stunden gedauert.
    pi@iobroker2:~ $ cd /opt/iobroker/
    pi@iobroker2:/opt/iobroker $ sudo -H -u iobroker npm cache clear --force
    npm WARN using --force Recommended protections disabled.
    pi@iobroker2:/opt/iobroker $ iobroker update
    node:internal/modules/cjs/loader:988
     throw err;
    Error: Cannot find module './lib/setup'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
       at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
       at Function.Module._load (node:internal/modules/cjs/loader:833:27)
       at Module.require (node:internal/modules/cjs/loader:1057:19)
       at require (node:internal/modules/cjs/helpers:103:18)
       at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
       at Module._compile (node:internal/modules/cjs/loader:1155:14)
       at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
       at Module.load (node:internal/modules/cjs/loader:1033:32)
       at Function.Module._load (node:internal/modules/cjs/loader:868:12)
       at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
     code: 'MODULE_NOT_FOUND',
     requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
    pi@iobroker2:/opt/iobroker $ npm install iobroker.js-controller
    npm ERR! code ERR_INVALID_ARG_TYPE
    npm ERR! The "from" argument must be of type string. Received undefined
    npm ERR!     /home/iobroker/.npm/_logs/2022-11-03T19_00_02_134Z-debug-0.log
    Das Logfile liegt diesmal bei knapp 9000 Zeilen daher wieder nur ein Auszug
    8555 http fetch GET 200 https://registry.npmjs.org/sshpk/-/sshpk-1.16.1.tgz 3030009ms (cache miss)
    8556 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@sinonjs/commons Completed in 3100514ms
    8557 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest-snapshot/node_modules/semver Completed in 3100867ms
    8558 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/node-notifier/node_modules/semver Completed in 3100887ms
    8559 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint/node_modules/semver Completed in 3100979ms
    8560 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/semver Completed in 3136616ms
    8561 http fetch GET 200 https://registry.npmjs.org/@babel/traverse/-/traverse-7.13.0.tgz 3057670ms (cache miss)
    8562 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@babel/preset-modules Completed in 3136558ms
    8563 http fetch GET 200 https://registry.npmjs.org/semver/-/semver-7.3.8.tgz 3126134ms (cache miss)
    8564 timing reifyNode:node_modules/@iobroker/db-objects-redis/node_modules/semver Completed in 3138377ms
    8565 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-modules Completed in 3139852ms
    8566 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/tar-fs Completed in 3140266ms
    8567 timing reifyNode:node_modules/zigbee-herdsman/node_modules/sshpk Completed in 3153045ms
    8568 http fetch GET 200 https://registry.npmjs.org/semver/-/semver-7.3.5.tgz 3140747ms (cache miss)
    8569 timing reifyNode:node_modules/iobroker.js-controller/node_modules/semver Completed in 3152904ms
    8570 http fetch GET 200 https://registry.npmjs.org/semver/-/semver-7.3.4.tgz 3075388ms (cache miss)
    8571 http fetch GET 200 https://registry.npmjs.org/fs-extra/-/fs-extra-9.1.0.tgz 3072713ms (cache miss)
    8572 http fetch GET 200 https://registry.npmjs.org/sshpk/-/sshpk-1.16.1.tgz 3090202ms (cache miss)
    8573 http fetch GET 200 https://registry.npmjs.org/fs-extra/-/fs-extra-9.1.0.tgz 3085002ms (cache miss)
    8574 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/typescript-estree/node_modules/semver Completed in 3179574ms
    8575 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/traverse Completed in 3180165ms
    8576 http fetch GET 200 https://registry.npmjs.org/enquirer/-/enquirer-2.3.6.tgz 3099925ms (cache miss)
    8577 http fetch GET 200 https://registry.npmjs.org/enquirer/-/enquirer-2.3.6.tgz 3098350ms (cache miss)
    8578 http fetch GET 200 https://registry.npmjs.org/enquirer/-/enquirer-2.3.6.tgz 3103519ms (cache miss)
    8579 timing reifyNode:node_modules/zigbee-herdsman/node_modules/fs-extra Completed in 3198555ms
    8580 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fs-extra Completed in 3201417ms
    8581 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/sshpk Completed in 3233191ms
    8582 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/enquirer Completed in 3249425ms
    8583 timing reifyNode:node_modules/zigbee-herdsman/node_modules/enquirer Completed in 3249287ms
    8584 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/enquirer Completed in 3250082ms
    8585 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.5.7.tgz 3230414ms (cache miss)
    8586 http fetch GET 200 https://registry.npmjs.org/parse5/-/parse5-5.1.1.tgz 3171015ms (cache miss)
    8587 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.5.7.tgz 3217837ms (cache miss)
    8588 http fetch GET 200 https://registry.npmjs.org/parse5/-/parse5-6.0.1.tgz 3170915ms (cache miss)
    8589 http fetch GET 200 https://registry.npmjs.org/logform/-/logform-2.4.2.tgz 3254080ms (cache miss)
    8590 timing reifyNode:node_modules/logform Completed in 3265341ms
    8591 http fetch GET 200 https://registry.npmjs.org/@nodelib/fs.stat/-/fs.stat-2.0.4.tgz 3189905ms (cache miss)
    8592 http fetch GET 200 https://registry.npmjs.org/jest-jasmine2/-/jest-jasmine2-26.6.3.tgz 3186686ms (cache miss)
    8593 http fetch GET 200 https://registry.npmjs.org/jest-jasmine2/-/jest-jasmine2-26.6.3.tgz 3184288ms (cache miss)
    8594 http fetch GET 200 https://registry.npmjs.org/@nodelib/fs.stat/-/fs.stat-2.0.4.tgz 3186309ms (cache miss)
    8595 http fetch GET 200 https://registry.npmjs.org/@nodelib/fs.stat/-/fs.stat-2.0.4.tgz 3175141ms (cache miss)
    8596 http fetch GET 200 https://registry.npmjs.org/jest-jasmine2/-/jest-jasmine2-26.6.3.tgz 3175333ms (cache miss)
    8597 http fetch GET 200 https://registry.npmjs.org/parse5/-/parse5-5.1.1.tgz 3186580ms (cache miss)
    8598 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.5.7.tgz 3244653ms (cache miss)
    8599 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.5.7.tgz 3222540ms (cache miss)
    8600 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/snapdragon/node_modules/source-map Completed in 3295080ms
    8601 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/parse5 Completed in 3294889ms
    8602 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/jest-jasmine2 Completed in 3295233ms
    8603 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/parse5 Completed in 3295438ms
    8604 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@babel/core/node_modules/source-map Completed in 3295792ms
    8605 timing reifyNode:node_modules/zigbee-herdsman/node_modules/jest-jasmine2 Completed in 3320486ms
    8606 http fetch GET 200 https://registry.npmjs.org/yargs/-/yargs-17.4.0.tgz 3308482ms (cache miss)
    8607 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest-jasmine2 Completed in 3321490ms
    8608 http fetch GET 200 https://registry.npmjs.org/table/-/table-6.7.1.tgz 3227296ms (cache miss)
    8609 http fetch GET 200 https://registry.npmjs.org/js-yaml/-/js-yaml-3.14.1.tgz 3227231ms (cache miss)
    8610 http fetch GET 200 https://registry.npmjs.org/js-yaml/-/js-yaml-3.14.1.tgz 3227037ms (cache miss)
    8611 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@nodelib/fs.stat Completed in 3322414ms
    8612 http fetch GET 200 https://registry.npmjs.org/semver/-/semver-7.3.4.tgz 3243686ms (cache miss)
    8613 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin/node_modules/semver Completed in 3322618ms
    8614 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@babel/generator/node_modules/source-map Completed in 3323244ms
    8615 http fetch GET 200 https://registry.npmjs.org/shelljs/-/shelljs-0.8.4.tgz 3244101ms (cache miss)
    8616 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/shelljs Completed in 3323403ms
    8617 timing reifyNode:node_modules/zigbee-herdsman/node_modules/source-map Completed in 3323482ms
    8618 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@nodelib/fs.stat Completed in 3323710ms
    8619 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@nodelib/fs.stat Completed in 3324298ms
    8620 http fetch GET 200 https://registry.npmjs.org/onigasm/-/onigasm-2.2.5.tgz 3306735ms (cache miss)
    8621 timing reifyNode:node_modules/zigbee-herdsman/node_modules/onigasm Completed in 3324066ms
    8622 timing reifyNode:node_modules/zigbee-herdsman/node_modules/parse5 Completed in 3324271ms
    8623 http fetch GET 200 https://registry.npmjs.org/axios/-/axios-0.21.1.tgz 3272711ms (cache miss)
    8624 http fetch GET 200 https://registry.npmjs.org/fast-glob/-/fast-glob-3.2.5.tgz 3269365ms (cache miss)
    8625 http fetch GET 200 https://registry.npmjs.org/fast-glob/-/fast-glob-3.2.5.tgz 3259973ms (cache miss)
    8626 http fetch GET 200 https://registry.npmjs.org/fast-glob/-/fast-glob-3.2.5.tgz 3259746ms (cache miss)
    8627 timing reifyNode:node_modules/iobroker.js-controller/node_modules/yargs Completed in 3354873ms
    8628 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/table Completed in 3355907ms
    8629 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/js-yaml Completed in 3356310ms
    8630 timing reifyNode:node_modules/zigbee-herdsman/node_modules/js-yaml Completed in 3356417ms
    8631 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.5.7.tgz 3319743ms (cache miss)
    8632 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/axios Completed in 3410407ms
    8633 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/source-map Completed in 3424145ms
    8634 timing reifyNode:node_modules/zigbee-herdsman/node_modules/fast-glob Completed in 3423536ms
    8635 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fast-glob Completed in 3423980ms
    8636 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/fast-glob Completed in 3423936ms
    8637 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3389454ms (cache miss)
    8638 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/source-map Completed in 3424467ms
    8639 http fetch GET 200 https://registry.npmjs.org/yargs/-/yargs-15.4.1.tgz 3341384ms (cache miss)
    8640 http fetch GET 200 https://registry.npmjs.org/yargs/-/yargs-15.4.1.tgz 3330144ms (cache miss)
    8641 http fetch GET 200 https://registry.npmjs.org/yargs/-/yargs-15.4.1.tgz 3329933ms (cache miss)
    8642 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3376353ms (cache miss)
    8643 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@jest/source-map/node_modules/source-map Completed in 3424558ms
    8644 http fetch GET 200 https://registry.npmjs.org/onigasm/-/onigasm-2.2.5.tgz 3333379ms (cache miss)
    8645 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/onigasm Completed in 3424497ms
    8646 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3355287ms (cache miss)
    8647 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/escodegen/node_modules/source-map Completed in 3424303ms
    8648 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3357064ms (cache miss)
    8649 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@jest/transform/node_modules/source-map Completed in 3424413ms
    8650 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3355528ms (cache miss)
    8651 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/handlebars/node_modules/source-map Completed in 3424330ms
    8652 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3356589ms (cache miss)
    8653 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@jest/reporters/node_modules/source-map Completed in 3424467ms
    8654 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3349056ms (cache miss)
    8655 timing reifyNode:node_modules/zigbee-herdsman/node_modules/handlebars/node_modules/source-map Completed in 3424006ms
    8656 http fetch GET 200 https://registry.npmjs.org/@iobroker/js-controller-adapter/-/js-controller-adapter-4.0.23.tgz 3412813ms (cache miss)
    8657 http fetch GET 200 https://registry.npmjs.org/@bcoe/v8-coverage/-/v8-coverage-0.2.3.tgz 3347017ms (cache miss)
    8658 http fetch GET 200 https://registry.npmjs.org/esquery/-/esquery-1.4.0.tgz 3343507ms (cache miss)
    8659 http fetch GET 200 https://registry.npmjs.org/esquery/-/esquery-1.4.0.tgz 3339914ms (cache miss)
    8660 http fetch GET 200 https://registry.npmjs.org/esquery/-/esquery-1.4.0.tgz 3342255ms (cache miss)
    8661 http fetch GET 200 https://registry.npmjs.org/rsvp/-/rsvp-4.8.5.tgz 3379963ms (cache miss)
    8662 http fetch GET 200 https://registry.npmjs.org/rsvp/-/rsvp-4.8.5.tgz 3353720ms (cache miss)
    8663 http fetch GET 200 https://registry.npmjs.org/nan/-/nan-2.14.2.tgz 3353016ms (cache miss)
    8664 http fetch GET 200 https://registry.npmjs.org/@bcoe/v8-coverage/-/v8-coverage-0.2.3.tgz 3330503ms (cache miss)
    8665 timing reifyNode:node_modules/zigbee-herdsman/node_modules/yargs Completed in 3443088ms
    8666 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3369402ms (cache miss)
    8667 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@jest/reporters/node_modules/source-map Completed in 3443137ms
    8668 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3367817ms (cache miss)
    8669 timing reifyNode:node_modules/zigbee-herdsman/node_modules/escodegen/node_modules/source-map Completed in 3443052ms
    8670 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3368147ms (cache miss)
    8671 timing reifyNode:node_modules/zigbee-herdsman/node_modules/istanbul-lib-source-maps/node_modules/source-map Completed in 3443080ms
    8672 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3369468ms (cache miss)
    8673 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@jest/source-map/node_modules/source-map Completed in 3443195ms
    8674 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/yargs Completed in 3443537ms
    8675 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/yargs Completed in 3443469ms
    8676 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3369160ms (cache miss)
    8677 timing reifyNode:node_modules/zigbee-herdsman/node_modules/source-map-support/node_modules/source-map Completed in 3443173ms
    8678 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3351712ms (cache miss)
    8679 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/istanbul-lib-source-maps/node_modules/source-map Completed in 3443623ms
    8680 timing reifyNode:node_modules/@iobroker/js-controller-adapter Completed in 3443215ms
    8681 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/esquery Completed in 3443582ms
    8682 timing reifyNode:node_modules/zigbee-herdsman/node_modules/esquery Completed in 3443416ms
    8683 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/esquery Completed in 3443819ms
    8684 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3352481ms (cache miss)
    8685 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/source-map-support/node_modules/source-map Completed in 3444076ms
    8686 http fetch GET 200 https://registry.npmjs.org/uuid/-/uuid-8.3.2.tgz 3350148ms (cache miss)
    8687 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@bcoe/v8-coverage Completed in 3445289ms
    8688 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/rsvp Completed in 3445435ms
    8689 timing reifyNode:node_modules/zigbee-herdsman/node_modules/rsvp Completed in 3444934ms
    8690 timing reifyNode:node_modules/zigbee-herdsman/node_modules/nan Completed in 3444935ms
    8691 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@bcoe/v8-coverage Completed in 3474243ms
    8692 http fetch GET 200 https://registry.npmjs.org/uri-js/-/uri-js-4.4.1.tgz 3335855ms (cache miss)
    8693 http fetch GET 200 https://registry.npmjs.org/axios/-/axios-0.24.0.tgz 3461653ms (cache miss)
    8694 timing reifyNode:node_modules/iobroker.js-controller/node_modules/axios Completed in 3473825ms
    8695 http fetch GET 200 https://registry.npmjs.org/uuid/-/uuid-8.3.2.tgz 3379912ms (cache miss)
    8696 http fetch GET 200 https://registry.npmjs.org/uuid/-/uuid-8.3.2.tgz 3379835ms (cache miss)
    8697 http fetch GET 200 https://registry.npmjs.org/rsvp/-/rsvp-4.8.5.tgz 3348318ms (cache miss)
    8698 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/uuid Completed in 3474664ms
    8699 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/uri-js Completed in 3475243ms
    8700 http fetch GET 200 https://registry.npmjs.org/@sentry/hub/-/hub-6.19.7.tgz 3465421ms (cache miss)
    8701 http fetch GET 200 https://registry.npmjs.org/nan/-/nan-2.17.0.tgz 3466296ms (cache miss)
    8702 timing reifyNode:node_modules/nan Completed in 3477528ms
    8703 http fetch GET 200 https://registry.npmjs.org/winston/-/winston-3.8.2.tgz 3466525ms (cache miss)
    8704 timing reifyNode:node_modules/winston Completed in 3477739ms
    8705 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/uuid Completed in 3478778ms
    8706 timing reifyNode:node_modules/zigbee-herdsman/node_modules/uuid Completed in 3478496ms
    8707 http fetch GET 200 https://registry.npmjs.org/uri-js/-/uri-js-4.4.1.tgz 3384439ms (cache miss)
    8708 http fetch GET 200 https://registry.npmjs.org/@bcoe/v8-coverage/-/v8-coverage-0.2.3.tgz 3432233ms (cache miss)
    8709 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/rsvp Completed in 3515126ms
    8710 http fetch GET 200 https://registry.npmjs.org/axios/-/axios-0.26.1.tgz 3503374ms (cache miss)
    8711 timing reifyNode:node_modules/@iobroker/js-controller-common/node_modules/axios Completed in 3515599ms
    8712 timing reifyNode:node_modules/@sentry/hub Completed in 3515828ms
    8713 timing reifyNode:node_modules/zigbee-herdsman/node_modules/uri-js Completed in 3515220ms
    8714 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@bcoe/v8-coverage Completed in 3515458ms
    8715 http fetch GET 200 https://registry.npmjs.org/source-map/-/source-map-0.6.1.tgz 3443501ms (cache miss)
    8716 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@jest/transform/node_modules/source-map Completed in 3517146ms
    8717 http fetch GET 200 https://registry.npmjs.org/table/-/table-6.0.7.tgz 3435732ms (cache miss)
    8718 http fetch GET 200 https://registry.npmjs.org/acorn/-/acorn-7.4.1.tgz 3438131ms (cache miss)
    8719 http fetch GET 200 https://registry.npmjs.org/@nodelib/fs.scandir/-/fs.scandir-2.1.4.tgz 3463409ms (cache miss)
    8720 http fetch GET 200 https://registry.npmjs.org/@nodelib/fs.scandir/-/fs.scandir-2.1.4.tgz 3452454ms (cache miss)
    8721 http fetch GET 200 https://registry.npmjs.org/acorn/-/acorn-7.4.1.tgz 3470401ms (cache miss)
    8722 timing reifyNode:node_modules/zigbee-herdsman/node_modules/table Completed in 3562585ms
    8723 http fetch GET 200 https://registry.npmjs.org/table/-/table-6.0.7.tgz 3490557ms (cache miss)
    8724 http fetch GET 200 https://registry.npmjs.org/acorn/-/acorn-7.4.1.tgz 3499047ms (cache miss)
    8725 timing reifyNode:node_modules/zigbee-herdsman/node_modules/acorn Completed in 3583523ms
    8726 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/acorn Completed in 3584272ms
    8727 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/acorn Completed in 3584325ms
    8728 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@nodelib/fs.scandir Completed in 3584717ms
    8729 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@nodelib/fs.scandir Completed in 3585279ms
    8730 http fetch GET 200 https://registry.npmjs.org/uglify-js/-/uglify-js-3.13.0.tgz 3502536ms (cache miss)
    8731 timing reifyNode:node_modules/zigbee-herdsman/node_modules/uglify-js Completed in 3585073ms
    8732 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/table Completed in 3586923ms
    8733 http fetch GET 200 https://registry.npmjs.org/uglify-js/-/uglify-js-3.13.0.tgz 3541090ms (cache miss)
    8734 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/uglify-js Completed in 3620353ms
    8735 http fetch GET 200 https://registry.npmjs.org/prompts/-/prompts-2.4.0.tgz 3537203ms (cache miss)
    8736 http fetch GET 200 https://registry.npmjs.org/@babel/core/-/core-7.13.8.tgz 3537722ms (cache miss)
    8737 http fetch GET 200 https://registry.npmjs.org/prompts/-/prompts-2.4.0.tgz 3526397ms (cache miss)
    8738 timing reifyNode:node_modules/zigbee-herdsman/node_modules/prompts Completed in 3620998ms
    8739 http fetch GET 200 https://registry.npmjs.org/prompts/-/prompts-2.4.1.tgz 3527773ms (cache miss)
    8740 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/prompts Completed in 3622437ms
    8741 http fetch GET 200 https://registry.npmjs.org/@jest/core/-/core-26.6.3.tgz 3545198ms (cache miss)
    8742 http fetch GET 200 https://registry.npmjs.org/@jest/core/-/core-26.6.3.tgz 3540226ms (cache miss)
    8743 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@babel/core Completed in 3643064ms
    8744 http fetch GET 200 https://registry.npmjs.org/@jest/core/-/core-26.6.3.tgz 3549385ms (cache miss)
    8745 http fetch GET 200 https://registry.npmjs.org/@nodelib/fs.scandir/-/fs.scandir-2.1.4.tgz 3566258ms (cache miss)
    8746 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@nodelib/fs.scandir Completed in 3643896ms
    8747 http fetch GET 200 https://registry.npmjs.org/cssstyle/-/cssstyle-2.3.0.tgz 3563592ms (cache miss)
    8748 http fetch GET 200 https://registry.npmjs.org/cssstyle/-/cssstyle-2.3.0.tgz 3562742ms (cache miss)
    8749 http fetch GET 200 https://registry.npmjs.org/cssstyle/-/cssstyle-2.3.0.tgz 3559260ms (cache miss)
    8750 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/prompts Completed in 3643992ms
    8751 http fetch GET 200 https://registry.npmjs.org/@babel/core/-/core-7.13.8.tgz 3549950ms (cache miss)
    8752 http fetch GET 200 https://registry.npmjs.org/@babel/parser/-/parser-7.13.9.tgz 3627996ms (cache miss)
    8753 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@babel/parser Completed in 3644738ms
    8754 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@jest/core Completed in 3645377ms
    8755 http fetch GET 200 https://registry.npmjs.org/js-yaml/-/js-yaml-3.14.1.tgz 3506121ms (cache miss)
    8756 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/js-yaml Completed in 3645297ms
    8757 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@jest/core Completed in 3645001ms
    8758 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@jest/core Completed in 3647656ms
    8759 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/cssstyle Completed in 3648181ms
    8760 http fetch GET 200 https://registry.npmjs.org/@types/node/-/node-14.14.31.tgz 3654443ms (cache miss)
    8761 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/cssstyle Completed in 3670606ms
    8762 timing reifyNode:node_modules/zigbee-herdsman/node_modules/cssstyle Completed in 3670278ms
    8763 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/core Completed in 3670934ms
    8764 http fetch GET 200 https://registry.npmjs.org/@babel/core/-/core-7.14.3.tgz 3593537ms (cache miss)
    8765 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@types/node Completed in 3671472ms
    8766 http fetch GET 200 https://registry.npmjs.org/@babel/parser/-/parser-7.14.3.tgz 3658943ms (cache miss)
    8767 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@babel/parser Completed in 3674124ms
    8768 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@babel/core Completed in 3699609ms
    8769 http fetch GET 200 https://registry.npmjs.org/@types/node/-/node-14.14.31.tgz 3684191ms (cache miss)
    8770 http fetch GET 200 https://registry.npmjs.org/typedoc-plugin-markdown/-/typedoc-plugin-markdown-3.6.0.tgz 3608961ms (cache miss)
    8771 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/node Completed in 3704236ms
    8772 http fetch GET 200 https://registry.npmjs.org/istanbul-reports/-/istanbul-reports-3.0.2.tgz 3638135ms (cache miss)
    8773 http fetch GET 200 https://registry.npmjs.org/tsutils/-/tsutils-3.20.0.tgz 3639072ms (cache miss)
    8774 http fetch GET 200 https://registry.npmjs.org/typedoc-plugin-markdown/-/typedoc-plugin-markdown-3.6.0.tgz 3594928ms (cache miss)
    8775 http fetch GET 200 https://registry.npmjs.org/tsutils/-/tsutils-3.20.0.tgz 3650464ms (cache miss)
    8776 timing reifyNode:node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown Completed in 3733272ms
    8777 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/tsutils Completed in 3734285ms
    8778 timing reifyNode:node_modules/zigbee-herdsman/node_modules/istanbul-reports Completed in 3734071ms
    8779 timing reifyNode:node_modules/zigbee-herdsman/node_modules/tsutils Completed in 3734318ms
    8780 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown Completed in 3735327ms
    8781 http fetch GET 200 https://registry.npmjs.org/istanbul-reports/-/istanbul-reports-3.0.2.tgz 3640789ms (cache miss)
    8782 http fetch GET 200 https://registry.npmjs.org/istanbul-reports/-/istanbul-reports-3.0.2.tgz 3641061ms (cache miss)
    8783 http fetch GET 200 https://registry.npmjs.org/tsutils/-/tsutils-3.21.0.tgz 3656233ms (cache miss)
    8784 http fetch GET 200 https://registry.npmjs.org/@nodelib/fs.walk/-/fs.walk-1.2.6.tgz 3677064ms (cache miss)
    8785 http fetch GET 200 https://registry.npmjs.org/@nodelib/fs.walk/-/fs.walk-1.2.6.tgz 3672177ms (cache miss)
    8786 http fetch GET 200 https://registry.npmjs.org/@types/node/-/node-15.6.0.tgz 3740091ms (cache miss)
    8787 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/tsutils Completed in 3755164ms
    8788 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/istanbul-reports Completed in 3755152ms
    8789 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/istanbul-reports Completed in 3755200ms
    8790 http fetch GET 200 https://registry.npmjs.org/@nodelib/fs.walk/-/fs.walk-1.2.6.tgz 3661439ms (cache miss)
    8791 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@nodelib/fs.walk Completed in 3758655ms
    8792 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@nodelib/fs.walk Completed in 3770430ms
    8793 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@types/node Completed in 3771918ms
    8794 http fetch GET 200 https://registry.npmjs.org/neo-async/-/neo-async-2.6.2.tgz 3756839ms (cache miss)
    8795 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@nodelib/fs.walk Completed in 3788793ms
    8796 http fetch GET 200 https://registry.npmjs.org/neo-async/-/neo-async-2.6.2.tgz 3771119ms (cache miss)
    8797 http fetch GET 200 https://registry.npmjs.org/eslint-plugin-jest/-/eslint-plugin-jest-24.3.6.tgz 3694549ms (cache miss)
    8798 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/typescript-estree/-/typescript-estree-4.16.1.tgz 3722171ms (cache miss)
    8799 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/neo-async Completed in 3804454ms
    8800 http fetch GET 200 https://registry.npmjs.org/@babel/parser/-/parser-7.13.9.tgz 3725525ms (cache miss)
    8801 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/parser Completed in 3804664ms
    8802 timing reifyNode:node_modules/zigbee-herdsman/node_modules/neo-async Completed in 3804269ms
    8803 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/typescript-estree/-/typescript-estree-4.16.1.tgz 3726248ms (cache miss)
    8804 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/typescript-estree/-/typescript-estree-4.24.0.tgz 3727983ms (cache miss)
    8805 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest Completed in 3805164ms
    8806 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@typescript-eslint/typescript-estree Completed in 3805395ms
    8807 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/typescript-estree Completed in 3807852ms
    8808 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@typescript-eslint/typescript-estree Completed in 3808283ms
    8809 http fetch GET 200 https://registry.npmjs.org/uri-js/-/uri-js-4.4.1.tgz 3523768ms attempt #3 (cache miss)
    8810 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/uri-js Completed in 3843200ms
    8811 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller/-/iobroker.js-controller-4.0.23.tgz 3896421ms (cache miss)
    8812 timing reifyNode:node_modules/iobroker.js-controller Completed in 3907687ms
    8813 http fetch GET 200 https://registry.npmjs.org/lunr/-/lunr-2.3.9.tgz 3848416ms (cache miss)
    8814 timing reifyNode:node_modules/zigbee-herdsman/node_modules/lunr Completed in 3921534ms
    8815 http fetch GET 200 https://registry.npmjs.org/lunr/-/lunr-2.3.9.tgz 3830698ms (cache miss)
    8816 http fetch GET 200 https://registry.npmjs.org/@babel/runtime/-/runtime-7.13.9.tgz 3905178ms (cache miss)
    8817 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/lunr Completed in 3922689ms
    8818 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@babel/runtime Completed in 3922413ms
    8819 http fetch GET 200 https://registry.npmjs.org/readline/-/readline-1.3.0.tgz 3937808ms (cache miss)
    8820 timing reifyNode:node_modules/readline Completed in 3948888ms
    8821 http fetch GET 200 https://registry.npmjs.org/@babel/runtime/-/runtime-7.13.9.tgz 3872623ms (cache miss)
    8822 http fetch GET 200 https://registry.npmjs.org/resolve/-/resolve-1.20.0.tgz 3959346ms (cache miss)
    8823 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/runtime Completed in 3975156ms
    8824 http fetch GET 200 https://registry.npmjs.org/resolve/-/resolve-1.20.0.tgz 3957748ms (cache miss)
    8825 http fetch GET 200 https://registry.npmjs.org/ajv/-/ajv-6.12.6.tgz 3894149ms (cache miss)
    8826 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/ajv Completed in 3975219ms
    8827 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/resolve Completed in 3975672ms
    8828 http fetch GET 200 https://registry.npmjs.org/ajv/-/ajv-6.12.6.tgz 3894546ms (cache miss)
    8829 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/ajv Completed in 3975909ms
    8830 timing reifyNode:node_modules/zigbee-herdsman/node_modules/resolve Completed in 3975617ms
    8831 http fetch GET 200 https://registry.npmjs.org/ajv/-/ajv-6.12.6.tgz 3891090ms (cache miss)
    8832 timing reifyNode:node_modules/zigbee-herdsman/node_modules/ajv Completed in 3975539ms
    8833 http fetch GET 200 https://registry.npmjs.org/@sentry/core/-/core-6.19.7.tgz 3964935ms (cache miss)
    8834 timing reifyNode:node_modules/@sentry/core Completed in 4013880ms
    8835 http fetch GET 200 https://registry.npmjs.org/async/-/async-3.2.4.tgz 4024232ms (cache miss)
    8836 timing reifyNode:node_modules/winston/node_modules/async Completed in 4036352ms
    8837 http fetch GET 200 https://registry.npmjs.org/typedoc-default-themes/-/typedoc-default-themes-0.12.7.tgz 3978471ms (cache miss)
    8838 timing reifyNode:node_modules/zigbee-herdsman/node_modules/typedoc-default-themes Completed in 4072742ms
    8839 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/resolve Completed in 4073323ms
    8840 http fetch GET 200 https://registry.npmjs.org/node-forge/-/node-forge-1.3.1.tgz 4063711ms (cache miss)
    8841 timing reifyNode:node_modules/node-forge Completed in 4074933ms
    8842 http fetch GET 200 https://registry.npmjs.org/typedoc-default-themes/-/typedoc-default-themes-0.12.7.tgz 3561606ms attempt #2 (cache miss)
    8843 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-default-themes Completed in 4095239ms
    8844 http fetch GET 200 https://registry.npmjs.org/@babel/types/-/types-7.14.2.tgz 4116017ms (cache miss)
    8845 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@babel/types Completed in 4195659ms
    8846 http fetch GET 200 https://registry.npmjs.org/@babel/types/-/types-7.13.0.tgz 4113322ms (cache miss)
    8847 http fetch GET 200 https://registry.npmjs.org/@babel/types/-/types-7.13.0.tgz 4101934ms (cache miss)
    8848 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@babel/types Completed in 4232126ms
    8849 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/types Completed in 4232501ms
    8850 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/experimental-utils/-/experimental-utils-4.16.1.tgz 4223226ms (cache miss)
    8851 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/experimental-utils Completed in 4332302ms
    8852 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/experimental-utils/-/experimental-utils-4.24.0.tgz 4255778ms (cache miss)
    8853 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/experimental-utils/-/experimental-utils-4.16.1.tgz 4251648ms (cache miss)
    8854 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@typescript-eslint/experimental-utils Completed in 4334657ms
    8855 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@typescript-eslint/experimental-utils Completed in 4335118ms
    8856 http fetch GET 200 https://registry.npmjs.org/@sentry/node/-/node-6.19.7.tgz 4524409ms (cache miss)
    8857 timing reifyNode:node_modules/@sentry/node Completed in 4555102ms
    8858 http fetch GET 200 https://registry.npmjs.org/@sentry/utils/-/utils-6.19.7.tgz 4623484ms (cache miss)
    8859 timing reifyNode:node_modules/@sentry/utils Completed in 4637289ms
    8860 http fetch GET 200 https://registry.npmjs.org/handlebars/-/handlebars-4.7.7.tgz 4544284ms (cache miss)
    8861 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/handlebars Completed in 4658844ms
    8862 http fetch GET 200 https://registry.npmjs.org/handlebars/-/handlebars-4.7.7.tgz 4574393ms (cache miss)
    8863 timing reifyNode:node_modules/zigbee-herdsman/node_modules/handlebars Completed in 4660143ms
    8864 http fetch GET 200 https://registry.npmjs.org/@sentry/types/-/types-6.19.7.tgz 4736372ms (cache miss)
    8865 timing reifyNode:node_modules/@sentry/types Completed in 4747935ms
    8866 http fetch GET 200 https://registry.npmjs.org/regenerate-unicode-properties/-/regenerate-unicode-properties-8.2.0.tgz 4709722ms (cache miss)
    8867 http fetch GET 200 https://registry.npmjs.org/regenerate-unicode-properties/-/regenerate-unicode-properties-8.2.0.tgz 4705903ms (cache miss)
    8868 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/regenerate-unicode-properties Completed in 4789878ms
    8869 timing reifyNode:node_modules/zigbee-herdsman/node_modules/regenerate-unicode-properties Completed in 4789505ms
    8870 http fetch GET 200 https://registry.npmjs.org/node-notifier/-/node-notifier-8.0.1.tgz 4775243ms (cache miss)
    8871 timing reifyNode:node_modules/zigbee-herdsman/node_modules/node-notifier Completed in 4862163ms
    8872 http fetch GET 200 https://registry.npmjs.org/node-notifier/-/node-notifier-8.0.2.tgz 4782227ms (cache miss)
    8873 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/node-notifier Completed in 4863174ms
    8874 http fetch GET 200 https://registry.npmjs.org/typedoc/-/typedoc-0.20.28.tgz 4837080ms (cache miss)
    8875 timing reifyNode:node_modules/zigbee-herdsman/node_modules/typedoc Completed in 4920051ms
    8876 http fetch GET 200 https://registry.npmjs.org/node-notifier/-/node-notifier-8.0.1.tgz 4537954ms attempt #2 (cache miss)
    8877 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/node-notifier Completed in 4921518ms
    8878 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/scope-manager/-/scope-manager-4.16.1.tgz 4827526ms (cache miss)
    8879 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/scope-manager/-/scope-manager-4.16.1.tgz 4839555ms (cache miss)
    8880 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/scope-manager/-/scope-manager-4.24.0.tgz 4844852ms (cache miss)
    8881 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/scope-manager Completed in 4922202ms
    8882 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@typescript-eslint/scope-manager Completed in 4921947ms
    8883 http fetch GET 200 https://registry.npmjs.org/ajv/-/ajv-7.1.1.tgz 4784208ms (cache miss)
    8884 http fetch GET 200 https://registry.npmjs.org/ajv/-/ajv-7.1.1.tgz 4839687ms (cache miss)
    8885 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/@typescript-eslint/scope-manager Completed in 4923051ms
    8886 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/table/node_modules/ajv Completed in 4922939ms
    8887 timing reifyNode:node_modules/zigbee-herdsman/node_modules/table/node_modules/ajv Completed in 4922779ms
    8888 http fetch GET 200 https://registry.npmjs.org/typedoc/-/typedoc-0.20.28.tgz 4033194ms (cache miss)
    8889 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc Completed in 4976190ms
    8890 http fetch GET 200 https://registry.npmjs.org/shiki/-/shiki-0.9.2.tgz 4950447ms (cache miss)
    8891 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/shiki Completed in 5029737ms
    8892 http fetch GET 200 https://registry.npmjs.org/ajv/-/ajv-8.5.0.tgz 4956575ms (cache miss)
    8893 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/table/node_modules/ajv Completed in 5051368ms
    8894 http fetch GET 200 https://registry.npmjs.org/shiki/-/shiki-0.9.2.tgz 4969002ms (cache miss)
    8895 timing reifyNode:node_modules/zigbee-herdsman/node_modules/shiki Completed in 5051689ms
    8896 http fetch GET 200 https://registry.npmjs.org/@sentry/integrations/-/integrations-6.19.7.tgz 5067614ms (cache miss)
    8897 timing reifyNode:node_modules/@sentry/integrations Completed in 5079627ms
    8898 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/eslint-plugin/-/eslint-plugin-4.16.1.tgz 4998193ms (cache miss)
    8899 timing reifyNode:node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin Completed in 5081888ms
    8900 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint/eslint-plugin/-/eslint-plugin-4.16.1.tgz 5010906ms (cache miss)
    8901 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin Completed in 5105781ms
    8902 http fetch GET 200 https://registry.npmjs.org/eslint/-/eslint-7.27.0.tgz 5143451ms (cache miss)
    8903 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/eslint Completed in 5237919ms
    8904 http fetch GET 200 https://registry.npmjs.org/eslint/-/eslint-7.21.0.tgz 5143334ms (cache miss)
    8905 timing reifyNode:node_modules/zigbee-herdsman/node_modules/eslint Completed in 5237628ms
    8906 http fetch GET 200 https://registry.npmjs.org/eslint/-/eslint-7.21.0.tgz 5099730ms (cache miss)
    8907 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint Completed in 5238086ms
    8908 http fetch GET 200 https://registry.npmjs.org/jsdom/-/jsdom-16.4.0.tgz 5101364ms (cache miss)
    8909 timing reifyNode:node_modules/zigbee-herdsman/node_modules/jsdom Completed in 5239485ms
    8910 http fetch GET 200 https://registry.npmjs.org/jsdom/-/jsdom-16.5.3.tgz 5110257ms (cache miss)
    8911 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/jsdom Completed in 5248584ms
    8912 http fetch GET 200 https://registry.npmjs.org/jsdom/-/jsdom-16.4.0.tgz 4870098ms attempt #2 (cache miss)
    8913 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jsdom Completed in 5253248ms
    8914 http fetch GET 200 https://registry.npmjs.org/caniuse-lite/-/caniuse-lite-1.0.30001194.tgz 5232059ms (cache miss)
    8915 http fetch GET 200 https://registry.npmjs.org/zigbee-herdsman/-/zigbee-herdsman-0.13.107.tgz 4538470ms attempt #2 (cache miss)
    8916 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/caniuse-lite Completed in 5326630ms
    8917 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman Completed in 5327140ms
    8918 http fetch GET 200 https://registry.npmjs.org/caniuse-lite/-/caniuse-lite-1.0.30001228.tgz 5259946ms (cache miss)
    8919 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/caniuse-lite Completed in 5341178ms
    8920 http fetch GET 200 https://registry.npmjs.org/caniuse-lite/-/caniuse-lite-1.0.30001194.tgz 5310945ms (cache miss)
    8921 timing reifyNode:node_modules/zigbee-herdsman/node_modules/caniuse-lite Completed in 5340881ms
    8922 http fetch GET 200 https://registry.npmjs.org/moment/-/moment-2.29.4.tgz 5329828ms (cache miss)
    8923 timing reifyNode:node_modules/moment Completed in 5341246ms
    8924 http fetch GET 200 https://registry.npmjs.org/lodash/-/lodash-4.17.21.tgz 5296939ms (cache miss)
    8925 timing reifyNode:node_modules/zigbee-herdsman/node_modules/lodash Completed in 5380639ms
    8926 http fetch GET 200 https://registry.npmjs.org/lodash/-/lodash-4.17.21.tgz 5302941ms (cache miss)
    8927 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/lodash Completed in 5383131ms
    8928 http fetch GET 200 https://registry.npmjs.org/lodash/-/lodash-4.17.21.tgz 5302495ms (cache miss)
    8929 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/lodash Completed in 5383061ms
    8930 http fetch GET 200 https://registry.npmjs.org/typescript/-/typescript-4.2.2.tgz 5601705ms (cache miss)
    8931 timing reifyNode:node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript Completed in 5740092ms
    8932 http fetch GET 200 https://registry.npmjs.org/typescript/-/typescript-4.2.2.tgz 5669990ms (cache miss)
    8933 timing reifyNode:node_modules/zigbee-herdsman/node_modules/typescript Completed in 5739785ms
    8934 timing reify:unpack Completed in 5740378ms
    8935 timing command:install Completed in 5798550ms
    8936 verbose stack TypeError [ERR_INVALID_ARG_TYPE]: The "from" argument must be of type string. Received undefined
    8936 verbose stack     at new NodeError (node:internal/errors:387:5)
    8936 verbose stack     at validateString (node:internal/validators:162:11)
    8936 verbose stack     at relative (node:path:1191:5)
    8936 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:1075:21
    8936 verbose stack     at Array.map (<anonymous>)
    8936 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:1073:66
    8936 verbose stack     at Arborist.[rollbackMoveBackRetiredUnchanged] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:1073:8)
    8936 verbose stack     at Arborist.[reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:236:31)
    8936 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:155:5)
    8937 verbose cwd /opt/iobroker
    8938 verbose Linux 5.10.103-v7+
    8939 verbose node v16.18.0
    8940 verbose npm  v8.19.2
    8941 error code ERR_INVALID_ARG_TYPE
    8942 error The "from" argument must be of type string. Received undefined
    8943 verbose exit 1
    8944 timing npm Completed in 5799416ms
    8945 verbose unfinished npm timer reify 1667502002981
    8946 verbose unfinished npm timer reify:unretire 1667507801468
    8947 verbose code 1
    8948 error A complete log of this run can be found in:
    8948 error     /home/iobroker/.npm/_logs/2022-11-03T19_00_02_134Z-debug-0.log
    • portyP porty
       throw err;
      Require stack:
      8943 verbose exit 1
      8947 verbose code 1
      @porty
      Keine Ahnung.
      portyP 1 Antwort Letzte Antwort
        @porty
        Keine Ahnung.
        portyP Offline
        portyP Offline
        porty
        Ich danke dir für deine Mühe und deinen Einsatz! 🤝
        Habe den Slave nun einfach neu aufgesetzt. Laufen nur wenige Instanzen drauf. Hätte ich das sofort gemacht wäre ich wahrscheinlich schneller gewesen aber ... :)
