  4. Hm-rpc: Meldungen im Log "Send this Info to developer"
1 Beiträge 1 Kommentatoren 512 Aufrufe
  • GoerschG Offline
    GoerschG Offline
    Goersch
    hab hier ein paar Ausgaben im Log mit dem Vermerkt "Send this Info to developer" - was ich hoffentlich hiermit tue:
    ! 2017-05-02 14:10:57.448 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"DEVICE_IN_BOOTLOADER":{"DEFAULT":false,"FLAGS":9,"ID":"DEVICE_IN_BOOTLOADER","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":7,"TYPE":"BOOL","UNIT":""},"DUTYCYCLE":{"DEFAULT":false,"FLAGS":9,"ID":"DUTYCYCLE","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"BOOL","UNIT":""},"LOWBAT":{"DEFAULT":false,"FLAGS":9,"ID":"LOWBAT","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"RSSI_DEVICE":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"RSSI_PEER":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":6,"TYPE":"INTEGER","UNIT":""},"STICKY_UNREACH":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"UNREACH":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"UPDATE_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"UPDATE_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":8,"TYPE":"BOOL","UNIT":""}}} 2017-05-02 14:10:57.559 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-Sec-SD.SMOKE_DETECTOR.10" 2017-05-02 14:10:57.560 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":1,"TYPE":"ACTION","UNIT":""},"STATE":{"CONTROL":"DANGER.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""}}} 2017-05-02 14:10:58.069 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-CC-RT-DN.MAINTENANCE.29" 2017-05-02 14:10:58.070 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"AES_KEY":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATIONS":1,"TAB_ORDER":9,"TYPE":"INTEGER","UNIT":""},"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"DEVICE_IN_BOOTLOADER":{"DEFAULT":false,"FLAGS":9,"ID":"DEVICE_IN_BOOTLOADER","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":7,"TYPE":"BOOL","UNIT":""},"INHIBIT":{"CONTROL":"NONE","DEFAULT":false,"FLAGS":1,"ID":"INHIBIT","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":6,"TYPE":"BOOL","UNIT":""},"LOWBAT":{"DEFAULT":false,"FLAGS":9,"ID":"LOWBAT","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"RSSI_DEVICE":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"INTEGER","UNIT":""},"RSSI_PEER":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"STICKY_UNREACH":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"UNREACH":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"UPDATE_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"UPDATE_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":8,"TYPE":"BOOL","UNIT":""}}} 2017-05-02 14:10:58.426 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-CC-RT-DN.CLIMATECONTROL_RT_TRANSCEIVER.29" 2017-05-02 14:10:58.427 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"ACTUAL_TEMPERATURE":{"CONTROL":"HEATING_CONTROL.TEMPERATURE","DEFAULT":0,"FLAGS":1,"ID":"ACTUAL_TEMPERATURE","MAX":56,"MIN":-10,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"FLOAT","UNIT":"?C"},"AUTO_MODE":{"CONTROL":"HEATING_CONTROL.AUTO","DEFAULT":false,"FLAGS":1,"ID":"AUTO_MODE","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":7,"TYPE":"ACTION","UNIT":""},"BATTERY_STATE":{"CONTROL":"NONE","DEFAULT":0,"FLAGS":1,"ID":"BATTERY_STATE","MAX":4.6,"MIN":1.5,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"FLOAT","UNIT":"V"},"BOOST_MODE":{"CONTROL":"HEATING_CONTROL.BOOST","DEFAULT":false,"FLAGS":1,"ID":"BOOST_MODE","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":9,"TYPE":"ACTION","UNIT":""},"BOOST_STATE":{"CONTROL":"NONE","DEFAULT":0,"FLAGS":1,"ID":"BOOST_STATE","MAX":30,"MIN":0,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"INTEGER","UNIT":"min"},"COMFORT_MODE":{"CONTROL":"HEATING_CONTROL.COMFORT","DEFAULT":false,"FLAGS":1,"ID":"COMFORT_MODE","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":10,"TYPE":"ACTION","UNIT":""},"CONTROL_MODE":{"CONTROL":"HEATING_CONTROL.CONTROL_MODE","DEFAULT":0,"FLAGS":1,"ID":"CONTROL_MODE","MAX":3,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"ENUM","UNIT":"","VALUE_LIST":["AUTO-MODE","MANU-MODE","PARTY-MODE","BOOST-MODE"]},"FAULT_REPORTING":{"CONTROL":"NONE","DEFAULT":0,"FLAGS":9,"ID":"FAULT_REPORTING","MAX":7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":1,"TYPE":"ENUM","UNIT":"","VALUE_LIST":["NO_FAULT","VALVE_TIGHT","ADJUSTING_RANGE_TOO_LARGE","ADJUSTING_RANGE_TOO_SMALL","COMMUNICATION_ERROR","","LOWBAT","VALVE_ERROR_POSITION"]},"LOWERING_MODE":{"CONTROL":"HEATING_CONTROL.LOWERING","DEFAULT":false,"FLAGS":1,"ID":"LOWERING_MODE","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":11,"TYPE":"ACTION","UNIT":""},"MANU_MODE":{"CONTROL":"HEATING_CONTROL.MANU","DEFAULT":20,"FLAGS":1,"ID":"MANU_MODE","MAX":30.5,"MIN":4.5,"OPERATIONS":2,"TAB_ORDER":8,"TYPE":"FLOAT","UNIT":"?C"},"PARTY_MODE_SUBMIT":{"CONTROL":"NONE","DEFAULT":"","FLAGS":1,"ID":"PARTY_MODE_SUBMIT","MAX":"","MIN":"","OPERATIONS":2,"TAB_ORDER":12,"TYPE":"STRING","UNIT":""},"PARTY_START_DAY":{"CONTROL":"HEATING_CONTROL.PARTY_START_DAY","DEFAULT":1,"FLAGS":1,"ID":"PARTY_START_DAY","MAX":31,"MIN":1,"OPERATIONS":3,"TAB_ORDER":15,"TYPE":"INTEGER","UNIT":"day"},"PARTY_START_MONTH":{"CONTROL":"HEATING_CONTROL.PARTY_START_MONTH","DEFAULT":1,"FLAGS":1,"ID":"PARTY_START_MONTH","MAX":12,"MIN":1,"OPERATIONS":3,"TAB_ORDER":16,"TYPE":"INTEGER","UNIT":"month"},"PARTY_START_TIME":{"CONTROL":"HEATING_CONTROL.PARTY_START_TIME","DEFAULT":0,"FLAGS":1,"ID":"PARTY_START_TIME","MAX":1410,"MIN":0,"OPERATIONS":3,"TAB_ORDER":14,"TYPE":"INTEGER","UNIT":"minutes"},"PARTY_START_YEAR":{"CONTROL":"HEATING_CONTROL.PARTY_START_YEAR","DEFAULT":12,"FLAGS":1,"ID":"PARTY_START_YEAR","MAX":99,"MIN":0,"OPERATIONS":3,"TAB_ORDER":17,"TYPE":"INTEGER","UNIT":"year"},"PARTY_STOP_DAY":{"CONTROL":"HEATING_CONTROL.PARTY_STOP_DAY","DEFAULT":1,"FLAGS":1,"ID":"PARTY_STOP_DAY","MAX":31,"MIN":1,"OPERATIONS":3,"TAB_ORDER":19,"TYPE":"INTEGER","UNIT":"day"},"PARTY_STOP_MONTH":{"CONTROL":"HEATING_CONTROL.PARTY_STOP_MONTH","DEFAULT":1,"FLAGS":1,"ID":"PARTY_STOP_MONTH","MAX":12,"MIN":1,"OPERATIONS":3,"TAB_ORDER":20,"TYPE":"INTEGER","UNIT":"month"},"PARTY_STOP_TIME":{"CONTROL":"HEATING_CONTROL.PARTY_STOP_TIME","DEFAULT":0,"FLAGS":1,"ID":"PARTY_STOP_TIME","MAX":1410,"MIN":0,"OPERATIONS":3,"TAB_ORDER":18,"TYPE":"INTEGER","UNIT":"minutes"},"PARTY_STOP_YEAR":{"CONTROL":"HEATING_CONTROL.PARTY_STOP_YEAR","DEFAULT":12,"FLAGS":1,"ID":"PARTY_STOP_YEAR","MAX":99,"MIN":0,"OPERATIONS":3,"TAB_ORDER":21,"TYPE":"INTEGER","UNIT":"year"},"PARTY_TEMPERATURE":{"CONTROL":"HEATING_CONTROL.PARTY_TEMP","DEFAULT":20,"FLAGS":1,"ID":"PARTY_TEMPERATURE","MAX":30,"MIN":5,"OPERATIONS":3,"TAB_ORDER":13,"TYPE":"FLOAT","UNIT":"?C"},"SET_TEMPERATURE":{"CONTROL":"HEATING_CONTROL.SETPOINT","DEFAULT":20,"FLAGS":1,"ID":"SET_TEMPERATURE","MAX":30.5,"MIN":4.5,"OPERATIONS":7,"TAB_ORDER":6,"TYPE":"FLOAT","UNIT":"?C"},"VALVE_STATE":{"CONTROL":"NONE","DEFAULT":0,"FLAGS":1,"ID":"VALVE_STATE","MAX":99,"MIN":0,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"INTEGER","UNIT":"%"}}} 2017-05-02 14:10:59.514 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-Sen-MDIR-O-2.MAINTENANCE.12" 2017-05-02 14:10:59.515 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"AES_KEY":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATIONS":1,"TAB_ORDER":8,"TYPE":"INTEGER","UNIT":""},"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"DEVICE_IN_BOOTLOADER":{"DEFAULT":false,"FLAGS":9,"ID":"DEVICE_IN_BOOTLOADER","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":6,"TYPE":"BOOL","UNIT":""},"ENTER_BOOTLOADER":{"DEFAULT":false,"FLAGS":3,"ID":"ENTER_BOOTLOADER","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":9,"TYPE":"ACTION","UNIT":""},"LOWBAT":{"DEFAULT":false,"FLAGS":9,"ID":"LOWBAT","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"RSSI_DEVICE":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"INTEGER","UNIT":""},"RSSI_PEER":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"STICKY_UNREACH":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"UNREACH":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"UPDATE_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"UPDATE_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":7,"TYPE":"BOOL","UNIT":""}}} 2017-05-02 14:10:59.613 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-Sen-MDIR-O-2.MOTION_DETECTOR.12" 2017-05-02 14:10:59.613 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"BRIGHTNESS":{"DEFAULT":0,"FLAGS":1,"ID":"BRIGHTNESS","MAX":255,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"INTEGER","UNIT":""},"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":3,"TYPE":"ACTION","UNIT":""},"MOTION":{"DEFAULT":false,"FLAGS":1,"ID":"MOTION","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""}}} 2017-05-02 14:11:00.169 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-LC-Sw2-FM.MAINTENANCE.26" 2017-05-02 14:11:00.170 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"AES_KEY":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATIONS":1,"TAB_ORDER":7,"TYPE":"INTEGER","UNIT":""},"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"DUTYCYCLE":{"DEFAULT":false,"FLAGS":9,"ID":"DUTYCYCLE","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"BOOL","UNIT":""},"LOWBAT":{"DEFAULT":false,"FLAGS":9,"ID":"LOWBAT","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"RSSI_DEVICE":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"RSSI_PEER":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":6,"TYPE":"INTEGER","UNIT":""},"STICKY_UNREACH":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"UNREACH":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""}}} 2017-05-02 14:11:00.280 - [33mwarn[39m: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-LC-Sw2-FM.SWITCH.26" 2017-05-02 14:11:00.281 - [33mwarn[39m: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INHIBIT":{"CONTROL":"NONE","DEFAULT":false,"FLAGS":1,"ID":"INHIBIT","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":3,"TYPE":"ACTION","UNIT":""},"ON_TIME":{"CONTROL":"NONE","DEFAULT":0,"FLAGS":1,"ID":"ON_TIME","MAX":85825945.5,"MIN":0,"OPERATIONS":2,"TAB_ORDER":1,"TYPE":"FLOAT","UNIT":"s"},"STATE":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"WORKING":{"DEFAULT":false,"FLAGS":3,"ID":"WORKING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"BOOL","UNIT":""}}} !
    ! 2017-05-02 14:11:03.201 - [31merror[39m: hm-rega.0 <-- invalid response: 2017-05-02 14:11:03.202 - [31merror[39m: hm-rega.0 "\r\n\r\n\t<title>HomeMatic</title>\r\n \r\n \r\n \r\n \r\n \r\n \r\n\r\n \r\n \r\n\r\n\r\n \r\n\r\n \r\n ! # ${ccuNotReady} ! \r\n ! ${ccuNotReadyHint} ! \r\n \r\n \r\n ![\"\"/](\"/ise/img/hm-logo.png\")\r\n \r\n\r\n\r\n\r\n\r\n ! <noscript>\r\n <div align=\"center\">\r\n <!-- <p>Um die HomeMatic WebUI nutzen zu k&ouml;nnen, muss JavaScript in Ihrem Browser aktiviert sein.</p> -->\r\n <p>Please activate JavaScript in your browser</p>\r\n </div>\r\n</noscript> ! \r\n \r\n\r\n\r\n" 2017-05-02 14:11:03.202 - [31merror[39m: hm-rega.0 Cannot parse answer for devices: 2017-05-02 14:11:05.477 - [31merror[39m: hm-rega.0 <-- invalid response: 2017-05-02 14:11:05.478 - [31merror[39m: hm-rega.0 "\r\n\r\n\t<title>HomeMatic</title>\r\n \r\n \r\n \r\n \r\n \r\n \r\n\r\n \r\n \r\n\r\n\r\n \r\n\r\n \r\n ! # ${ccuNotReady} ! \r\n ! ${ccuNotReadyHint} ! \r\n \r\n \r\n ![\"\"/](\"/ise/img/hm-logo.png\")\r\n \r\n\r\n\r\n\r\n\r\n ! <noscript>\r\n <div align=\"center\">\r\n <!-- <p>Um die HomeMatic WebUI nutzen zu k&ouml;nnen, muss JavaScript in Ihrem Browser aktiviert sein.</p> -->\r\n <p>Please activate JavaScript in your browser</p>\r\n </div>\r\n</noscript> ! \r\n \r\n\r\n\r\n" 2017-05-02 14:11:35.481 - [31merror[39m: hm-rega.0 <-- invalid response: 2017-05-02 14:11:35.482 - [31merror[39m: hm-rega.0 "\r\n\r\n\t<title>HomeMatic</title>\r\n \r\n \r\n \r\n \r\n \r\n \r\n\r\n \r\n \r\n\r\n\r\n \r\n\r\n \r\n ! # ${ccuNotReady} ! \r\n ! ${ccuNotReadyHint} ! \r\n \r\n \r\n ![\"\"/](\"/ise/img/hm-logo.png\")\r\n \r\n\r\n\r\n\r\n\r\n ! <noscript>\r\n <div align=\"center\">\r\n <!-- <p>Um die HomeMatic WebUI nutzen zu k&ouml;nnen, muss JavaScript in Ihrem Browser aktiviert sein.</p> -->\r\n <p>Please activate JavaScript in your browser</p>\r\n </div>\r\n</noscript> ! \r\n \r\n\r\n\r\n" 2017-05-02 14:11:37.708 - [31merror[39m: hm-rega.0 <-- invalid response: 2017-05-02 14:11:37.709 - [31merror[39m: hm-rega.0 "\r\n\r\n\t<title>HomeMatic</title>\r\n \r\n \r\n \r\n \r\n \r\n \r\n\r\n \r\n \r\n\r\n\r\n \r\n\r\n \r\n ! # ${ccuNotReady} ! \r\n ! ${ccuNotReadyHint} ! \r\n \r\n \r\n ![\"\"/](\"/ise/img/hm-logo.png\")\r\n \r\n\r\n\r\n\r\n\r\n ! <noscript>\r\n <div align=\"center\">\r\n <!-- <p>Um die HomeMatic WebUI nutzen zu k&ouml;nnen, muss JavaScript in Ihrem Browser aktiviert sein.</p> -->\r\n <p>Please activate JavaScript in your browser</p>\r\n </div>\r\n</noscript> ! \r\n \r\n\r\n\r\n" 2017-05-02 14:11:37.710 - [31merror[39m: hm-rega.0 Cannot parse answer for devices: 2017-05-02 14:12:05.495 - [31merror[39m: hm-rega.0 <-- invalid response: 2017-05-02 14:12:05.496 - [31merror[39m: hm-rega.0 "\r\n\r\n\t<title>HomeMatic</title>\r\n \r\n \r\n \r\n \r\n \r\n \r\n\r\n \r\n \r\n\r\n\r\n \r\n\r\n \r\n ! # ${ccuNotReady} ! \r\n ! ${ccuNotReadyHint} ! \r\n \r\n \r\n ![\"\"/](\"/ise/img/hm-logo.png\")\r\n \r\n\r\n\r\n\r\n\r\n ! <noscript>\r\n <div align=\"center\">\r\n <!-- <p>Um die HomeMatic WebUI nutzen zu k&ouml;nnen, muss JavaScript in Ihrem Browser aktiviert sein.</p> -->\r\n <p>Please activate JavaScript in your browser</p>\r\n </div>\r\n</noscript> ! \r\n \r\n\r\n\r\n" 2017-05-02 14:12:35.495 - [31merror[39m: hm-rega.0 <-- invalid response: 2017-05-02 14:12:35.505 - [31merror[39m: hm-rega.0 "\r\n\r\n\t<title>HomeMatic</title>\r\n \r\n \r\n \r\n \r\n \r\n \r\n\r\n \r\n \r\n\r\n\r\n \r\n\r\n \r\n ! # ${ccuNotReady} ! \r\n ! ${ccuNotReadyHint} ! \r\n \r\n \r\n ![\"\"/](\"/ise/img/hm-logo.png\")\r\n \r\n\r\n\r\n\r\n\r\n ! <noscript>\r\n <div align=\"center\">\r\n <!-- <p>Um die HomeMatic WebUI nutzen zu k&ouml;nnen, muss JavaScript in Ihrem Browser aktiviert sein.</p> -->\r\n <p>Please activate JavaScript in your browser</p>\r\n </div>\r\n</noscript> ! \r\n \r\n\r\n\r\n" 2017-05-02 14:13:05.536 - [31merror[39m: hm-rega.0 <-- invalid response: 2017-05-02 14:13:05.537 - [31merror[39m: hm-rega.0 "\r\n\r\n\t<title>HomeMatic</title>\r\n \r\n \r\n \r\n \r\n \r\n \r\n\r\n \r\n \r\n\r\n\r\n \r\n\r\n \r\n ! # ${ccuNotReady} ! \r\n ! ${ccuNotReadyHint} ! \r\n \r\n \r\n ![\"\"/](\"/ise/img/hm-logo.png\")\r\n \r\n\r\n\r\n\r\n\r\n ! <noscript>\r\n <div align=\"center\">\r\n <!-- <p>Um die HomeMatic WebUI nutzen zu k&ouml;nnen, muss JavaScript in Ihrem Browser aktiviert sein.</p> -->\r\n <p>Please activate JavaScript in your browser</p>\r\n </div>\r\n</noscript> ! \r\n \r\n\r\n\r\n" 2017-05-02 14:13:35.501 - [31merror[39m: hm-rega.0 <-- invalid response: 2017-05-02 14:13:35.502 - [31merror[39m: hm-rega.0 "\r\n\r\n\t<title>HomeMatic</title>\r\n \r\n \r\n \r\n \r\n \r\n \r\n\r\n \r\n \r\n\r\n\r\n \r\n\r\n \r\n ! # ${ccuNotReady} ! \r\n ! ${ccuNotReadyHint} ! \r\n \r\n \r\n ![\"\"/](\"/ise/img/hm-logo.png\")\r\n \r\n\r\n\r\n\r\n\r\n ! <noscript>\r\n <div align=\"center\">\r\n <!-- <p>Um die HomeMatic WebUI nutzen zu k&ouml;nnen, muss JavaScript in Ihrem Browser aktiviert sein.</p> -->\r\n <p>Please activate JavaScript in your browser</p>\r\n </div>\r\n</noscript> ! \r\n \r\n\r\n\r\n" 2017-05-02 14:13:54.387 - [32minfo[39m: hm-rpc.0 setValue ["IEQ0104794:1","STATE",false] BOOL 2017-05-02 14:14:05.500 - [31merror[39m: hm-rega.0 <-- invalid response: !
    Meldungen sind nach Neustart der CCU gekommen (nach Update auf Firmware 2.27.8)
    Geändert: Quote-tags in code-tags: Homoran (Mod)
