  4. Node-red Adapter Installation funktioniert nicht
5 Beiträge 3 Kommentatoren 2.0k Aufrufe
  • F Offline
    Fonzo
    ich habe versucht unter Windows Server 2012 R2 den node-red Adapter von der Admin Console von ioBroker heraus zu installieren. Python 2.7 sowie Microsoft NET Framework 3.5 sowie NET Framework 4.5 sind als Features unter Windows Server 2012 installiert.
    Bei dem Versuch node-red Adapter zu installieren erscheint folgende Fehlermeldung:
    $ ./iobroker add node-red
    npm install iobroker.node-red --production --prefix "D:/ioBroker" (System call)
    gyp
    ERR! configure error
    gyp
     ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack     at failNoPython (D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:103:14)
    gyp ERR!
    stack     at D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:64:11gyp ERR! stack     at FSReqWrap.oncomplete (evalmachine.<anonymous>:99:15)
    gyp ERR! System Windows_NT 6.3.9600
    gyp ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\irc\node_modules\node-icu-charset-detector
    gyp ERR! node -v v0.11.16gyp ERR! node-gyp -v v1.0.2
    gyp ERR! not ok
    gyp
    gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack     at failNoPython (D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:103:14)
    gyp ERR! stack     at D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:64:11gyp ERR! stack     at FSReqWrap.oncomplete (evalmachine.<anonymous>:99:15)
    gyp ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\bcrypt
    gyp ERR! not ok
    npm
     WARN optional dep failed, continuing node-icu-charset-detector@0.0.7
    gyp
     stack     at failNoPython (D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:103:14)gyp ERR! stack     at D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:64:11
    gyp ERR! System Windows_NT 6.3.9600gyp ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\ws\node_modules\bufferutil
    gyp ERR! not ok
    npm
     WARN optional dep failed, continuing bcrypt@0.8.1
    gyp
    gyp ERR! stack     at failNoPython (D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:103:14)gyp ERR! stack     at D:\Programme\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:64:11
    gyp ERR! stack     at FSReqWrap.oncomplete (evalmachine.<anonymous>:99:15)gyp ERR! System Windows_NT 6.3.9600
    gyp ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\ws\node_modules\utf-8-validate
    gyp
     ERR! not ok
    npm
     WARN optional dep failed, continuing bufferutil@1.0.1
    npm
     WARN optional dep failed, continuing utf-8-validate@1.0.1
    gyp
    ERR!
    configure error gyp ERR!
     stack
    gyp
    ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\mongodb\\node_modules\\mongodb-core\\node_modules\\bson\\node_modules\\bson-ext\\build\\Release\\bson.node" "--module_name=bson" "--module_path=D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\mongodb\\node_modules\\mongodb-core\\node_modules\\bson\\node_modules\\bson-ext\\build\\Release"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext
    gyp ERR! not ok
    node-pre-gyp
    ERR! build error
    node-pre-gyp ERR! stack
     Error: Failed to execute 'node-gyp.cmd configure --fallback-to-build --module=D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext\build\Release\bson.node --module_name=bson --module_path=D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext\build\Release' (1)node-pre-gyp ERR!
    stack     at ChildProcess. <anonymous>(D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext\node_modules\node-pre-gyp\lib\util\compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:110:17)
    node-pre-gyp ERR! stack     at maybeClose (child_process.js:1008:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:1080:5)
    node-pre-gyp ERR! System Windows_NT 6.3.9600
    node-pre-gyp ERR! command "node" "D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\mongodb\\node_modules\\mongodb-core\\node_modules\\bson\\node_modules\\bson-ext\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp.js" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\mongodb\node_modules\mongodb-core\node_modules\bson\node_modules\bson-ext
    node-pre-gyp ERR! node -v v0.11.16
    node-pre-gyp ERR! node-pre-gyp -v v0.6.4
    node-pre-gyp ERR! not ok
    gyp
    gyp
    gyp
    ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\irc\node_modules\iconvgyp ERR! node -v v0.11.16
    gyp ERR! not ok
    child_process: customFds option is deprecated, use stdio instead.
    gyp
    gyp ERR!
     ERR! command "node" "D:\\Programme\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" "--name=serialport" "--configuration=Release" "--module_name=serialport" "--version=1.4.10" "--major=1" "--minor=4" "--patch=10" "--runtime=node" "--node_abi=node-v14" "--platform=win32" "--target_platform=win32" "--arch=x64" "--target_arch=x64" "--module_main=./serialport" "--host=https://node-serialport.s3.amazonaws.com/" "--module_path=D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\node-red\\node_modules\\serialport\\build\\serialport\\v1.4.10\\Release\\node-v14-win32-x64" "--remote_path=./serialport/v1.4.10/Release/" "--package_name=node-v14-win32-x64.tar.gz" "--staged_tarball=build\\stage\\serialport\\v1.4.10\\Release\\node-v14-win32-x64.tar.gz" "--hosted_path=https://node-serialport.s3.amazonaws.com/serialport/v1.4.10/Release/" "--hosted_tarball=https://node-serialport.s3.amazonaws.com/serialport/v1.4.10/Release/node-v14-win32-x64.tar.gz"gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport
    gyp ERR! not ok
    node-pre-gyp
     ERR! build error
    node-pre-gyp
     ERR! stack Error: Failed to execute 'node-gyp.cmd rebuild --name=serialport --configuration=Release --module_name=serialport --version=1.4.10 --major=1 --minor=4 --patch=10 --runtime=node --node_abi=node-v14 --platform=win32 --target_platform=win32 --arch=x64 --target_arch=x64 --module_main=./serialport --host=https://node-serialport.s3.amazonaws.com/ --module_path=D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v14-win32-x64 --remote_path=./serialport/v1.4.10/Release/ --package_name=node-v14-win32-x64.tar.gz --staged_tarball=build\stage\serialport\v1.4.10\Release\node-v14-win32-x64.tar.gz --hosted_path=https://node-serialport.s3.amazonaws.com/serialport/v1.4.10/Release/ --hosted_tarball=https://node-serialport.s3.amazonaws.com/serialport/v1.4.10/Release/node-v14-win32-x64.tar.gz' (1)node-pre-gyp
     ERR! stack     at ChildProcess. <anonymous>(D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\node_modules\node-pre-gyp\lib\util\compile.js:76:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:110:17)
    node-pre-gyp ERR! System Windows_NT 6.3.9600node-pre-gyp
     ERR! command "node" "D:\\ioBroker\\node_modules\\iobroker.node-red\\node_modules\\node-red\\node_modules\\serialport\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd D:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport
    node-pre-gyp ERR! node-pre-gyp -v v0.5.19
    npm
     WARN optional dep failed, continuing iconv@2.1.7
    npm
     ERR! Windows_NT 6.3.9600npm ERR! argv "D:\\Programme\\nodejs\\\\node.exe" "D:\\Programme\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.node-red" "--production" "--prefix" "D:/ioBroker"
    npm ERR! node v0.11.16
    npm ERR! npm  v2.3.0
    npm ERR! code ELIFECYCLE
    npm ERR! serialport@1.4.10 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the serialport@1.4.10 install script 'node-pre-gyp install --fallback-to-build'.
    npm ERR! This is most likely a problem with the serialport package,
    npm ERR! not with npm itself.
    npm ERR!
     Tell the author that this fails on your system:npm ERR!     node-pre-gyp install --fallback-to-build
    npm ERR! You can get their info via:
    npm ERR!     npm owner ls serialport
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:npm ERR!
         C:\Windows\system32\npm-debug.log
    Cannot install iobroker.node-red: 1
    ERROR: process exited with code 25</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
    • BluefoxB Offline
      BluefoxB Offline
      @Fonzo:
      gyp
      gyp
      gyp ERR!
      gyp ERR! not ok
      gyp
      gyp ERR! not ok
      npm
      gyp
      gyp ERR! not ok
      npm
      gyp
      gyp
       ERR! not ok
      npm
      npm
      gyp
      ERR!
       stack
      gyp
      gyp ERR! not ok
      node-pre-gyp
      ERR! build error
      gyp
      gyp
      gyp
      gyp ERR! not ok
      gyp
      gyp ERR!
      gyp ERR! not ok
      node-pre-gyp
       ERR! build error
      node-pre-gyp
      npm
      npm
      npm ERR! npm  v2.3.0
      npm ERR!
      npm ERR!
      Viel zu viel… Was für eine node.js Version hast du? Es geht nur kleine 0.12.0.
      Probiere mal aus "als Administrator" Konsole in ioBroker Verzeichnis:
        @akamia in anderm Thread:
        Es ist unsportlich - gebe ich ja zu - aber ich habe einfach nur
        http://download.iobroker.org/ioBrokerIn … .0.5.0.exe
        ausgeführt. Vorher Deine Node-Version sauber deinstallieren. `
        Hast du das gemacht?
        Rainer
        • F Offline
          Fonzo
          @Bluefox:
          Version 0.11.6
          Wenn ich das npm in der Admin Konsole ausführe findet er wohl Pyton aber es kommt dann eine Meldung
          Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parall
          ele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
          MSBUILD : error MSB3428: Die Visual C++-Komponente "VCBuild.exe" konnte nicht g
          eladen werden. Um dieses Problem zu beheben, installieren Sie entweder 1) .NET
          Framework 2.0 SDK oder 2) Microsoft Visual Studio 2005 oder 3) fügen Sie den Sp
          eicherort der Komponente zum Systempfad hinzu, falls er vom Standardspeicherort
           abweicht.
          Net Framework 3.5 und 4.0 läuft allerdings auf dem Server. Die höheren Versionen sollten an sich ja die kleineren inkludiert haben.
          • BluefoxB Offline
            BluefoxB Offline
            @Fonzo:
            @Bluefox:
            Version 0.11.6
             abweicht.
            Net Framework 3.5 und 4.0 läuft allerdings auf dem Server. Die höheren Versionen sollten an sich ja die kleineren inkludiert haben. `
            Visual Studio ist optional.
            So lange, dass " WARN optional dep failed," erscheinen, ist es ok.
