  4. Zigbee Adapter mit Cobee 2 Adapter
    5.7k
13 Beiträge 4 Kommentatoren 1.3k Aufrufe 4 Beobachtet
    Blechbixn
    Hallo.
    Konnte gestern Abend noch 5 Sensoren anmelden, ohne Probleme.
    Heute geht nix mehr, kein Anlernen mehr möglich.
    Die gestrigen Sensoren funktionieren einwandfrei.
    Jemand ne Idee was hier falsch sein könnte?
    2022-09-30 08:37:47.327  - info: host.ioBroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-09-30 08:37:49.646  - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 15500
    2022-09-30 08:37:51.078  - info: zigbee.0 (15500) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.17.1, js-controller: 4.0.23
    2022-09-30 08:37:51.117  - info: zigbee.0 (15500) delete old Backup files. keep only last 10
    2022-09-30 08:37:51.118  - info: zigbee.0 (15500) Starting Zigbee  npm ...
    2022-09-30 08:37:51.281  - info: zigbee.0 (15500) Installed Version: iobroker.zigbee@1.7.5
    2022-09-30 08:37:51.337  - info: zigbee.0 (15500) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
    2022-09-30 08:37:51.360  - info: zigbee.0 (15500) Unable to disable LED, unsupported function.
    2022-09-30 08:37:51.367  - info: zigbee.0 (15500)   --> transmitPower : normal
    2022-09-30 08:37:51.421  - info: zigbee.0 (15500) Unable to set transmit power, unsupported function.
    2022-09-30 08:37:51.422  - info: zigbee.0 (15500) Currently 5 devices are joined:
    2022-09-30 08:37:51.436  - info: zigbee.0 (15500) 0x00158d00053ef2a4 (addr 35027): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-09-30 08:37:51.438  - info: zigbee.0 (15500) 0x00158d00028a0e97 (addr 64695): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
    2022-09-30 08:37:51.439  - info: zigbee.0 (15500) 0x00158d00023e7b9b (addr 51487): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2022-09-30 08:37:51.440  - info: zigbee.0 (15500) 0x00158d00047db813 (addr 59339): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-09-30 08:37:51.440  - info: zigbee.0 (15500) 0x00158d0002786d73 (addr 902): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-09-30 08:37:51.440  - info: zigbee.0 (15500) Zigbee started
    2022-09-30 08:38:45.532  - info: admin.0 (154) ==> Connected system.user.admin from ::ffff:192.168.1.103
    2022-09-30 08:38:47.488  - info: zigbee.0 (15500) Zigbee: allowing new devices to join.
    2022-09-30 08:40:48.841  - info: zigbee.0 (15500) Zigbee: stop joining
    2022-09-30 08:41:03.153  - info: zigbee.0 (15500) Zigbee: allowing new devices to join.
    2022-09-30 08:43:04.446  - info: zigbee.0 (15500) Zigbee: stop joining
    arteckA S 2 Antworten Letzte Antwort
    • B Blechbixn
      Hallo.
      arteckA Offline
      arteckA Offline
      arteck
      @blechbixn nö aber wird bestimmt daran liegen, weil meine Glaskugel zur politur ist
      B 1 Antwort Letzte Antwort
      • arteckA arteck
        Blechbixn
        @arteck welche Infos darf ich dir nachreichen, die ich offensichtlich nichtwissend vergessen habe?
        • B Blechbixn
          arteckA Offline
          arteckA Offline
          arteck
          @blechbixn zieh mal den stick kurz raus..gehts dann wieder
          • arteckA arteck
            Blechbixn
            @arteck Halt mich für blöd.. ich hab das anzulernende Device kreisförmig um den Stick bewegt... dann ists gegangen... Das Device ist jetzt ca. 20 meter weit weg vom Stick und funktioniert einwandfrei.
            Zuvor beim anlernen waren maximal 50cm dazwischen. schon komisch..
            • B Blechbixn
              Hallo.
              Smolo
              @blechbixn Ich muss mal deinen Thread kappern und eine Verständnisfrage stellen.
              Ich habe selbst einen RPI4, Conbee 2 Stick, ein Buschjäger 4 Taster und einen ZIGBEE Relais ZG-003 liegen. Für die IOBroker integration gibt es soweit ich verstanden habe mehrere Möglichkeiten V1 = Zigbee Adapter und V2 = Deconz als App installieren und dann den Deconz Adapter?
              Mein Problem:
              • Iobroker / Zigbee Adapter sagt der Stick ist erreichbar und funzt aber ich kann keine Geräte anlernen
              Verständnis:
              • Hast du noch irgendwas installiert außer dem Adapter?
              • Wie mache ich ein Firmware Update für den Conbee bzw. wo kriege ich das her?
              • S Smolo
                Mein Problem:
                Verständnis:
                mickymM Offline
                mickymM Offline
                mickym
                @smolo sagte in Zigbee Adapter mit Cobee 2 Adapter:
                Bei der Frage kann ich vielleicht helfen:
                Du nimmst den GCFlasher unter Windows. Hier ist eine Anleitung:
                https://github.com/dresden-elektronik/deconz-rest-plugin/wiki/Update-deCONZ-manually
                die Firmware ist hier:
                https://deconz.dresden-elektronik.de/deconz-firmware/?C=M;O=D
                • mickymM mickym
                  Smolo
                  @mickym Danke Mickym das hilft schon mal weiter. Nutzt du den Zigbee Adapter oder gehst du per Deconz Adapter drauf?
                  • S Smolo
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @smolo Im Prinzip den Zigbee Adapter - aber ich hab mich davon komplett verabschiedet und nutze nur noch zigbee2mqtt und reines mqtt. Gibt auch einen neuen Adapter. Beim Zigbee Adapter wird der Conbee2 sehr ungern von den Entwicklern unterstützt, deswegen betreibe ich die direkte Anbindung über zigbee2mqtt.
                    • mickymM mickym
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @mickym sagte in Zigbee Adapter mit Cobee 2 Adapter:
                      wo hast du den Schwachsinn her ... ???
                      der conbee zickt sehr oft und da die Firmware nicht offen ..was sollen wir da machen..
                      • arteckA arteck
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @arteck sagte in Zigbee Adapter mit Cobee 2 Adapter:
                        Das ausgerechnet von Dir.
                        Na ich weiß ja, dass du einer der Gründe warst, warum ich gewechselt habe, um nicht mehr auf Deine Hilfe angewiesen zu sein.
                        Solche Posts, wie diese (https://forum.iobroker.net/post/672092) lassen sich ja auch dutzendweise finden, bin nur zu faul zum suchen und da gibts einige weitere User an Board, die ähnliche Antworten bekommen haben, in den Du schreibst, dass der conbee2 nicht vom Zigbee Adapter unterstützt wird, obwohl dieser zu dem Zeitpunkt offiziell vom zigbee2mqtt Projekt unterstützt wurde und unter empfohlener Coordinator gelistet war.
                        Auch die Ansteuerung von Gruppen mit dem conbee2 wurde nur behelfsmäßig geflickt.
                        Der letzte Grund ist sicher Dein Tonfall. Das wir keine Freunde in diesem Leben mehr werden, ist ja ein offenes Geheimnis. Dein Humor mit der Glaskugel hier, scheint manchen genauso verständlich, wie mein „Schwachsinn“.
                        Du kannst ja auch gerne widersprechen, aber ich werde weiterhin meine Erfahrungen posten, dass Zigbee Adapter und Conbee2 (und arteck) gerade aufgrund Deiner Aussagen nicht zusammen passen. Und dabei war „ungern“ unterstützt noch milde ausgedrückt.
                        Und selbst wenn „ihr“, da Firmware nicht offen liegt, nichts machen könnt, dann scheint jedenfalls zigbee2mqtt das besser zu können.
                        Ich weiß auch nicht, ob ihr inzwischen das Einschaltverhalten von Lampen ohne irgendwelche „SendTo“ Befehle sauber unterstützt. Ich persönlich bereue den Umstieg jedenfalls nicht.
                        • mickymM mickym
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @mickym nochmal für dich
                          der conbee wurde laaaaaaaaaaaaaaaaaaaange als alpha behandelt .. da der probleme bereitet hat im converter. aber das ist an dir auch vorbei gegangen.. da du ja z2m verwendest und da hat es von anfang an direkt super funktioniert... ach ne warte mal .auch nicht.. . ist ja der gleiche herdsman und der gleiche converter.
                          also war da auch ziemlich lange buggy..
                          du kannst gerne mich IMMER in Bezug zu conbee erwähnen.. ja ich bin kein verfechter von dem Teil.
                          JA. und ?? ist veraltert und zu teuer für das was es machen soll. PUNKT..
                          zurück zum Thema..
                          die Gruppen verarbeitung wurde geändert ja.. weil z2m Projekt es endlcih geschafft die Gruppen über Netzwerk anzusteuern.. aber das ist auch an dir vorbei gegangen.. ach ja warte weil du z2m verwendest.. und da werden der converter und der herdsman zuerst angepasst.
                          also wie du siehst.. z2m ist hier der Vorreiter.. und wir laufen hinterher..
                          aber hey da du ja hier der spezi bist. kannst ja den adapter überarbeiten und alles richtig machen
                          so ich bin raus hier..
                          • arteckA arteck
                            zurück zum Thema..
                            mickymM Offline
                            mickymM Offline
                            mickym
                            zurück zum Thema..
                            Na ich bin kein Spezialist, sondern war nur dummer Anwender oder Nutzer des Adapters, insofern kann ich hier keine Hilfe sein.
                            Aber mehr kann ich sonst auch nicht dazu sagen, die Beiträge sprechen für sich.
                            Ist ja auch schön zu wissen, dass sich vieles zum Positiven gewendet hat, was ich nicht mehr mitbekommen habe. Insgesamt gefällt mir ja das zigbee2mqtt oder der Adapter ja auch besser als Deconz, weil meines Erachtens mehr Geräte unterstützt werden und ggf. auch feiner zu konfigurieren sind, wobei ich mich mit Deconz nie in der Tiefe beschäftigt habe.
