  2. English
  3. Scripting / Logic
  5. using iobroker.socket-client in a NodeJs project
    apollon77A
6 Beiträge 3 Kommentatoren 2.0k Aufrufe 3 Beobachtet
  • T
    T
    Taragorm
    Hi, I'm in the process of writng a NodeJs project that will talk to IOBroker.
    According to npm:
    @iobroker/socket-client@1.1.14
    when I try to create a connection, I get:
    ReferenceError: window is not defined
        at P:\Projects\Vue\logik\logik-backend\node_modules\@iobroker\socket-client\dist\cjs\Connection.js:123:7
        at new Promise (<anonymous>)
        at Connection.waitForSocketLib (P:\Projects\Vue\logik\logik-backend\node_modules\@iobroker\socket-client\dist\cjs\Connection.js:122:34)
        at new Connection (P:\Projects\Vue\logik\logik-backend\node_modules\@iobroker\socket-client\dist\cjs\Connection.js:87:10)
    As I understand it, this happens because "window" is not defined in NodeJS projects [I am by no means an expert JS programmer, btw]
    So.
    Is this the right library for the job?
    Does it in fact support Node?
    Am I missing some bit of initialisation to create a suitable "window" object under node.
    Hints appreciated.
    • T Taragorm
      According to npm:
      So.
      Hints appreciated.
      AlCalzoneA
      AlCalzoneA
      AlCalzone
      @taragorm That library is meant for the browser.
      Warum sudo böse ist: https://forum.iobroker.net/post/17109
      • AlCalzoneA AlCalzone
        T
        T
        Taragorm
        @alcalzone That was my assumption.
        Is there a NodeJs version?
        I can always use the basic REST interface, but it wouldn't be my first choice here...
        BluefoxB 1 Antwort Letzte Antwort
        • T Taragorm
          @taragorm if you will use normal "ws" library for node.js, it will be possible to communicate with ioBroker. But ioBroker.rest-api is very advanced and supports long polling and web hooks for events.
          T 2 Antworten Letzte Antwort
          • BluefoxB Bluefox
            T
            T
            Taragorm
            @bluefox So you suggest the REST interface? - I'll go with that then. The app will likely be running on the same machine as ioBroker, anyhow.
            • BluefoxB Bluefox
              T
              T
              Taragorm
              @bluefox The API seems straightforwards enough; a couple of questions though:
              • How do I unsubscribe? - I didn't see a command for that
              • Can I do a "Bulk" subscribe - i.e. ask for a list of states?
              84.0k
              1.4m
