  4. mihome vaccum ist offt gelb
    5.8k
126 Beiträge 5 Kommentatoren 16.1k Aufrufe 5 Beobachtet
    @krisiun
    Aus dem HowTo:
    Check:
    Wenn alles sauber gelaufen ist sollte bei
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    die Ausgabe etwa so aussehen:
    echad@chet:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.15.1
    v16.15.1
    8.11.0
    echad
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://repos.influxdata.com/debian bullseye InRelease
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Hit:7 https://deb.nodesource.com/node_12.x bullseye InRelease
    Hit:8 https://deb.nodesource.com/node_14.x bullseye InRelease
    Hit:9 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:10 https://packages.redis.io/deb bullseye InRelease
    Get:12 https://pkgs.tailscale.com/stable/debian bullseye InRelease
    Hit:11 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Fetched 5,536 B in 2s (2,475 B/s)
    Reading package lists... Done
    Building dependency tree... Done
    All packages are up to date.
    nodejs:
      Installed: 16.15.1-deb-1nodesource1
      Candidate: 16.15.1-deb-1nodesource1
      Version table:
     *** 16.15.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         12.22.8-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x bullseye/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/
    Das ist doch nicht schwer zu finden?
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    #101
    @thomas-braun sagte in mihome vaccum ist offt gelb:
    @krisiun
    Aus dem HowTo:
    Check:
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.15.1
    v16.15.1
    8.11.0
    echad
    nodejs:
      Version table:
    Soll ich also das hier im putty eingeben?
    Thomas BraunT KrisiunK 2 Antworten Letzte Antwort
    • KrisiunK Krisiun
      @krisiun
      Aus dem HowTo:
      Check:
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.15.1
      v16.15.1
      8.11.0
      echad
      nodejs:
        Version table:
      #102
      @krisiun
      Natürlich nur die ersten beiden Zeilen...
      Der Rest ist die Antwort in der Konsole.
      KrisiunK 1 Antwort Letzte Antwort
        @krisiun
        KrisiunK Offline
        KrisiunK Offline
        Krisiun
        #103
        Das ist mir auch klar. Danke. Aber wenn ich das eingebe bekomme ich nichts zurück
        • KrisiunK Krisiun
          #104
          @krisiun
          Kann nicht sein.
            @krisiun
            Kann nicht sein.
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            #105
            ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
            • KrisiunK Krisiun
              #106
              @krisiun
              Ja, das ist okay.
                @krisiun
                Ja, das ist okay.
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                #107
                @thomas-braun ```
                code_text -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                -bash: pi: Kommando nicht gefunden.
                • KrisiunK Krisiun
                  @thomas-braun ```
                  #108
                  @krisiun
                  Ich sehe nicht was du da reinkopiert oder reintippst, es ist aber falsch.
                  'pi' kommt in den Kommandos nicht vor, kann also gar nicht als unbekannter Befehl angemeckert werden.
                  KrisiunK 3 Antworten Letzte Antwort
                    @krisiun
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    #109
                    Ich kann das leider nicht anderes hier rein kopieren. Das mit dem schwarzen Hintergrund geht einfach nicht bei mir. Keine Ahnung warum
                      @krisiun
                      KrisiunK Offline
                      KrisiunK Offline
                      Krisiun
                      #110
                      Mal klappt aber öfter nicht
                      • KrisiunK Krisiun
                        #111
                        @krisiun
                        Die Steuerzeichen müssen in einer neuen Zeile stehen.
                        Und den Platzhalter code_text überschreibt oder löscht man. Dann passt das auch mit der Konsolendarstellung.
                          @krisiun
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          #112
                          Trotzdem vielen Dank für Deine Hilfe. Wie gesagt wenn Du morgen auch noch die Kraft hast hier weiter zu machen dann sehr gerne. Muss leider jetzt ins Bett. Morgen um 3Uhr früh muss ich raus. Bis Morgen
                            @krisiun
                            KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            #113
                            Danke. Das können wir mal gleich morgen testen
                            • KrisiunK Krisiun
                              @krisiun
                              Aus dem HowTo:
                              Check:
                              aarch64
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.15.1
                              v16.15.1
                              8.11.0
                              echad
                              nodejs:
                                Version table:
                              KrisiunK Offline
                              KrisiunK Offline
                              Krisiun
                              #114
                              @krisiun sagte in mihome vaccum ist offt gelb:
                              @krisiun
                              Aus dem HowTo:
                              Check:
                              aarch64
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.15.1
                              v16.15.1
                              8.11.0
                              echad
                              nodejs:
                                Version table:
                              uname -m && type -P nodejs node npm && nodejs -v && node    -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt updat   e && apt policy nodejs
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.17.0
                              v16.17.0
                              8.15.0
                              pi
                              /home/pi
                              OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              OK:2 http://archive.raspberrypi.org/debian buster InRelease
                              OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                              Aktualisierung für 39 Pakete verfügbar. Führen Sie »apt list --upgradable« aus,    um sie anzuzeigen.
                              nodejs:
                                Installiert:           16.17.0-deb-1nodesource1
                                Installationskandidat: 16.17.0-deb-1nodesource1
                                Versionstabelle:
                               *** 16.17.0-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                   10.24.0~dfsg-1~deb10u1 500
                              Hi. Das ist die Konsole Antwort bei mir da steht zwar die v16.17.0 aber in Wirklichkeit ist bei mir die v14.19.3
                              • KrisiunK Krisiun
                                @krisiun
                                Aus dem HowTo:
                                Check:
                                aarch64
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.15.1
                                v16.15.1
                                8.11.0
                                echad
                                nodejs:
                                  Version table:
                                armv7l
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.17.0
                                v16.17.0
                                8.15.0
                                pi
                                /home/pi
                                nodejs:
                                  Versionstabelle:
                                #115
                                Nein, 'in Wirklichkeit' ist da die nodejs 16.7.0-deb-1nodesource1 installiert.
                                Zieh die 39 Updates nach:
                                iobroker stop
                                sudo apt update
                                sudo apt full-upgrade
                                sudo reboot
                                  iobroker stop
                                  sudo apt update
                                  sudo reboot
                                  KrisiunK Offline
                                  KrisiunK Offline
                                  Krisiun
                                  #116
                                  @thomas-braun OK
                                  • KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    schrieb am zuletzt editiert von Krisiun
                                    #117
                                    @Thomas-Braun
                                    Also updates sind fertig. Jetzt sind allerdings alle Instanzen rot aber die werden noch grün hoffe ich. Die node version passt jetzt. Ist die 16.17.0
                                      iobroker stop
                                      sudo apt update
                                      sudo reboot
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      #118
                                      Unter Nodejs-Installation und Upgrades unter Debian
                                      schreibst Du wie man Node richtig updaten soll.
                                      Nach der Angabe von
                                      cd /opt/iobroker
                                      npm ls | grep -E 'github|ERR'
                                      Kommt bei mir das hier raus
                                      /opt/iobroker $ npm ls | grep -E 'github|ERR'
                                      ├── iobroker.enigma2@1.3.2 (git+ssh://git@github.com/Matten-Matten/ioBroker.enigma2.git#9d3d3b7f884e7bd309db9a1c1984b69fb0528e17)
                                      pi@raspberrypi4-iob:/opt/iobroker $
                                      Ich nehme an dass ist nicht OK? oder?
                                      • KrisiunK Krisiun
                                        Nach der Angabe von
                                        cd /opt/iobroker
                                        #119
                                        @krisiun
                                        Den enigma-Adapter gibt es soweit ich das sehe nur aus dem github.
                                        Musst du also als Alpha-Version dann mit parat kommen.
                                          @krisiun
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          #120
                                          Also ist nicht weiter schlimm oder ?
