  4. Update von Adaptern nicht mehr möglich
    5.8k
36 Beiträge 3 Kommentatoren 4.1k Aufrufe 3 Beobachtet
  • GlasfaserG Glasfaser
    @heinzie sagte in Update von Adaptern nicht mehr möglich:
    Den Rest habe ich alles so gemacht wie von dir beschrieben (leider ohne Erfolg) , oder habe ich was übersehen?
    https://forum.iobroker.net/post/848193
    Keine Rückinfo dazu bekommen zu den Befehlen
    heinzie
    @glasfaser ```
    root@iobroker_v4:/opt/iobroker# pkill -u iobroker
    root@iobroker_v4:/opt/iobroker# rm /opt/iobroker/package*
    root@iobroker_v4:/opt/iobroker# iobroker update -i
    Used repository: beta
    Adapter "admin" : 6.2.18 , installed 6.2.14 [Updatable]
    Adapter "alexa2" : 3.19.7 , installed 3.19.5 [Updatable]
    Adapter "backitup" : 2.4.12 , installed 2.4.12
    Adapter "broadlink2" : 2.1.5 , installed 2.1.5
    Adapter "cloud" : 4.2.2 , installed 4.2.1 [Updatable]
    Adapter "daswetter" : 3.1.4 , installed 3.1.3 [Updatable]
    Adapter "discovery" : 3.0.5 , installed 3.0.5
    Adapter "dwd" : 2.8.3 , installed 2.8.3
    Adapter "echarts" : 1.0.12 , installed 1.0.8 [Updatable]
    Adapter "email" : 1.1.3 , installed 1.1.3
    Adapter "flot" : 1.11.0 , installed 1.11.0
    Adapter "fritzbox" : 0.5.0 , installed 0.5.0
    Adapter "fritzdect" : 2.2.3 , installed 2.2.6
    Adapter "fullcalendar" : 1.2.0 , installed 1.2.0
    Adapter "fullybrowser" : 2.1.2 , installed 2.1.2
    Adapter "growatt" : 1.1.17 , installed 1.1.17
    Adapter "habpanel" : 0.5.0 , installed 0.5.0
    Adapter "history" : 2.2.1 , installed 2.2.1
    Adapter "homeconnect" : 1.0.1 , installed 1.0.1
    Adapter "homee" : 1.2.0 , installed 1.2.0
    Adapter "hue-extended" : 2.0.0 , installed 2.0.1
    Adapter "ical" : 1.13.1 , installed 1.13.1
    Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
    Adapter "icons-material-png": 0.1.0, installed 0.1.0
    Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
    Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
    Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter "info" : 1.9.19 , installed 1.9.19
    Adapter "iqontrol" : 2.0.1 , installed 2.0.1
    Adapter "javascript" : 6.0.0 , installed 6.0.0
    Controller "js-controller": 4.0.23 , installed 4.0.23
    Adapter "landroid" : 1.0.3 , installed 1.0.3
    Adapter "material" : 1.1.2 , installed 1.1.2
    Adapter "mihome" : 1.4.0 , installed 1.4.0
    Adapter "mobile" : 1.0.1 , installed 1.0.1
    Adapter "mqtt" : 4.0.7 , installed 4.0.7
    Adapter "net-tools" : 0.2.0 , installed 0.2.0
    Adapter "node-red" : 4.0.0 , installed 4.0.0
    Adapter "onvif" : 0.4.4 , installed 0.4.5
    Adapter "openweathermap": 0.3.0 , installed 0.3.0
    Adapter "parser" : 1.1.8 , installed 1.1.8
    Adapter "paw" : 0.3.2 , installed 0.3.2
    Adapter "ping" : 1.5.3 , installed 1.5.3
    Adapter "pollenflug" : 1.0.6 , installed 1.0.6
    Adapter "proxy" : 1.3.1 , installed 1.3.1
    Adapter "renault" : 0.0.13 , installed 0.0.13
    Adapter "ring" : 3.1.1 , installed 3.1.1
    Adapter "sayit" : 1.12.6 , installed 1.12.6
    Adapter "scenes" : 2.3.9 , installed 2.3.9
    Adapter "shelly" : 6.0.0 , installed 6.0.0
    Adapter "shuttercontrol": 1.4.14 , installed 1.4.14
    Adapter "simple-api" : 2.7.0 , installed 2.7.0
    Adapter "smartcontrol" : 1.2.1 , installed 1.2.1
    Adapter "socketio" : 6.1.10 , installed 6.1.8 [Updatable]
    Adapter "solarwetter" : 1.0.0 , installed 1.0.0
    Adapter "sonoff" : 2.5.1 , installed 2.5.1
    Adapter "sql" : 2.1.8 , installed 2.1.8
    Adapter "synology" : 2.1.9 , installed 2.1.9
    Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1
    Adapter "telegram" : 1.14.1 , installed 1.14.1
    Adapter "text2command" : 2.2.2 , installed 2.2.2
    Adapter "tr-064" : 4.2.16 , installed 4.2.16
    Adapter "trashschedule": 2.0.3 , installed 2.0.3
    Adapter "upnp" : 1.0.21 , installed 1.0.21
    Adapter "uv-protect" : 0.3.6 , installed 0.3.6
    Adapter "vis" : 1.4.15 , installed 1.4.15
    Adapter "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter "vis-colorpicker": 1.2.0 , installed 1.2.0
    Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
    Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
    Adapter "vis-material" : 0.1.3 , installed 0.3.0
    Adapter "vis-material-webfont": 0.0.3, installed 0.0.3
    Adapter "vis-metro" : 1.2.0 , installed 1.2.0
    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
    Adapter "vw-connect" : 0.0.51 , installed 0.0.51
    Adapter "weatherunderground": 3.4.2, installed 3.4.2
    Adapter "web" : 5.2.5 , installed 5.2.4 [Updatable]
    Adapter "web-speedy" : 0.2.0 , installed 0.2.0
    Adapter "wifilight" : 1.1.4 , installed 1.1.4
    Adapter "windows-control": 0.1.5 , installed 0.1.5
    Adapter "wiobrowser" : 1.1.4 , installed 1.1.4
    Adapter "worx" : 1.6.6 , installed 1.6.6
    Adapter "ws" : 2.1.5 , installed 2.1.3 [Updatable]
    Adapter "yeelight-2" : 1.2.1 , installed 1.2.1
    Adapter "yr" : 5.3.0 , installed 5.3.0
    Adapter "zigbee" : 1.7.6 , installed 1.7.6
    root@iobroker_v4:/opt/iobroker# iobroker upgrade all
    This upgrade of "echarts" will introduce the following changes:
    -> 1.0.12:
    Made it work with ioBroker cloud
    -> 1.0.10:
    Corrected the problem with socket.io
    -> 1.0.9:
    Added 2 weeks as relative period
    Would you like to upgrade echarts from @1.0.8 to @1.0.12 now? [(y)es, (n)o]: n
    No upgrade of "echarts" desired.
    This upgrade of "daswetter" will introduce the following changes:
    -> 3.1.4:
    update dependencies
    Would you like to upgrade daswetter from @3.1.3 to @3.1.4 now? [(y)es, (n)o]: y
    Update daswetter from @3.1.3 to @3.1.4
    host.iobroker_v4 Adapter "system.adapter.daswetter.0" is stopped.
    NPM version: 8.15.0
    Installing iobroker.daswetter@3.1.4... (System call)
    removed 3703 packages, changed 1 package, and audited 14 packages in 1m
    1 package is looking for funding
    run npm fund for details
    found 0 vulnerabilities
    Update "system.adapter.daswetter.0"
    Cannot upgrade: Cannot find module 'mime'
    Require stack:
    • /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js
    • /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js
    • /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    • /opt/iobroker/iobroker
      @heinzie
      Zeigen
      iobroker repo list
      heinzie
      @glasfaser sagte in Update von Adaptern nicht mehr möglich:
      @heinzie
      Zeigen
      iobroker repo list
      root@iobroker_v4:/opt/iobroker# iobroker repo list
      node:internal/modules/cjs/loader:959
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup'
      Require stack:
      - /opt/iobroker/iobroker
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
          at Function.Module._load (node:internal/modules/cjs/loader:804:27)
          at Module.require (node:internal/modules/cjs/loader:1028:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/opt/iobroker/iobroker:2:1)
          at Module._compile (node:internal/modules/cjs/loader:1126:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
          at Module.load (node:internal/modules/cjs/loader:1004:32)
          at Function.Module._load (node:internal/modules/cjs/loader:839:12)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [ '/opt/iobroker/iobroker' ]
      • H heinzie
        @glasfaser ```
        -> 1.0.12:
        -> 1.0.10:
        -> 1.0.9:
        -> 3.1.4:
        update dependencies
        NPM version: 8.15.0
        Require stack:
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        Falsch
        nach
        solltest du den Container neu starten !
        habe ich extra betont .
        H 1 Antwort Letzte Antwort
          Falsch
          nach
          heinzie
          Falsch
          nach
          Habe ich jetzt gemacht. dann erscheint folgendes:
          Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
          -> 1.0.12:
          -> 1.0.10:
          Corrected the problem with `socket.io`
          -> 1.0.9:
          -> 3.1.4:
          update dependencies
          Would you like to upgrade daswetter from @3.1.3 to @3.1.4 now? [(y)es, (n)o]: n
          No upgrade of "daswetter" desired.
          This upgrade of "cloud" will introduce the following changes:
          -> 4.2.2:
          Corrected error with services list and admin6
          Would you like to upgrade cloud from @4.2.1 to @4.2.2 now? [(y)es, (n)o]: y
          Update cloud from @4.2.1 to @4.2.2
          NPM version: 8.15.0
          Installing iobroker.cloud@4.2.2... (System call)
           Objects database error: connect ECONNREFUSED 127.0.0.1:9001
           States database error: connect ECONNREFUSED 127.0.0.1:9000
          removed 3658 packages, changed 5 packages, and audited 59 packages in 1m
          2 packages are looking for funding
            run `npm fund` for details
          6 vulnerabilities (1 low, 5 high)
          To address all issues (including breaking changes), run:
            npm audit fix --force
          Run `npm audit` for details.
          Cannot set system.adapter.cloud: DB closed
           Cannot find view "system" for search "instance" : Connection is closed.
          Cannot upgrade: Cannot find view "system"
          • H heinzie
            Falsch
            nach
            -> 1.0.12:
            -> 1.0.10:
            -> 1.0.9:
            -> 3.1.4:
            update dependencies
            -> 4.2.2:
            NPM version: 8.15.0
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            das bringt jetzt nichts mehr ..
            setzte ioBroker neu auf ,( habe ich oben verlinkt )
            Warum .. habe ich schon oben geschrieben .
            • H Offline
              heinzie
              Habe ich jetzt gemacht. Läuft soweit auch alles wieder. Das einzige Problem ist noch das ich nicht mehr ain die Systemeinstellungen komme. Am Anfang ging es noch, aber nachdem ich das Backup eingepielt hatte geht es nicht mehr. Hängt sich beim Aufruf auf und unten links erscheint teilweise "Cannot read settings: timeout"
              Was mir noch aufgefallen ist, dass bei den Adaptern ober noch steht
              "WARNUNG: Aktuelles Repository ist "beta". Benutzung auf eigene Gefahr!"
              Noch eine Idee dazu?
              • H heinzie
                iob repo list
                  iob repo list
                  heinzie
                  @thomas-braun sagte in Update von Adaptern nicht mehr möglich:
                  iob repo list
                  root@NAS:/opt/iobroker# iob repo list
                  Active repo(s): beta
                  root@NAS:/opt/iobroker# ^C
                  • H heinzie
                    iob repo list
                    @heinzie
                    iob repo unset beta
                    iob repo set stable
                    iob update
                      @heinzie
                      iob repo unset beta
                      iob repo set stable
                      iob update
                      heinzie
                      iob update
                      Danke. Die Beta Anzeige ist jetzt schon mal weg. Die systemeinstellungen gehen zwar immer noch nict. werde dann aber mal alle Adapter die Beta sind zurück setzen.
                      Active repo(s):
                      root@NAS:/opt/iobroker# iob repo set stable
                      Repository "stable" set as active.
                      Active repo(s): stable
                      root@NAS:/opt/iobroker# iob update
                      Used repository: stable
                      Adapter    "admin"        : 6.2.17   , installed 6.2.18
                      Adapter    "alexa2"       : 3.11.2   , installed 3.19.7
                      Adapter    "backitup"     : 2.4.10   , installed 2.4.12
                      Adapter    "daswetter"    : 3.1.2    , installed 3.1.4
                      Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
                      Adapter    "history"      : 2.2.0    , installed 2.2.1
                      Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
                      Adapter    "node-red"     : 3.3.1    , installed 4.0.0
                      Adapter    "ring"         : 3.0.4    , installed 3.1.1
                      Adapter    "sayit"        : 1.12.3   , installed 1.12.6
                      Adapter    "socketio"     : 4.2.0    , installed 6.1.10
                      Adapter    "telegram"     : 1.13.0   , installed 1.14.1
                      Adapter    "web"          : 4.3.0    , installed 5.2.5
                      Adapter    "ws"           : 1.3.0    , installed 2.1.5
                      Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
                      Adapter    "zigbee"       : 1.7.5    , installed 1.7.6
                      • H heinzie
                        iob update
                        Active repo(s):
                        Ich würde es sich 'auswachsen' lassen.
                          heinzie
                          Du meinst das es dann irgendwann einfach weider geht?
                          • H heinzie
                            @heinzie
                            Ich meine die beta-Versionen in Ruhe zu lassen und abzuwarten, bis die stabile Version die Nummerierung überholt.
                            Zu dem Problem mit der Systemsteuerung:
                            Iobroker / Container neustarten, Auszug aus dem LogFile bei Versuch die Einstellungen zu erreichen posten.
                            • H Offline
                              heinzie
                              @heinzie
                              Hoffe das ich die Stelle erwischt habe:
                              2022-08-27 19:37:43.495  - error: vis.0 (2260) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2022-08-27 19:37:43.497  - error: vis.0 (2260) unhandled promise rejection: Not exists
                              2022-08-27 19:37:43.502  - error: vis.0 (2260) Error: Not exists
                                  at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
                                  at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26)
                                  at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29)
                                  at processImmediate (node:internal/timers:468:21)
                              2022-08-27 19:37:43.505  - error: vis.0 (2260) Not exists
                              2022-08-27 19:37:44.013  - info: vis.0 (2260) terminating
                              2022-08-27 19:37:44.014  - warn: vis.0 (2260) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2022-08-27 19:37:44.822  - error: host.NAS iobroker npm-install: host.NAS Cannot install iobroker.vis@1.4.15: 6
                              2022-08-27 19:37:45.402  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:37:45.455  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:37:45.456  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:37:45.842  - info: host.NAS iobroker npm-install: exit 25
                              2022-08-27 19:37:46.851  - warn: host.NAS startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
                              2022-08-27 19:37:46.852  - info: host.NAS iobroker install vis@1.4.15 using installedVersion
                              2022-08-27 19:37:46.912  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                              2022-08-27 19:37:50.085  - info: host.NAS iobroker npm-install: NPM version: 8.15.0
                              2022-08-27 19:37:50.086  - info: host.NAS iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                              2022-08-27 19:37:54.346  - info: alexa2.0 (726) Unknown Device, but enabling commands, Try it and report back if commands work.
                              2022-08-27 19:37:54.347  - info: alexa2.0 (726) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                              2022-08-27 19:37:54.348  - info: alexa2.0 (726)     Device-type:A324YMIUSWQDGE - Theodor's Samsung TV 2020-Q (Samsung TV 2020-Q) (Samsung TV 2020-Q) (Samsung TV 2020-Q) (Samsung TV 2020-Q) (Samsung TV 2020-Q) (Samsung TV 2020-Q) (SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,CHANGE_NAME,EARCONS,TOUCH_INITIATED,CUSTOM_ALARM_TONE,SET_TIME_ZONE,MUSIC_SKILL,TIDAL,SUPPORTS_LOCALE_SWITCH,DEREGISTER_DEVICE,DIALOG_INTERFACE_VERSION,APPLE_MUSIC,DEEZER,AMAZON_MUSIC,AUDIO_PLAYER,SIRIUSXM,SOUND_SETTINGS,PERSISTENT_CONNECTION,SET_LOCALE,SUPPORTS_LOCALE,MICROPHONE,TIMERS_AND_ALARMS,TUNE_IN,SPEECH_RECOGNIZER_USS,MULTI_WAKEWORDS_SUPPORTED,ASCENDING_ALARM_VOLUME,AUDIBLE,REMINDERS,GOLDFISH,VOLUME_SETTING,DREAM_TRAINING,HANDS_FREE,KINDLE_BOOKS,I_HEART_RADIO,SLEEP,ADAPTIVE_LISTENING)
                              2022-08-27 19:37:55.432  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:37:55.444  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:37:55.445  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:37:56.910  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:01.944  - info: vis.0 (2632) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.17.0, js-controller: 4.0.23
                              2022-08-27 19:38:02.089  - info: vis.0 (2632) vis license is OK.
                              2022-08-27 19:38:02.429  - error: vis.0 (2632) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2022-08-27 19:38:02.431  - error: vis.0 (2632) unhandled promise rejection: Not exists
                              2022-08-27 19:38:02.434  - error: vis.0 (2632) Error: Not exists
                              2022-08-27 19:38:02.455  - error: vis.0 (2632) Not exists
                              2022-08-27 19:38:02.998  - info: vis.0 (2632) terminating
                              2022-08-27 19:38:02.999  - warn: vis.0 (2632) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2022-08-27 19:38:04.125  - error: host.NAS iobroker npm-install: host.NAS Cannot install iobroker.vis@1.4.15: 6
                              2022-08-27 19:38:05.268  - info: host.NAS iobroker npm-install: exit 25
                              2022-08-27 19:38:06.268  - error: host.NAS Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                              2022-08-27 19:38:06.606  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:06.651  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:06.652  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:08.834  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:12.094  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:13.028  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Power_Grid_Voltage" has to be stringified but received type "number"
                              2022-08-27 19:38:13.688  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Power_Grid_Current" has to be stringified but received type "number"
                              2022-08-27 19:38:14.616  - info: alexa2.0 (726) Unknown Device, but enabling commands, Try it and report back if commands work.
                              2022-08-27 19:38:14.617  - info: alexa2.0 (726) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                              2022-08-27 19:38:14.618  - info: alexa2.0 (726)     Device-type:A2QAQUVM4NZTWI - Theodor's Bar 5.0 MultiBeam (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,CHANGE_NAME,EARCONS,CUSTOM_ALARM_TONE,SET_TIME_ZONE,MUSIC_SKILL,TIDAL,SUPPORTS_LOCALE_SWITCH,EQUALIZER_CONTROLLER_TREBLE,DEREGISTER_DEVICE,DIALOG_INTERFACE_VERSION,APPLE_MUSIC,AUDIO_CONTROLS,DEEZER,AMAZON_MUSIC,AUDIO_PLAYER,SIRIUSXM,SOUND_SETTINGS,PERSISTENT_CONNECTION,SET_LOCALE,SUPPORTS_LOCALE,MICROPHONE,TIMERS_AND_ALARMS,TUNE_IN,SPEECH_RECOGNIZER_USS,MULTI_WAKEWORDS_SUPPORTED,ASCENDING_ALARM_VOLUME,AUDIBLE,REMINDERS,EQUALIZER_CONTROLLER_BASS,GOLDFISH,VOLUME_SETTING,EQUALIZER_CONTROLLER_MIDRANGE,DREAM_TRAINING,MIC_LESS,HANDS_FREE,KINDLE_BOOKS,I_HEART_RADIO,SLEEP,ADAPTIVE_LISTENING)
                              2022-08-27 19:38:15.138  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Peak_Active_Power_of_current_Day" has to be stringified but received type "number"
                              2022-08-27 19:38:16.818  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:16.825  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:17.323  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Efficiency" has to be type "number" but received type "object"
                              2022-08-27 19:38:19.587  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:26.166  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:26.173  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:26.174  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:28.604  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:30.546  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:30.695  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:30.697  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:33.696  - error: growatt.0 (1083) Growatt exception: AxiosError: Request failed with status code 588
                              2022-08-27 19:38:36.314  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:36.320  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:36.321  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:38.182  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:42.649  - info: smartcontrol.0 (1016) Trigger [Bew. Büro] activated but current brightness of 32 is >= threshold of 20 -> Motion disregarded.
                              2022-08-27 19:38:45.329  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:45.351  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:46.709  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:54.930  - info: alexa2.0 (726) Subscribing to states...
                              2022-08-27 19:38:55.327  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:55.334  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:38:57.574  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                              2022-08-27 19:38:58.197  - info: alexa2.0 (726) Alexa-Push-Connection (macDms = true) established. Disable Polling
                              2022-08-27 19:39:06.147  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                              2022-08-27 19:39:06.155  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              2022-08-27 19:39:06.158  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                              • H heinzie
                                @heinzie
                                @heinzie
                                Ich sehe da überwiegend das bekannte Problem mit vis.
                                  @heinzie
                                  heinzie
                                  @heinzie
                                  Habe heute nochmal neu aufgesetzt. Bis zur Installation von 10 Adaptern funktinierte es noch. Wenn ich mehr instaliere kommt wieder der Fehler. Das ist aber unabhäging von den Adaptern. Ich muss nur eine gewisse Anzahl von Adaptern überschreiten dann kommt wieder Fehler. Deshalb vermute ich, dass es einfach nur ein Performance Problem ist. Deshalb auch die Fehlermeldung "Cannot read settings: timeout"
                                  Kann man ggf. die timeout Zeit irgendwo vorgeben?
