  4. Update von Adaptern nicht mehr möglich
    5.8k
36 Beiträge 3 Kommentatoren 4.1k Aufrufe 3 Beobachtet
  • GlasfaserG Glasfaser
    @heinzie sagte in Update von Adaptern nicht mehr möglich:
    root@iobroker_v4:/opt/iobroker# pkill -u iobroker
    root@iobroker_v4:/opt/iobroker# rm /opt/iobroker/package*
    root@iobroker_v4:/opt/iobroker# iobroker update -i
    Falsch
    nach
    solltest du den Container neu starten !
    habe ich extra betont .
    heinzie
    @glasfaser sagte in Update von Adaptern nicht mehr möglich:
    Falsch
    nach
    Habe ich jetzt gemacht. dann erscheint folgendes:
    Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
    root@iobroker_v4:/opt/iobroker# iobroker upgrade all
    This upgrade of "echarts" will introduce the following changes:
    -> 1.0.12:
    Made it work with ioBroker cloud
    -> 1.0.10:
    Corrected the problem with `socket.io`
    -> 1.0.9:
    Added 2 weeks as relative period
    Would you like to upgrade echarts from @1.0.8 to @1.0.12 now? [(y)es, (n)o]: n
    No upgrade of "echarts" desired.
    This upgrade of "daswetter" will introduce the following changes:
    -> 3.1.4:
    update dependencies
    Would you like to upgrade daswetter from @3.1.3 to @3.1.4 now? [(y)es, (n)o]: n
    No upgrade of "daswetter" desired.
    This upgrade of "cloud" will introduce the following changes:
    -> 4.2.2:
    Corrected error with services list and admin6
    Would you like to upgrade cloud from @4.2.1 to @4.2.2 now? [(y)es, (n)o]: y
    Update cloud from @4.2.1 to @4.2.2
    NPM version: 8.15.0
    Installing iobroker.cloud@4.2.2... (System call)
     Objects database error: connect ECONNREFUSED 127.0.0.1:9001
     States database error: connect ECONNREFUSED 127.0.0.1:9000
    removed 3658 packages, changed 5 packages, and audited 59 packages in 1m
    2 packages are looking for funding
      run `npm fund` for details
    6 vulnerabilities (1 low, 5 high)
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    Cannot set system.adapter.cloud: DB closed
     Cannot find view "system" for search "instance" : Connection is closed.
    Cannot upgrade: Cannot find view "system"
    • H heinzie
      Falsch
      nach
      -> 1.0.12:
      -> 1.0.10:
      -> 1.0.9:
      -> 3.1.4:
      update dependencies
      -> 4.2.2:
      NPM version: 8.15.0
      GlasfaserG Offline
      GlasfaserG Offline
      das bringt jetzt nichts mehr ..
      setzte ioBroker neu auf ,( habe ich oben verlinkt )
      Warum .. habe ich schon oben geschrieben .
      • H Offline
        heinzie
        Habe ich jetzt gemacht. Läuft soweit auch alles wieder. Das einzige Problem ist noch das ich nicht mehr ain die Systemeinstellungen komme. Am Anfang ging es noch, aber nachdem ich das Backup eingepielt hatte geht es nicht mehr. Hängt sich beim Aufruf auf und unten links erscheint teilweise "Cannot read settings: timeout"
        Was mir noch aufgefallen ist, dass bei den Adaptern ober noch steht
        "WARNUNG: Aktuelles Repository ist "beta". Benutzung auf eigene Gefahr!"
        Noch eine Idee dazu?
        • H heinzie
          iob repo list
          H 1 Antwort Letzte Antwort
            iob repo list
            heinzie
            @thomas-braun sagte in Update von Adaptern nicht mehr möglich:
            iob repo list
            root@NAS:/opt/iobroker# iob repo list
            Active repo(s): beta
            root@NAS:/opt/iobroker# ^C
            • H heinzie
              iob repo list
              @heinzie
              iob repo unset beta
              iob repo set stable
              iob update
                @heinzie
                iob repo unset beta
                iob repo set stable
                iob update
                heinzie
                iob update
                Danke. Die Beta Anzeige ist jetzt schon mal weg. Die systemeinstellungen gehen zwar immer noch nict. werde dann aber mal alle Adapter die Beta sind zurück setzen.
                Active repo(s):
                root@NAS:/opt/iobroker# iob repo set stable
                Repository "stable" set as active.
                Active repo(s): stable
                root@NAS:/opt/iobroker# iob update
                Used repository: stable
                Adapter    "admin"        : 6.2.17   , installed 6.2.18
                Adapter    "alexa2"       : 3.11.2   , installed 3.19.7
                Adapter    "backitup"     : 2.4.10   , installed 2.4.12
                Adapter    "daswetter"    : 3.1.2    , installed 3.1.4
                Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                Adapter    "echarts"      : 1.0.12   , installed 1.0.8  [Updatable]
                Adapter    "email"        : 1.1.3    , installed 1.1.3
                Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
                Adapter    "fritzdect"    : 2.2.3    , installed 2.2.6
                Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
                Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                Adapter    "growatt"      : 1.1.17   , installed 1.1.17
                Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                Adapter    "history"      : 2.2.0    , installed 2.2.1
                Adapter    "homeconnect"  : 1.0.1    , installed 1.0.1
                Adapter    "hue-extended" : 2.0.0    , installed 2.0.1
                Adapter    "ical"         : 1.13.1   , installed 1.13.1
                Adapter    "info"         : 1.9.19   , installed 1.9.19
                Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
                Adapter    "javascript"   : 6.0.0    , installed 6.0.0
                Controller "js-controller": 4.0.23   , installed 4.0.23
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                Adapter    "node-red"     : 3.3.1    , installed 4.0.0
                Adapter    "onvif"        : 0.4.4    , installed 0.4.5
                Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                Adapter    "parser"       : 1.1.8    , installed 1.1.8
                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                Adapter    "proxy"        : 1.3.1    , installed 1.3.1
                Adapter    "renault"      : 0.0.13   , installed 0.0.13
                Adapter    "ring"         : 3.0.4    , installed 3.1.1
                Adapter    "sayit"        : 1.12.3   , installed 1.12.6
                Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
                Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
                Adapter    "socketio"     : 4.2.0    , installed 6.1.10
                Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                Adapter    "synology"     : 2.1.9    , installed 2.1.9
                Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                Adapter    "telegram"     : 1.13.0   , installed 1.14.1
                Adapter    "text2command" : 2.2.2    , installed 2.2.2
                Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                Adapter    "uv-protect"   : 0.3.6    , installed 0.3.6
                Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                Adapter    "vw-connect"   : 0.0.51   , installed 0.0.51
                Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                Adapter    "web"          : 4.3.0    , installed 5.2.5
                Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                Adapter    "wiobrowser"   : 1.1.4    , installed 1.1.4
                Adapter    "worx"         : 1.6.6    , installed 1.6.6
                Adapter    "ws"           : 1.3.0    , installed 2.1.5
                Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
                Adapter    "yr"           : 5.3.0    , installed 5.3.0
                Adapter    "zigbee"       : 1.7.5    , installed 1.7.6
                • H heinzie
                  iob update
                  Active repo(s):
                  Ich würde es sich 'auswachsen' lassen.
                    heinzie
                    Du meinst das es dann irgendwann einfach weider geht?
                    • H heinzie
                      @heinzie
                      Ich meine die beta-Versionen in Ruhe zu lassen und abzuwarten, bis die stabile Version die Nummerierung überholt.
                      Zu dem Problem mit der Systemsteuerung:
                      Iobroker / Container neustarten, Auszug aus dem LogFile bei Versuch die Einstellungen zu erreichen posten.
                      • H Offline
                        heinzie
                        @heinzie
                        Hoffe das ich die Stelle erwischt habe:
                        2022-08-27 19:37:43.495  - error: vis.0 (2260) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2022-08-27 19:37:43.497  - error: vis.0 (2260) unhandled promise rejection: Not exists
                        2022-08-27 19:37:43.502  - error: vis.0 (2260) Error: Not exists
                            at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
                            at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26)
                            at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29)
                            at processImmediate (node:internal/timers:468:21)
                        2022-08-27 19:37:43.505  - error: vis.0 (2260) Not exists
                        2022-08-27 19:37:44.013  - info: vis.0 (2260) terminating
                        2022-08-27 19:37:44.014  - warn: vis.0 (2260) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2022-08-27 19:37:44.822  - error: host.NAS iobroker npm-install: host.NAS Cannot install iobroker.vis@1.4.15: 6
                        2022-08-27 19:37:45.402  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:37:45.455  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:37:45.456  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:37:45.842  - info: host.NAS iobroker npm-install: exit 25
                        2022-08-27 19:37:46.851  - warn: host.NAS startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
                        2022-08-27 19:37:46.852  - info: host.NAS iobroker install vis@1.4.15 using installedVersion
                        2022-08-27 19:37:46.912  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                        2022-08-27 19:37:50.085  - info: host.NAS iobroker npm-install: NPM version: 8.15.0
                        2022-08-27 19:37:50.086  - info: host.NAS iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                        2022-08-27 19:37:54.346  - info: alexa2.0 (726) Unknown Device, but enabling commands, Try it and report back if commands work.
                        2022-08-27 19:37:54.347  - info: alexa2.0 (726) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                        2022-08-27 19:37:54.348  - info: alexa2.0 (726)     Device-type:A324YMIUSWQDGE - Theodor's Samsung TV 2020-Q (Samsung TV 2020-Q) (Samsung TV 2020-Q) (Samsung TV 2020-Q) (Samsung TV 2020-Q) (Samsung TV 2020-Q) (Samsung TV 2020-Q) (SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,CHANGE_NAME,EARCONS,TOUCH_INITIATED,CUSTOM_ALARM_TONE,SET_TIME_ZONE,MUSIC_SKILL,TIDAL,SUPPORTS_LOCALE_SWITCH,DEREGISTER_DEVICE,DIALOG_INTERFACE_VERSION,APPLE_MUSIC,DEEZER,AMAZON_MUSIC,AUDIO_PLAYER,SIRIUSXM,SOUND_SETTINGS,PERSISTENT_CONNECTION,SET_LOCALE,SUPPORTS_LOCALE,MICROPHONE,TIMERS_AND_ALARMS,TUNE_IN,SPEECH_RECOGNIZER_USS,MULTI_WAKEWORDS_SUPPORTED,ASCENDING_ALARM_VOLUME,AUDIBLE,REMINDERS,GOLDFISH,VOLUME_SETTING,DREAM_TRAINING,HANDS_FREE,KINDLE_BOOKS,I_HEART_RADIO,SLEEP,ADAPTIVE_LISTENING)
                        2022-08-27 19:37:55.432  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:37:55.444  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:37:55.445  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:37:56.910  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:01.944  - info: vis.0 (2632) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.17.0, js-controller: 4.0.23
                        2022-08-27 19:38:02.089  - info: vis.0 (2632) vis license is OK.
                        2022-08-27 19:38:02.429  - error: vis.0 (2632) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2022-08-27 19:38:02.431  - error: vis.0 (2632) unhandled promise rejection: Not exists
                        2022-08-27 19:38:02.434  - error: vis.0 (2632) Error: Not exists
                        2022-08-27 19:38:02.455  - error: vis.0 (2632) Not exists
                        2022-08-27 19:38:02.998  - info: vis.0 (2632) terminating
                        2022-08-27 19:38:02.999  - warn: vis.0 (2632) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2022-08-27 19:38:04.125  - error: host.NAS iobroker npm-install: host.NAS Cannot install iobroker.vis@1.4.15: 6
                        2022-08-27 19:38:05.268  - info: host.NAS iobroker npm-install: exit 25
                        2022-08-27 19:38:06.268  - error: host.NAS Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                        2022-08-27 19:38:06.606  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:06.651  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:06.652  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:08.834  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:12.094  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:13.028  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Power_Grid_Voltage" has to be stringified but received type "number"
                        2022-08-27 19:38:13.688  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Power_Grid_Current" has to be stringified but received type "number"
                        2022-08-27 19:38:14.616  - info: alexa2.0 (726) Unknown Device, but enabling commands, Try it and report back if commands work.
                        2022-08-27 19:38:14.617  - info: alexa2.0 (726) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                        2022-08-27 19:38:14.618  - info: alexa2.0 (726)     Device-type:A2QAQUVM4NZTWI - Theodor's Bar 5.0 MultiBeam (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (Bar 5.0 MultiBeam) (SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,CHANGE_NAME,EARCONS,CUSTOM_ALARM_TONE,SET_TIME_ZONE,MUSIC_SKILL,TIDAL,SUPPORTS_LOCALE_SWITCH,EQUALIZER_CONTROLLER_TREBLE,DEREGISTER_DEVICE,DIALOG_INTERFACE_VERSION,APPLE_MUSIC,AUDIO_CONTROLS,DEEZER,AMAZON_MUSIC,AUDIO_PLAYER,SIRIUSXM,SOUND_SETTINGS,PERSISTENT_CONNECTION,SET_LOCALE,SUPPORTS_LOCALE,MICROPHONE,TIMERS_AND_ALARMS,TUNE_IN,SPEECH_RECOGNIZER_USS,MULTI_WAKEWORDS_SUPPORTED,ASCENDING_ALARM_VOLUME,AUDIBLE,REMINDERS,EQUALIZER_CONTROLLER_BASS,GOLDFISH,VOLUME_SETTING,EQUALIZER_CONTROLLER_MIDRANGE,DREAM_TRAINING,MIC_LESS,HANDS_FREE,KINDLE_BOOKS,I_HEART_RADIO,SLEEP,ADAPTIVE_LISTENING)
                        2022-08-27 19:38:15.138  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Peak_Active_Power_of_current_Day" has to be stringified but received type "number"
                        2022-08-27 19:38:16.818  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:16.825  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:17.323  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Efficiency" has to be type "number" but received type "object"
                        2022-08-27 19:38:19.587  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:26.166  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:26.173  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:26.174  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:28.604  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:30.546  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:30.695  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:30.697  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:33.696  - error: growatt.0 (1083) Growatt exception: AxiosError: Request failed with status code 588
                        2022-08-27 19:38:36.314  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:36.320  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:36.321  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:38.182  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:42.649  - info: smartcontrol.0 (1016) Trigger [Bew. Büro] activated but current brightness of 32 is >= threshold of 20 -> Motion disregarded.
                        2022-08-27 19:38:45.329  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:45.351  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:46.709  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:54.930  - info: alexa2.0 (726) Subscribing to states...
                        2022-08-27 19:38:55.327  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:55.334  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:38:57.574  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
                        2022-08-27 19:38:58.197  - info: alexa2.0 (726) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2022-08-27 19:39:06.147  - info: node-red.0 (540) State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
                        2022-08-27 19:39:06.155  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        2022-08-27 19:39:06.158  - info: javascript.0 (577) State value to set for "0_userdata.0.Solar.Einspeisung" has to be type "number" but received type "string"
                        • H heinzie
                          @heinzie
                          @heinzie
                          Ich sehe da überwiegend das bekannte Problem mit vis.
                            @heinzie
                            heinzie
                            @heinzie
                            Habe heute nochmal neu aufgesetzt. Bis zur Installation von 10 Adaptern funktinierte es noch. Wenn ich mehr instaliere kommt wieder der Fehler. Das ist aber unabhäging von den Adaptern. Ich muss nur eine gewisse Anzahl von Adaptern überschreiten dann kommt wieder Fehler. Deshalb vermute ich, dass es einfach nur ein Performance Problem ist. Deshalb auch die Fehlermeldung "Cannot read settings: timeout"
                            Kann man ggf. die timeout Zeit irgendwo vorgeben?
