  4. Fehlermeldung bei Insatallation von Javascript/Node.js
5 Beiträge 3 Kommentatoren 1.1k Aufrufe
  • C Offline
    cburger
    Hallo Zusammen,
    möchte mich gerade im Javascript üben, allerdings bekomme ich schon eine Fehlermeldung bei der Installation des Javascript/node.js Adapter:
    In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
    #include <dns_sd.h>
    ! compilation terminated.
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
    gyp
    ERR! build error
    gyp
    ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
    ! gyp ERR! System Linux 4.4.50-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns
    gyp ERR! node -v v4.8.0
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    ! npm
    ERR! Linux 4.4.50-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.yahka" "--production" "--prefix" "/opt/iobroker"
    ! npm ERR! node v4.8.0npm ERR! npm v2.15.11
    npm ERR! code ELIFECYCLE
    ! npm ERR! mdns@2.3.3 install: node-gyp rebuild
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the mdns@2.3.3 install script 'node-gyp rebuild'.
    npm ERR! This is most likely a problem with the mdns package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs mdns
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR! npm owner ls mdns
    npm ERR! There is likely additional logging output above.
    ! npm
    ERR! Please include the following file with any support request:
    npm ERR! /npm-debug.log
    ERROR: host.raspberrypi3 Cannot install iobroker.yahka: 1
    ERROR: process exited with code 25</dns_sd.h>
    Danke für eure Hilfe
    Christoph
    CCU3 mit 2 Extender mit >515 Kanäle an 84 Homematic und HomematicIP Geräten / Iobroker @ Raspberry 3 / SQL Server @ Synology NAS / WebMatic im Einsatz
      @cburger:
      bei der Installation des Javascript/node.js Adapter `
      @cburger:
      Cannot install iobroker.yahka: 1 `
      Das ist der Homekit-Adapter.
      Rainer
      • C Offline
        cburger
        Danke - muss mich da wohl erst reinarbeiten …
        • apollon77A Offline
          man braucht in dem Fall noch ein paa weitere Linux-Libraries:
          sudo apt-get install libavahi-compat-libdnssd-dev
          z.B.
          • C Offline
            cburger
            Danke apollon77 für die schnelle Antwort.
            Hatte Probleme mit Javascript Entwicklung und dachte diese Instanz sei die Lösung.
