  4. Admin Adapter wird immer wieder gestoppt
    5.8k
63 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
    @hanni700
    iobroker stop
    iobroker update
    iobroker upgrade admin@5.3.8 --debug
    Hanni700
    schrieb am zuletzt editiert von Hanni700
    @thomas-braun said in Admin Adapter wird immer wieder gestoppt:
    > iobroker stop        > pi@raspberrypi:/opt/iobroker $ iobroker update
    > Used repository: Stable (default)
    > Adapter    "alexa2"       : 3.11.2   , installed 3.12.0
    > Adapter    "backitup"     : 2.4.10   , installed 2.4.9  [Updatable]
    > Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    > Adapter    "devices"      : 1.0.12   , installed 1.0.10 [Updatable]
    > Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
    > Adapter    "echarts"      : 1.0.12   , installed 1.0.8  [Updatable]
    > Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
    > Adapter    "flot"         : 1.11.0   , installed 1.11.0
    > Adapter    "ham"          : 4.0.2    , installed 5.0.2
    > Adapter    "ham-wemo"     : 3.0.0    , installed 3.0.0
    > Adapter    "history"      : 2.2.0    , installed 2.1.2  [Updatable]
    > Adapter    "hue"          : 3.7.0    , installed 3.7.0
    > Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    > Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
    > Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    > Adapter    "info"         : 1.9.19   , installed 1.9.19
    > Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    > Controller "js-controller": 4.0.23   , installed 4.0.23
    > Adapter    "kecontact"    : 1.4.1    , installed 1.4.0  [Updatable]
    > Adapter    "modbus"       : 5.0.4    , installed 5.0.3  [Updatable]
    > Adapter    "mqtt"         : 3.0.6    , installed 3.0.5  [Updatable]
    > Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
    > Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    > Adapter    "parser"       : 1.1.7    , installed 1.1.6  [Updatable]
    > Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    > Adapter    "rssfeed"      : 1.0.0    , installed 1.0.0
    > Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    > Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
    > Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    > Adapter    "socketio"     : 4.2.0    , installed 6.1.4
    > Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    > Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    > Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    > Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    > Adapter    "trashschedule": 2.0.3    , installed 1.4.3  [Updatable]
    > Adapter    "tuya"         : 3.6.15   , installed 3.6.15
    > Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    > Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
    > Adapter    "vis"          : 1.4.15   , installed 1.4.15
    > Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    > Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    > Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
    > Adapter    "vw-connect"   : 0.0.51   , installed 0.0.50 [Updatable]
    > Adapter    "web"          : 4.3.0    , installed 5.2.0
    > Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    > Adapter    "wifilight"    : 1.1.4    , installed 1.1.3  [Updatable]
    > Adapter    "ws"           : 1.3.0    , installed 2.1.3
    > Adapter    "zehnder-cloud": 0.0.6    , installed 0.0.6
    > spberrypi:/opt/iobroker $  iobroker upgrade admin@5.3.8
    This upgrade of "admin" will at least introduce the following changes:
    -> 5.3.8:
    Changed the datapoint history list
    Added support of swagger adapter
    -> 5.3.7:
    Changed the charts rendering
    -> 5.3.6:
    Corrected the host selector in "add instance" dialog
    corrected display of "null" values, e.g. by time/date
    -> 5.3.5:
    -> 5.3.4:
    Fix some crash cases reported by Sentry
    Corrected user tab
    -> 5.3.3:
    Implemented the objects coloring depends on other states
    -> 5.3.2:
    added Radio Buttons for value2table
    Corrected many GUI errors
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @0.0.0 to @5.3.8 now? [(y)es, (n)o]: y
    Update admin from @0.0.0 to @5.3.8
    NPM version: 8.11.0
    Installing iobroker.admin@5.3.8... (System call)
    host.raspberrypi Cannot install iobroker.admin@5.3.8: 1
    • H Hanni700
      -> 5.3.8:
      -> 5.3.7:
      -> 5.3.6:
      -> 5.3.5:
      -> 5.3.4:
      Corrected user tab
      -> 5.3.3:
      -> 5.3.2:
      NPM version: 8.11.0
      @hanni700
      iobroker upgrade all
      H 1 Antwort Letzte Antwort
        @hanni700
        Hanni700
        Dann wird bei allen adaptern gefragt, ob ich sie udgraden will. Soll ich dann bei allen mit y bestätigen? Das dauert sicher was....
        • DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          Also mir kommt die ganze Installation schon komisch vor... @Hanni700 ist im "Stable" aber super viele Adapter sind vom "Latest" auch der "ham"... kann mich aber auch mal wieder täuschen 😰
          Lehrling seit 1975 !!!
          • H Hanni700
            @hanni700 sagte in Admin Adapter wird immer wieder gestoppt:
            Genau das sollst du tun.
            Hättest du schon vor dem Wechsel auf nodejs16 / npm8 machen sollen.
            H 2 Antworten Letzte Antwort
              Hanni700
              Das hatte ich vom Webinterface schon versucht, aber irgendwie ging das nicht. Dann mache ich das jetzt und melde mich mit dem Ergebnis....
              • H Hanni700
                Vermutlich weil da bereits was quer saß. Da knallt man dann aber nicht auch noch eine andere nodejs/npm-Version drauf, um das Chaos dann perfekt zu machen.
                • DJMarc75D DJMarc75
                  @djmarc75 sagte in Admin Adapter wird immer wieder gestoppt:
                  ja!
                  ich sehe nur ham und die zusammenhängenden mit web, socket und ws
                    ja!
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    @homoran sagte in Admin Adapter wird immer wieder gestoppt:
                    ok, scheint ja dann damit wohl nix zu tun haben wenn diese Adapter aus dem Latest kommen dürfen - halte mich dann raus...
                      Hanni700
                      habe ich gemacht:
                      pi@raspberrypi:/opt/iobroker $ iobroker upgrade all
                      This upgrade of "wifilight" will introduce the following changes:
                      -> 1.1.4:
                      Prevent crash case reported by sentry
                      Would you like to upgrade wifilight from @1.1.3 to @1.1.4 now? [(y)es, (n)o]: y
                      Update wifilight from @1.1.3 to @1.1.4
                      NPM version: 8.11.0
                      Installing iobroker.wifilight@1.1.4... (System call)
                      Update "system.adapter.wifilight.0"
                      upload [12] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [11] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [10] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [9] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [8] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [7] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [6] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [5] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [4] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [3] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [2] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/index.html index.html text/html
                      upload [1] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/wifilight.png wifilight.png image/png
                      upload [0] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/words.js words.js application/javascript
                      This upgrade of "vw-connect" will introduce the following changes:
                      -> 0.0.51:
                      fix Audi etron login
                      Would you like to upgrade vw-connect from @0.0.50 to @0.0.51 now? [(y)es, (n)o]: y
                      Update vw-connect from @0.0.50 to @0.0.51
                      NPM version: 8.11.0
                      Installing iobroker.vw-connect@0.0.51... (System call)
                      Update "system.adapter.vw-connect.0"
                      upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
                      upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
                      upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
                      upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
                      upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
                      This upgrade of "shelly" will introduce the following changes:
                      -> 6.0.0:
                      Important: The adapter now requires at least Node.js 14.5
                      * Added Shelly TRV (beta)
                      * Just publish data to Shelly device, if value changed
                      * **Breaking**: Configuration is only working in the new Admin 5 UI
                      * **Breaking**: Uptime is now a number (seconds since boot)
                      Would you like to upgrade shelly from @5.3.2 to @6.0.0 now? [(y)es, (n)o]: y
                      Update shelly from @5.3.2 to @6.0.0
                      NPM version: 8.11.0
                      Installing iobroker.shelly@6.0.0... (System call)
                      Update "system.adapter.shelly.0"
                      upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
                      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                      This upgrade of "parser" will introduce the following changes:
                      -> 1.1.7:
                      Fix potential crash cases reported by Sentry
                      Would you like to upgrade parser from @1.1.6 to @1.1.7 now? [(y)es, (n)o]: y
                      Update parser from @1.1.6 to @1.1.7
                      NPM version: 8.11.0
                      Installing iobroker.parser@1.1.7... (System call)
                      Update "system.adapter.parser.0"
                      upload [13] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [12] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [11] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [10] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [9] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [8] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [7] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [6] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [5] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [4] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [3] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/index.html index.html text/html
                      upload [2] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/index_m.html index_m.html text/html
                      upload [1] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/parser.png parser.png image/png
                      upload [0] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/words.js words.js application/javascript
                      This upgrade of "mqtt" will introduce the following changes:
                      -> 3.0.6:
                      Allows to use some special characters like # in client passwords
                      Correct handing of `QoS 2` messages
                      Implement resend support of pubrec
                      When resending a package set the dup flag as required by specs
                      Add more debug for special debug mode
                      Would you like to upgrade mqtt from @3.0.5 to @3.0.6 now? [(y)es, (n)o]: y
                      Update mqtt from @3.0.5 to @3.0.6
                      NPM version: 8.11.0
                      Installing iobroker.mqtt@3.0.6... (System call)
                      Update "system.adapter.mqtt.1"
                      upload [12] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [11] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [10] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [9] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [8] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [7] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [6] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [5] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [4] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
                      upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/jsonConfig.json jsonConfig.json application/json
                      upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
                      This upgrade of "modbus" will introduce the following changes:
                      -> 5.0.4:
                      Corrected the coils reading in slave mode
                      Corrected type of connection indicator
                      Would you like to upgrade modbus from @5.0.3 to @5.0.4 now? [(y)es, (n)o]: y
                      Update modbus from @5.0.3 to @5.0.4
                      NPM version: 8.11.0
                      Installing iobroker.modbus@5.0.4... (System call)
                      Update "system.adapter.modbus.0"
                      Update "system.adapter.modbus.1"
                      upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
                      upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                      upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
                      upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
                      upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                      upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.fb1757a1.css static/css/main.fb1757a1.css text/css
                      upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.fb1757a1.css.map static/css/main.fb1757a1.css.map application/json
                      upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.40825b5f.js static/js/main.40825b5f.js application/javascript
                      upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.40825b5f.js.LICENSE.txt static/js/main.40825b5f.js.LICENSE.txt text/plain
                      upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.40825b5f.js.map static/js/main.40825b5f.js.map application/json
                      This upgrade of "kecontact" will introduce the following changes:
                      -> 1.4.1:
                      separate states for charging and discharging battery storage, additional states to (de)authorize or unlock charging station and set date/time, fix unsubscribing foreign states (sentry IOBROKER-KECONTACT-10)
                      Would you like to upgrade kecontact from @1.4.0 to @1.4.1 now? [(y)es, (n)o]: y
                      Update kecontact from @1.4.0 to @1.4.1
                      NPM version: 8.11.0
                      Installing iobroker.kecontact@1.4.1... (System call)
                      Update "system.adapter.kecontact.0"
                      upload [5] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/admin.d.ts admin.d.ts video/mp2t
                      upload [4] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/custom_m.html custom_m.html text/html
                      upload [3] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/index_m.html index_m.html text/html
                      upload [2] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/kecontact.png kecontact.png image/png
                      upload [1] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/style.css style.css text/css
                      upload [0] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/words.js words.js application/javascript
                      This upgrade of "ical" will introduce the following changes:
                      -> 1.13.1:
                      Changed request library
                      -> 1.13.0:
                      Added Admin 5 UI
                      Translated all object names
                      -> 1.12.2:
                      Fix displaying rest-time of event in one case
                      Would you like to upgrade ical from @1.12.1 to @1.13.1 now? [(y)es, (n)o]: y
                      Update ical from @1.12.1 to @1.13.1
                      NPM version: 8.11.0
                      Installing iobroker.ical@1.13.1... (System call)
                      Update "system.adapter.ical.0"
                      Update "system.adapter.ical.1"
                      upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                      upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                      upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
                      upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                      This upgrade of "history" will introduce the following changes:
                      -> 2.2.0:
                      make sure getHistory works for all cases
                      Add option to add comment and user info to results
                      -> 2.1.7:
                      Allow to remove a configuration value for "round" in config again
                      -> 2.1.6:
                      When not count is provided for aggregate "none" or "onchange" then the limit (default 2000) is used as count to define the number of data to return.
                      -> 2.1.5:
                      Ignore errors from forked process after response was sent for GetHistory
                      -> 2.1.4:
                      Make sure debug log is active according to the settings
                      -> 2.1.3:
                      Huge performance optimizations for GetHistory calls
                      Would you like to upgrade history from @2.1.2 to @2.2.0 now? [(y)es, (n)o]: y
                      Update history from @2.1.2 to @2.2.0
                      NPM version: 8.11.0
                      Installing iobroker.history@2.2.0... (System call)
                      Update "system.adapter.history.0"
                      upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                      upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                      upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                      upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                      This upgrade of "echarts" will introduce the following changes:
                      -> 1.0.12:
                      Made it work with ioBroker cloud
                      -> 1.0.10:
                      Corrected the problem with `socket.io`
                      -> 1.0.9:
                      Added 2 weeks as relative period
                      Would you like to upgrade echarts from @1.0.8 to @1.0.12 now? [(y)es, (n)o]: y
                      Update echarts from @1.0.8 to @1.0.12
                      NPM version: 8.11.0
                      Installing iobroker.echarts@1.0.12... (System call)
                      upload [14] echarts /opt/iobroker/node_modules/iobroker.echarts/www/asset-manifest.json asset-manifest.json application/json
                      upload [13] echarts /opt/iobroker/node_modules/iobroker.echarts/www/favicon.ico favicon.ico image/vnd.microsoft.icon
                      upload [12] echarts /opt/iobroker/node_modules/iobroker.echarts/www/index.html index.html text/html
                      upload [11] echarts /opt/iobroker/node_modules/iobroker.echarts/www/manifest.json manifest.json application/json
                      upload [10] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/2.fcd307b3.chunk.css static/css/2.fcd307b3.chunk.css text/css
                      upload [9] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/2.fcd307b3.chunk.css.map static/css/2.fcd307b3.chunk.css.map application/json
                      upload [8] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.47916834.chunk.css static/css/main.47916834.chunk.css text/css
                      upload [7] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.47916834.chunk.css.map static/css/main.47916834.chunk.css.map application/json
                      upload [6] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/2.b5f07201.chunk.js static/js/2.b5f07201.chunk.js application/javascript
                      upload [5] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/2.b5f07201.chunk.js.LICENSE.txt static/js/2.b5f07201.chunk.js.LICENSE.txt text/plain
                      upload [4] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/2.b5f07201.chunk.js.map static/js/2.b5f07201.chunk.js.map application/json
                      upload [3] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.48bdb390.chunk.js static/js/main.48bdb390.chunk.js application/javascript
                      upload [2] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.48bdb390.chunk.js.map static/js/main.48bdb390.chunk.js.map application/json
                      upload [1] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/runtime-main.41dbf396.js static/js/runtime-main.41dbf396.js application/javascript
                      upload [0] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/runtime-main.41dbf396.js.map static/js/runtime-main.41dbf396.js.map application/json
                      Update "system.adapter.echarts.0"
                      upload [31] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/asset-manifest.json asset-manifest.json application/json
                      upload [30] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/asset-manifest.json chart/asset-manifest.json application/json
                      upload [20] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/2.b5f07201.chunk.js.map chart/static/js/2.b5f07201.chunk.js.map application/json
                      upload [19] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.48bdb390.chunk.js chart/static/js/main.48bdb390.chunk.js application/javascript
                      upload [18] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.48bdb390.chunk.js.map chart/static/js/main.48bdb390.chunk.js.map application/json
                      upload [17] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/runtime-main.41dbf396.js chart/static/js/runtime-main.41dbf396.js application/javascript
                      upload [16] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/runtime-main.41dbf396.js.map chart/static/js/runtime-main.41dbf396.js.map application/json
                      upload [15] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/echarts.png echarts.png image/png
                      upload [14] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                      upload [13] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/manifest.json manifest.json application/json
                      upload [12] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/2.8295ec30.chunk.css static/css/2.8295ec30.chunk.css text/css
                      upload [11] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/2.8295ec30.chunk.css.map static/css/2.8295ec30.chunk.css.map application/json
                      upload [10] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/main.a34c3d8f.chunk.css static/css/main.a34c3d8f.chunk.css text/css
                      upload [9] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/main.a34c3d8f.chunk.css.map static/css/main.a34c3d8f.chunk.css.map application/json
                      upload [8] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/2.8753f1c9.chunk.js static/js/2.8753f1c9.chunk.js application/javascript
                      upload [7] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/2.8753f1c9.chunk.js.LICENSE.txt static/js/2.8753f1c9.chunk.js.LICENSE.txt text/plain
                      upload [6] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/2.8753f1c9.chunk.js.map static/js/2.8753f1c9.chunk.js.map application/json
                      upload [5] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.a9954af5.chunk.js static/js/main.a9954af5.chunk.js application/javascript
                      upload [4] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.a9954af5.chunk.js.map static/js/main.a9954af5.chunk.js.map application/json
                      upload [3] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/runtime-main.07a098e2.js static/js/runtime-main.07a098e2.js application/javascript
                      upload [2] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/runtime-main.07a098e2.js.map static/js/runtime-main.07a098e2.js.map application/json
                      upload [1] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/tab.html tab.html text/html
                      upload [0] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                      This upgrade of "discovery" will introduce the following changes:
                      -> 3.0.5:
                      -> 3.0.4:
                      Disable configuration settings for this adapter
                      Would you like to upgrade discovery from @3.0.3 to @3.0.5 now? [(y)es, (n)o]: y
                      Update discovery from @3.0.3 to @3.0.5
                      NPM version: 8.11.0
                      Installing iobroker.discovery@3.0.5... (System call)
                      Update "system.adapter.discovery.0"
                      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                      This upgrade of "devices" will introduce the following changes:
                      -> 1.0.12:
                      Allowed to work with devices behind reverse proxy
                      Replaced the function icon
                      -> 1.0.11:
                      Updated some libraries
                      Would you like to upgrade devices from @1.0.10 to @1.0.12 now? [(y)es, (n)o]: y
                      Update devices from @1.0.10 to @1.0.12
                      NPM version: 8.11.0
                      Installing iobroker.devices@1.0.12... (System call)
                      INFO: Directory "/opt/iobroker/node_modules/iobroker.devices/www" was not found! Nothing was uploaded or deleted.
                      Update "system.adapter.devices.0"
                      upload [136] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/asset-manifest.json asset-manifest.json application/json
                      upload [100] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Consumption.fecd7a10.svg static/media/Consumption.fecd7a10.svg image/svg+xml
                      upload [90] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Driveway.fbd31101.svg static/media/Driveway.fbd31101.svg image/svg+xml
                      upload [80] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Garden.51c2e94f.svg static/media/Garden.51c2e94f.svg image/svg+xml
                      upload [70] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Heater.b53bccc3.svg static/media/Heater.b53bccc3.svg image/svg+xml
                      upload [60] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Light.21f1a5df.svg static/media/Light.21f1a5df.svg image/svg+xml
                      upload [50] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Office.7e6a3821.svg static/media/Office.7e6a3821.svg image/svg+xml
                      upload [40] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Receiver.26b5ae16.svg static/media/Receiver.26b5ae16.svg image/svg+xml
                      upload [30] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Speaker.db548379.svg static/media/Speaker.db548379.svg image/svg+xml
                      upload [20] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Toilet.83604dd2.svg static/media/Toilet.83604dd2.svg image/svg+xml
                      upload [19] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Tv.4e9745a5.svg static/media/Tv.4e9745a5.svg image/svg+xml
                      upload [18] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Upstairs.441813e5.svg static/media/Upstairs.441813e5.svg image/svg+xml
                      upload [17] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Vacuum Cleaner.9c8d50e4.svg static/media/Vacuum Cleaner.9c8d50e4.svg image/svg+xml
                      upload [16] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Ventilation.c31761d8.svg static/media/Ventilation.c31761d8.svg image/svg+xml
                      upload [15] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Wardrobe.e8019970.svg static/media/Wardrobe.e8019970.svg image/svg+xml
                      upload [14] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Washing Machines.577f3acd.svg static/media/Washing Machines.577f3acd.svg image/svg+xml
                      upload [13] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Washroom.bfb54196.svg static/media/Washroom.bfb54196.svg image/svg+xml
                      upload [12] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water Consumption.68891649.svg static/media/Water Consumption.68891649.svg image/svg+xml
                      upload [11] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water Heater.7e4bb4d9.svg static/media/Water Heater.7e4bb4d9.svg image/svg+xml
                      upload [10] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water.f5041198.svg static/media/Water.f5041198.svg image/svg+xml
                      upload [9] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Wc.83604dd2.svg static/media/Wc.83604dd2.svg image/svg+xml
                      upload [8] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Weather.e91dae64.svg static/media/Weather.e91dae64.svg image/svg+xml
                      upload [7] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Window.421664f5.svg static/media/Window.421664f5.svg image/svg+xml
                      upload [6] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Windscreen.6058448b.svg static/media/Windscreen.6058448b.svg image/svg+xml
                      upload [5] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Workshop.7856e59f.svg static/media/Workshop.7856e59f.svg image/svg+xml
                      upload [4] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Workspace.97d73e41.svg static/media/Workspace.97d73e41.svg image/svg+xml
                      upload [3] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.3a7dae0b.txt static/media/names.3a7dae0b.txt text/plain
                      upload [2] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.e7efb528.txt static/media/names.e7efb528.txt text/plain
                      upload [1] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/tab.html tab.html text/html
                      upload [0] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                      This upgrade of "backitup" will introduce the following changes:
                      -> 2.4.10:
                      Code cleaning
                      dependencies updated
                      Disclaimer added
                      Travis Support removed
                      Fix backup-download with ssl
                      Would you like to upgrade backitup from @2.4.9 to @2.4.10 now? [(y)es, (n)o]: y
                      Update backitup from @2.4.9 to @2.4.10
                      host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                      NPM version: 8.11.0
                      Installing iobroker.backitup@2.4.10... (System call)
                      Update "system.adapter.backitup.0"
                      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                      host.raspberrypi Adapter "system.adapter.backitup.0" is started
                      This upgrade of "trashschedule" will introduce the following changes:
                      -> 2.0.3:
                      Allow whitespaces in the match pattern
                      -> 2.0.2:
                      Fixed error handling for trash types with empty name
                      -> 2.0.1:
                      Added ical instance as comment for states
                      Just update states if value changed
                      -> 2.0.0:
                      NodeJS 14.x is required (NodeJS 12.x is EOL)
                      * Added timestamp of last and next refresh
                      * Added icon to channels and fixed color
                      * Added default trash types for new installations
                      * Updated dependency for ical to 1.12.1
                      * Updated depedency for js-controller to 4.0.15
                      -> 1.4.5:
                      Allow spaces in next text seperator
                      -> 1.4.4:
                      Updated dependencies
                      Would you like to upgrade trashschedule from @1.4.3 to @2.0.3 now? [(y)es, (n)o]: y
                      Update trashschedule from @1.4.3 to @2.0.3
                      NPM version: 8.11.0
                      Installing iobroker.trashschedule@2.0.3... (System call)
                      Adapter "system.adapter.vis.0" restarted.
                      Update "system.adapter.trashschedule.0"
                      upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/index_m.html index_m.html text/html
                      upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                      upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                      ist ohne Fehler durchgelaufen, aber trotzdem kommt:
                      • H Hanni700
                        habe ich gemacht:
                        -> 1.1.4:
                        NPM version: 8.11.0
                        -> 0.0.51:
                        NPM version: 8.11.0
                        -> 6.0.0:
                        NPM version: 8.11.0
                        -> 1.1.7:
                        NPM version: 8.11.0
                        -> 3.0.6:
                        NPM version: 8.11.0
                        -> 5.0.4:
                        NPM version: 8.11.0
                        -> 1.4.1:
                        NPM version: 8.11.0
                        -> 1.13.1:
                        -> 1.13.0:
                        Added Admin 5 UI
                        -> 1.12.2:
                        NPM version: 8.11.0
                        -> 2.2.0:
                        -> 2.1.7:
                        -> 2.1.6:
                        -> 2.1.5:
                        -> 2.1.4:
                        -> 2.1.3:
                        NPM version: 8.11.0
                        -> 1.0.12:
                        -> 1.0.10:
                        -> 1.0.9:
                        NPM version: 8.11.0
                        -> 3.0.5:
                        -> 3.0.4:
                        NPM version: 8.11.0
                        -> 1.0.12:
                        -> 1.0.11:
                        NPM version: 8.11.0
                        -> 2.4.10:
                        Code cleaning
                        Disclaimer added
                        NPM version: 8.11.0
                        -> 2.0.3:
                        -> 2.0.2:
                        -> 2.0.1:
                        -> 2.0.0:
                        -> 1.4.5:
                        -> 1.4.4:
                        NPM version: 8.11.0
                        iobroker upgrade ical --debug
                          Hanni700
                          pi@raspberrypi:/opt/iobroker $ iobroker upgrade ical --debug
                          -> 1.13.1:
                          -> 1.13.0:
                          Added Admin 5 UI
                          -> 1.12.2:
                          NPM version: 8.11.0
                          npm ERR! code EBADENGINE
                          npm ERR! engine Unsupported engine
                          npm ERR! engine Not compatible with your version of node/npm: homebridge-lib@4.7.16
                          npm ERR! notsup Not compatible with your version of node/npm: homebridge-lib@4.7.16
                          npm ERR! notsup Required: {"homebridge":"^1.1.0","node":"^12.19.0"}
                          npm ERR! notsup Actual:   {"npm":"8.11.0","node":"v16.16.0"}
                          npm ERR!     /home/iobroker/.npm/_logs/2022-08-14T14_17_37_656Z-debug-0.log
                          • H Hanni700
                            -> 1.13.1:
                            -> 1.13.0:
                            Added Admin 5 UI
                            -> 1.12.2:
                            NPM version: 8.11.0
                            code EBADENGINE
                            immer noch!
                            wo steckt das ding?
                            Mal die package-lock.json löschen?
                            • H Hanni700
                              -> 1.13.1:
                              -> 1.13.0:
                              Added Admin 5 UI
                              -> 1.12.2:
                              NPM version: 8.11.0
                              homebridge
                              cd /opt/iobroker
                              npm ls homebridge homebridge-lib
                                homebridge
                                cd /opt/iobroker
                                Hanni700
                                cd /opt/iobroker
                                pi@raspberrypi:/opt/iobroker $ npm ls homebridge homebridge-lib
                                iobroker.inst@2.0.3 /opt/iobroker
                                └── (empty)
                                • H Hanni700
                                  cd /opt/iobroker
                                  └── (empty)
                                  @hanni700
                                  Lösch mal wie von @Homoran vorgeschlagen die package-lock.json
                                    @hanni700
                                    Hanni700
                                    Kannst Du mir bitte sagen, wie ich das mache (bzw. wo ich die finde)?
                                    Gefunden und gelöscht, und nun nochmal upgrade ical?
                                    H HomoranH 2 Antworten Letzte Antwort
                                    • H Hanni700
                                      Hanni700
                                      @hanni700
                                      Bleibt dabei:
                                      -> 1.13.1:
                                      -> 1.13.0:
                                      Added Admin 5 UI
                                      -> 1.12.2:
                                      NPM version: 8.11.0
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-14T14_38_42_708Z-debug-0.log
                                      • H Hanni700
                                        musste selber suchen
                                        cd /opt/iobroker
                                        sudo rm package-lock.json
                                          cd /opt/iobroker
                                          Hanni700
                                          Hat funktioniert, habre es gelöscht, aber das EWrgebnis beim upgrade ist noch so wie vorher
