  4. Admin Adapter wird immer wieder gestoppt
    5.8k
63 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
    @hanni700
    Versuch mal
    iobroker stop
    iobroker del iobroker.ham-wemo
    iobroker del iobroker.admin
    iobroker update
    iobroker upgrade all
    Hanni700
    @thomas-braun said in Admin Adapter wird immer wieder gestoppt:
    pi@raspberrypi:/opt/iobroker $ iobroker del iobroker.ham-wemo
    Delete adapter "ham-wemo"
    host.raspberrypi Counted 1 meta of ham-wemo
    host.raspberrypi Counted 1 adapter for ham-wemo
    host.raspberrypi Counted 1 states (system.adapter.ham-wemo.*) from states
    host.raspberrypi file ham-wemo.admin deleted
    host.raspberrypi object ham-wemo deleted
    host.raspberrypi object ham-wemo.admin deleted
    host.raspberrypi Deleting 2 object(s).
    host.raspberrypi Deleting 1 state(s).
    Error deleting adapter ham-wemo from disk: host.raspberrypi: Cannot uninstall iobroker.ham-wemo: 217
    You might have to delete it yourself!
    pi@raspberrypi:/opt/iobroker $ iobroker del iobroker.admin
    Delete adapter "admin"
    host.raspberrypi Counted 1 instances of admin
    Cannot remove adapter "admin", because instance "backitup" depends on it!
    Muss ich den iobroker vorher stoppen?
    • H Hanni700
      @hanni700
      iobroker stop
      iobroker update
      iobroker upgrade admin@5.3.8 --debug
      H 1 Antwort Letzte Antwort
        @hanni700
        iobroker stop
        iobroker update
        Hanni700
        schrieb am zuletzt editiert von Hanni700
        > iobroker stop        > pi@raspberrypi:/opt/iobroker $ iobroker update
        > Used repository: Stable (default)
        > Adapter    "alexa2"       : 3.11.2   , installed 3.12.0
        > Adapter    "backitup"     : 2.4.10   , installed 2.4.9  [Updatable]
        > Adapter    "cloud"        : 4.1.1    , installed 4.1.1
        > Adapter    "devices"      : 1.0.12   , installed 1.0.10 [Updatable]
        > Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
        > Adapter    "echarts"      : 1.0.12   , installed 1.0.8  [Updatable]
        > Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
        > Adapter    "flot"         : 1.11.0   , installed 1.11.0
        > Adapter    "ham"          : 4.0.2    , installed 5.0.2
        > Adapter    "ham-wemo"     : 3.0.0    , installed 3.0.0
        > Adapter    "history"      : 2.2.0    , installed 2.1.2  [Updatable]
        > Adapter    "hue"          : 3.7.0    , installed 3.7.0
        > Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        > Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
        > Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        > Adapter    "info"         : 1.9.19   , installed 1.9.19
        > Adapter    "javascript"   : 5.7.0    , installed 5.7.0
        > Controller "js-controller": 4.0.23   , installed 4.0.23
        > Adapter    "kecontact"    : 1.4.1    , installed 1.4.0  [Updatable]
        > Adapter    "modbus"       : 5.0.4    , installed 5.0.3  [Updatable]
        > Adapter    "mqtt"         : 3.0.6    , installed 3.0.5  [Updatable]
        > Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
        > Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        > Adapter    "parser"       : 1.1.7    , installed 1.1.6  [Updatable]
        > Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        > Adapter    "rssfeed"      : 1.0.0    , installed 1.0.0
        > Adapter    "scenes"       : 2.3.9    , installed 2.3.9
        > Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
        > Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        > Adapter    "socketio"     : 4.2.0    , installed 6.1.4
        > Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        > Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        > Adapter    "telegram"     : 1.13.0   , installed 1.13.0
        > Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        > Adapter    "trashschedule": 2.0.3    , installed 1.4.3  [Updatable]
        > Adapter    "tuya"         : 3.6.15   , installed 3.6.15
        > Adapter    "unifi"        : 0.5.10   , installed 0.5.10
        > Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
        > Adapter    "vis"          : 1.4.15   , installed 1.4.15
        > Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        > Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
        > Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
        > Adapter    "vw-connect"   : 0.0.51   , installed 0.0.50 [Updatable]
        > Adapter    "web"          : 4.3.0    , installed 5.2.0
        > Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
        > Adapter    "wifilight"    : 1.1.4    , installed 1.1.3  [Updatable]
        > Adapter    "ws"           : 1.3.0    , installed 2.1.3
        > Adapter    "zehnder-cloud": 0.0.6    , installed 0.0.6
        > spberrypi:/opt/iobroker $  iobroker upgrade admin@5.3.8
        This upgrade of "admin" will at least introduce the following changes:
        -> 5.3.8:
        Changed the datapoint history list
        Added support of swagger adapter
        -> 5.3.7:
        Changed the charts rendering
        -> 5.3.6:
        Corrected the host selector in "add instance" dialog
        corrected display of "null" values, e.g. by time/date
        -> 5.3.5:
        -> 5.3.4:
        Fix some crash cases reported by Sentry
        Corrected user tab
        -> 5.3.3:
        Implemented the objects coloring depends on other states
        -> 5.3.2:
        added Radio Buttons for value2table
        Corrected many GUI errors
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade admin from @0.0.0 to @5.3.8 now? [(y)es, (n)o]: y
        Update admin from @0.0.0 to @5.3.8
        NPM version: 8.11.0
        Installing iobroker.admin@5.3.8... (System call)
        host.raspberrypi Cannot install iobroker.admin@5.3.8: 1
        • H Hanni700
          -> 5.3.8:
          -> 5.3.7:
          -> 5.3.6:
          -> 5.3.5:
          -> 5.3.4:
          Corrected user tab
          -> 5.3.3:
          -> 5.3.2:
          NPM version: 8.11.0
          @hanni700
            @hanni700
            Hanni700
            Dann wird bei allen adaptern gefragt, ob ich sie udgraden will. Soll ich dann bei allen mit y bestätigen? Das dauert sicher was....
            • DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              Also mir kommt die ganze Installation schon komisch vor... @Hanni700 ist im "Stable" aber super viele Adapter sind vom "Latest" auch der "ham"... kann mich aber auch mal wieder täuschen 😰
              Lehrling seit 1975 !!!
              • H Hanni700
                @hanni700 sagte in Admin Adapter wird immer wieder gestoppt:
                Genau das sollst du tun.
                Hättest du schon vor dem Wechsel auf nodejs16 / npm8 machen sollen.
                H 2 Antworten Letzte Antwort
                  Hanni700
                  Das hatte ich vom Webinterface schon versucht, aber irgendwie ging das nicht. Dann mache ich das jetzt und melde mich mit dem Ergebnis....
                  • H Hanni700
                    Vermutlich weil da bereits was quer saß. Da knallt man dann aber nicht auch noch eine andere nodejs/npm-Version drauf, um das Chaos dann perfekt zu machen.
                    • DJMarc75D DJMarc75
                      @djmarc75 sagte in Admin Adapter wird immer wieder gestoppt:
                      ja!
                      ich sehe nur ham und die zusammenhängenden mit web, socket und ws
                        ja!
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @homoran sagte in Admin Adapter wird immer wieder gestoppt:
                        ok, scheint ja dann damit wohl nix zu tun haben wenn diese Adapter aus dem Latest kommen dürfen - halte mich dann raus...
                          Hanni700
                          habe ich gemacht:
                          pi@raspberrypi:/opt/iobroker $ iobroker upgrade all
                          This upgrade of "wifilight" will introduce the following changes:
                          -> 1.1.4:
                          Prevent crash case reported by sentry
                          Would you like to upgrade wifilight from @1.1.3 to @1.1.4 now? [(y)es, (n)o]: y
                          Update wifilight from @1.1.3 to @1.1.4
                          NPM version: 8.11.0
                          Installing iobroker.wifilight@1.1.4... (System call)
                          Update "system.adapter.wifilight.0"
                          upload [12] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [11] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [10] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [9] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [8] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [7] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [6] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [5] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [4] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [3] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [2] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/index.html index.html text/html
                          upload [1] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/wifilight.png wifilight.png image/png
                          upload [0] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/words.js words.js application/javascript
                          This upgrade of "vw-connect" will introduce the following changes:
                          -> 0.0.51:
                          fix Audi etron login
                          Would you like to upgrade vw-connect from @0.0.50 to @0.0.51 now? [(y)es, (n)o]: y
                          Update vw-connect from @0.0.50 to @0.0.51
                          NPM version: 8.11.0
                          Installing iobroker.vw-connect@0.0.51... (System call)
                          Update "system.adapter.vw-connect.0"
                          upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
                          upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
                          upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
                          upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
                          upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
                          This upgrade of "shelly" will introduce the following changes:
                          -> 6.0.0:
                          Important: The adapter now requires at least Node.js 14.5
                          * Added Shelly TRV (beta)
                          * Just publish data to Shelly device, if value changed
                          * **Breaking**: Configuration is only working in the new Admin 5 UI
                          * **Breaking**: Uptime is now a number (seconds since boot)
                          Would you like to upgrade shelly from @5.3.2 to @6.0.0 now? [(y)es, (n)o]: y
                          Update shelly from @5.3.2 to @6.0.0
                          NPM version: 8.11.0
                          Installing iobroker.shelly@6.0.0... (System call)
                          Update "system.adapter.shelly.0"
                          upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                          upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
                          upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                          upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                          This upgrade of "parser" will introduce the following changes:
                          -> 1.1.7:
                          Fix potential crash cases reported by Sentry
                          Would you like to upgrade parser from @1.1.6 to @1.1.7 now? [(y)es, (n)o]: y
                          Update parser from @1.1.6 to @1.1.7
                          NPM version: 8.11.0
                          Installing iobroker.parser@1.1.7... (System call)
                          Update "system.adapter.parser.0"
                          upload [13] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [12] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [11] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [10] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [9] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [8] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [7] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [6] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [5] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [4] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [3] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/index.html index.html text/html
                          upload [2] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/index_m.html index_m.html text/html
                          upload [1] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/parser.png parser.png image/png
                          upload [0] parser.admin /opt/iobroker/node_modules/iobroker.parser/admin/words.js words.js application/javascript
                          This upgrade of "mqtt" will introduce the following changes:
                          -> 3.0.6:
                          Allows to use some special characters like # in client passwords
                          Correct handing of `QoS 2` messages
                          Implement resend support of pubrec
                          When resending a package set the dup flag as required by specs
                          Add more debug for special debug mode
                          Would you like to upgrade mqtt from @3.0.5 to @3.0.6 now? [(y)es, (n)o]: y
                          Update mqtt from @3.0.5 to @3.0.6
                          NPM version: 8.11.0
                          Installing iobroker.mqtt@3.0.6... (System call)
                          Update "system.adapter.mqtt.1"
                          upload [12] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [11] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [10] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [9] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [8] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [7] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [6] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [5] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [4] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
                          upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/jsonConfig.json jsonConfig.json application/json
                          upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
                          This upgrade of "modbus" will introduce the following changes:
                          -> 5.0.4:
                          Corrected the coils reading in slave mode
                          Corrected type of connection indicator
                          Would you like to upgrade modbus from @5.0.3 to @5.0.4 now? [(y)es, (n)o]: y
                          Update modbus from @5.0.3 to @5.0.4
                          NPM version: 8.11.0
                          Installing iobroker.modbus@5.0.4... (System call)
                          Update "system.adapter.modbus.0"
                          Update "system.adapter.modbus.1"
                          upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
                          upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                          upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
                          upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
                          upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                          upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.fb1757a1.css static/css/main.fb1757a1.css text/css
                          upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.fb1757a1.css.map static/css/main.fb1757a1.css.map application/json
                          upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.40825b5f.js static/js/main.40825b5f.js application/javascript
                          upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.40825b5f.js.LICENSE.txt static/js/main.40825b5f.js.LICENSE.txt text/plain
                          upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.40825b5f.js.map static/js/main.40825b5f.js.map application/json
                          This upgrade of "kecontact" will introduce the following changes:
                          -> 1.4.1:
                          separate states for charging and discharging battery storage, additional states to (de)authorize or unlock charging station and set date/time, fix unsubscribing foreign states (sentry IOBROKER-KECONTACT-10)
                          Would you like to upgrade kecontact from @1.4.0 to @1.4.1 now? [(y)es, (n)o]: y
                          Update kecontact from @1.4.0 to @1.4.1
                          NPM version: 8.11.0
                          Installing iobroker.kecontact@1.4.1... (System call)
                          Update "system.adapter.kecontact.0"
                          upload [5] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/admin.d.ts admin.d.ts video/mp2t
                          upload [4] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/custom_m.html custom_m.html text/html
                          upload [3] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/index_m.html index_m.html text/html
                          upload [2] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/kecontact.png kecontact.png image/png
                          upload [1] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/style.css style.css text/css
                          upload [0] kecontact.admin /opt/iobroker/node_modules/iobroker.kecontact/admin/words.js words.js application/javascript
                          This upgrade of "ical" will introduce the following changes:
                          -> 1.13.1:
                          Changed request library
                          -> 1.13.0:
                          Added Admin 5 UI
                          Translated all object names
                          -> 1.12.2:
                          Fix displaying rest-time of event in one case
                          Would you like to upgrade ical from @1.12.1 to @1.13.1 now? [(y)es, (n)o]: y
                          Update ical from @1.12.1 to @1.13.1
                          NPM version: 8.11.0
                          Installing iobroker.ical@1.13.1... (System call)
                          Update "system.adapter.ical.0"
                          Update "system.adapter.ical.1"
                          upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                          upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                          upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
                          upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                          This upgrade of "history" will introduce the following changes:
                          -> 2.2.0:
                          make sure getHistory works for all cases
                          Add option to add comment and user info to results
                          -> 2.1.7:
                          Allow to remove a configuration value for "round" in config again
                          -> 2.1.6:
                          When not count is provided for aggregate "none" or "onchange" then the limit (default 2000) is used as count to define the number of data to return.
                          -> 2.1.5:
                          Ignore errors from forked process after response was sent for GetHistory
                          -> 2.1.4:
                          Make sure debug log is active according to the settings
                          -> 2.1.3:
                          Huge performance optimizations for GetHistory calls
                          Would you like to upgrade history from @2.1.2 to @2.2.0 now? [(y)es, (n)o]: y
                          Update history from @2.1.2 to @2.2.0
                          NPM version: 8.11.0
                          Installing iobroker.history@2.2.0... (System call)
                          Update "system.adapter.history.0"
                          upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                          upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                          upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                          upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                          This upgrade of "echarts" will introduce the following changes:
                          -> 1.0.12:
                          Made it work with ioBroker cloud
                          -> 1.0.10:
                          Corrected the problem with `socket.io`
                          -> 1.0.9:
                          Added 2 weeks as relative period
                          Would you like to upgrade echarts from @1.0.8 to @1.0.12 now? [(y)es, (n)o]: y
                          Update echarts from @1.0.8 to @1.0.12
                          NPM version: 8.11.0
                          Installing iobroker.echarts@1.0.12... (System call)
                          upload [14] echarts /opt/iobroker/node_modules/iobroker.echarts/www/asset-manifest.json asset-manifest.json application/json
                          upload [13] echarts /opt/iobroker/node_modules/iobroker.echarts/www/favicon.ico favicon.ico image/vnd.microsoft.icon
                          upload [12] echarts /opt/iobroker/node_modules/iobroker.echarts/www/index.html index.html text/html
                          upload [11] echarts /opt/iobroker/node_modules/iobroker.echarts/www/manifest.json manifest.json application/json
                          upload [10] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/2.fcd307b3.chunk.css static/css/2.fcd307b3.chunk.css text/css
                          upload [9] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/2.fcd307b3.chunk.css.map static/css/2.fcd307b3.chunk.css.map application/json
                          upload [8] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.47916834.chunk.css static/css/main.47916834.chunk.css text/css
                          upload [7] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.47916834.chunk.css.map static/css/main.47916834.chunk.css.map application/json
                          upload [6] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/2.b5f07201.chunk.js static/js/2.b5f07201.chunk.js application/javascript
                          upload [5] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/2.b5f07201.chunk.js.LICENSE.txt static/js/2.b5f07201.chunk.js.LICENSE.txt text/plain
                          upload [4] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/2.b5f07201.chunk.js.map static/js/2.b5f07201.chunk.js.map application/json
                          upload [3] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.48bdb390.chunk.js static/js/main.48bdb390.chunk.js application/javascript
                          upload [2] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.48bdb390.chunk.js.map static/js/main.48bdb390.chunk.js.map application/json
                          upload [1] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/runtime-main.41dbf396.js static/js/runtime-main.41dbf396.js application/javascript
                          upload [0] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/runtime-main.41dbf396.js.map static/js/runtime-main.41dbf396.js.map application/json
                          Update "system.adapter.echarts.0"
                          upload [31] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/asset-manifest.json asset-manifest.json application/json
                          upload [30] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/asset-manifest.json chart/asset-manifest.json application/json
                          upload [20] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/2.b5f07201.chunk.js.map chart/static/js/2.b5f07201.chunk.js.map application/json
                          upload [19] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.48bdb390.chunk.js chart/static/js/main.48bdb390.chunk.js application/javascript
                          upload [18] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.48bdb390.chunk.js.map chart/static/js/main.48bdb390.chunk.js.map application/json
                          upload [17] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/runtime-main.41dbf396.js chart/static/js/runtime-main.41dbf396.js application/javascript
                          upload [16] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/runtime-main.41dbf396.js.map chart/static/js/runtime-main.41dbf396.js.map application/json
                          upload [15] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/echarts.png echarts.png image/png
                          upload [14] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                          upload [13] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/manifest.json manifest.json application/json
                          upload [12] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/2.8295ec30.chunk.css static/css/2.8295ec30.chunk.css text/css
                          upload [11] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/2.8295ec30.chunk.css.map static/css/2.8295ec30.chunk.css.map application/json
                          upload [10] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/main.a34c3d8f.chunk.css static/css/main.a34c3d8f.chunk.css text/css
                          upload [9] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/main.a34c3d8f.chunk.css.map static/css/main.a34c3d8f.chunk.css.map application/json
                          upload [8] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/2.8753f1c9.chunk.js static/js/2.8753f1c9.chunk.js application/javascript
                          upload [7] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/2.8753f1c9.chunk.js.LICENSE.txt static/js/2.8753f1c9.chunk.js.LICENSE.txt text/plain
                          upload [6] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/2.8753f1c9.chunk.js.map static/js/2.8753f1c9.chunk.js.map application/json
                          upload [5] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.a9954af5.chunk.js static/js/main.a9954af5.chunk.js application/javascript
                          upload [4] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.a9954af5.chunk.js.map static/js/main.a9954af5.chunk.js.map application/json
                          upload [3] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/runtime-main.07a098e2.js static/js/runtime-main.07a098e2.js application/javascript
                          upload [2] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/runtime-main.07a098e2.js.map static/js/runtime-main.07a098e2.js.map application/json
                          upload [1] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/tab.html tab.html text/html
                          upload [0] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                          This upgrade of "discovery" will introduce the following changes:
                          -> 3.0.5:
                          -> 3.0.4:
                          Disable configuration settings for this adapter
                          Would you like to upgrade discovery from @3.0.3 to @3.0.5 now? [(y)es, (n)o]: y
                          Update discovery from @3.0.3 to @3.0.5
                          NPM version: 8.11.0
                          Installing iobroker.discovery@3.0.5... (System call)
                          Update "system.adapter.discovery.0"
                          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                          This upgrade of "devices" will introduce the following changes:
                          -> 1.0.12:
                          Allowed to work with devices behind reverse proxy
                          Replaced the function icon
                          -> 1.0.11:
                          Updated some libraries
                          Would you like to upgrade devices from @1.0.10 to @1.0.12 now? [(y)es, (n)o]: y
                          Update devices from @1.0.10 to @1.0.12
                          NPM version: 8.11.0
                          Installing iobroker.devices@1.0.12... (System call)
                          INFO: Directory "/opt/iobroker/node_modules/iobroker.devices/www" was not found! Nothing was uploaded or deleted.
                          Update "system.adapter.devices.0"
                          upload [136] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/asset-manifest.json asset-manifest.json application/json
                          upload [100] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Consumption.fecd7a10.svg static/media/Consumption.fecd7a10.svg image/svg+xml
                          upload [90] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Driveway.fbd31101.svg static/media/Driveway.fbd31101.svg image/svg+xml
                          upload [80] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Garden.51c2e94f.svg static/media/Garden.51c2e94f.svg image/svg+xml
                          upload [70] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Heater.b53bccc3.svg static/media/Heater.b53bccc3.svg image/svg+xml
                          upload [60] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Light.21f1a5df.svg static/media/Light.21f1a5df.svg image/svg+xml
                          upload [50] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Office.7e6a3821.svg static/media/Office.7e6a3821.svg image/svg+xml
                          upload [40] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Receiver.26b5ae16.svg static/media/Receiver.26b5ae16.svg image/svg+xml
                          upload [30] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Speaker.db548379.svg static/media/Speaker.db548379.svg image/svg+xml
                          upload [20] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Toilet.83604dd2.svg static/media/Toilet.83604dd2.svg image/svg+xml
                          upload [19] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Tv.4e9745a5.svg static/media/Tv.4e9745a5.svg image/svg+xml
                          upload [18] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Upstairs.441813e5.svg static/media/Upstairs.441813e5.svg image/svg+xml
                          upload [17] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Vacuum Cleaner.9c8d50e4.svg static/media/Vacuum Cleaner.9c8d50e4.svg image/svg+xml
                          upload [16] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Ventilation.c31761d8.svg static/media/Ventilation.c31761d8.svg image/svg+xml
                          upload [15] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Wardrobe.e8019970.svg static/media/Wardrobe.e8019970.svg image/svg+xml
                          upload [14] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Washing Machines.577f3acd.svg static/media/Washing Machines.577f3acd.svg image/svg+xml
                          upload [13] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Washroom.bfb54196.svg static/media/Washroom.bfb54196.svg image/svg+xml
                          upload [12] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water Consumption.68891649.svg static/media/Water Consumption.68891649.svg image/svg+xml
                          upload [11] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water Heater.7e4bb4d9.svg static/media/Water Heater.7e4bb4d9.svg image/svg+xml
                          upload [10] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Water.f5041198.svg static/media/Water.f5041198.svg image/svg+xml
                          upload [9] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Wc.83604dd2.svg static/media/Wc.83604dd2.svg image/svg+xml
                          upload [8] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Weather.e91dae64.svg static/media/Weather.e91dae64.svg image/svg+xml
                          upload [7] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Window.421664f5.svg static/media/Window.421664f5.svg image/svg+xml
                          upload [6] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Windscreen.6058448b.svg static/media/Windscreen.6058448b.svg image/svg+xml
                          upload [5] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Workshop.7856e59f.svg static/media/Workshop.7856e59f.svg image/svg+xml
                          upload [4] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Workspace.97d73e41.svg static/media/Workspace.97d73e41.svg image/svg+xml
                          upload [3] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.3a7dae0b.txt static/media/names.3a7dae0b.txt text/plain
                          upload [2] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.e7efb528.txt static/media/names.e7efb528.txt text/plain
                          upload [1] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/tab.html tab.html text/html
                          upload [0] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                          This upgrade of "backitup" will introduce the following changes:
                          -> 2.4.10:
                          Code cleaning
                          dependencies updated
                          Disclaimer added
                          Travis Support removed
                          Fix backup-download with ssl
                          Would you like to upgrade backitup from @2.4.9 to @2.4.10 now? [(y)es, (n)o]: y
                          Update backitup from @2.4.9 to @2.4.10
                          host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                          NPM version: 8.11.0
                          Installing iobroker.backitup@2.4.10... (System call)
                          Update "system.adapter.backitup.0"
                          upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                          upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                          upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                          upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                          upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                          upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                          upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                          upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                          upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                          upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                          upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                          host.raspberrypi Adapter "system.adapter.backitup.0" is started
                          This upgrade of "trashschedule" will introduce the following changes:
                          -> 2.0.3:
                          Allow whitespaces in the match pattern
                          -> 2.0.2:
                          Fixed error handling for trash types with empty name
                          -> 2.0.1:
                          Added ical instance as comment for states
                          Just update states if value changed
                          -> 2.0.0:
                          NodeJS 14.x is required (NodeJS 12.x is EOL)
                          * Added timestamp of last and next refresh
                          * Added icon to channels and fixed color
                          * Added default trash types for new installations
                          * Updated dependency for ical to 1.12.1
                          * Updated depedency for js-controller to 4.0.15
                          -> 1.4.5:
                          Allow spaces in next text seperator
                          -> 1.4.4:
                          Updated dependencies
                          Would you like to upgrade trashschedule from @1.4.3 to @2.0.3 now? [(y)es, (n)o]: y
                          Update trashschedule from @1.4.3 to @2.0.3
                          NPM version: 8.11.0
                          Installing iobroker.trashschedule@2.0.3... (System call)
                          Adapter "system.adapter.vis.0" restarted.
                          Update "system.adapter.trashschedule.0"
                          upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/index_m.html index_m.html text/html
                          upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                          upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                          ist ohne Fehler durchgelaufen, aber trotzdem kommt:
                          • H Hanni700
                            habe ich gemacht:
                            -> 1.1.4:
                            NPM version: 8.11.0
                            -> 0.0.51:
                            NPM version: 8.11.0
                            -> 6.0.0:
                            NPM version: 8.11.0
                            -> 1.1.7:
                            NPM version: 8.11.0
                            -> 3.0.6:
                            NPM version: 8.11.0
                            -> 5.0.4:
                            NPM version: 8.11.0
                            -> 1.4.1:
                            NPM version: 8.11.0
                            -> 1.13.1:
                            -> 1.13.0:
                            Added Admin 5 UI
                            -> 1.12.2:
                            NPM version: 8.11.0
                            -> 2.2.0:
                            -> 2.1.7:
                            -> 2.1.6:
                            -> 2.1.5:
                            -> 2.1.4:
                            -> 2.1.3:
                            NPM version: 8.11.0
                            -> 1.0.12:
                            -> 1.0.10:
                            -> 1.0.9:
                            NPM version: 8.11.0
                            -> 3.0.5:
                            -> 3.0.4:
                            NPM version: 8.11.0
                            -> 1.0.12:
                            -> 1.0.11:
                            NPM version: 8.11.0
                            -> 2.4.10:
                            Code cleaning
                            Disclaimer added
                            NPM version: 8.11.0
                            -> 2.0.3:
                            -> 2.0.2:
                            -> 2.0.1:
                            -> 2.0.0:
                            -> 1.4.5:
                            -> 1.4.4:
                            NPM version: 8.11.0
                            iobroker upgrade ical --debug
                              Hanni700
                              pi@raspberrypi:/opt/iobroker $ iobroker upgrade ical --debug
                              -> 1.13.1:
                              -> 1.13.0:
                              Added Admin 5 UI
                              -> 1.12.2:
                              NPM version: 8.11.0
                              npm ERR! code EBADENGINE
                              npm ERR! engine Unsupported engine
                              npm ERR! engine Not compatible with your version of node/npm: homebridge-lib@4.7.16
                              npm ERR! notsup Not compatible with your version of node/npm: homebridge-lib@4.7.16
                              npm ERR! notsup Required: {"homebridge":"^1.1.0","node":"^12.19.0"}
                              npm ERR! notsup Actual:   {"npm":"8.11.0","node":"v16.16.0"}
                              npm ERR!     /home/iobroker/.npm/_logs/2022-08-14T14_17_37_656Z-debug-0.log
                              • H Hanni700
                                -> 1.13.1:
                                -> 1.13.0:
                                Added Admin 5 UI
                                -> 1.12.2:
                                NPM version: 8.11.0
                                code EBADENGINE
                                immer noch!
                                wo steckt das ding?
                                Mal die package-lock.json löschen?
                                • H Hanni700
                                  -> 1.13.1:
                                  -> 1.13.0:
                                  Added Admin 5 UI
                                  -> 1.12.2:
                                  NPM version: 8.11.0
                                  homebridge
                                  cd /opt/iobroker
                                  npm ls homebridge homebridge-lib
                                    homebridge
                                    cd /opt/iobroker
                                    Hanni700
                                    cd /opt/iobroker
                                    pi@raspberrypi:/opt/iobroker $ npm ls homebridge homebridge-lib
                                    iobroker.inst@2.0.3 /opt/iobroker
                                    └── (empty)
                                    • H Hanni700
                                      cd /opt/iobroker
                                      └── (empty)
                                      @hanni700
                                      Lösch mal wie von @Homoran vorgeschlagen die package-lock.json
                                        @hanni700
                                        Hanni700
                                        Kannst Du mir bitte sagen, wie ich das mache (bzw. wo ich die finde)?
                                        Gefunden und gelöscht, und nun nochmal upgrade ical?
                                        H HomoranH 2 Antworten Letzte Antwort
                                        • H Hanni700
                                          Hanni700
                                          @hanni700
                                          Bleibt dabei:
                                          -> 1.13.1:
                                          -> 1.13.0:
                                          Added Admin 5 UI
                                          -> 1.12.2:
                                          NPM version: 8.11.0
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-08-14T14_38_42_708Z-debug-0.log
