  4. [2.5.9 Fehler existiert] - Backup-Adapter erzeugt Fehler
    3.2k
    3.1k
66 Beiträge 6 Kommentatoren 7.9k Aufrufe 5 Beobachtet
  • Siggi0904S Siggi0904
    @simatec
    Super, der Fehler tritt nach dem Neustart des Adapters im Debug-Mode nicht auf.
    Dann muss ich wieder ein paar Tage warten, bis der Fehler auftritt.
    Dann hier die Logs:
    Startup der Instanz mit Debug-Mode
    2022-12-19 16:09:08.926 - info: backitup.0 (3064907) Got terminate signal TERMINATE_YOURSELF
    2022-12-19 16:09:08.927 - info: backitup.0 (3064907) cleaned everything up...
    2022-12-19 16:09:08.928 - info: backitup.0 (3064907) terminating
    2022-12-19 16:09:08.929 - info: backitup.0 (3064907) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-12-19 16:09:09.162 - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
    2022-12-19 16:09:09.671 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-12-19 16:09:12.300 - info: host.iobroker instance system.adapter.backitup.0 started with pid 989622
    2022-12-19 16:09:13.615 - debug: backitup.0 (989622) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-12-19 16:09:13.660 - debug: backitup.0 (989622) Objects client ready ... initialize now
    2022-12-19 16:09:13.756 - debug: backitup.0 (989622) Objects create System PubSub Client
    2022-12-19 16:09:13.757 - debug: backitup.0 (989622) Objects create User PubSub Client
    2022-12-19 16:09:13.890 - debug: backitup.0 (989622) Objects client initialize lua scripts
    2022-12-19 16:09:13.903 - debug: backitup.0 (989622) Objects connected to redis: 127.0.0.1:9001
    2022-12-19 16:09:13.951 - debug: backitup.0 (989622) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-12-19 16:09:14.046 - debug: backitup.0 (989622) States create System PubSub Client
    2022-12-19 16:09:14.047 - debug: backitup.0 (989622) States create User PubSub Client
    2022-12-19 16:09:14.123 - debug: backitup.0 (989622) States connected to redis: 127.0.0.1:9000
    2022-12-19 16:09:14.282 - debug: backitup.0 (989622) Plugin sentry Initialize Plugin (enabled=true)
    2022-12-19 16:09:14.938 - info: backitup.0 (989622) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
    2022-12-19 16:09:14.999 - debug: backitup.0 (989622) Backitup has recognized a linux system
    2022-12-19 16:09:15.085 - info: backitup.0 (989622) [iobroker] backup was activated at 01:00 every 2 day(s)
    2022-12-19 16:09:15.158 - debug: backitup.0 (989622) [iobroker] 10 00 01 */2 * *
    2022-12-19 16:09:15.159 - info: backitup.0 (989622) [ccu] backup was activated at 01:15 every 3 day(s)
    2022-12-19 16:09:15.176 - debug: backitup.0 (989622) [ccu] 10 15 01 */3 * *
    2022-12-19 16:09:15.218 - debug: backitup.0 (989622) noserverino option: false
    2022-12-19 16:09:15.218 - debug: backitup.0 (989622) cifs-mount command: "sudo mount -t cifs -o username=admin,password=****,rw,file_mode=0777,dir_mode=0777,vers=2.0 //Datenschlampe/Backup/Homematic-Pi/iobroker/standard /opt/iobroker/backups"
    2022-12-19 16:09:20.159 - debug: backitup.0 (989622) mount successfully completed
    2022-12-19 16:09:22.891 - debug: backitup.0 (989622) detect backup file 1 from NAS: iobroker_2022_12_03-01_00_27_backupiobroker.tar.gz
    2022-12-19 16:09:22.891 - debug: backitup.0 (989622) detect backup file 2 from NAS: iobroker_2022_12_05-01_00_24_backupiobroker.tar.gz
    2022-12-19 16:09:22.892 - debug: backitup.0 (989622) detect backup file 3 from NAS: iobroker_2022_12_07-01_00_27_backupiobroker.tar.gz
    2022-12-19 16:09:22.892 - debug: backitup.0 (989622) detect backup file 4 from NAS: iobroker_2022_12_15-01_00_25_backupiobroker.tar.gz
    2022-12-19 16:09:22.892 - debug: backitup.0 (989622) detect backup file 5 from NAS: iobroker_2022_12_17-01_00_25_backupiobroker.tar.gz
    2022-12-19 16:09:22.893 - debug: backitup.0 (989622) detect last backup file: iobroker_2022_12_17-01_00_25_backupiobroker.tar.gz
    2022-12-19 16:09:25.087 - debug: backitup.0 (989622) mount activ... umount in 2 Seconds!!
    2022-12-19 16:09:27.493 - debug: backitup.0 (989622) umount successfully completed
    Log vom Backup (Leider ohne Fehler):
    2022-12-19 16:12:26.816 - debug: backitup.0 (989622) Backup has started ...
    2022-12-19 16:12:36.816 - debug: backitup.0 (989622) [iobroker/mount] noserverino option: false
    2022-12-19 16:12:36.817 - debug: backitup.0 (989622) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=admin,password=****,rw,file_mode=0777,dir_mode=0777,vers=2.0 //Datenschlampe/Backup/Homematic-Pi/iobroker/standard /opt/iobroker/backups"
    2022-12-19 16:12:41.581 - debug: backitup.0 (989622) [iobroker/mount] mount successfully completed
    2022-12-19 16:12:41.583 - debug: backitup.0 (989622) [iobroker/mount] done
    2022-12-19 16:12:44.936 - debug: backitup.0 (989622) [iobroker/iobroker] host.iobroker 7667 states saved
    2022-12-19 16:12:45.076 - debug: backitup.0 (989622) [iobroker/iobroker] host.iobroker 9295 objects saved
    2022-12-19 16:12:48.650 - debug: backitup.0 (989622) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2022_12_19-16_12_41_backupiobroker.tar.gz
    2022-12-19 16:12:49.718 - debug: backitup.0 (989622) [iobroker/iobroker] done
    2022-12-19 16:12:50.022 - debug: backitup.0 (989622) [iobroker/mysql] MySql-Backup started ...
    2022-12-19 16:14:36.723 - debug: backitup.0 (989622) [iobroker/mysql] MySql File deleted!
    2022-12-19 16:14:36.726 - debug: backitup.0 (989622) [iobroker/mysql] MySql-Backup for is finish
    2022-12-19 16:14:36.726 - debug: backitup.0 (989622) [iobroker/mysql] done
    2022-12-19 16:14:37.977 - debug: backitup.0 (989622) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    2022-12-19 16:14:38.312 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-Wohnzimmer
    2022-12-19 16:14:38.313 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Wechselschaltung
    2022-12-19 16:14:38.313 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Fenster_geschlossen
    2022-12-19 16:14:38.313 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-Bad
    2022-12-19 16:14:38.314 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-Schlafzimmer
    2022-12-19 16:14:38.314 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Tests
    2022-12-19 16:14:38.314 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Fenster_geschlossen
    2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: BattUeberwachung
    2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: FensterOffenLichtAnSteckdosenEin
    2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Licht_überall_aus
    2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Steckdosen_überall_aus
    2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Eingangstür_offen
    2022-12-19 16:14:38.315 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: BattUeberwachungAlexa
    2022-12-19 16:14:38.318 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Alarmanlage
    2022-12-19 16:14:38.319 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: ErreichbarkeitAlexa
    2022-12-19 16:14:38.319 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Aqara_Zauberwürfel
    2022-12-19 16:14:38.319 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: MorgensLichtEinArbeit
    2022-12-19 16:14:38.320 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: EingangstürAlexa
    2022-12-19 16:14:38.321 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TemperaturAnsage
    2022-12-19 16:14:38.321 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftfeuchtigkeitAnsage
    2022-12-19 16:14:38.322 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftdruckAnsage
    2022-12-19 16:14:38.322 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftfeuchtigkeitAnsage
    2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftfeuchtigkeitAnsage
    2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AnwesenheitTaster
    2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AnwesenheitHandy
    2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TestHandyErreichbarkeit
    2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: PersonKommt
    2022-12-19 16:14:38.323 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: WillkommenZuhause
    2022-12-19 16:14:38.324 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: HandyLaden100%
    2022-12-19 16:14:38.324 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: HandystatusAnsage
    2022-12-19 16:14:38.326 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: HandyAkkustandMinimal
    2022-12-19 16:14:38.326 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TabletStatusAnsage
    2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TabletAkkustandMinimal
    2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: TabletLaden100%
    2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AdapterNeustarten
    2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: CarportLichtAus
    2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: CarportLichtMorgensEin
    2022-12-19 16:14:38.327 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: CarportLichtAbendsEin
    2022-12-19 16:14:38.328 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AstroDaten
    2022-12-19 16:14:38.328 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Jalousiesteuerung
    2022-12-19 16:14:38.328 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Helligkeit-AußenAnsage
    2022-12-19 16:14:38.330 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Klima-AußenAnsage
    2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Jalousiesteuerung
    2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Xiaomi_Geräte
    2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftreinigerEinAus
    2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: LuftqualitätAnsage
    2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Nachtmodus
    2022-12-19 16:14:38.331 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: BenzinpreiseAnsage
    2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: NachttischAus
    2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: StatusHomeMatic
    2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: WeckerAusUrlaubKrank
    2022-12-19 16:14:38.332 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: IchBinWeg
    2022-12-19 16:14:38.335 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: AnwesenheitBewegung
    2022-12-19 16:14:38.335 - debug: backitup.0 (989622) [iobroker/javascripts] found Script: Eiswarnung
    2022-12-19 16:14:38.931 - debug: backitup.0 (989622) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    2022-12-19 16:14:39.085 - debug: backitup.0 (989622) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    2022-12-19 16:14:39.086 - debug: backitup.0 (989622) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2022_12_19-16_14_37_backupiobroker.tar.gz
    2022-12-19 16:14:39.086 - debug: backitup.0 (989622) [iobroker/javascripts] done
    2022-12-19 16:14:39.538 - debug: backitup.0 (989622) [iobroker/cifs] used copy path: /Backup/Homematic-Pi/iobroker/standard
    2022-12-19 16:14:39.538 - debug: backitup.0 (989622) [iobroker/cifs] done
    2022-12-19 16:14:40.141 - debug: backitup.0 (989622) [iobroker/clean] done
    2022-12-19 16:14:41.057 - debug: backitup.0 (989622) [iobroker/historyHTML] new history html values created
    2022-12-19 16:14:41.058 - debug: backitup.0 (989622) [iobroker/historyHTML] done
    2022-12-19 16:14:41.322 - debug: backitup.0 (989622) [iobroker/historyJSON] new history json values created
    2022-12-19 16:14:41.323 - debug: backitup.0 (989622) [iobroker/historyJSON] done
    2022-12-19 16:14:41.492 - debug: backitup.0 (989622) [iobroker/umount] mount activ, umount is started ...
    2022-12-19 16:14:46.709 - debug: backitup.0 (989622) [iobroker/umount] umount successfully completed
    2022-12-19 16:14:46.711 - debug: backitup.0 (989622) [iobroker/umount] done
    2022-12-19 16:14:46.863 - debug: backitup.0 (989622) [iobroker] exec: done
    Aus der Historie (log von heute vor dem Restart des Adapters), der Fehler:
    2022-12-19 15:44:32.227 - error: backitup.0 (3064907) [iobroker/iobroker] node:internal/bootstrap/switches/does_own_process_state:126
    2022-12-19 15:44:32.229 - error: backitup.0 (3064907) [iobroker/iobroker] cachedCwd = rawMethods.cwd();
    2022-12-19 15:44:32.229 - error: backitup.0 (3064907) [iobroker/iobroker] ^
    2022-12-19 15:44:32.229 - error: backitup.0 (3064907) [iobroker/iobroker] Error: ENOENT: no such file or directory, uv_cwd
    2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at process.wrappedCwd (node:internal/bootstrap/switches/does_own_process_state:126:28)
    2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at Object.process.cwd (/opt/iobroker/node_modules/graceful-fs/polyfills.js:10:19)
    2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at fe.Yargs (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:61304)
    2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at Argv (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:12:16)
    2022-12-19 15:44:32.230 - error: backitup.0 (3064907) [iobroker/iobroker] at Object. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:7:1)
    2022-12-19 15:44:32.235 - error: backitup.0 (3064907) [iobroker/iobroker] at Module._compile (node:internal/modules/cjs/loader:1155:14)
    2022-12-19 15:44:32.235 - error: backitup.0 (3064907) [iobroker/iobroker] at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
    2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] at Module.load (node:internal/modules/cjs/loader:1033:32)
    2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] at Function.Module._load (node:internal/modules/cjs/loader:868:12)
    2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] at Module.require (node:internal/modules/cjs/loader:1057:19) {
    2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] errno: -2,
    2022-12-19 15:44:32.236 - error: backitup.0 (3064907) [iobroker/iobroker] code: 'ENOENT',
    2022-12-19 15:44:32.237 - error: backitup.0 (3064907) [iobroker/iobroker] syscall: 'uv_cwd'
    2022-12-19 15:44:32.237 - error: backitup.0 (3064907) [iobroker/iobroker] }
    #41
    @siggi0904
    Smb vers=2.0 dürfte falsch sein. Mittlerweile sollte eigentlich alles auf Version 3 sein.
    Siggi0904S 1 Antwort Letzte Antwort
      @siggi0904
      Siggi0904S Offline
      Siggi0904S Offline
      Siggi0904
      #42
      @thomas-braun Ne, NAS ist auf Minimum 2.0 und Maximum 3.0 eingestellt (Synology DSM 6).
      Das sollte also passen und das Backup läuft ja auch grundsätzlich.
        #43
        @siggi0904
        Dann stell es im Backitup-Adapter auf 3.0.
          @simatec
          Dann hier die Logs:
          simatecS Offline
          simatecS Offline
          simatec
          #44
          @siggi0904 Poste mal die Ausgaben von:
          npm -v
          node -v
          nodjs -v
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          • simatecS simatec
            npm -v
            node -v
            nodjs -v
            Siggi0904S Offline
            Siggi0904S Offline
            Siggi0904
            #45
            @simatec sagte in [Mit Version 2.5.9 behoben] - Backup-Adapter erzeugt Fehler:
            npm -v
            8.19.2
            v16.18.1
            v16.18.1
            @thomas-braun sagte in [Mit Version 2.5.9 behoben] - Backup-Adapter erzeugt Fehler:
            @siggi0904
            Behebt das, das Problem?
              npm -v
              8.19.2
              v16.18.1
              v16.18.1
              @siggi0904
              #46
              @siggi0904 sagte in [Mit Version 2.5.9 behoben] - Backup-Adapter erzeugt Fehler:
              Möglicherweise...
                Möglicherweise...
                simatecS Offline
                simatecS Offline
                simatec
                schrieb am zuletzt editiert von simatec
                #47
                Das Problem liegt hier eher tiefer im nodejs oder npm.
                Es wird bei einer handvoll User der auszuführende Pfad des iobroker Backups nicht gefunden bzw. kann nicht drauf zugegriffen werden.
                Das sagt dieses uv_cwd oder so aus
                • simatecS simatec
                  #48
                  @simatec
                  Weiß ich.
                    @simatec
                    Weiß ich.
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #49
                    Wir suchen aktuell nach Lösungen dieses Bugs.
                    In meiner Welt eher schwierig, da es sich nicht auf Backitup zurückführen lässt.
                    Der Bug kam mit irgendeiner Node Version oder auch npm.
                    Ein npm clear cache oder reboot behebt das Problem temporär
                      skinni
                      #50
                      Ich bin ja der Meinung er kam bei mir mit dem node Update von 14 auf 16. Seit ich aber mein System neu aufgesetzt habe, hatte ich bisher Ruhe.. Dafür hab ich seit dem "Cannot check node.js versions", aber das ist jetzt hier nicht das Thema :)
                      • simatecS simatec
                        #51
                        @simatec
                        Da passt was mit den Pfaden / den Berechtigungen nicht. Kann auch mit mount optionen oder dem verwendeten Protokoll zusammenhängen.
                        • Siggi0904S Offline
                          Siggi0904S Offline
                          Siggi0904
                          #52
                          Das merkwürdige ist, dass der Fehler auftritt wenn man ein Addon aktualisiert hat.
                          Wenn ich am System nichts ändere, läuft das super durch.
                            #53
                            @siggi0904
                            Was für ein 'Addon'?
                              @siggi0904
                              Siggi0904S Offline
                              Siggi0904S Offline
                              Siggi0904
                              #54
                              @thomas-braun egal welches. Sobald eine Aktualisierung läuft, kommt beim nächsten Backup-Lauf der Fehler.
                              Aber das ist nur ein Gefühl. Ich stellte aber das Verhalten so fest.
                                @simatec
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #55
                                @simatec
                                Da gehe ich nicht von aus. Denn der Fehler besagt, dass er den Backup Prozess nicht ausführen kann, da der Pfad in Benutzung und somit blockiert ist.
                                Damit wird aber nicht der Backuppfad sondern der Pfad zum js-controller gemeint
                                  Siggi0904S Offline
                                  Siggi0904
                                  #56
                                  Und noch ergänzend:
                                  Wenn der Fehler im Backitup auftritt kann ich manuell sauber ein iob backup machen.
                                  Da kommt kein Fehler.
                                    Und noch ergänzend:
                                    #57
                                    Da wird ja auch nix gemountet.
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #58
                                      Und der Befehl wird nicht über node Module gefahren sondern direkt über die CLI
                                      Wenn du denkst, dass es was mit dem mount zu tun hat, bin ich gerne für weitere Ideen bereit
                                        skinni
                                        #59
                                        Bei mir wurde nur history und iobroker nicht gesichert, alle anderen Daten schon. Bei history hat ers noch geschafft anzufangen, aber nur 1kb. Wie ist das bei dir @Siggi0904 ? Das liegt doch dann eher nicht an den mount optionen.
                                        Thomas BraunT Siggi0904S 2 Antworten Letzte Antwort
                                        • S skinni
                                          #60
                                          @skinni
                                          Was haste denn da überhaupt am Start?
                                          Cifs-Einstellungen auf dem Server?
                                          Dateisystem auf dem Medium?
                                          Einstellungen im Backitup-Adapter?
