  4. Problem beim loggen von Tankerkönig mit Influxdb 3.xx
    5.2k
49 Beiträge 6 Kommentatoren 6.5k Aufrufe 6 Beobachtet
  • S SpacerX
    @apollon77 hier das log.
    2022-07-28 20:32:21.567 - info: influxdb.0 (5109) enabled logging of DP_HEM-B184, Alias=true
    2022-07-28 20:32:39.847 - info: host.ioBroker stopInstance system.adapter.influxdb.0 (force=false, process=true)
    2022-07-28 20:32:40.059 - info: influxdb.0 (5109) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-28 20:32:40.590 - info: host.ioBroker instance system.adapter.influxdb.0 terminated for restart.
    2022-07-28 20:32:40.590 - info: host.ioBroker Adapter system.adapter.influxdb.0 will be restarted automatically
    2022-07-28 20:32:53.135 - info: host.ioBroker instance system.adapter.influxdb.0 started with pid 5124
    2022-07-28 20:32:53.539 - debug: influxdb.0 (5124) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-07-28 20:32:53.557 - debug: influxdb.0 (5124) Objects client ready ... initialize now
    2022-07-28 20:32:53.557 - debug: influxdb.0 (5124) Objects create System PubSub Client
    2022-07-28 20:32:53.558 - debug: influxdb.0 (5124) Objects create User PubSub Client
    2022-07-28 20:32:53.578 - debug: influxdb.0 (5124) Objects client initialize lua scripts
    2022-07-28 20:32:53.580 - debug: influxdb.0 (5124) Objects connected to redis: 127.0.0.1:9001
    2022-07-28 20:32:53.592 - debug: influxdb.0 (5124) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-07-28 20:32:53.598 - debug: influxdb.0 (5124) States create System PubSub Client
    2022-07-28 20:32:53.598 - debug: influxdb.0 (5124) States create User PubSub Client
    2022-07-28 20:32:53.608 - debug: influxdb.0 (5124) States connected to redis: 127.0.0.1:9000
    2022-07-28 20:32:53.650 - debug: influxdb.0 (5124) Plugin sentry Initialize Plugin (enabled=true)
    2022-07-28 20:32:53.761 - info: influxdb.0 (5124) starting. Version 3.1.7 in /opt/iobroker/node_modules/iobroker.influxdb, node: v16.15.1, js-controller: 4.0.23
    2022-07-28 20:32:53.774 - info: influxdb.0 (5124) No stored data from last exit found
    2022-07-28 20:32:53.774 - info: influxdb.0 (5124) Connecting http://10.0.1.25:8086/ ...
    2022-07-28 20:32:53.774 - info: influxdb.0 (5124) Influx DB Version used: 2.x
    2022-07-28 20:32:53.775 - debug: influxdb.0 (5124) Connect InfluxDB2: http://10.0.1.25:8086/ [ioBroker]
    2022-07-28 20:32:53.776 - debug: influxdb.0 (5124) Organization being checked: RBE
    2022-07-28 20:32:53.791 - debug: influxdb.0 (5124) Organizations: (gekuerzt)
    2022-07-28 20:32:53.796 - debug: influxdb.0 (5124) Buckets: (gekuerzt)
    2022-07-28 20:32:53.797 - info: influxdb.0 (5124) Applying retention policy for ioBroker to infinity. Shard Group Duration (calculated): 604800 seconds
    2022-07-28 20:32:53.797 - debug: influxdb.0 (5124) Query to execute: import "influxdata/influxdb/schema" schema.tagKeys(bucket: "ioBroker")
    2022-07-28 20:32:53.802 - debug: influxdb.0 (5124) connected set to true
    2022-07-28 20:32:53.818 - debug: influxdb.0 (5124) Query to execute: import "influxdata/influxdb/schema" schema.fieldKeys(bucket: "ioBroker")
    2022-07-28 20:32:53.819 - debug: influxdb.0 (5124) connected set to true
    2022-07-28 20:32:53.825 - debug: influxdb.0 (5124) Result of metadata storage type check: [[{"result":"_result","table":0,"_value":"_start"},{"result":"_result","table":0,"_value":"_stop"},{"result":"_result","table":0,"_value":"_field"},{"result":"_result","table":0,"_value":"_measurement"},{"result":"_result","table":0,"_value":"ack"},{"result":"_result","table":0,"_value":"from"},{"result":"_result","table":0,"_value":"q"}],[{"result":"_result","table":0,"_value":"value"}]]
    2022-07-28 20:32:53.825 - debug: influxdb.0 (5124) Storage type for metadata found in DB: tags
    2022-07-28 20:32:53.826 - info: influxdb.0 (5124) Connected!
    2022-07-28 20:32:53.853 - debug: influxdb.0 (5124) Found Alias: tankerkoenig.0.stations.3.diesel.feed --> DP_HEM-B184
    2022-07-28 20:32:53.853 - info: influxdb.0 (5124) enabled logging of DP_HEM-B184, Alias=true, 33 points now activated
    2022-07-28 20:32:53.890 - debug: influxdb.0 (5124) new value received for DP_HEM-B184 (storageType Number), new-value=1.789, ts=1659032984703, relog=true
    2022-07-28 20:32:53.890 - debug: influxdb.0 (5124) timed-relog DP_HEM-B184, value=1.789, lastLogTime=undefined, ts=1659033173890
    2022-07-28 20:32:53.890 - debug: influxdb.0 (5124) Value logged DP_HEM-B184, value=1.789, ts=1659032984703
    2022-07-28 20:32:53.890 - debug: influxdb.0 (5124) Datatype DP_HEM-B184: Currently: number, StorageType: Number
    2022-07-28 20:32:53.890 - debug: influxdb.0 (5124) Write Point: DP_HEM-B184 values:{"value":1.789,"time":"2022-07-28T18:32:53.890Z","from":"system.adapter.influxdb.0","q":0,"ack":true} options: null
    2022-07-28 20:32:53.906 - debug: influxdb.0 (5124) Point written to ioBroker
    2022-07-28 20:33:08.827 - debug: influxdb.0 (5124) PING OK
    2022-07-28 20:34:44.739 - debug: influxdb.0 (5124) new value received for DP_HEM-B184 (storageType Number), new-value=0, ts=1659033284698, relog=false
    2022-07-28 20:34:44.751 - debug: influxdb.0 (5124) new value received for DP_HEM-B184 (storageType Number), new-value=1.789, ts=1659033284698, relog=false
    2022-07-28 20:34:44.751 - debug: influxdb.0 (5124) value not changed debounce DP_HEM-B184, value=1.789, ts=1659033284698, debounce timer keeps running
    2022-07-28 20:34:45.739 - debug: influxdb.0 (5124) Value logged DP_HEM-B184, value=0, ts=1659033284698
    2022-07-28 20:34:45.740 - debug: influxdb.0 (5124) Datatype DP_HEM-B184: Currently: number, StorageType: Number
    2022-07-28 20:34:45.740 - debug: influxdb.0 (5124) Write Point: DP_HEM-B184 values:{"value":0,"time":"2022-07-28T18:34:44.698Z","from":"system.adapter.tankerkoenig.0","q":0,"ack":true} options: null
    2022-07-28 20:34:45.746 - debug: influxdb.0 (5124) Point written to ioBroker
    2022-07-28 20:34:53.829 - debug: influxdb.0 (5124) PING OK
    2022-07-28 20:39:44.749 - debug: influxdb.0 (5124) new value received for DP_HEM-B184 (storageType Number), new-value=0, ts=1659033584704, relog=false
    2022-07-28 20:39:44.755 - debug: influxdb.0 (5124) new value received for DP_HEM-B184 (storageType Number), new-value=1.789, ts=1659033584719, relog=false
    2022-07-28 20:39:44.755 - debug: influxdb.0 (5124) value not changed debounce DP_HEM-B184, value=1.789, ts=1659033584719, debounce timer keeps running
    2022-07-28 20:39:45.749 - debug: influxdb.0 (5124) Value logged DP_HEM-B184, value=0, ts=1659033584704
    2022-07-28 20:39:45.750 - debug: influxdb.0 (5124) Datatype DP_HEM-B184: Currently: number, StorageType: Number
    2022-07-28 20:39:45.750 - debug: influxdb.0 (5124) Write Point: DP_HEM-B184 values:{"value":0,"time":"2022-07-28T18:39:44.704Z","from":"system.adapter.tankerkoenig.0","q":0,"ack":true} options: null
    2022-07-28 20:39:45.756 - debug: influxdb.0 (5124) Point written to ioBroker
    2022-07-28 20:40:38.832 - debug: influxdb.0 (5124) PING OK
    HomoranH Offline
    HomoranH Offline
    @spacerx sagte in Problem beim loggen von Tankerkönig mit Influxdb 3.xx:
    ich sehe diesen Zeitpunkt nicht
    istcdie Systemzeit richtig oder das log über eine Stunde alt?
      SpacerX
      Der Screenshoot passend zum Zeitraum des loggens:
      DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
      • S SpacerX
        HomoranH Offline
        HomoranH Offline
        @spacerx Danke!
        Jetzt frage ich mich nur, warum influxdb.0(!!!) später den richtigen Preis hinein schreibt.
          @spacerx Danke!
          SpacerX
          Das Passiert wenn die Instanz von influxdb.0 neu startet oder die Einstellungen vom Datenpunktloggen gespeichert werden. In dem Fall wird der Datenpunkt nicht geändert sondern ist wie er ist.
          • S SpacerX
            HomoranH Offline
            HomoranH Offline
            aber das geht nur, wenn influx diesen Wert auch kennt.
            Nach deinen Daten hätte influx in soneinem Fall eine 0 schreiben müssen
              SpacerX
              @homoran sagte in Problem beim loggen von Tankerkönig mit Influxdb 3.xx:
              Dieser Steht im Datenpunkt. Siehe oben. Nach einer 0 folgt immer der Preis ( z.B. 1,799 ).
              • S SpacerX
                HomoranH Offline
                HomoranH Offline
                das ist aber nicht influxdb.0
                bei einem Neustart wird (bei entsprechender Einstellung) der letzte Wert in der Datenbank geschrieben. Deswegen auch influxdb.0 als Quelle des Wertes
                • S SpacerX
                  @spacerx oohhh thats a nice one .... Please create a GitHub issue for it ... he ignores the second value because "same as before" but did not stops the debouce counter in this case ...
                  Hmmm... vllt doch nicht der History Adapter ... tankerkoenig feuert die State Daten so schnell das sie GLEICHEN timestamp für beide werte bekommen - die 0 und den anderen ... damit hebelt er die Erkennung aus ob sich der Wert geändert hat.
                  Puuuh da muss ich überlegen
                  • apollon77A Offline
                    Ok, das müssen wir im Tankerkoenig ändern ... das ist so nicht sinnvoll. Der gleiche Wert wird so schnell gesetzt das die Logik die die Änderung erkennt im js-controller das auch nicht erkennen kann.
                    Bitte mal meinen Fork probieren https://github.com/Apollon77/ioBroker.tankerkoenig (und gern nochmal so ein Log wie oben von influxdb senden)
                    • apollon77A apollon77
                      SpacerX
                      @apollon77
                      Das vorherige zurücksetzten vor dem schreiben des Datenpunktes könnte man im Tankerkönig-Adapter auch ausschalten nur dann sieht man dann in dem Graphen auch nicht mehr wenn die Tankstelle geschlossen wäre.
                      Bestimmt auch besser das im Tankerkönig-Adapter zu ändern, das nicht der Datenpunkt vorsorglich vor der Aktualisierung auf 0 gesetzt wird falls der Server nicht erreichbar ist. 0 nur wenn Tankstelle geschlossen oder Server nicht erreichbar. die Logik sollte Adapter-intern implementiert werden.
                      • S SpacerX
                        @apollon77
                        @spacerx Bitte mal meinen Fork probieren https://github.com/Apollon77/ioBroker.tankerkoenig (und gern nochmal so ein Log wie oben von influxdb senden)
                          SpacerX
                          @apollon77
                          Werde ich machen. Komme leider erst nach dem WE wieder auf die Installation.
                          • IssiI Offline
                            IssiI Offline
                            Issi
                            Ich habe den Adapter komplett umgebaut ⇨ neue React UI und auch der Adapter code ist neu geschrieben.
                            In der neuen Version wird die Funktion das beim Aktualisieren eine 0 geschrieben wird nicht mehr da sein da der Adapter das dann durch die state quality (q-flag) geregelt wird siehe Issue Nr.79.
                            Das funktioniert so, wenn die Tankstelle geschlossen ist, wird der letzte wert der im ioBroker geschrieben wurde, im state gelassen und der q-flag auf 0x40 ⇒ Substitute value from device gesetzt.
                            Auch dann wen von der Tankstelle keine gültigen Werte kommen z. B. "e5": false/ "status": "no prices"
                                "ok": true,
                                "license": "CC BY 4.0 -  https:\/\/creativecommons.tankerkoenig.de",
                                "data": "MTS-K",
                                "prices": {
                                    "60c0eefa-d2a8-4f5c-82cc-b5244ecae955": {
                                        "status": "open",                               - Tankstelle ist offen
                                        "e5": false,                                    - kein Super
                                        "e10": false,                                   - kein E10
                                        "diesel": 1.189                                 - Tankstelle führt nur Diesel
                                    "446bdcf5-9f75-47fc-9cfa-2c3d6fda1c3b": {
                                        "status": "closed"                              - Tankstelle ist zu
                                    "4429a7d9-fb2d-4c29-8cfe-2ca90323f9f8": {
                                        "status": "open",
                                        "e5": 1.409,
                                        "e10": 1.389,
                                        "diesel": 1.129
                                    "44444444-4444-4444-4444-444444444444": {
                                        "status": "no prices"                           - keine Preise für Tankstelle verfügbar
                            wenn der state nicht gültig ist, sollte der influxdb Adapter den state nicht logen ausgenommen man aktiviert => trotzdem gleiche Werte aufzeichnen (Sekunden) wen er auf Nur Änderungen aufzeichnensollte er das nicht tun
                            ein PR an den Adapter habe ich bereits erstellt muss nur noch zusammengeführt werden
                            • IssiI Issi
                                  "ok": true,
                                  "data": "MTS-K",
                                  "prices": {
                                          "status": "open",
                                          "e5": 1.409,
                                          "e10": 1.389,
                                          "diesel": 1.129
                              SpacerX
                              @issi
                              Feine Sache.
                              Eine 0 bei geschlossener Tankstelle wäre trotzdem Klasse. Dann könnte man auf Änderung loggen und würde im Graphen schön auch die Schließung einer Tanke sehen. Wenn nur keine Werte von Tankerkönig kommen ist deine Variante die Eleganteste weil man die Gültigkeit der Preise in einem Script auswerten kann. Das jetzige ständige 0, Preis, 0, Preis … sollt auf jeden Fall weg.
                              IssiI 1 Antwort Letzte Antwort
                              • S SpacerX
                                @issi
                                Feine Sache.
                                IssiI Offline
                                IssiI Offline
                                Issi
                                schrieb am zuletzt editiert von Issi
                                @spacerx
                                Das Zurücksetzen vom state bei jeder Aktualisierung ist nicht so gut, da das öfter mal Probleme verursacht hat wie in diesem Issue.
                                Ich könnte da eine zusätzliche Funktion einbauen ⇒ standardmäßig deaktiviert ist die Funktion aktiviert wird, dann nur bei geschlossener Station eine 0 im state geschrieben und der q-flag wird nicht gesetzt, wenn die Funktion deaktiviert ist, wird der q-flag benutzt.
                                Bei allen anderen Sachen wie z.B. keine Preise wird dann der q-flag Funktion angewendet.
                                Und auf die Günstigste Tankstellen wird sich die Funktion auch nicht auswirken, da ist nur der q-flag aktiv.
                                • IssiI Issi
                                  @spacerx
                                  SpacerX
                                  @issi genau so. 👍
                                  Danke für eure Bemühungen.
                                  • S SpacerX
                                    @issi genau so. 👍
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    @spacerx Da bei mir seit dem Update der Influx auf 3.1.7 auch nur noch die "0" geloggt wird, habe ich diesen gesamten Post mt viel Interesse gelesen. Verstehe ich das als Laie richtig, das demnächst eine aktualisierte Version des Tankerkönig Adapters kommt und ich mich ein wenig in Geduld üben soll?
                                    Meine Einstellungen beim Datenpunkt sehen so aus:
                                    Mit besten Grüßen
                                    Andy
                                    • Damrak2022D Damrak2022
                                      @damrak2022 mal neben dem größten rewrite von Issi ist die github Version Bzw mein fork schon angepasst und wenn das mal jemand testet und bestätigt könnte man diese Version schon mal veröffentlichen…
                                      DJMarc75D S 2 Antworten Letzte Antwort
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        @apollon77 sagte in Problem beim loggen von Tankerkönig mit Influxdb 3.xx:
                                        Kann ich das auch per History testen ? Hab auf dem Testsystem kein influx drauf.
                                        Müsste doch eigentlich Wurscht sein da ja die Daten vom TK kommen, oder ?
                                        Lehrling seit 1975 !!!
                                        • DJMarc75D DJMarc75
                                          @djmarc75 exakt. Sql oder History oder influxdb sollte egal sein. Das problem das gleiche mit der bisherigen Adapter Version. Müsstest du ja sehen in den geloggten Daten oder?!
