  2. English
  3. ioBroker general
  4. Zigbee adapter stopped running
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
zigbee
43 Beiträge 5 Kommentatoren 9.5k Aufrufe 5 Beobachtet
  • A ap2017
    @asgothian
    Not sure how to check which USB port is which, don't know Linux enough.
    Nothing is connected to USB ports except MySensors gateway, Zwave adapter and Zigbee adapter.
    There is certainly a chance that Zigbee adapter failed, but it was working fine for many months, this is not new setup. I think that it uses firmware version 20190608.
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @ap2017 sagte in Zigbee adapter stopped running:
    @asgothian
    Please test:
    remove the MySensors gateway and the Zwave adapter and see if the zigbee adapter starts. Please be on the lookout for the first log message containing Starting zigbee-herdsman problem :, ignoring all messages after info: zigbee.0 (2610) Try to reconnect. as they will point you to a wrong direction.
    If the zigbee adapter starts in this configuration there might be some interference between either the mysensors gateway and the zigbee stick or the zwave stick and the zigbee stick. If it does not start in this configuration, the firmware on the stick has become corrupted and should be refreshed.
    The Zigbee-Herdsman Library which is used by the zigbee adapter requires a specific serialport library version, which is why it is completely normal to have a separate installation of the serial port library.
    A.
    A 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      @asgothian
      Please test:
      A.
      ap2017
      @asgothian
      I disabled MySensors and Zwave then restarted controller. Here is what I am getting:
      2022-07-15 15:49:58.005 - error: zigbee.0 (20495) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      2022-07-15 15:49:58.006 - error: zigbee.0 (20495) Failed to start Zigbee
      2022-07-15 15:49:58.006 - error: zigbee.0 (20495) Error herdsman start
      • A ap2017
        @asgothian
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @ap2017 Please reread my previous post and check for the correct message. I am 99% certain that this message is the one i explicitly told you was a false flag.
        A.
          A.
          ap2017
          @asgothian
          2022-07-15 18:26:04.695 - info: zigbee.0 (25872) Starting Zigbee npm ...
          2022-07-15 18:26:04.921 - info: zigbee.0 (25872) Installed Version: iobroker.zigbee@1.7.5
          2022-07-15 18:26:09.726 - info: mysensors.0 (21245) STARTED
          2022-07-15 18:26:24.873 - error: zigbee.0 (25872) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          2022-07-15 18:26:24.875 - error: zigbee.0 (25872) Failed to start Zigbee
          2022-07-15 18:26:24.875 - error: zigbee.0 (25872) Error herdsman start
          2022-07-15 18:26:34.876 - info: zigbee.0 (25872) Try to reconnect. 1 attempts left
          2022-07-15 18:26:34.877 - info: zigbee.0 (25872) Starting Zigbee npm ...
          2022-07-15 18:26:34.889 - info: zigbee.0 (25872) Installed Version: iobroker.zigbee@1.7.5
          2022-07-15 18:26:34.989 - error: zigbee.0 (25872) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          2022-07-15 18:26:34.990 - error: zigbee.0 (25872) Failed to start Zigbee
          2022-07-15 18:26:34.990 - error: zigbee.0 (25872) Error herdsman start
          • A ap2017
            @asgothian
            @ap2017
            I quote:
            So try to reflash the Firmware.
              @ap2017
              I quote:
              ap2017
              schrieb am zuletzt editiert von ap2017
              @thomas-braun After reflashing the firmware Zigbeee adapter started to behave differently. It works for some seconds then shuts down with error code. After restarting the adapter is does it again - works for a short time then shuts down with error code. I received another stick, reflashed it as well, but system behaves same way.
              2022-07-17 21:10:10.373 - info: zigbee.0 (2538) Zigbee started
              2022-07-17 21:10:12.539 - info: admin.0 (1256) ==> Connected system.user.admin from ::ffff:192.168.1.244
              2022-07-17 21:10:21.356 - warn: zigbee.0 (2538) DeviceAvailability:Failed to ping 0x90fd9ffffe2bad6b TRADFRI bulb E26 W opal 1000lm
              2022-07-17 21:10:40.020 - warn: zigbee.0 (2538) Device '0x90fd9ffffe2baf88' announced itself
              2022-07-17 21:10:40.023 - error: zigbee.0 (2538) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2022-07-17 21:10:40.024 - error: zigbee.0 (2538) unhandled promise rejection: Cannot read properties of undefined (reading 'color_options')
              2022-07-17 21:10:40.024 - error: zigbee.0 (2538) TypeError: Cannot read properties of undefined (reading 'color_options')
              at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
              at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
              at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
              at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
              at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
              2022-07-17 21:10:40.025 - error: zigbee.0 (2538) Cannot read properties of undefined (reading 'color_options')
              2022-07-17 21:10:40.028 - info: zigbee.0 (2538) cleaned everything up...
              2022-07-17 21:10:40.056 - info: zigbee.0 (2538) Zigbee: disabling joining new devices.
              2022-07-17 21:10:40.528 - info: zigbee.0 (2538) terminating
              2022-07-17 21:10:40.529 - warn: zigbee.0 (2538) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2022-07-17 21:10:41.035 - warn: zigbee.0 (2538) get state error: Connection is closed.
              2022-07-17 21:10:41.101 - error: host.AP-Tiny instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              2022-07-17 21:10:41.102 - info: host.AP-Tiny Restart adapter system.adapter.zigbee.0 because enabled
              2022-07-17 21:10:41.102 - warn: host.AP-Tiny Do not restart adapter system.adapter.zigbee.0 because restart loop detected
              2022-07-17 21:10:43.459 - info: mysensors.0 (2199) STARTED
              2022-07-17 21:10:43.460 - info: mysensors.0 (2199) STARTED
              2022-07-17 21:10:48.629 - info: admin.0 (1256) <== Disconnect system.user.admin from ::ffff:192.168.1.244
              • A ap2017
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @ap2017 Please see here for cause and temporary fix:
                https://forum.iobroker.net/topic/55346/zigbee-stürzt-beim-schalten-von-birnen-über-shalter-ab/7?_=1658123566370
                A.
                  A.
                  ap2017
                  @asgothian
                  Thanks if I can figure out how to edit file in terminal mode...
                  • A ap2017
                    @asgothian
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @ap2017 you should be able to use the "nano" command. You may have to use sudo to be able to write the file, or have to modify the access rights via sudo chmod a+w
                    A.
                    A 2 Antworten Letzte Antwort
                      A.
                      ap2017
                      @asgothian I did not have a chance to manually change the code, but noticed new version of adapter just released with fixed IKEA interface. Unfortunately it does not work for me, see log. It starts fine adapter is operational but it is not able to ping devices
                      2022-07-24 18:48:09.741 - info: host.AP-Tiny stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      2022-07-24 18:48:09.745 - info: zigbee.0 (2399) Got terminate signal TERMINATE_YOURSELF
                      2022-07-24 18:48:09.746 - info: zigbee.0 (2399) cleaned everything up...
                      2022-07-24 18:48:09.755 - info: zigbee.0 (2399) Zigbee: disabling joining new devices.
                      2022-07-24 18:48:09.792 - info: host.AP-Tiny stopInstance system.adapter.zigbee.0 send kill signal
                      2022-07-24 18:48:10.237 - info: zigbee.0 (2399) terminating
                      2022-07-24 18:48:10.238 - info: zigbee.0 (2399) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-07-24 18:48:10.795 - info: host.AP-Tiny instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-07-24 18:48:12.834 - info: host.AP-Tiny instance system.adapter.zigbee.0 started with pid 2431
                      2022-07-24 18:48:14.205 - info: zigbee.0 (2431) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2022-07-24 18:48:14.356 - info: zigbee.0 (2431) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
                      2022-07-24 18:48:14.401 - info: zigbee.0 (2431) delete old Backup files. keep only last 10
                      2022-07-24 18:48:14.402 - info: zigbee.0 (2431) Starting Zigbee npm ...
                      2022-07-24 18:48:14.633 - info: zigbee.0 (2431) Installed Version: iobroker.zigbee@1.7.6
                      2022-07-24 18:48:15.005 - info: zigbee.0 (2431) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                      2022-07-24 18:48:15.009 - info: zigbee.0 (2431) Disable LED
                      2022-07-24 18:48:15.010 - info: zigbee.0 (2431) Unable to disable LED, unsupported function.
                      2022-07-24 18:48:15.011 - info: zigbee.0 (2431) --> transmitPower : normal
                      2022-07-24 18:48:15.018 - info: zigbee.0 (2431) Currently 15 devices are joined:
                      2022-07-24 18:48:15.037 - info: zigbee.0 (2431) 0x90fd9ffffe2bad6b (addr 43852): LED1622G12 - IKEA TRADFRI LED bulb E26 1000 lumen, dimmable, opal white (Router)
                      2022-07-24 18:48:15.041 - info: zigbee.0 (2431) 0x00158d00044678ff (addr 48528): WXKG12LM - Xiaomi Aqara wireless switch (with gyroscope) (EndDevice)
                      2022-07-24 18:48:15.041 - info: zigbee.0 (2431) 0x00124b001f90ed15 (addr 54998): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
                      2022-07-24 18:48:15.042 - info: zigbee.0 (2431) 0xd0cf5efffedaa37c (addr 43246): LED1622G12 - IKEA TRADFRI LED bulb E26 1000 lumen, dimmable, opal white (Router)
                      2022-07-24 18:48:15.042 - info: zigbee.0 (2431) 0x000b57fffebcfc39 (addr 38662): LED1622G12 - IKEA TRADFRI LED bulb E26 1000 lumen, dimmable, opal white (Router)
                      2022-07-24 18:48:15.043 - info: zigbee.0 (2431) 0x00124b0022658a2b (addr 33323): SNZB-01 - SONOFF Wireless button (EndDevice)
                      2022-07-24 18:48:15.043 - info: zigbee.0 (2431) 0xd0cf5efffe7d475c (addr 30129): LED1622G12 - IKEA TRADFRI LED bulb E26 1000 lumen, dimmable, opal white (Router)
                      2022-07-24 18:48:15.044 - info: zigbee.0 (2431) 0x00158d00045a362e (addr 24701): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                      2022-07-24 18:48:15.045 - info: zigbee.0 (2431) 0xbc33acfffeff263f (addr 65507): SM-AZ713 - UseeLink Smart water/gas valve (Router)
                      2022-07-24 18:48:15.046 - info: zigbee.0 (2431) 0x90fd9ffffe2baf88 (addr 53737): LED1622G12 - IKEA TRADFRI LED bulb E26 1000 lumen, dimmable, opal white (Router)
                      2022-07-24 18:48:15.046 - info: zigbee.0 (2431) 0x000b57fffe8b9e9c (addr 56023): LED1650R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
                      2022-07-24 18:48:15.047 - info: zigbee.0 (2431) 0x00124b0022419f47 (addr 23822): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
                      2022-07-24 18:48:15.047 - info: zigbee.0 (2431) 0xccccccfffe939035 (addr 18190): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
                      2022-07-24 18:48:15.048 - info: zigbee.0 (2431) 0x04cf8cdf3c79009e (addr 52418): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
                      2022-07-24 18:48:15.048 - info: zigbee.0 (2431) 0x00158d0006ea578f (addr 63873): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                      2022-07-24 18:48:15.049 - info: zigbee.0 (2431) Zigbee started
                      2022-07-24 18:48:38.963 - info: mysensors.0 (2339) STARTED
                      2022-07-24 18:49:01.024 - info: admin.0 (1527) ==> Connected system.user.admin from ::ffff:192.168.1.244
                      2022-07-24 18:49:19.328 - info: admin.0 (1527) <== Disconnect system.user.admin from ::ffff:192.168.1.244
                      2022-07-24 18:49:23.126 - warn: zigbee.0 (2431) DeviceAvailability:Failed to ping 0x00124b001f90ed15 SA-003-Zigbee
                      2022-07-24 18:49:23.750 - warn: zigbee.0 (2431) DeviceAvailability:Failed to ping 0xd0cf5efffedaa37c TRADFRI bulb E26 W opal 1000lm
                      2022-07-24 18:49:24.226 - warn: zigbee.0 (2431) DeviceAvailability:Failed to ping 0x000b57fffebcfc39 TRADFRI bulb E26 W opal 1000lm
                      2022-07-24 18:49:33.874 - warn: zigbee.0 (2431) DeviceAvailability:Failed to ping 0xd0cf5efffe7d475c TRADFRI bulb E26 W opal 1000lm
                      2022-07-24 18:49:34.415 - warn: zigbee.0 (2431) DeviceAvailability:Failed to ping 0x000b57fffe8b9e9c TRADFRI bulb GU10 W 400lm
                      2022-07-24 18:49:34.858 - warn: zigbee.0 (2431) DeviceAvailability:Failed to ping 0x90fd9ffffe2baf88 TRADFRI bulb E26 W opal 1000lm
                      2022-07-24 18:49:35.014 - warn: zigbee.0 (2431) DeviceAvailability:Failed to ping 0x00124b0022419f47 SA-003-Zigbee
                        A.
                        ap2017
                        @asgothian Do you still recommend to manually edit the file or the latest adapter update incorporate all the changes?
                        • A ap2017
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @ap2017 the latest version should contain the edit.
                          A.
                            A.
                            ap2017
                            @asgothian It does not work for me see my message from July 24
                            • A ap2017
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @ap2017 Please check if you have duplicate zigbee-herdsman-converters libraries installed, or if their permissions do not allow overwriting.
                              if need be, follow this method:
                              • stop the zigbee adapter
                              • remove the zigbee-herdsman-converters library
                              • remove the zigbee-herdsman library
                              • reinstall the zigbee adapter.
                              A.
                                A.
                                ap2017
                                @asgothian Thanks, but it I don't know how to:
                                • reinstall the zigbee adapter. How to reinstall? Delete and then install new adapter? Will all devices configuration stay?
                                • A ap2017
                                  ap2017
                                  @ap2017 Please help
                                    A.
                                    ap2017
                                    @asgothian Do I need to reconfigure devices after swapping the CC2531 dongle and changing serial port to proper "by-id"?
                                    • A ap2017
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      If you swap to a different hardware, you may need to repair all devices. Just swapping the port of the identical hardware does not require a reconfiguration / repairing.
                                      As to the earlier question. The easiest way is:
                                      • remove the zigbee adapter through the admin interface.
                                      • open a console, navigate to /opt/iobroker
                                      • execute npm list | grep -e "herdsman" to see if this produces lines containing either "zigbee-herdsman" or "zigbee-herdsman-converters". if it does you can attempt to remove these via nom remove (please read the npm documentation for this)
                                      • reinstall the zigbee adapter through the admin interface.
                                      • start the zigbee adapter.
                                      A.
                                        A.
                                        ap2017
                                        @asgothian Would you recommend to switch from CC2531 to Sonoff stick based on CC2652P?
                                        • A ap2017
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          @ap2017 Yes
