  3. Einsteigerfragen
  4. backitup kein Backup von iobroker
    5.6k
53 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • N Neuling mit großem Interesse
    @glasfaser said in backitup kein Backup von iobroker:
    ps auxww|grep io
    pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ ps auxww|grep io
    root        13  0.0  0.0      0     0 ?        S    17:12   0:00 [migration/0]
    root        16  0.0  0.0      0     0 ?        S    17:12   0:00 [migration/1]
    root        21  0.0  0.0      0     0 ?        S    17:12   0:00 [migration/2]
    root        26  0.0  0.0      0     0 ?        S    17:12   0:00 [migration/3]
    root        62  0.0  0.0      0     0 ?        I<   17:12   0:00 [blkcg_punt_bio]
    root        66  0.0  0.0      0     0 ?        I<   17:12   0:00 [rpciod]
    root        68  0.0  0.0      0     0 ?        I<   17:12   0:00 [xprtiod]
    root        71  0.0  0.0      0     0 ?        I<   17:12   0:00 [nfsiod]
    root        80  0.0  0.0      0     0 ?        I<   17:12   0:00 [DWC Notificatio]
    message+   439  0.0  0.0   8204  4168 ?        Ss   17:12   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
    grafana   1053  0.2  0.9 963292 80424 ?        Ssl  17:12   0:15 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafana/plugins cfg:default.paths.provisioning=/etc/grafana/provisioning
    iobroker  1057 11.4  5.1 523620 414836 ?       Ssl  17:12  11:45 iobroker.js-controller
    iobroker  1162  0.5  1.2 208788 100684 ?       Sl   17:12   0:32 io.admin.0
    root      1177  0.0  0.0  33204  7576 ?        Sl   17:13   0:00 lightdm --session-child 14 23
    iobroker  1178  0.3  0.9 187712 72936 ?        Sl   17:13   0:21 io.history.0
    iobroker  1202  2.8  4.0 437120 331376 ?       Sl   17:13   2:57 io.javascript.0
    pi        1220  0.0  0.1 377272 10772 ?        S<sl 17:13   0:00 /usr/bin/pulseaudio --daemonize=no --log-target=journal
    pi        1222  0.0  0.0   7780  3764 ?        Ss   17:13   0:04 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
    pi        1223  0.0  0.0  19636  4816 ?        S<l  17:13   0:00 /usr/bin/pipewire-media-session
    pi        1232  0.0  0.1  52404 12988 ?        Ssl  17:13   0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE -w openbox-lxde-pi
    pi        1276  0.0  0.0   4616   280 ?        Ss   17:13   0:00 /usr/bin/ssh-agent x-session-manager
    iobroker  1443  0.2  0.8 182492 70532 ?        Sl   17:13   0:12 io.node-red.0
    pi        1509  0.0  0.0  32516  5740 ?        Sl   17:13   0:00 /usr/libexec/at-spi2-registryd --use-gnome-session
    iobroker  1632  0.1  0.7 184772 62236 ?        Sl   17:13   0:11 io.pushover.0
    iobroker  1885  1.4  1.9 282648 161704 ?       Sl   17:13   1:29 node-red
    iobroker  1915  0.5  0.9 194012 76516 ?        Sl   17:13   0:30 io.sql.0
    iobroker  1921  0.6  0.9 192340 80516 ?        Sl   17:13   0:41 io.hm-rega.0
    iobroker  1943  0.4  0.9 190352 74596 ?        Sl   17:13   0:24 io.hm-rpc.1
    iobroker  2011  0.2  0.8 185832 65300 ?        Sl   17:13   0:13 io.hm-rpc.2
    iobroker  2019  0.2  0.8 183600 70404 ?        Sl   17:13   0:16 io.hm-rpc.3
    iobroker  2047  0.2  0.7 186016 64528 ?        Sl   17:13   0:14 io.hm-rpc.4
    iobroker  2059  0.4  0.8 183176 64992 ?        Sl   17:13   0:30 io.rpi2.0
    iobroker  2074  0.6  0.9 194384 77736 ?        Sl   17:13   0:41 io.alexa2.0
    iobroker  2125  0.6  0.9 194840 78496 ?        Sl   17:13   0:41 io.alexa2.1
    iobroker  2155  0.4  0.9 189288 75824 ?        Sl   17:13   0:26 io.hm-rpc.5
    iobroker  2170  0.1  0.7 182976 60936 ?        Sl   17:14   0:12 io.discovery.0
    iobroker  2185  0.3  0.9 194168 78604 ?        Sl   17:14   0:22 io.tankerkoenig.0
    iobroker  2215  0.2  0.8 187656 67528 ?        Sl   17:14   0:14 io.web.0
    iobroker  2245  0.2  0.9 191564 75052 ?        Sl   17:14   0:18 io.info.0
    iobroker  2264  0.5  1.1 206104 90728 ?        Sl   17:14   0:32 io.ring.0
    iobroker  2279  0.2  0.7 182356 59360 ?        Sl   17:14   0:12 io.ble.0
    iobroker  2336  0.3  0.8 190412 70568 ?        Sl   17:14   0:23 io.fb-checkpresence.0
    iobroker  2346  0.5  0.5 123852 42112 ?        Sl   17:14   0:30 /usr/bin/node /opt/iobroker/node_modules/iobroker.ble/build/scanProcess -s fe95
    iobroker  2390  0.2  0.9 187008 73052 ?        Sl   17:14   0:12 io.backitup.0
    iobroker  2419  0.2  0.8 185560 65764 ?        Sl   17:14   0:15 io.trashschedule.0
    iobroker  2555  0.2  0.8 185012 67852 ?        Sl   17:14   0:12 io.backitup.1
    iobroker 11577  7.8  0.8 185304 72492 ?        Sl   18:55   0:03 io.smartgarden.0
    pi       11649  0.0  0.0   3536  1780 pts/0    S+   18:55   0:00 grep --color=auto io
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    #41
    @neuling-mit-großem-interesse sagte in backitup kein Backup von iobroker:
    io.backitup.1
    Warum hast du 2 instanzen !?
    Zeige mal
    iobroker list instances
    N 1 Antwort Letzte Antwort
      Für mich als anfänger ist es einfacher um an die speicherorte und dateipfade zu kommen... das eigentliche Problem hat nichts mit dem Monitor zu tun.
      #42
      Mit dem Monitor nicht. Aber vielleicht mit dem ganzen DesktopEnvironment das da mitrumpelt und das ganze komplexer, unsicherer und ressourcenhungriger macht.
      • GlasfaserG Glasfaser
        io.backitup.1
        Zeige mal
        N Offline
        N Offline
        #43
        @glasfaser
        pi@raspberrypi:~ $ iobroker list instances
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
        + system.adapter.alexa2.1                 : alexa2                : raspberrypi                              -  enabled, compact disabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
        + system.adapter.backitup.1               : backitup              : raspberrypi                              -  enabled, compact disabled
        + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact disabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled, compact disabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled, compact disabled
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
        + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
        + system.adapter.hm-rpc.5                 : hm-rpc                : raspberrypi                              -  enabled, compact disabled, port: 0
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact disabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled, compact disabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
        + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, compact disabled, port: 1880, bind: 192.168.178.73
        + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled, compact disabled
        + system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled, compact disabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled, compact disabled
        + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, compact disabled, port: 3306
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled, compact disabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled, compact disabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        pi@raspberrypi:~ $
          N Offline
          N Offline
          #44
          wie gesagt wenn node js 3x instaliert ist dann geht backup....
          in der konsole wird etwas von speicher erwähnt....
          [ERROR] [iobroker] -
          <--- Last few GCs --->
          [32392:0x4fbafc8]    23688 ms: Mark-sweep (reduce) 586.4 (593.5) -> 586.4 (590.5) MB, 114.8 / 0.0 ms  (+ 0.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 2269 ms) (average mu = 0.970, current mu = 0.951) last [32392:0x4fbafc8]    23765 ms: Mark-sweep (reduce) 586.4 (590.5) -> 586.4 (589.8) MB, 77.4 / 0.0 ms  (average mu = 0.951, current mu = 0.001) last resort GC in old space requested
          <--- JS stacktrace --->
            @glasfaser
            + instance is alive
            pi@raspberrypi:~ $
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            #45
            @Thomas-Braun
            compact disabled
            Was ist das , sagt mir gerade nichts
            Thomas BraunT N 2 Antworten Letzte Antwort
              @Thomas-Braun
              compact disabled
              #46
              @glasfaser
              Der 'Kompakt'-Modus. Da kann man beim Speicher ein paar MB einsparen. Hat aber soweit ich weiß an anderer Stelle wieder Stolperfallen, wenn der aktiv ist.
              Bei mir ist der auch aus.
                @Thomas-Braun
                compact disabled
                N Offline
                N Offline
                #47
                @glasfaser
                sorry ...js-controller 4.0 dann fehler
                js-controller 3.0 dann geht es mit dem backup
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  #48
                  Ich weiß .... du wirst gerade mit Fragen zugeschüttet .
                  Aber oben sind noch welche offen !!!
                    @glasfaser
                    N Offline
                    N Offline
                    #49
                    @thomas-braun said in backitup kein Backup von iobroker:
                    Hatte ich auch schon versucht....
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #50
                      Nee die von @Homoran
                      und von mir mit dem Neustart
                        #51
                        Jedenfalls hast du ein Problem mit dem Speicher.
                        https://www.geeksforgeeks.org/mark-and-sweep-garbage-collection-algorithm/
                        Und da trägt ein fetter Desktop nicht gerade dazu bei da mehr Ressourcen zu haben.
                          N Offline
                          N Offline
                          #52
                          @glasfaser
                          habe ich dann übersehen...
                          kannst du die bitte erneut stellen
                            @glasfaser
                            N Offline
                            N Offline
                            #53
                            sorry
