  4. [gelöst] VIS lässt sich nicht installieren
    6.3k
errorvis
13 Beiträge 4 Kommentatoren 1.1k Aufrufe 2 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    habe in proxmox eine neue VM erstellt mit bullseye.
    Danach iob installiert.
    Und per backitup ein restore eingespielt.
    Hat alles geklappt, bis auf die Installation von VIS.
    Im log kommt:
    vis.0
    2022-07-10 11:19:53.933	error	Not exists
    vis.0
    2022-07-10 11:19:53.931	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
    vis.0
    2022-07-10 11:19:53.928	error	unhandled promise rejection: Not exists
    vis.0
    2022-07-10 11:19:53.927	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    vis.0
    2022-07-10 11:19:53.361	info	vis license is OK.
    vis.0
    2022-07-10 11:19:53.244	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.16.0, js-controller: 4.0.23
    Danach manuell per putty probiert mit:
    iob upgrade vis@1.4.15 --debug
    This upgrade of "vis" will at least introduce the following changes:
    -> 1.4.15:
    Better check of the offline license
    -> 1.4.14:
    Corrected GUI bug
    -> 1.4.13:
    The group attributes will be replaced recursively
    -> 1.4.12:
    Fixed bug with the export of specific widgets
    -> 1.4.11:
    Removed ES6 commands to be supported by older browsers
    Fixed problem with update of grouped widgets
    Added web manifest to be able to handle vis as the web app
    -> 1.4.8:
    Added support for js-controller 4.x
    -> 1.4.7:
    Fixed subscribeOidAtRuntime if called with invalid IDs
    Added support of license manager
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade vis from @0.0.0 to @1.4.15 now? [(y)es, (n)o]: Y
    Update vis from @0.0.0 to @1.4.15
    NPM version: 8.11.0
    Installing iobroker.vis@1.4.15... (System call)
    npm ERR! code 6
    npm ERR! path /opt/iobroker/node_modules/iobroker.vis
    npm ERR! command failed
    npm ERR! command sh -c node main.js --install
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-10T09_25_08_664Z-debug-0.log
    host.iobroker Cannot install iobroker.vis@1.4.15: 6
    Und in dem da gezeigten log steht dann folgendes:
    Frage:
    Warum lässt sich VIS als einzige Instanz nicht installieren. (alle anderen Instanzen wurden nach installiert)
    Bitte mal kurz drüber schauen wo dort der Fehler liegt.
    Danke.
    mfg
    Dieter
    Danke.
    HomoranH crunchipC M 3 Antworten Letzte Antwort
    • bahnuhrB bahnuhr
      Im log kommt:
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      -> 1.4.15:
      -> 1.4.14:
      Corrected GUI bug
      -> 1.4.13:
      -> 1.4.12:
      -> 1.4.11:
      -> 1.4.8:
      -> 1.4.7:
      NPM version: 8.11.0
      npm ERR! code 6
      Frage:
      Danke.
      mfg
      Dieter
      @bahnuhr was sagt iobroker list adapters ?
      • bahnuhrB bahnuhr
        Im log kommt:
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        -> 1.4.15:
        -> 1.4.14:
        Corrected GUI bug
        -> 1.4.13:
        -> 1.4.12:
        -> 1.4.11:
        -> 1.4.8:
        -> 1.4.7:
        NPM version: 8.11.0
        npm ERR! code 6
        Frage:
        Danke.
        mfg
        Dieter
        crunchipC Offline
        crunchipC Offline
        Problem ist ja schon mehrfach hier im Forum aufgetreten
        @bahnuhr sagte in VIS lässt sich nicht installieren:
        geht doch eigentlich gar nicht, da vis Adapter nicht vorhanden
        daher auch
          daher auch
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @crunchip
          bei iob install vis@1.4.15 --debug
          kommt:
          dieter@iobroker:~$ iob install  vis@1.4.15 --debug
          NPM version: 8.11.0
          npm ERR! code 6
          npm ERR!     /home/iobroker/.npm/_logs/2022-07-10T11_54_23_970Z-debug-0.log
          und das dazugehörige log:
          Danke.
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @homoran sagte in VIS lässt sich nicht installieren:
            dieter@iobroker:~$ iob list adapters
            system.adapter.admin                   : admin          - v5.3.8
            system.adapter.alias-manager           : alias-manager  - v1.2.4
            system.adapter.asterisk                : asterisk       - v1.0.6
            system.adapter.backitup                : backitup       - v2.4.9
            system.adapter.bmw                     : bmw            - v2.5.4
            system.adapter.bosch-ebike             : bosch-ebike    - v0.0.1
            system.adapter.cloud                   : cloud          - v4.1.1
            system.adapter.contact                 : contact        - v1.1.3
            system.adapter.daswetter               : daswetter      - v3.1.2
            system.adapter.doorio                  : doorio         - v2.1.4
            system.adapter.dwd                     : dwd            - v2.8.3
            system.adapter.email                   : email          - v1.1.3
            system.adapter.fb-checkpresence        : fb-checkpresence - v1.1.14
            system.adapter.feiertage               : feiertage      - v1.1.0
            system.adapter.flot                    : flot           - v1.11.0
            system.adapter.fritzbox                : fritzbox       - v0.2.1
            system.adapter.fritzdect               : fritzdect      - v2.2.3
            system.adapter.hm-rega                 : hm-rega        - v3.0.40
            system.adapter.hm-rpc                  : hm-rpc         - v1.15.12
            system.adapter.ical                    : ical           - v1.12.1
            system.adapter.icons-material-png      : icons-material-png - v0.1.0
            system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
            system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
            system.adapter.info                    : info           - v1.9.19
            system.adapter.javascript              : javascript     - v5.7.0
            system.adapter.linux-control           : linux-control  - v1.1.3
            system.adapter.logparser               : logparser      - v1.1.0
            system.adapter.mbus                    : mbus           - v2.3.4
            system.adapter.mihome                  : mihome         - v1.4.0
            system.adapter.mihome-vacuum           : mihome-vacuum  - v3.4.2
            system.adapter.mqtt                    : mqtt           - v3.0.6
            system.adapter.musiccast               : musiccast      - v1.0.5
            system.adapter.octoprint               : octoprint      - v4.0.0
            system.adapter.onvif                   : onvif          - v0.4.5
            system.adapter.parser                  : parser         - v1.1.7
            system.adapter.ping                    : ping           - v1.5.3
            system.adapter.pollenflug              : pollenflug     - v1.0.6
            system.adapter.proxmox                 : proxmox        - v1.3.4
            system.adapter.rest-api                : rest-api       - v1.0.0
            system.adapter.rssfeed                 : rssfeed        - v1.0.0
            system.adapter.sayit                   : sayit          - v1.12.3
            system.adapter.shelly                  : shelly         - v5.3.2
            system.adapter.simple-api              : simple-api     - v2.7.0
            system.adapter.smartmeter              : smartmeter     - v3.3.4
            system.adapter.socketio                : socketio       - v4.2.0
            system.adapter.sql                     : sql            - v2.1.7
            system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
            system.adapter.telegram                : telegram       - v1.13.0
            system.adapter.tr-064                  : tr-064         - v4.2.16
            system.adapter.tuya                    : tuya           - v3.6.15
            system.adapter.viessmann               : viessmann      - v1.3.7
            system.adapter.vis                     : vis            - v1.4.15
            system.adapter.vis-bars                : vis-bars       - v0.1.4
            system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
            system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
            system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
            system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.3
            system.adapter.vis-history             : vis-history    - v1.0.0
            system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
            system.adapter.vis-icontwo             : vis-icontwo    - v0.87.0
            system.adapter.vis-inventwo            : vis-inventwo   - v3.3.1
            system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
            system.adapter.vis-justgage            : vis-justgage   - v1.0.2
            system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
            system.adapter.vis-lcars               : vis-lcars      - v1.0.4
            system.adapter.vis-map                 : vis-map        - v1.0.4
            system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.86
            system.adapter.vis-metro               : vis-metro      - v1.2.0
            system.adapter.vis-players             : vis-players    - v0.1.6
            system.adapter.vis-plumb               : vis-plumb      - v1.0.2
            system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
            system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
            system.adapter.web                     : web            - v4.3.0
            system.adapter.wiobrowser              : wiobrowser     - v1.1.4
            system.adapter.yamaha                  : yamaha         - v0.5.2
            system.adapter.zigbee                  : zigbee         - v1.7.5
            dieter@iobroker:~$
            Da steht vis drin. Ist ja auch logisch. Wurde ja durch restore bei backitup eingespielt.
            Er lässt sich nur nicht installieren.
            Danke.
            crunchipC HomoranH 2 Antworten Letzte Antwort
            • bahnuhrB bahnuhr
              dieter@iobroker:~$
              crunchipC Offline
              crunchipC Offline
              @bahnuhr https://forum.iobroker.net/post/813432 war z.b. vis/backitup ein Thema
              allerdings war es üblicherweise so, das der vis Adapter nicht vorhanden war, aber die Instanz
              aus dem log sehe ich z.b.
              39 silly fetch manifest iobroker.vis@1.4.15
              40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
              64 info run iobroker.vis@1.4.15 install node_modules/iobroker.vis node main.js --install
              65 info run iobroker.vis@1.4.15 install { code: 6, signal: null }
              66 timing reify:rollback:createSparse Completed in 433ms
              67 timing reify:rollback:retireShallow Completed in 0ms
              68 timing command:install Completed in 16463ms
              69 verbose stack Error: command failed
              69 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
              69 verbose stack     at ChildProcess.emit (node:events:527:28)
              69 verbose stack     at maybeClose (node:internal/child_process:1092:16)
              69 verbose stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
              70 verbose pkgid iobroker.vis@1.4.15
              71 verbose cwd /opt/iobroker
              jedoch kann ich damit auch nix anfangen
              probier es mal im Nachgang mit
              cd /opt/iobroker
              npm install vis@1.4.12
              • bahnuhrB bahnuhr
                Im log kommt:
                vis.0
                vis.0
                vis.0
                vis.0
                vis.0
                vis.0
                -> 1.4.15:
                -> 1.4.14:
                Corrected GUI bug
                -> 1.4.13:
                -> 1.4.12:
                -> 1.4.11:
                -> 1.4.8:
                -> 1.4.7:
                NPM version: 8.11.0
                npm ERR! code 6
                Frage:
                Danke.
                mfg
                Dieter
                Michi68
                @bahnuhr
                hatte letztens das selbe Problem als ich meinen Raspberry auf Bullseye geupdatet habe.
                Installiere VIS bevor du das Backup zurückspielst dann sollte es gehen.
                • bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  @crunchip
                  @Michi68
                  Danke an alle.
                  Die Lösung stand auf git:
                  https://github.com/ioBroker/ioBroker.vis/issues/459
                  zuerst:
                  iobroker install vis@1.4.5
                  Und dann bei den Adapter upgrade gedrückt.
                  Läuft wieder.
                  P.S.
                  Dieser Fehler sollte trotzdem bereinigt werden.
                  Danke.
                  • bahnuhrB bahnuhr
                    dieter@iobroker:~$
                    @bahnuhr sagte in [gelöst] VIS lässt sich nicht installieren:
                    eben icht!
                    gerade wenn durch den vis bug bei Backitup ein Backup wiederhergestellt wurde.
                    Dann wurde zwar die Instanz, aber eben nicht der Adapter installiert.
                    Dieser ist bei dir ja aus irgendeinem Grund vorhanden.
                    was willst du denn dan installieren?
                      eben icht!
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      Ein Anwender setzt alles neu auf (gemäß proxmox Doku auf iobroker)
                      Backitup eingespielt.
                      Alle Adapter/Intanzen werden nachinstalliert.
                      Nur nicht vis.
                      Alles muss da irgendwo der Fehler sein.
                      Entweder in vis, oder in iob, oder wo auch immer.
                      Und diesen Fehler/bug sollte man bereinigen.
                      Danke.
                      • bahnuhrB bahnuhr
                        Nur nicht vis.
                        Richtig!
                        gibt es gefühlt 100 Threads zu
                          Richtig!
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          @homoran sagte in [gelöst] VIS lässt sich nicht installieren:
                          Das freut mich für dich wenn du diese alle gelesen hast.
                          Für mich war dies nicht present (obwohl ich mehrere Stunden täglich hier im Forum bin).
                          Danke.
                          • bahnuhrB bahnuhr
                            crunchipC Offline
                            crunchipC Offline
                            alleine, wenn man genau deinen Threadtitel in die Suche eingibt, findet man etliche Thread's zumal Tage dabei waren, an denen es fast Top Thema war.
