  4. Javascript Instanz wird von MailListener getötet
15 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • W Offline
    W Offline
    WolfgangFB
    Hallo, bei manchen E-Mails bring der Mail Listener die gesamte Javaskript Instanz zum Absturz.
    Den Code habe ich eigentlich 1:1 von der github Seite übernommen.
    Folgendes steht im Logfile:
    TypeError: mime.extension is not a function at MailParser._generateFileName (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mailparser/lib/mailparser.js:1407:27) at MailParser._processStateHeader (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mailparser/lib/mailparser.js:309:61) at MailParser._process (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mailparser/lib/mailparser.js:227:22) at processImmediate (internal/timers.js:464:21)
    error	Error: mime.extension is not a function
    error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    Das Skript dass meine Mails überwachen soll besteht bisher nur aus:
    var MailListener = require("mail-listener2");
    var mailobj = {val:
                        topic: "",
                        text: "",
    var mailListener = new MailListener({
      username: "xxxxxxxxxx",
      password: "xxxxx",
      host: "imap.1und1.de",
      port: 993, // imap port
      tls: true,
      connTimeout: 10000, // Default by node-imap
      authTimeout: 5000, // Default by node-imap,
      debug: console.log, // Or your custom function with only one incoming argument. Default: null
      tlsOptions: { rejectUnauthorized: false },
      mailbox: "Inbox", // mailbox to monitor
      searchFilter: ["*"], //;["UNSEEN", "FLAGGED"], // the search filter being used after an IDLE notification has been retrieved
      markSeen: true, // all fetched email willbe marked as seen and not fetched next time
      fetchUnreadOnStart: true, // use it only if you want to get all unread email on lib start. Default is `false`,
      mailParserOptions: {streamAttachments: true}, // options to be passed to mailParser lib.
      attachments: true, // download attachments as they are encountered to the project directory
      attachmentOptions: { directory: "attachments/" } // specify a download directory for attachments
    mailListener.on("mail", function(mail, seqno, attributes){
            log(mail.from[0].address);
            log(mail.from[0].name);
            log(mail.subject);
            log( mail.text);
            var mailobj = {val:
                        topic: mail.subject,
                        text:  mail.text
            setState("Email.Reception",mailobj);
            setState("Email.from_address", mail.from[0].address);
            setState("Email.from_name", mail.from[0].name);
            setState("Email.mail_subject", mail.subject);
            setState("Email.mail_text", mail.text);
    Was läuft hier schief?
    mickymM F 2 Antworten Letzte Antwort
    • W WolfgangFB
      var mailobj = {val:
                          topic: "",
                          text: "",
        password: "xxxxx",
        tls: true,
              log(mail.subject);
              log( mail.text);
              var mailobj = {val:
                          text:  mail.text
      mickymM Offline
      mickymM Offline
      mickym
      @wolfgangfb Kill den Mörder. ;)
      • W WolfgangFB
        var mailobj = {val:
                            topic: "",
                            text: "",
          password: "xxxxx",
          tls: true,
                log(mail.subject);
                log( mail.text);
                var mailobj = {val:
                            text:  mail.text
        F Online
        F Online
        fastfoot
        @wolfgangfb ich habe const MailListener = require("mail-listener2-updated") verwendet und das funktioniert mit gmail. In deinem code fehlt noch mailListener.start()
        Evtl solltest du auch mal die Attachements abschalten. Unbedingt muss ins Skript das hier rein, sonst hört der auch bei Stop des Skripts nicht auf :-)
        onStop(() => {
            mailListener.stop();
        iobroker läuft unter Docker auf Windows (WSL2)
        W 1 Antwort Letzte Antwort
        • F fastfoot
          onStop(() => {
          W Offline
          W Offline
          WolfgangFB
          @fastfoot
          Die Zeile mailListener.start() ist ei copy&paste verloren gegangen. Ich habe das jetzt mal probiert, mal sehen ob es hilf.
          F 1 Antwort Letzte Antwort
          • W WolfgangFB
            @fastfoot
            F Online
            F Online
            fastfoot
            @wolfgangfb Diese Zeile war aber nicht für den Fehler verantwortlich. Deshalb besser die Nachfolgeversion installieren. Ob er generell connected solltest du sofort nach dem Start sehen, selbst wenn keine neue Mail da ist
            • F fastfoot
              W Offline
              W Offline
              WolfgangFB
              @fastfoot
              Das Problem taucht immer noch auf
              Kann es sein,. dass es sich um Anhänge handelt, die das Problem auslösen?
              Ich habe aber den Part mit
              mailListener.on("attachment"
              schon rausgenommen. Kann man dem Maillistener irgendwie beibringen, Anhänge zu ignorieren?
              • W WolfgangFB
                @fastfoot
                F Online
                F Online
                fastfoot
                @wolfgangfb
                • W Offline
                  W Offline
                  WolfgangFB
                  @fastfoot
                  Ich konnte jetzt zu 100% nachvollziehen, dass die gesamte Javascript Instanz abstürzt, sobald die letzte Mail einen Anhang enthält.
                  Ich habe inzwischen
                  var MailListener = require("mail-listener2-updated");
                  und
                    mailParserOptions: {streamAttachments: false}, // options to be passed to mailParser lib.
                    attachments: false, // download attachments as they are encountered to the project directory
                    attachmentOptions: { directory: AttachmentsDirectory } // specify a download directory for attachments
                  gesetzt.
                  Der Trigger
                  wird bis zum Ende durchlaufen (mit Logdatei kontrolliert). Dann kommt kein weiterer Logeintrag und die Javascript Instanz stürzt ab, Nach ca. 40 Sekunden startet die Javascript Instanz neu, demnach auch das Skript und das ganze geht in eine Endlosschleife.
                  Hat noch jemand eine Ahnung, wie ich das abstellen könnte?
                  Es wäre ja schon hilfreich, wenn on("mail") wirklich nur aufgerufen werden würde, wenn wirklich eine neue Mail kommt und nicht bei jedem Skriptstart die letzte Mail wieder gelesen werden würde.
                  Welche Alternativen gibt es zu mail-listener2? Ich brauche eigentlich nur den Betreff und den Absender. Der Rest ist für diese Aufgabe irrelevant.
                  DJMarc75D F 2 Antworten Letzte Antwort
                  • W WolfgangFB
                    @fastfoot
                    Ich habe inzwischen
                    und
                    gesetzt.
                    Der Trigger
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    @wolfgangfb sagte in Javascript Instanz wird von MailListener getötet:
                    Da ich ein ähnliches Problem hatte habe ich das per NODE-RED gelöst - läuft und ich schreibe mir alle Werte einzeln in ein JSON damit.
                    Lehrling seit 1975 !!!
                    • W WolfgangFB
                      @fastfoot
                      Ich habe inzwischen
                      und
                      gesetzt.
                      Der Trigger
                      F Online
                      F Online
                      fastfoot
                      hast markSeen auf false gesetzt?
                      Stimmt dein attachmentOptions: { directory: AttachmentsDirectory }?
                      Ansonsten ist das Programm halt schon recht betagt. Mehr fällt mir dazu nicht ein
                      • F fastfoot
                        W Offline
                        W Offline
                        WolfgangFB
                        @fastfoot
                        MarkSeen hat das ganze etwas verbessert.
                        Gibt es denn Alternativen um Mails zu empfangen?
                        • W WolfgangFB
                          @fastfoot
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          Ähm... ignoriert ?
                          @djmarc75 sagte in Javascript Instanz wird von MailListener getötet:
                          • W WolfgangFB
                            @fastfoot
                            F Online
                            F Online
                            fastfoot
                            schau dir mal node-imap an, das ist recht aktuell
                            • F Online
                              F Online
                              fastfoot
                              Hier mal ein Beispiel mit node-imap:
                               * Zweck:     liest emails von Imap Providern
                               * Datum:     07.07.2022
                               * Autor:     @fastfoot
                               *            für iobroker modifizierter Beispielcode von https://github.com/mscdex/node-imap
                              var Imap = require('imap'),
                                  inspect = require('util').inspect;
                              var imap = new Imap({
                                  user: 'user@gmail.com',
                                  password: 'mypassword',
                                  host: 'imap.gmail.com',
                                  port: 993,
                                  tls: true,
                                  tlsOptions: { rejectUnauthorized: false }, //verhindert den Fehler 'self signed certificate'
                                  debug: console.log // oder null
                              function openInbox(cb) {
                                  imap.openBox('INBOX', true, cb);
                              imap.once('ready', function () {
                                  openInbox(function (err, box) {
                                      if (err) throw err;
                                      var f = imap.seq.fetch('1:5', {
                                          bodies: 'HEADER.FIELDS (FROM TO SUBJECT DATE)',
                                          struct: true
                                      f.on('message', function (msg, seqno) {
                                          console.log('Message #' + seqno);
                                          var prefix = '(#' + seqno + ') ';
                                          msg.on('body', function (stream, info) {
                                              var buffer = '';
                                              stream.on('data', function (chunk) {
                                                  buffer += chunk.toString('utf8');
                                              stream.once('end', function () {
                                                  const headers = Imap.parseHeader(buffer);
                                                  log('Datum: ' + headers.date[0]);
                                                  log('From: ' + headers.from[0]);
                                                  log('To: ' + headers.to[0]);
                                                  log('Subject: ' + headers.subject[0]);
                                          msg.once('attributes', function (attrs) {
                                              console.log(prefix + 'Attributes: ' + inspect(attrs, false, 8));
                                          msg.once('end', function () {
                                              console.log(prefix + 'Finished');
                                      f.once('error', function (err) {
                                          console.log('Fetch error: ' + err);
                                      f.once('end', function () {
                                          console.log('Done fetching all messages!');
                                          imap.end();
                              imap.once('error', function (err) {
                                  console.log(err);
                              imap.once('end', function () {
                                  console.log('Connection ended');
                              imap.connect();
                              onStop(() => {
                                  imap.end();
                              • F fastfoot
                                 * Datum:     07.07.2022
                                 * Autor:     @fastfoot
                                    port: 993,
                                    tls: true,
                                        if (err) throw err;
                                            struct: true
                                                var buffer = '';
                                            imap.end();
                                    console.log(err);
                                imap.connect();
                                onStop(() => {
                                    imap.end();
                                Masl
                                @fastfoot Kannst du mir zufällig helfen, wie man einen Datenpunkt mit dieser Vorlage erstellt die man später auslesen kann? Der Mail-Listener bringt mir nur Fehler...
