  4. IOBroker nur manuell startbar, reagiert nicht auf Befehle
    5.9k
68 Beiträge 5 Kommentatoren 7.4k Aufrufe 3 Beobachtet
  • S Silencerbob
    Beta nicht anhaken oder?
    Dann bringt rödelt er etwas und meldet dann neue Updates!!!
    #61
    @silencerbob
    Nein, Beta würde ich nicht generell aktiv setzen.
    iobroker repo list
    iobroker update -i
    sagen nun?
      @silencerbob
      iobroker repo list
      iobroker update -i
      sagen nun?
      Silencerbob
      #62
      pi@raspberrypi:~ $ iobroker repo list
      Active repo(s): stable
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ iobroker update -i
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
      Adapter    "beckhoff"     : 1.5.0    , installed 1.5.0
      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "history"      : 1.11.1   , installed 1.11.1
      Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "odl"          : 2.0.5    , installed 2.0.5
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "scenes"       : 2.3.9    , installed 2.3.9
      Adapter    "simple-api"   : 2.7.0    , installed 2.6.5  [Updatable]
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "synology"     : 2.1.7    , installed 2.1.6  [Updatable]
      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
      Adapter    "telegram"     : 1.13.0   , installed 1.12.6 [Updatable]
      Adapter    "text2command" : 2.2.1    , installed 2.2.1
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
      Adapter    "traccar"      : 0.0.11   , installed 0.0.11
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      • S Silencerbob
        pi@raspberrypi:~ $
        #63
        @silencerbob
        Dann sollte
        iobroker upgrade all
        jetzt die drei Updates auf das System werfen.
        • S Silencerbob
          Was meinst du mit msl?
          #64
          @silencerbob sagte in IOBroker nur manuell startbar, reagiert nicht auf Befehle:
          dicke finger am Handy
            Silencerbob
            #65
            Das kenne ich 👊
            • S Silencerbob
              So?
              #66
              So?
              War da vorher gar nichts drin?
              Sehr seltsam!
              oder hattest du diese gelöscht?
                So?
                Sehr seltsam!
                Silencerbob
                #67
                Nein, da war nichts drin
                • S Silencerbob
                  #68
                  kann eigentlich nicht sein.
                  Wer weiß ob sonst noch etwas bei der Installation schief gelaufen ist.
