  4. VIS nach Backitup Fehler
    5.8k
3 Beiträge 3 Kommentatoren 449 Aufrufe 3 Beobachtet
  • ConstantinC Offline
    ConstantinC Offline
    Constantin
    wollte mein System nun auf Raspberry OS Bullseye umstellen.
    Also vorher Backup per Backitup erstellt und dann SD Karte mit der Version Bullseye installiert.
    Wieder iobroker drauf und Backup wieder per Backitup eingespielt.
    Jetzt macht allerdings VIS probleme.
    Wenn ich jetzt VIS aufrufe über localhost:8082 kommt File index.html not found: {}.
    Beim aufspielen des Backups kam folgender Fehler:
    host.SmartHome
    	2022-06-02 17:13:06.739	info	iobroker npm-install: exit 25
    host.SmartHome
    	2022-06-02 17:13:05.704	error	iobroker npm-install: host.SmartHome Cannot install iobroker.vis@1.4.15: 6
    vis.0
    	2022-06-02 17:13:02.118	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    vis.0
    	2022-06-02 17:13:02.115	info	terminating
    vis.0
    	2022-06-02 17:13:01.606	error	Not exists
    vis.0
    	2022-06-02 17:13:01.605	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:466:21)
    vis.0
    	2022-06-02 17:13:01.602	error	unhandled promise rejection: Not exists
    vis.0
    	2022-06-02 17:13:01.600	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    vis.0
    	2022-06-02 17:13:01.133	info	vis license is OK.
    vis.0
    	2022-06-02 17:13:00.929	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.3, js-controller: 4.0.23
    host.SmartHome
    	2022-06-02 17:12:58.393	info	iobroker npm-install: > iobroker.vis@1.4.15 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
    host.SmartHome
    	2022-06-02 17:12:33.212	info	iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
    host.SmartHome
    	2022-06-02 17:12:33.209	info	iobroker npm-install: NPM version: 6.14.17
    host.SmartHome
    	2022-06-02 17:12:29.644	info	iobroker install vis@1.4.15 using installedFrom
    host.SmartHome
    	2022-06-02 17:12:29.643	warn	startInstance cannot find adapter "vis@1.4.15". Try to install it... 1 attempt
    Hat da jemand einen Lösungsvorschlag?
    GlasfaserG crunchipC 2 Antworten Letzte Antwort
    • ConstantinC Constantin
      host.SmartHome
      host.SmartHome
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      host.SmartHome
      host.SmartHome
      host.SmartHome
      host.SmartHome
      host.SmartHome
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @constantin sagte in VIS nach Backitup Fehler:
      Die Suche mal nutzen ... das ist gerade Hauptthema von 1.2.3 Thread´s dazu .
      Beispiel ::
      https://forum.iobroker.net/topic/55307/kann-vis-edit-html-nicht-finden/43
        host.SmartHome
        host.SmartHome
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        host.SmartHome
        host.SmartHome
        host.SmartHome
        host.SmartHome
        host.SmartHome
        crunchipC Abwesend
        crunchipC Abwesend
        @constantin Forums(suche) wobei man nichtmal großartig suchen müsste, da es ganz oben in der Liste steht
        https://forum.iobroker.net/topic/55307/kann-vis-edit-html-nicht-finden/72
