  4. Fehler nach Update iobroker
    6.3k
7 Beiträge 4 Kommentatoren 840 Aufrufe 4 Beobachtet
  • H Offline
    hoschiman0
    Moin,
    Ich habe heute mein iobroker ( Admin )ein update verpasst.
    Nun bekomme ich den nicht mehr zum laufen und folgende Meldung.
    internal/modules/cjs/loader.js:905
    throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
    at internal/main/run_main_module.js:17:47 {
    code: 'MODULE_NOT_FOUND',
    requireStack: []
    Kann mir jemand helfen wo der Fehler liegt?
    Vielen Dank
    • H hoschiman0
      Moin,
      throw err;
      requireStack: []
      Vielen Dank
      crunchipC Offline
      crunchipC Offline
      @hoschiman0 sagte in Fehler nach Update iobroker:
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      iobroker stop
      iobroker fix
      iobroker start
      und danach
      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      H S 2 Antworten Letzte Antwort
        cd /opt/iobroker
        iobroker stop
        iobroker fix
        iobroker start
        und danach
        hoschiman0
        @crunchip das sind die Meldungen
        pi@iobroker-pi:~ $ cd /opt/iobroker
        pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        node lib/preinstallCheck.js
        NPM version: 6.14.16
        iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
        node iobroker.js setup first
        No connection to databases possible ...
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
        npm ERR! code ELIFECYCLE
        npm ERR! errno 22
        npm ERR! iobroker.js-controller@4.0.21 install: node iobroker.js setup first
        npm ERR! Exit status 22
        npm ERR!
        npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR! /home/iobroker/.npm/_logs/2022-05-01T20_04_42_209Z-debug.log
        pi@iobroker-pi:/opt/iobroker $ iobroker stop
        pi@iobroker-pi:/opt/iobroker $ iobroker fix
        library: loaded
        Library version=2022-02-10
        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
        pi@iobroker-pi:/opt/iobroker $ iobroker start
        pi@iobroker-pi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        pi@iobroker-pi:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.0
        v14.19.0
        6.14.16
        pi
        /opt/iobroker
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
        Reading package lists... Done
        Building dependency tree
        All packages are up to date.
        nodejs:
        Installed: 14.19.0-deb-1nodesource1
        Candidate: 14.19.0-deb-1nodesource1
        Version table:
        *** 14.19.0-deb-1nodesource1 100
        100 /var/lib/dpkg/status
        10.24.1-1nodesource1 500
        500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
        10.24.0~dfsg-1~deb10u1 500
        pi@iobroker-pi:/opt/iobroker $ reboot
        • H hoschiman0
          npm ERR! errno 22
          npm ERR!
          library: loaded
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.19.0
          v14.19.0
          6.14.16
          pi
          /opt/iobroker
          nodejs:
          Version table:
          @hoschiman0
          nodesource.list gescheit einrichten. Da steht bei dir 10 drin, es sollte 14 drin stehen.
          Ausgaben aus der Konsole in CodeTags eingebettet hier rein.
            cd /opt/iobroker
            iobroker stop
            iobroker fix
            iobroker start
            und danach
            Sneak-L8
            @crunchip Ich hatte das gleiche Problem eben.
            Die ersten 5 Schritte von Dir konnten so angewendet werden und ioBroker läuft wieder (mit altem js-controller).
            Wenn ich dann weitermache bekomme ich aber
            pi@ioBroker-RasPi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
            Bevor ich jetzt weitermache und was zerschieße: ist das ok und ich führe den nächsten Befehl auch aus oder stimmt das was nicht? Bisher haben die Updates problemlos funktioniert.
            Soll ic hdann das Update js-controller nochmal versuchen?
            • S Sneak-L8
              crunchipC Offline
              crunchipC Offline
              @sneak-l8 passt, weitermachen
                Sneak-L8
                @crunchip Super, vielen Dank, Folgebefhl lief dann durch und anschließend hat auch das Update des js-controller geklappt.
                Befürchte, dass aber noch mehr auf diesen Fehler stoßen werden. Zum Glück gibt's dann schon diesen Thread...
