  3. Einsteigerfragen
  4. Npm Fehler / ioBroker startet nicht
    5.6k
npm err
45 Beiträge 4 Kommentatoren 4.7k Aufrufe 3 Beobachtet
    @christian-sandkaulen sagte in Npm Fehler / ioBroker startet nicht:
    mv /opt/iobroker/iobroker-data/iobroker.json /opt/iobroker/iobroker-data/iobroker.jsonbak
    ChrisNettC Offline
    ChrisNettC Offline
    ChrisNett
    schrieb am zuletzt editiert von ChrisNett
    @thomas-braun sagte in Npm Fehler / ioBroker startet nicht:
    pi@PI4:/opt/iobroker $ mv /opt/iobroker/iobroker-data/iobroker.json /opt/iobroker/iobroker-data/iobroker.jsonbak
    pi@PI4:/opt/iobroker $ iobroker start
    pi@PI4:/opt/iobroker $ ^C
    pi@PI4:/opt/iobroker $ iobroker list instances
    Uncaught Rejection: Error: /opt/iobroker/iobroker-data/iobroker.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/iobroker.json'
        at Object.openSync (node:fs:585:3)
        at Object.readFileSync (node:fs:453:35)
        at Object.readFileSync (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:50:22)
        at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3088:23)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1308:13)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
        at Module._compile (node:internal/modules/cjs/loader:1103:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
        at Module.load (node:internal/modules/cjs/loader:981:32)
    • ChrisNettC ChrisNett
      Keine Ahnung wie oder wer die iobroker.json anlegt.
      Versuch mal
      iobroker setup first
      ChrisNettC 1 Antwort Letzte Antwort
        Versuch mal
        ChrisNettC Offline
        ChrisNettC Offline
        ChrisNett
        danke, scheinbar war es das er fährt hoch
        pi@PI4:/opt/iobroker $ iobroker setup first
        creating conf/iobroker.json
        Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
        + system.adapter.admin.1                  : admin                 : PI4                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.1                 : alexa2                : PI4                                      -  enabled
          system.adapter.backitup.0               : backitup              : PI4                                      -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : PI4                                      -  enabled
        + system.adapter.cloud.0                  : cloud                 : PI4                                      -  enabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: PI4                                      -  enabled
        + system.adapter.denon.0                  : denon                 : PI4                                      -  enabled
          system.adapter.devices.0                : devices               : PI4                                      - disabled
          system.adapter.discovery.0              : discovery             : PI4                                      - disabled
        + system.adapter.dwd.0                    : dwd                   : PI4                                      -  enabled
          system.adapter.echarts.0                : echarts               : PI4                                      -  enabled
          system.adapter.fahrplan.0               : fahrplan              : PI4                                      -  enabled
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : PI4                                      -  enabled
        + system.adapter.feiertage.0              : feiertage             : PI4                                      -  enabled
          system.adapter.flot.0                   : flot                  : PI4                                      - disabled
        + system.adapter.history.0                : history               : PI4                                      -  enabled
        + system.adapter.hmip.0                   : hmip                  : PI4                                      -  enabled
          system.adapter.ical.0                   : ical                  : PI4                                      -  enabled
          system.adapter.ical.1                   : ical                  : PI4                                      -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: PI4                                      - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : PI4                                      - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : PI4                                      - disabled
          system.adapter.info.0                   : info                  : PI4                                      -  enabled
          system.adapter.iot.0                    : iot                   : PI4                                      -  enabled
        + system.adapter.javascript.0             : javascript            : PI4                                      -  enabled
        + system.adapter.klf200.0                 : klf200                : PI4                                      -  enabled
          system.adapter.logparser.0              : logparser             : PI4                                      - disabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
        + system.adapter.mihome-vacuum.2          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
          system.adapter.mqtt.0                   : mqtt                  : PI4                                      - disabled, port: 1893, bind: 0.0.0.0
          system.adapter.onvif.0                  : onvif                 : PI4                                      - disabled
          system.adapter.parcel.0                 : parcel                : PI4                                      -  enabled
          system.adapter.parser.0                 : parser                : PI4                                      - disabled
        + system.adapter.pegelalarm.0             : pegelalarm            : PI4                                      -  enabled
          system.adapter.pi-hole.0                : pi-hole               : PI4                                      -  enabled
        + system.adapter.ping.0                   : ping                  : PI4                                      -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : PI4                                      -  enabled
          system.adapter.pvforecast.0             : pvforecast            : PI4                                      -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : PI4                                      -  enabled
        + system.adapter.samsung.0                : samsung               : PI4                                      -  enabled
        + system.adapter.shelly.0                 : shelly                : PI4                                      -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : PI4                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : PI4                                      -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.sourceanalytix.0         : sourceanalytix        : PI4                                      - disabled
          system.adapter.tankerkoenig.0           : tankerkoenig          : PI4                                      -  enabled
        + system.adapter.telegram.0               : telegram              : PI4                                      -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : PI4                                      -  enabled
        + system.adapter.tr-064.0                 : tr-064                : PI4                                      -  enabled
          system.adapter.trashschedule.0          : trashschedule         : PI4                                      -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : PI4                                      - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : PI4                                      - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : PI4                                      - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : PI4                                      - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : PI4                                      -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : PI4                                      - disabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : PI4                                      - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : PI4                                      - disabled
          system.adapter.vis-metro.0              : vis-metro             : PI4                                      - disabled
          system.adapter.vis.0                    : vis                   : PI4                                      -  enabled
        + system.adapter.weatherunderground.0     : weatherunderground    : PI4                                      -  enabled
          system.adapter.web-speedy.0             : web-speedy            : PI4                                      - disabled
          system.adapter.web.0                    : web                   : PI4                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.worx.0                   : worx                  : PI4                                      -  enabled
        + system.adapter.zigbee.0                 : zigbee                : PI4                                      -  enabled, port: /dev/ttyUSB0
        + instance is alive
          + instance is alive
          ChrisNettC Offline
          ChrisNettC Offline
          ChrisNett
          kommt jetzt muss ich da noch was machen?
            Das heißt, du warst noch gar nicht auf jsonl?
            Dann ist es jetzt wohl so weit.
            iobroker status
            sagt?
            iobroker update -i
              iobroker status
              sagt?
              iobroker update -i
              ChrisNettC Offline
              ChrisNettC Offline
              ChrisNett
              pi@PI4:/opt/iobroker $ iobroker status
              Objects type: jsonl
              States  type: jsonl
              pi@PI4:/opt/iobroker $ iobroker update -i
              Adapter    "admin"        : 5.3.8    , installed 5.3.8
              Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
              Adapter    "backitup"     : 2.4.6    , installed 2.4.6
              Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
              Adapter    "cloud"        : 4.1.1    , installed 4.1.1
              Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
              Adapter    "denon"        : 1.13.3   , installed 1.13.3
              Adapter    "devices"      : 1.0.10   , installed 1.0.10
              Adapter    "discovery"    : 3.0.3    , installed 3.0.3
              Adapter    "dwd"          : 2.8.3    , installed 2.8.3
              Adapter    "echarts"      : 1.0.3    , installed 1.0.3
              Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
              Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
              Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
              Adapter    "flot"         : 1.10.7   , installed 1.10.7
              Adapter    "history"      : 1.11.1   , installed 1.11.1
              Adapter    "hmip"         : 1.15.4   , installed 1.15.4
              Adapter    "hs100"        : 2.0.6    , installed 2.0.6
              Adapter    "ical"         : 1.12.1   , installed 1.12.1
              Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
              Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
              Adapter    "info"         : 1.9.18   , installed 1.9.18
              Adapter    "iot"          : 1.11.4   , installed 1.11.4
              Adapter    "javascript"   : 5.2.21   , installed 5.2.21
              Controller "js-controller": 4.0.21   , installed 4.0.21
              Adapter    "klf200"       : 1.0.1    , installed 1.0.1
              Adapter    "km200"        : 2.0.3    , installed 2.0.3
              Adapter    "landroid"     : 1.0.3    , installed 1.0.3
              Adapter    "logparser"    : 1.1.0    , installed 1.1.0
              Adapter    "mihome"       : 1.4.0    , installed 1.4.0
              Adapter    "mihome-vacuum": 3.3.1    , installed 3.3.1
              Adapter    "moma"         : 1.2.9    , installed 1.2.9
              Adapter    "mqtt"         : 2.7.4    , installed 2.7.4
              Adapter    "onvif"        : 0.4.4    , installed 0.4.4
              Adapter    "parcel"       : 0.0.15   , installed 0.0.15
              Adapter    "parser"       : 1.1.4    , installed 1.1.4
              Adapter    "pegelalarm"   : 1.2.5    , installed 1.2.5
              Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
              Adapter    "ping"         : 1.5.3    , installed 1.5.3
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "radar2"       : 2.0.3    , installed 2.0.3
              Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
              Adapter    "samsung"      : 0.2.9    , installed 0.2.9
              Adapter    "seq"          : 0.2.10   , installed 0.2.10
              Adapter    "shelly"       : 5.3.2    , installed 5.3.2
              Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
              Adapter    "socketio"     : 4.2.0    , installed 4.2.0
              Adapter    "sonoff"       : 2.5.0    , installed 2.5.0
              Adapter    "spotify-premium": 1.0.0  , installed 1.1.3
              Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
              Adapter    "telegram"     : 1.12.2   , installed 1.12.2
              Adapter    "text2command" : 2.2.1    , installed 2.2.1
              Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
              Adapter    "trashschedule": 1.4.5    , installed 1.4.5
              Adapter    "unifi"        : 0.5.10   , installed 0.5.10
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "vis"          : 1.4.5    , installed 1.4.5
              Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
              Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
              Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
              Adapter    "weatherunderground": 3.4.1, installed 3.4.1
              Adapter    "web"          : 4.2.3    , installed 4.2.3
              Adapter    "wifilight"    : 1.1.0    , installed 1.1.0
              Adapter    "worx"         : 1.5.5    , installed 1.5.5
              Adapter    "ws"           : 1.2.0    , installed 1.3.0
              Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
                Objects type: jsonl
                States  type: jsonl
                Gut. Sollte laufen.
                  Gut. Sollte laufen.
                  ChrisNettC Offline
                  ChrisNettC Offline
                  ChrisNett
                  danke, die Visualisierung ist nur weg, kann ich dir irgendwie aus dem backup wieder herstellen?
                    Ich hab keine Vis laufen. Ich kann dir nicht sagen ob und wie die gebackupt wird.
                      irgendwo müsste die vis-views.json liegen. Da sind alle Views drin
                        ChrisNettC Offline
                        ChrisNettC Offline
                        ChrisNett
                        @homoran sagte in Npm Fehler / ioBroker startet nicht:
                        danke die habe ich gefunden aber wie spiele ich das wieder ein? Import? View
                          Austauschen!
                          Da sind alle Views und Projekte drin
                            Austauschen!
                            ChrisNettC Offline
                            ChrisNettC Offline
                            ChrisNett
                            Austauschen!
                            okay als nicht linux user was ist der einfachtse weg? FTP oder geht das auch per ssh?
                              Austauschen!
                              Als Nicht Linux User kann ich dir nicht sagen, wie es mit SSH geht.
                              Dazu könnte @Thomas-Braun etwas sagen.
                              Ich mache es mit filezilla, aber als user, der auch in der Gruppe iobroker ist, auf keinen Fall als root
                                ChrisNettC Offline
                                ChrisNettC Offline
                                ChrisNett
                                also nicht der "pi" std user?
                                  bei mir ist der user pi in der Gruppe iobroker drin
                                  Aber warte doch mal auf die Antwort von Thomas
                                    ChrisNettC Offline
                                    ChrisNettC Offline
                                    ChrisNett
                                    @thomasBraun
                                    könntest du mir helfen?
                                      @thomasBraun
                                      Wo liegt die Datei denn nun?
                                      cp /pfad/zur/quelle /pfad/zum/ziel
                                      Vorausgesetzt dein Standarduser ist in der Gruppe 'iobroker' drin.
                                      Sonst:
                                      sudo -u iobroker cp /pfad/zur/quelle /pfad/zum/ziel
                                        Sonst:
                                        ChrisNettC Offline
                                        ChrisNettC Offline
                                        ChrisNett
                                        Sonst:
                                        ähm vom Windows PC zum pi ?
                                          Sonst:
                                          Machs mit Filezilla... :-D
                                          Ich würde mir vermutlich eine SMB-Freigabe auf dem Windows einrichten und die in den Raspberry mounten und dann von dort wegkopieren.
