  3. Einsteigerfragen
  4. Npm Fehler / ioBroker startet nicht
    5.6k
npm err
45 Beiträge 4 Kommentatoren 4.7k Aufrufe 3 Beobachtet
    @christian-sandkaulen
    cd /opt/iobroker
    iobroker stop
    sudo -H -u iobroker npm install iobroker.js-controller
    iobroker start
    ChrisNettC Offline
    ChrisNettC Offline
    ChrisNett
    @thomas-braun sagte in Npm Fehler / ioBroker startet nicht:
    cd /opt/iobroker
    iobroker stop
    iobroker start
    pi@PI4:/opt/iobroker $ iobroker stop
    pi@PI4:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm ERR! code 6
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! Cannot check config file: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input
    npm ERR! Uncaught Rejection: SyntaxError: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input
    npm ERR!     at JSON.parse (<anonymous>)
    npm ERR!     at Object.readFileSync (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:52:17)
    npm ERR!     at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3088:23)
    npm ERR!     at setupObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:252:9)
    npm ERR!     at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:1140:13)
    npm ERR!     at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:571:23)
    npm ERR!     at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5)
    npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
    npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1103:14)
    npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
    npm ERR!     /home/iobroker/.npm/_logs/2022-04-24T09_55_05_166Z-debug-0.log
    pi@PI4:/opt/iobroker $ iobroker start
    pi@PI4:/opt/iobroker $ ^C
    pi@PI4:/opt/iobroker $ iobroker list instances
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1308:13)
        at Module.load (node:internal/modules/cjs/loader:981:32)
        at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    • ChrisNettC ChrisNett
      cd /opt/iobroker
      iobroker stop
      iobroker start
      npm ERR! code 6
      @christian-sandkaulen sagte in Npm Fehler / ioBroker startet nicht:
      mv /opt/iobroker/iobroker-data/iobroker.json /opt/iobroker/iobroker-data/iobroker.jsonbak
      ChrisNettC 1 Antwort Letzte Antwort
        ChrisNettC Offline
        ChrisNettC Offline
        ChrisNett
        schrieb am zuletzt editiert von ChrisNett
        pi@PI4:/opt/iobroker $ mv /opt/iobroker/iobroker-data/iobroker.json /opt/iobroker/iobroker-data/iobroker.jsonbak
        Uncaught Rejection: Error: /opt/iobroker/iobroker-data/iobroker.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/iobroker.json'
            at Object.openSync (node:fs:585:3)
            at Object.readFileSync (node:fs:453:35)
            at Object.readFileSync (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:50:22)
          Keine Ahnung wie oder wer die iobroker.json anlegt.
          Versuch mal
          iobroker setup first
            Versuch mal
            ChrisNettC Offline
            ChrisNettC Offline
            ChrisNett
            danke, scheinbar war es das er fährt hoch
            pi@PI4:/opt/iobroker $ iobroker setup first
            creating conf/iobroker.json
            Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
            + system.adapter.admin.1                  : admin                 : PI4                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.1                 : alexa2                : PI4                                      -  enabled
              system.adapter.backitup.0               : backitup              : PI4                                      -  enabled
            + system.adapter.broadlink2.0             : broadlink2            : PI4                                      -  enabled
            + system.adapter.cloud.0                  : cloud                 : PI4                                      -  enabled
              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: PI4                                      -  enabled
            + system.adapter.denon.0                  : denon                 : PI4                                      -  enabled
              system.adapter.devices.0                : devices               : PI4                                      - disabled
              system.adapter.discovery.0              : discovery             : PI4                                      - disabled
            + system.adapter.dwd.0                    : dwd                   : PI4                                      -  enabled
              system.adapter.echarts.0                : echarts               : PI4                                      -  enabled
              system.adapter.fahrplan.0               : fahrplan              : PI4                                      -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : PI4                                      -  enabled
            + system.adapter.feiertage.0              : feiertage             : PI4                                      -  enabled
              system.adapter.flot.0                   : flot                  : PI4                                      - disabled
            + system.adapter.history.0                : history               : PI4                                      -  enabled
            + system.adapter.hmip.0                   : hmip                  : PI4                                      -  enabled
              system.adapter.ical.0                   : ical                  : PI4                                      -  enabled
              system.adapter.ical.1                   : ical                  : PI4                                      -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: PI4                                      - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : PI4                                      - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : PI4                                      - disabled
              system.adapter.info.0                   : info                  : PI4                                      -  enabled
              system.adapter.iot.0                    : iot                   : PI4                                      -  enabled
            + system.adapter.javascript.0             : javascript            : PI4                                      -  enabled
            + system.adapter.klf200.0                 : klf200                : PI4                                      -  enabled
              system.adapter.logparser.0              : logparser             : PI4                                      - disabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
            + system.adapter.mihome-vacuum.1          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
            + system.adapter.mihome-vacuum.2          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
              system.adapter.mqtt.0                   : mqtt                  : PI4                                      - disabled, port: 1893, bind: 0.0.0.0
              system.adapter.onvif.0                  : onvif                 : PI4                                      - disabled
              system.adapter.parcel.0                 : parcel                : PI4                                      -  enabled
              system.adapter.parser.0                 : parser                : PI4                                      - disabled
            + system.adapter.pegelalarm.0             : pegelalarm            : PI4                                      -  enabled
              system.adapter.pi-hole.0                : pi-hole               : PI4                                      -  enabled
            + system.adapter.ping.0                   : ping                  : PI4                                      -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : PI4                                      -  enabled
              system.adapter.pvforecast.0             : pvforecast            : PI4                                      -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : PI4                                      -  enabled
            + system.adapter.samsung.0                : samsung               : PI4                                      -  enabled
            + system.adapter.shelly.0                 : shelly                : PI4                                      -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : PI4                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : PI4                                      -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.sourceanalytix.0         : sourceanalytix        : PI4                                      - disabled
              system.adapter.tankerkoenig.0           : tankerkoenig          : PI4                                      -  enabled
            + system.adapter.telegram.0               : telegram              : PI4                                      -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0           : text2command          : PI4                                      -  enabled
            + system.adapter.tr-064.0                 : tr-064                : PI4                                      -  enabled
              system.adapter.trashschedule.0          : trashschedule         : PI4                                      -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : PI4                                      - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : PI4                                      - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : PI4                                      - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : PI4                                      - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : PI4                                      -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : PI4                                      - disabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : PI4                                      - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : PI4                                      - disabled
              system.adapter.vis-metro.0              : vis-metro             : PI4                                      - disabled
              system.adapter.vis.0                    : vis                   : PI4                                      -  enabled
            + system.adapter.weatherunderground.0     : weatherunderground    : PI4                                      -  enabled
              system.adapter.web-speedy.0             : web-speedy            : PI4                                      - disabled
              system.adapter.web.0                    : web                   : PI4                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.worx.0                   : worx                  : PI4                                      -  enabled
            + system.adapter.zigbee.0                 : zigbee                : PI4                                      -  enabled, port: /dev/ttyUSB0
            + instance is alive
              + instance is alive
              ChrisNettC Offline
              ChrisNettC Offline
              ChrisNett
              kommt jetzt muss ich da noch was machen?
                Das heißt, du warst noch gar nicht auf jsonl?
                Dann ist es jetzt wohl so weit.
                iobroker status
                sagt?
                iobroker update -i
                  iobroker status
                  sagt?
                  iobroker update -i
                  ChrisNettC Offline
                  ChrisNettC Offline
                  ChrisNett
                  pi@PI4:/opt/iobroker $ iobroker status
                  Objects type: jsonl
                  States  type: jsonl
                  pi@PI4:/opt/iobroker $ iobroker update -i
                  Adapter    "admin"        : 5.3.8    , installed 5.3.8
                  Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                  Adapter    "backitup"     : 2.4.6    , installed 2.4.6
                  Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                  Adapter    "cloud"        : 4.1.1    , installed 4.1.1
                  Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                  Adapter    "denon"        : 1.13.3   , installed 1.13.3
                  Adapter    "devices"      : 1.0.10   , installed 1.0.10
                  Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                  Adapter    "echarts"      : 1.0.3    , installed 1.0.3
                  Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
                  Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
                  Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                  Adapter    "flot"         : 1.10.7   , installed 1.10.7
                  Adapter    "history"      : 1.11.1   , installed 1.11.1
                  Adapter    "hmip"         : 1.15.4   , installed 1.15.4
                  Adapter    "hs100"        : 2.0.6    , installed 2.0.6
                  Adapter    "ical"         : 1.12.1   , installed 1.12.1
                  Adapter    "info"         : 1.9.18   , installed 1.9.18
                  Adapter    "iot"          : 1.11.4   , installed 1.11.4
                  Adapter    "javascript"   : 5.2.21   , installed 5.2.21
                  Controller "js-controller": 4.0.21   , installed 4.0.21
                  Adapter    "klf200"       : 1.0.1    , installed 1.0.1
                  Adapter    "km200"        : 2.0.3    , installed 2.0.3
                  Adapter    "landroid"     : 1.0.3    , installed 1.0.3
                  Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                  Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                  Adapter    "mihome-vacuum": 3.3.1    , installed 3.3.1
                  Adapter    "moma"         : 1.2.9    , installed 1.2.9
                  Adapter    "mqtt"         : 2.7.4    , installed 2.7.4
                  Adapter    "onvif"        : 0.4.4    , installed 0.4.4
                  Adapter    "parcel"       : 0.0.15   , installed 0.0.15
                  Adapter    "parser"       : 1.1.4    , installed 1.1.4
                  Adapter    "pegelalarm"   : 1.2.5    , installed 1.2.5
                  Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                  Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                  Adapter    "samsung"      : 0.2.9    , installed 0.2.9
                  Adapter    "seq"          : 0.2.10   , installed 0.2.10
                  Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                  Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
                  Adapter    "sonoff"       : 2.5.0    , installed 2.5.0
                  Adapter    "spotify-premium": 1.0.0  , installed 1.1.3
                  Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                  Adapter    "telegram"     : 1.12.2   , installed 1.12.2
                  Adapter    "text2command" : 2.2.1    , installed 2.2.1
                  Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                  Adapter    "trashschedule": 1.4.5    , installed 1.4.5
                  Adapter    "unifi"        : 0.5.10   , installed 0.5.10
                  Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                  Adapter    "vis"          : 1.4.5    , installed 1.4.5
                  Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                  Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                  Adapter    "weatherunderground": 3.4.1, installed 3.4.1
                  Adapter    "web"          : 4.2.3    , installed 4.2.3
                  Adapter    "wifilight"    : 1.1.0    , installed 1.1.0
                  Adapter    "worx"         : 1.5.5    , installed 1.5.5
                  Adapter    "ws"           : 1.2.0    , installed 1.3.0
                  Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
                    Objects type: jsonl
                    States  type: jsonl
                    Gut. Sollte laufen.
                      Gut. Sollte laufen.
                      ChrisNettC Offline
                      ChrisNettC Offline
                      ChrisNett
                      danke, die Visualisierung ist nur weg, kann ich dir irgendwie aus dem backup wieder herstellen?
                        Ich hab keine Vis laufen. Ich kann dir nicht sagen ob und wie die gebackupt wird.
                          irgendwo müsste die vis-views.json liegen. Da sind alle Views drin
                            ChrisNettC Offline
                            ChrisNettC Offline
                            ChrisNett
                            @homoran sagte in Npm Fehler / ioBroker startet nicht:
                            danke die habe ich gefunden aber wie spiele ich das wieder ein? Import? View
                              Austauschen!
                              Da sind alle Views und Projekte drin
                                Austauschen!
                                ChrisNettC Offline
                                ChrisNettC Offline
                                ChrisNett
                                Austauschen!
                                okay als nicht linux user was ist der einfachtse weg? FTP oder geht das auch per ssh?
                                  Austauschen!
                                  Als Nicht Linux User kann ich dir nicht sagen, wie es mit SSH geht.
                                  Dazu könnte @Thomas-Braun etwas sagen.
                                  Ich mache es mit filezilla, aber als user, der auch in der Gruppe iobroker ist, auf keinen Fall als root
                                    ChrisNettC Offline
                                    ChrisNettC Offline
                                    ChrisNett
                                    also nicht der "pi" std user?
                                      bei mir ist der user pi in der Gruppe iobroker drin
                                      Aber warte doch mal auf die Antwort von Thomas
                                        ChrisNettC Offline
                                        ChrisNettC Offline
                                        ChrisNett
                                        @thomasBraun
                                        könntest du mir helfen?
                                          @thomasBraun
                                          Wo liegt die Datei denn nun?
                                          cp /pfad/zur/quelle /pfad/zum/ziel
                                          Vorausgesetzt dein Standarduser ist in der Gruppe 'iobroker' drin.
                                          Sonst:
                                          sudo -u iobroker cp /pfad/zur/quelle /pfad/zum/ziel
