  4. [fixed] Zigbee - lost connection to devices
    6.3k
3 Beiträge 1 Kommentatoren 633 Aufrufe 2 Beobachtet
  • mcm1957M Online
    mcm1957M Online
    mcm1957
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4.
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Raspian
    Node-Version: 14.19.0
    NPM-Version: 6.14.16
    Installationsart: ?
    Image genutzt: Nein
    Zigbee Adapter 1.6.16
    Sonoff Zigbee 3 USB Dongle
    I've encountered the following problem.
    I use a Zigbee Installation at RasperryPi 4 with an Sonoff Zibee 3 USB Dongle. I (currently) connected two Ikea switches to it.
    Suddenly BOTH of the devices are not reachable / do not cause any action at the adapter. Even if near the Adapter (less than 0,5m).
    I already restarted the pi several times including a complete power down for one or two minutes. All otehr adapters work normally.
    The zigbee logs the follwing info during startup (with debug herdsman enabled)
    zigbee.0 2022-04-01 14:10:02.121	info	Zigbee started
    zigbee.0 2022-04-01 14:10:02.120	info	0x2c1165fffeccfb66 (addr 59363): E1812 - IKEA TRADFRI shortcut button (EndDevice)
    zigbee.0 2022-04-01 14:10:02.113	info	0x5c0272fffeafbacf (addr 38149): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    zigbee.0 2022-04-01 14:10:02.077	info	Currently 2 devices are joined:
    zigbee.0 2022-04-01 14:10:02.063	info	--> transmitPower : normal
    zigbee.0 2022-04-01 14:10:02.046	info	Unable to disable LED, unsupported function.
    zigbee.0 2022-04-01 14:10:02.036	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    zigbee.0 2022-04-01 14:09:58.585	info	Installed Version: iobroker.zigbee@1.6.16
    zigbee.0 2022-04-01 14:09:58.010	info	Starting Zigbee npm ...
    zigbee.0 2022-04-01 14:09:57.860	info	starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.0, js-controller: 4.0.21
    @arteck do you or anyone else have a hint how to diagnose further whats going wrong?
    Is there any easy way to verify that the USB Dongle is OK? (The read led is on near the antenna)
    Thanks
    McM
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    • mcm1957M mcm1957
      Festplattenart: SSD
      Installationsart: ?
      Image genutzt: Nein
      Thanks
      McM
      mcm1957M Online
      mcm1957M Online
      mcm1957
      Screenshot of devices for Info
      • mcm1957M mcm1957
        mcm1957M Online
        mcm1957M Online
        mcm1957
        The problem has been solved.
        The ZigBees use channel 11. And my Fritzbox with about 1m distance decided to use WLAN channel 1. Together with a quaterly Backup of some WLAN devices the zigbees were unable to communicate.
        Channel scan showed 187% usage for chanlle 11...
        Solved by fixing WLAN to channel 11
