  4. javascript.0 Fehlermeldung beim Starten der Instanz
    6.3k
16 Beiträge 4 Kommentatoren 1.6k Aufrufe 4 Beobachtet
    mguenther
    Systemdata Bitte Ausfüllen
    Hardwaresystem: PI4.
    Arbeitsspeicher: 8GB
    Festplattenart: SSD
    Betriebssystem: Debian
    Node-Version: 14.19.1
    Nodejs-Version: 14.19.1
    NPM-Version: 6.14.16
    Installationsart: Skript
    Image genutzt: Ja
    Hallo Zusammen,
    ich bekomme -wenn ich die Instanz javascript.0 stoppe und dann wieder starte- folgende LOG-Einträge:
    2022-03-21 02:04:10.373 - error: javascript.0 (4316) In file included from ../src/binding.cc:1:
    /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type]
    793 | (node::addon_register_func) (regfunc), \
    /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
    827 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
    ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’
    153 | NODE_MODULE(cpufeatures, init)
    und
    2022-03-21 02:04:15.210 - error: javascript.0 (4316) In file included from ../src/binding.cc:6:
    ../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’
    2003 | NODE_MODULE(sshcrypto, init)
    Log-File mit Meldungen davor und etwas danach:
    2022-03-21 02:03:37.992 - info: host.raspberrypi "system.adapter.javascript.0" enabled
    2022-03-21 02:03:38.468 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 4316
    2022-03-21 02:03:42.717 - info: javascript.0 (4316) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.1, js-controller: 4.0.21
    2022-03-21 02:03:42.773 - info: javascript.0 (4316) npm install dewpoint --production (System call)
    2022-03-21 02:04:03.275 - info: javascript.0 (4316)
    > cpu-features@0.0.2 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
    > node-gyp rebuild
    2022-03-21 02:04:04.590 - info: javascript.0 (4316) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build“ wird betreten
    2022-03-21 02:04:04.595 - info: javascript.0 (4316) ACTION Configuring dependencies /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/Makefile
    2022-03-21 02:04:04.851 - info: javascript.0 (4316) -- The C compiler identification is GNU 10.2.1
    2022-03-21 02:04:04.882 - info: javascript.0 (4316) -- Detecting C compiler ABI info
    2022-03-21 02:04:05.151 - info: javascript.0 (4316) -- Detecting C compiler ABI info - done
    2022-03-21 02:04:05.201 - info: javascript.0 (4316) -- Check for working C compiler: /usr/bin/cc - skipped
    2022-03-21 02:04:05.203 - info: javascript.0 (4316) -- Detecting C compile features
    2022-03-21 02:04:05.205 - info: javascript.0 (4316) -- Detecting C compile features - done
    2022-03-21 02:04:05.224 - info: javascript.0 (4316) -- Looking for dlfcn.h
    2022-03-21 02:04:05.537 - info: javascript.0 (4316) -- Looking for dlfcn.h - found
    2022-03-21 02:04:05.542 - info: javascript.0 (4316) -- Looking for getauxval
    2022-03-21 02:04:05.842 - info: javascript.0 (4316) -- Looking for getauxval - found
    2022-03-21 02:04:05.863 - info: javascript.0 (4316) -- Configuring done
    2022-03-21 02:04:05.887 - info: javascript.0 (4316) -- Generating done
    2022-03-21 02:04:05.892 - info: javascript.0 (4316) -- Build files have been written to: /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build
    2022-03-21 02:04:05.905 - info: javascript.0 (4316) TOUCH Release/obj.target/config_deps.stamp
    2022-03-21 02:04:05.917 - info: javascript.0 (4316) ACTION Building dependencies /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/libcpu_features.a
    2022-03-21 02:04:05.966 - info: javascript.0 (4316) gmake[1]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:06.037 - info: javascript.0 (4316) gmake[2]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:06.042 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:06.077 - info: javascript.0 (4316) Scanning dependencies of target utils
    2022-03-21 02:04:06.081 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:06.087 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:06.120 - info: javascript.0 (4316) [ 11%] Building C object CMakeFiles/utils.dir/src/filesystem.c.o
    2022-03-21 02:04:06.323 - info: javascript.0 (4316) [ 22%] Building C object CMakeFiles/utils.dir/src/stack_line_reader.c.o
    2022-03-21 02:04:06.561 - info: javascript.0 (4316) [ 33%] Building C object CMakeFiles/utils.dir/src/string_view.c.o
    2022-03-21 02:04:06.826 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:06.867 - info: javascript.0 (4316) [ 33%] Built target utils
    2022-03-21 02:04:06.882 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:06.919 - info: javascript.0 (4316) Scanning dependencies of target unix_based_hardware_detection
    2022-03-21 02:04:06.923 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:06.928 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:06.976 - info: javascript.0 (4316) [ 44%] Building C object CMakeFiles/unix_based_hardware_detection.dir/src/hwcaps.c.o
    2022-03-21 02:04:07.253 - info: javascript.0 (4316) [ 55%] Building C object CMakeFiles/unix_based_hardware_detection.dir/src/unix_features_aggregator.c.o
    2022-03-21 02:04:07.373 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:07.411 - info: javascript.0 (4316) [ 55%] Built target unix_based_hardware_detection
    2022-03-21 02:04:07.424 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:07.468 - info: javascript.0 (4316) Scanning dependencies of target cpu_features
    2022-03-21 02:04:07.474 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:07.480 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:07.530 - info: javascript.0 (4316) [ 66%] Building C object CMakeFiles/cpu_features.dir/src/cpuinfo_arm.c.o
    2022-03-21 02:04:08.014 - info: javascript.0 (4316) [ 77%] Linking C static library libcpu_features.a
    2022-03-21 02:04:08.103 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:08.137 - info: javascript.0 (4316) [ 77%] Built target cpu_features
    2022-03-21 02:04:08.145 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:08.180 - info: javascript.0 (4316) Scanning dependencies of target list_cpu_features
    2022-03-21 02:04:08.185 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:08.190 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
    2022-03-21 02:04:08.222 - info: javascript.0 (4316) [ 88%] Building C object CMakeFiles/list_cpu_features.dir/src/utils/list_cpu_features.c.o
    2022-03-21 02:04:08.547 - info: javascript.0 (4316) [100%] Linking C executable list_cpu_features
    2022-03-21 02:04:08.671 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:08.707 - info: javascript.0 (4316) [100%] Built target list_cpu_features
    2022-03-21 02:04:08.713 - info: javascript.0 (4316) gmake[2]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:08.765 - info: javascript.0 (4316) gmake[1]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
    2022-03-21 02:04:08.774 - info: javascript.0 (4316) TOUCH Release/obj.target/build_deps.stamp
    2022-03-21 02:04:08.787 - info: javascript.0 (4316) CXX(target) Release/obj.target/cpufeatures/src/binding.o
    2022-03-21 02:04:10.987 - info: javascript.0 (4316) SOLINK_MODULE(target) Release/obj.target/cpufeatures.node
    2022-03-21 02:04:11.261 - info: javascript.0 (4316) COPY Release/cpufeatures.node
    2022-03-21 02:04:11.276 - info: javascript.0 (4316) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build“ wird verlassen
    2022-03-21 02:04:11.307 - info: javascript.0 (4316)
    > ssh2@1.6.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
    > node install.js
    2022-03-21 02:04:12.657 - info: unifi.0 (6404) State value to set for "unifi.0.default.clients.e4:5f:01:15:7d:62.satisfaction" has to be type "number" but received type "string"
    2022-03-21 02:04:13.015 - info: javascript.0 (4316) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build“ wird betreten
    2022-03-21 02:04:13.018 - info: javascript.0 (4316) CXX(target) Release/obj.target/sshcrypto/src/binding.o
    2022-03-21 02:04:13.498 - info: unifi.0 (6404) State value to set for "unifi.0.default.clients.b8:27:eb:3d:9e:da.satisfaction" has to be type "number" but received type "string"
    2022-03-21 02:04:13.655 - info: unifi.0 (6404) State value to set for "unifi.0.default.clients.e4:5f:01:27:f2:57.satisfaction" has to be type "number" but received type "string"
    2022-03-21 02:04:19.059 - info: javascript.0 (4316) SOLINK_MODULE(target) Release/obj.target/sshcrypto.node
    2022-03-21 02:04:19.346 - info: javascript.0 (4316) COPY Release/sshcrypto.node
    2022-03-21 02:04:19.362 - info: javascript.0 (4316) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build“ wird verlassen
    2022-03-21 02:04:19.385 - info: javascript.0 (4316) Succeeded in building optional crypto binding
    2022-03-21 02:04:20.496 - info: javascript.0 (4316) + dewpoint@1.0.0
    added 109 packages from 199 contributors and audited 702 packages in 36.267s
    2022-03-21 02:04:21.645 - info: javascript.0 (4316)
    7 packages are looking for funding
    run `npm fund` for details
    2022-03-21 02:04:21.650 - info: javascript.0 (4316) found 2 high severity vulnerabilities
    run `npm audit fix` to fix them, or `npm audit` for details
    2022-03-21 02:04:21.767 - info: javascript.0 (4316) requesting all states
    2022-03-21 02:04:21.768 - info: javascript.0 (4316) requesting all objects
    2022-03-21 02:04:26.131 - info: javascript.0 (4316) received all objects
    2022-03-21 02:04:28.257 - info: javascript.0 (4316) received all states
    2022-03-21 02:04:28.487 - warn: host.raspberrypi-Server Cannot execute map: Cannot read property 'match' of undefined
    Danach werden die Skripte gestartet. Ich habe noch in der letzten Zeile ein Warning, was hin und wieder angezeigt wird.
    @liv-in-sky - das ist die Fehlermeldung, die ich dir zeigen wollte und wir es letztes Mal nicht mehr finden konnten. Auch jetzt war es wieder so, dass ein schedule nicht gestoppt werden konnte (daher die Instanz stoppen und wieder starten)
    2022-03-20 22:32:55.335 - error: javascript.0 (4990) Error by canceling scheduled job ""
    • M mguenther
      Festplattenart: SSD
      Image genutzt: Ja
      Hallo Zusammen,
      und
      > node-gyp rebuild
      > node install.js
      mguenther
      schrieb am zuletzt editiert von mguenther
      Im Logfile steht ja noch:
      pi@raspberrypi:~ $ npm audit fix
      npm ERR! code EAUDITNOPJSON
      npm ERR! audit No package.json found: Cannot audit a project without a package.json
      npm ERR!     /home/pi/.npm/_logs/2022-03-21T17_24_43_439Z-debug.log
      pi@raspberrypi:~ $
      Und nun? Lösung?
      crunchipC Thomas BraunT 2 Antworten Letzte Antwort
      • M mguenther
        pi@raspberrypi:~ $
        Und nun? Lösung?
        crunchipC Abwesend
        crunchipC Abwesend
        @mguenther das kannst du ignorieren, ist für die Entwickler
        • M mguenther
          pi@raspberrypi:~ $
          Und nun? Lösung?
          @mguenther
          Das müsste im richtigen Verzeichnis ausgeführt werden.
          Aber lass die Finger von npm audit fix oder gar npm audit fix -force.
          Das macht mehr kaputt als das es was bringt.
            @mguenther
            mguenther
            ok
            hast du ansonsten eine Idee, wieso die Fehlermeldung oben bei mir kommt?
            • Thomas BraunT Online
              @mguenther
              Welche?
                @mguenther
                Welche?
                mguenther
                die 2 error Meldungen beim Starten der javascript Instanz - beide von oben aus dem ersten Beitrag
                W 1 Antwort Letzte Antwort
                • M mguenther
                  W Offline
                  W Offline
                  wodkab
                  @mguenther
                  Ich habe bei mir die beiden gleichen Fehlermeldungen im Log, wenn ich javascript.0 restarte oder den Pi4 reboote:
                  2022-04-16 10:50:23.745 - info: javascript.0 (6665) AR(target) Release/obj.target/deps/cpu_features/cpu_features.a
                  2022-04-16 10:50:23.776 - info: javascript.0 (6665) COPY Release/cpu_features.a
                  2022-04-16 10:50:23.802 - info: javascript.0 (6665) CXX(target) Release/obj.target/cpufeatures/src/binding.o
                  2022-04-16 10:50:26.277 - error: javascript.0 (6665) In file included from ../src/binding.cc:1:
                  /opt/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type]
                  /opt/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                  ../src/binding.cc:152:1: note: in expansion of macro ‘NODE_MODULE’
                  152 | NODE_MODULE(cpufeatures, init)
                  2022-04-16 10:50:27.088 - info: javascript.0 (6665) SOLINK_MODULE(target) Release/obj.target/cpufeatures.node
                  2022-04-16 10:50:27.410 - info: javascript.0 (6665) COPY Release/cpufeatures.node
                  2022-04-16 10:50:27.428 - info: javascript.0 (6665) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build'
                  2022-04-16 10:50:27.461 - info: javascript.0 (6665)
                  > ssh2@1.9.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
                  > node install.js
                  2022-04-16 10:50:29.372 - info: javascript.0 (6665) make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
                  2022-04-16 10:50:29.374 - info: javascript.0 (6665) CXX(target) Release/obj.target/sshcrypto/src/binding.o
                  2022-04-16 10:50:31.325 - error: javascript.0 (6665) In file included from ../src/binding.cc:5:
                  ../src/binding.cc:2148:1: note: in expansion of macro ‘NODE_MODULE’
                  2148 | NODE_MODULE(sshcrypto, init)
                  2022-04-16 10:50:35.335 - info: javascript.0 (6665) SOLINK_MODULE(target) Release/obj.target/sshcrypto.node
                  2022-04-16 10:50:35.631 - info: javascript.0 (6665) COPY Release/sshcrypto.node
                  2022-04-16 10:50:35.649 - info: javascript.0 (6665) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
                  2022-04-16 10:50:35.675 - info: javascript.0 (6665) Succeeded in building optional crypto binding
                  Gibt es Neuigkeiten, wie ich das wieder fixen kann?
                  M Thomas BraunT 2 Antworten Letzte Antwort
                  • W wodkab
                    @mguenther
                    > node install.js
                    mguenther
                    @wodkab
                    habe keine Lösung (bekommen)
                    • M mguenther
                      @wodkab
                      W Offline
                      W Offline
                      wodkab
                      @mguenther Ich habe eigentlich nichts geändert ... aber bei mir kommt die Fehlermeldung jetzt nicht mehr 😕 aber soll mir rechts sein. So oft restarte/reboote ich ja auch nicht. Zur Info ... bei mir läuft iobroker in einem Docker-Container.
                      • W wodkab
                        @mguenther
                        > node install.js
                        @wodkab sagte in javascript.0 Fehlermeldung beim Starten der Instanz:
                        ssh2@1.9.0
                        Wo hängt denn das Modul?
                        cd /opt/iobroker
                        npm ls ssh2
                          ssh2@1.9.0
                          cd /opt/iobroker
                          npm ls ssh2
                          W Offline
                          W Offline
                          wodkab
                          • W wodkab
                            @wodkab
                            Okay, also als manuelles Modul im javaskript-Adapter.
                            Brauchst du das wirklich? Ich würde das sonst rauswerfen.
                            Wenn wirklich benötigt, dann muss das vielleicht nochmal reinstalliert oder neugebaut werden.
                              @wodkab
                              W Offline
                              W Offline
                              wodkab
                              @thomas-braun @thomas-braun Ok ... Danke, dann weiß ich schon mal woher der Fehler kommt. Brauchen tue ich es schon, ich führe damit ssh-Kommandos auf meinen LibreEelecs, NAS, RaspPis etc. aus.
                              • W wodkab
                                @wodkab
                                Ich hab jetzt erst genauer geschaut... Mea culpa!
                                Aber das sind gar keine 'Fehler', das sind ganz normale Meldungen, wenn Module neugebaut werden. Wird ja auch erfolgreich abgeschlossen:
                                  @wodkab
                                  W Offline
                                  W Offline
                                  wodkab
                                  @thomas-braun Cool ... Danke, das erklärt auch, warum die "Fehler", die eigentlich Build-Warnings aus dem Modul-Build sind nicht mehr kommen ... Modul wird ja (denke ich) nicht dauernd neu gebaut ;-)
