  2. English
  4. Update js-controller from @3.3.22 to @4.0.19 shows errors
    1.0k
3 Beiträge 3 Kommentatoren 2.6k Aufrufe 2 Beobachtet
  • O Offline
    O Offline
    Orghol
    Systemdata Bitte Ausfüllen
    Hardwaresystem: RPI4
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Linux 5.10.103-v7l+ #1530 SMP
    Node-Version: v14.19.0
    Nodejs-Version: v14.19.0
    NPM-Version: 6.14.16
    Installationsart: Manuell
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    Update message:
    code_textNPM version: 6.14.16
    npm install iobroker.js-controller@4.0.19 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../../nan/nan.h:58,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      793 |       (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
      827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
    Server Objects 127.0.0.1:34030 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
    Server States 127.0.0.1:44942 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
    Server Objects 127.0.0.1:34030 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
    Server States 127.0.0.1:44944 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
    Server Objects 127.0.0.1:34030 Error from InMemDB: Error: Unknown LUA script load
    Server Objects 127.0.0.1:34030 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    Further log messages:
    info.0	2022-03-10 14:01:39.281	info	cpu Temp res = {"main":63.296,"cores":[],"max":63.296,"socket":[],"chipset":null}
    info.0	2022-03-10 14:01:39.075	info	State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
    info.0	2022-03-10 14:01:39.067	info	State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
    info.0	2022-03-10 14:01:39.048	info	State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
    info.0	2022-03-10 14:01:38.983	info	State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
    info.0	2022-03-10 14:01:38.019	info	State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
    info.0	2022-03-10 14:01:36.298	info	Reading/updating systemdata.
    info.0	2022-03-10 14:01:36.227	info	starting. Version 1.9.8 in /opt/iobroker/node_modules/iobroker.info, node: v14.19.0, js-controller: 4.0.19
    info.0	2022-03-10 14:01:35.793	warn	This object will not be created in future versions. Please report this to the developer.
    info.0	2022-03-10 14:01:35.792	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadIrq is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0	2022-03-10 14:01:35.786	warn	This object will not be created in future versions. Please report this to the developer.
    info.0	2022-03-10 14:01:35.785	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadIdle is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0	2022-03-10 14:01:35.779	warn	This object will not be created in future versions. Please report this to the developer.
    info.0	2022-03-10 14:01:35.779	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadNice is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0	2022-03-10 14:01:35.772	warn	This object will not be created in future versions. Please report this to the developer.
    info.0	2022-03-10 14:01:35.771	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadSystem is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0	2022-03-10 14:01:35.765	warn	This object will not be created in future versions. Please report this to the developer.
    info.0	2022-03-10 14:01:35.764	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadUser is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0	2022-03-10 14:01:35.752	warn	This object will not be created in future versions. Please report this to the developer.
    info.0	2022-03-10 14:01:35.749	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoad is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    host.rpi4iobroker	2022-03-10 14:01:32.795	info	instance system.adapter.info.0 started with pid 2990
    discovery.0	2022-03-10 14:01:31.321	info	starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 4.0.19code_text
    iobroker starts and I can login.
    What to do?
    Carlo
    WinniW arteckA 2 Antworten Letzte Antwort
    • O Orghol
      Festplattenart: SSD
      Image genutzt: Nein
      Update message:
      What to do?
      Carlo
      WinniW Offline
      WinniW Offline
      Winni
      @orghol Look here: https://forum.iobroker.net/topic/52886/js-controller-4-0-x-jetzt-für-alle-user-im-stable
      Die Installation wird - wenn Sie von einem 2.x/3.x-System aus erfolgt - einige Warnungen/Fehler loggen. Wenn diese aussehen wie im folgenden Bild gezeigt (GET/SET-UNSUPPOTED bzw LUA script load error), ist dies erwartet und ok
      Es gibt nicht Gutes. Außer man tut es. Erich Kästner
      • O Orghol
        Festplattenart: SSD
        Image genutzt: Nein
        Update message:
        What to do?
        Carlo
        arteckA Offline
        arteckA Offline
        arteck
        @orghol sagte in Update js-controller from @3.3.22 to @4.0.19 shows errors:
        What to do?
        nothing.. all is fine..
