  4. [Fixed] Frisches ioBroker, Installation homekit2 schlägt fehl
3 Beiträge 2 Kommentatoren 1.5k Aufrufe
  • G Offline
    Gorg
    habe letzte Woche nach einem SD-Karten Problem den Raspi neu installiert und iobroker (tolles Projekt) ebenfalls ganz frisch installiert.
    Als letztes wollte ich das Homekit2 nachziehen, aber leider bekomme ich folgende Fehlermeldung.
    Wie gesagt, alles frisch installiert !?
    Eine Idee ?
    Gorg
    $ ./iobroker add homekit2
    npm install iobroker.homekit2 --production --prefix "/opt/iobroker" (System call)
    In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
     #include <dns_sd.h>
    compilation terminated.
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
    gyp
    ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack     at emitTwo (events.js:87:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:172:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
    gyp ERR! System Linux 4.4.38-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/mdns
    gyp ERR! node -v v4.8.0
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    npm
     ERR! Linux 4.4.38-v7+
    npm
     ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit2" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.0
    npm ERR! npm  v2.15.11
    npm ERR! code ELIFECYCLE
    npm ERR! mdns@2.3.3 install: `node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the mdns@2.3.3 install script 'node-gyp rebuild'.
    npm ERR! This is most likely a problem with the mdns package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs mdns
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR!     npm owner ls mdns
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:npm ERR!     /opt/npm-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.homekit2: 1
    ERROR: process exited with code 25</dns_sd.h>
    geändert: Code in Code-Tags; Homoran (Mod)
    • BluefoxB Offline
      BluefoxB Offline
      Da fehlt noch: libavahi-compat-libdnssd-dev
      So installieren:
      sudo apt-get install libavahi-compat-libdnssd-dev
      Ist hier zu finden:
      https://github.com/jensweigele/ioBroker … stallation
      • G Offline
        Gorg
        Super, das war es …..
        Vielen Dank !
        :D
        Gorg
