  5. (SOLVED) Create Alias in TypeScript
9 Beiträge 3 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • U Offline
    U Offline
    uwe72
    schrieb am zuletzt editiert von uwe72
    Hallo, kann mir jemand diese funktionierende JS-Function in TypeScript zu übersetzen? Ich kriege es nicht hin:
    const idAlias = "test12345";
    const idOrigin = "deconz.1.Lights.2.on";
    function createAlias(idSrc, idDst, typeAlias) {
       if(!getObject(idDst)) {
          var obj = {};
          obj.type = 'state';
          obj.common = getObject(idSrc).common;
          if(typeAlias) obj.common.type = typeAlias;
          obj.common.alias = {};
          obj.common.alias.id = idSrc;
          setObject(idDst, obj);
       } //else log ("Alias schon vorhanden: " + idDst, 'warn');
    createAlias(idOrigin, idAlias, 'boolean');
    DANKE !!!!
    javascript.0 (4416) script.js.common.#RGB#.CreateAliase: TypeScript compilation failed: obj.type = 'state'; ^ ERROR: Property 'type' does not exist on type '{}'. obj.common = getObject(idSrc).common; ^ ERROR: Property 'common' does not exist on type '{}'. obj.common.type = typeAlias; ^ ERROR: Property 'common' does not exist on type '{}'. obj.common.alias = {}; ^ ERROR: Property 'common' does not exist on type '{}'. obj.common.alias.id = idSrc; ^ ERROR: Property 'common' does not exist on type '{}'. setObject(idDst, obj); ^ ERROR: Argument of type '{}' is not assignable to parameter of type '(Omit<StateObject, "acl" | "_id"> & { _id?: string; acl?: StateACL; }) | (Omit<InstanceObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }) | ... 10 more ... | (Omit<...> & { ...; })'. Type '{}' is not assignable to type 'Omit<OtherObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }'. Type '{}' is missing the following properties from type 'Omit<OtherObject, "acl" | "_id">': common, type, native
    • C Offline
      CruziX
      schrieb am zuletzt editiert von CruziX
      @uwe72
      type TAlias = {
      type TCommon = {
       type?: string;
       alias?: TAlias;
      type TCustomObject ={
       type: string;
       common: TCommon;
      function createAlias(idSrc: string, idDst: string, typeAlias: string) {
            var obj: TCustomObject = {
       type: 'state',
       common: {
      type: '',
      alias: {
      Kurz mitm Handy getippt, vielleicht hilfts ja
      U 1 Antwort Letzte Antwort
      • C CruziX
        @uwe72
        type TAlias = {
        type TCommon = {
         type?: string;
         alias?: TAlias;
         type: string;
         common: TCommon;
         type: 'state',
         common: {
        type: '',
        alias: {
        U Offline
        U Offline
        uwe72
        @cruzix bin dir so dankbar, dass Du mein Problem angeschaut hast!!
        Leider gibts noch irgendwie ein "Cast-Problem":
          "_id": "alias.0.Light.Device_1.WORKING",
          "type": "state",
          "common": {
            "alias": {
              "id": "admin.0.connected"
            "name": "WORKING",
            "role": "indicator.working",
            "type": "boolean"
          "native": {}
        type TAlias = {
        type TCommon = {
            type: string;
            alias: TAlias;
            type: string;
            common: TCommon;
            if (!getObject(idDst)) {
                    type: '',
                    common: {
                        type: '',
                        alias: {
                obj.type = 'state';
        Den ersten Fehler gibts an dieser Stelle (Zeile 44):
        Type '{ [x: string]: any; [x: number]: any; }' is missing the following properties from type 'TCommon': type, alias(2739)
        (property) common: TCommon
        C 1 Antwort Letzte Antwort
        • U uwe72
            "type": "state",
            "common": {
              "alias": {
              "name": "WORKING",
              "type": "boolean"
            "native": {}
          type TAlias = {
          type TCommon = {
              type: string;
              alias: TAlias;
              type: string;
              common: TCommon;
                      type: '',
                      common: {
                          type: '',
                          alias: {
                  obj.type = 'state';
          CruziX
          @uwe72 ja, verstehe was das Problem ist, habe in meinem vorherigen Post den Common type mit optionalen Properties ergänzt und die zeile entfernt wo alias mit {} gesetzt wird. Sollte nun klappen
          • C CruziX
            U Offline
            U Offline
            uwe72
            @cruzix
            Danke dir!! Das TypeScript passt nun, irgendwie akzeptiert die setObject Methode noch nicht den Parameter:
            type TAlias = {
            type TCommon = {
             type?: string;
             alias?: TAlias;
             type: string;
             common: TCommon;
                     type: 'state',
                    common: {
                    type: '',
                    alias: {
            //createAlias("deconz.1.Lights.6.on", "alias.0.rgb.Z005.on", "boolean");
            Argument of type 'TCustomObject' is not assignable to parameter of type '(Omit<StateObject, "acl" | "_id"> & { _id?: string; acl?: StateACL; }) | (Omit<InstanceObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }) | ... 10 more ... | (Omit<...> & { ...; })'.
              Type 'TCustomObject' is not assignable to type 'Omit<OtherObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }'.
                Property 'native' is missing in type 'TCustomObject' but required in type 'Omit<OtherObject, "acl" | "_id">'.(2345)
            (local var) obj: TCustomObject
            • U uwe72
              @cruzix
              type TAlias = {
              type TCommon = {
               type?: string;
               alias?: TAlias;
               type: string;
               common: TCommon;
                       type: 'state',
                      common: {
                      type: '',
                      alias: {
              U Offline
              U Offline
              uwe72
              Gibts wirklich niemand von den ioBroker-Profis wo dieses Thema lösen können, eigentlich sollte es ja nur eine Kleinigkeit sein?
              Wäre wirklich sehr dankbar!
              LG
              • U Offline
                U Offline
                uwe72
                OK i think i have a working solution now:
                function createAlias(originalDatenpunkt, aliasDatenpunkt) {
                    setObject(aliasDatenpunkt, {
                        type: 'state',
                            common: {
                            type: getObject(originalDatenpunkt).common.type,
                            unit: getObject(originalDatenpunkt).common.unit,
                            read: true,
                            write: true,
                            role: getObject(originalDatenpunkt).common.role,
                            alias: {
                        native: {}
                var originalDatenpunkt = "deconz.1.Lights.2.on";
                var aliasDatenpunkt = "alias.0.test.mytest12_new2_NG";
                createAlias(originalDatenpunkt, aliasDatenpunkt);
                • U uwe72
                  LG
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @uwe72 sagte in (SOLVED) Create Alias in TypeScript:
                  Ja, stand auch in der von dir zitierten Fehlermeldung :)
                  Warum sudo böse ist: https://forum.iobroker.net/post/17109
                  • AlCalzoneA AlCalzone
                    U Offline
                    U Offline
                    uwe72
                    @alcalzone
                    Wie ist deine Meinung dann zu
                    https://forum.iobroker.net/topic/57264/typescript-kompilierfehler-setobject/5
                    Da gibts auch eine Fehlermeldung, für die "ich" eigentlich nicht verantwortlich sein kann?
