  4. [gelöst] Zigbee Adapter nach Update "defekt"
    6.0k
28 Beiträge 6 Kommentatoren 4.2k Aufrufe 7 Beobachtet
  • S SigiMOE
    gerade alle Adapter, Host auf den neuen Stand gebracht leider kein Erfolg
    immer noch gleiche Fehler
    Hier das LOG. Was kann ich noch prüfen ?
    2022-02-12 18:02:05.973 - info: zigbee.0 (12653) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-02-12 18:02:06.290 - info: zigbee.0 (12653) starting. Version 1.6.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.0, js-controller: 4.0.8
    2022-02-12 18:02:06.417 - info: zigbee.0 (12653) Starting Zigbee npm ...
    2022-02-12 18:02:06.936 - info: zigbee.0 (12653) Installed Version: iobroker.zigbee@1.6.14
    2022-02-12 18:02:07.409 - info: zigbee.0 (12653) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    2022-02-12 18:02:07.420 - info: zigbee.0 (12653) Unable to disable LED, unsupported function.
    2022-02-12 18:02:07.421 - info: zigbee.0 (12653) --> transmitPower : normal
    2022-02-12 18:02:07.430 - info: zigbee.0 (12653) Currently no devices.
    2022-02-12 18:02:07.431 - info: zigbee.0 (12653) Zigbee started
    2022-02-12 18:02:07.435 - error: zigbee.0 (12653) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
    2022-02-12 18:02:07.512 - info: host.raspi4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2022-02-12 18:02:07.517 - warn: zigbee.0 (12653) State "zigbee.0.info.undefinedDevices" has no existing object, this might lead to an error in future versions
    2022-02-12 18:02:07.526 - info: zigbee.0 (12653) Got terminate signal TERMINATE_YOURSELF
    2022-02-12 18:02:07.529 - info: zigbee.0 (12653) cleaned everything up...
    2022-02-12 18:02:07.532 - info: zigbee.0 (12653) Zigbee: disabling joining new devices.
    2022-02-12 18:02:07.592 - info: host.raspi4 stopInstance system.adapter.zigbee.0 send kill signal
    2022-02-12 18:02:08.030 - info: zigbee.0 (12653) terminating
    2022-02-12 18:02:08.033 - info: zigbee.0 (12653) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-02-12 18:02:08.667 - info: host.raspi4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-02-12 18:02:10.635 - info: host.raspi4 instance system.adapter.zigbee.0 started with pid 12829
    2022-02-12 18:02:14.620 - info: zigbee.0 (12829) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-02-12 18:02:14.890 - info: zigbee.0 (12829) starting. Version 1.6.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.0, js-controller: 4.0.8
    2022-02-12 18:02:14.999 - info: zigbee.0 (12829) Starting Zigbee npm ...
    2022-02-12 18:02:15.514 - info: zigbee.0 (12829) Installed Version: iobroker.zigbee@1.6.14
    2022-02-12 18:02:15.720 - error: zigbee.0 (12829) Configuration is not consistent with adapter state/backup!
    2022-02-12 18:02:15.721 - error: zigbee.0 (12829) - PAN ID: configured=6553, adapter=6553
    2022-02-12 18:02:15.722 - error: zigbee.0 (12829) - Extended PAN ID: configured=dd2dc1dddddb4da3, adapter=00124b0024cae2bc
    2022-02-12 18:02:15.723 - error: zigbee.0 (12829) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    2022-02-12 18:02:15.723 - error: zigbee.0 (12829) - Channel List: configured=11, adapter=11
    2022-02-12 18:02:15.724 - error: zigbee.0 (12829) Please update configuration to prevent further issues.
    2022-02-12 18:02:15.724 - error: zigbee.0 (12829) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    2022-02-12 18:02:15.725 - error: zigbee.0 (12829) Re-commissioning your network will require re-pairing of all devices!
    2022-02-12 18:02:15.726 - error: zigbee.0 (12829) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    2022-02-12 18:02:15.727 - error: zigbee.0 (12829) Failed to start Zigbee
    2022-02-12 18:02:15.728 - error: zigbee.0 (12829) Error herdsman start
    2022-02-12 18:02:18.105 - warn: octoprint.1 (5345) You should update your OctoPrint installation - supported version of this adapter is 1.7.2 (or later). Your current version is 1.7.0
    2022-02-12 18:02:22.791 - error: iot.0 (5453) [GHOME] device hm-rpc.1.NEQ0510324.2.STATE is unknown to google home
    2022-02-12 18:02:23.636 - info: plenticore.0 (4434) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
    2022-02-12 18:02:25.729 - info: zigbee.0 (12829) Try to reconnect. 1 attempts left
    2022-02-12 18:02:25.730 - info: zigbee.0 (12829) Starting Zigbee npm ...
    2022-02-12 18:02:25.753 - info: zigbee.0 (12829) Installed Version: iobroker.zigbee@1.6.14
    2022-02-12 18:02:25.978 - error: zigbee.0 (12829) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2022-02-12 18:02:25.979 - error: zigbee.0 (12829) Failed to start Zigbee
    2022-02-12 18:02:25.980 - error: zigbee.0 (12829) Error herdsman start
    2022-02-12 18:02:44.188 - info: plenticore.0 (4434) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
    2022-02-12 18:02:48.063 - warn: octoprint.1 (5345) You should update your OctoPrint installation - supported version of this adapter is 1.7.2 (or later). Your current version is 1.7.0
    2022-02-12 18:02:50.040 - info: host.raspi4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2022-02-12 18:02:50.051 - info: zigbee.0 (12829) Got terminate signal TERMINATE_YOURSELF
    2022-02-12 18:02:50.089 - info: host.raspi4 stopInstance system.adapter.zigbee.0 send kill signal
    2022-02-12 18:02:50.064 - info: zigbee.0 (12829) cleaned everything up...
    2022-02-12 18:02:50.082 - info: zigbee.0 (12829) Zigbee: disabling joining new devices.
    2022-02-12 18:02:50.100 - warn: zigbee.0 (12829) Failed to stop zigbee during startup
    2022-02-12 18:02:50.102 - info: zigbee.0 (12829) terminating
    2022-02-12 18:02:50.105 - info: zigbee.0 (12829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-02-12 18:02:50.757 - info: host.raspi4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-02-12 18:02:53.129 - info: host.raspi4 instance system.adapter.zigbee.0 started with pid 13616
    2022-02-12 18:02:58.159 - info: zigbee.0 (13616) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-02-12 18:02:58.645 - info: zigbee.0 (13616) starting. Version 1.6.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.0, js-controller: 4.0.8
    2022-02-12 18:02:58.799 - info: zigbee.0 (13616) Starting Zigbee npm ...
    2022-02-12 18:02:59.344 - info: zigbee.0 (13616) Installed Version: iobroker.zigbee@1.6.14
    2022-02-12 18:02:59.557 - error: zigbee.0 (13616) Configuration is not consistent with adapter state/backup!
    2022-02-12 18:02:59.558 - error: zigbee.0 (13616) - PAN ID: configured=6553, adapter=6553
    2022-02-12 18:02:59.559 - error: zigbee.0 (13616) - Extended PAN ID: configured=dd2dc1dddddb4da3, adapter=00124b0024cae2bc
    2022-02-12 18:02:59.559 - error: zigbee.0 (13616) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    2022-02-12 18:02:59.560 - error: zigbee.0 (13616) - Channel List: configured=11, adapter=11
    2022-02-12 18:02:59.561 - error: zigbee.0 (13616) Please update configuration to prevent further issues.
    2022-02-12 18:02:59.561 - error: zigbee.0 (13616) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    2022-02-12 18:02:59.561 - error: zigbee.0 (13616) Re-commissioning your network will require re-pairing of all devices!
    2022-02-12 18:02:59.563 - error: zigbee.0 (13616) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    2022-02-12 18:02:59.563 - error: zigbee.0 (13616) Failed to start Zigbee
    2022-02-12 18:02:59.564 - error: zigbee.0 (13616) Error herdsman start
    2022-02-12 18:03:04.758 - info: plenticore.0 (4434) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
    2022-02-12 18:03:09.566 - info: zigbee.0 (13616) Try to reconnect. 1 attempts left
    2022-02-12 18:03:09.567 - info: zigbee.0 (13616) Starting Zigbee npm ...
    2022-02-12 18:03:09.589 - info: zigbee.0 (13616) Installed Version: iobroker.zigbee@1.6.14
    2022-02-12 18:03:09.781 - error: zigbee.0 (13616) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2022-02-12 18:03:09.782 - error: zigbee.0 (13616) Failed to start Zigbee
    2022-02-12 18:03:09.783 - error: zigbee.0 (13616) Error herdsman start
    @sigimoe sagte in [gelöst] Zigbee Adapter nach Update "defekt":
    Riecht nach Issues mit der Firmware. Flash die vielleicht mal neu.
    Muss übereinstimmen.
    • S SigiMOE
      amg_666A Offline
      amg_666A Offline
      amg_666
      du hast die pan id geändert und er meckert jetzt rum dass die neue Konfiguration nicht mit seinem backup übereinstimmt und dass du ggf alle Geräte neu pairen musst. und wenn du das willst (bzw wohl machen musst), dann sollst du das backup des zigbee coordinators erst löschen, siehe Zeile 67 in deinem geposteten log.
      halte den Adapter an, gehe in der Konsole in das Verzeichnis und benenne die nvbackup.json um zum Beispiel nvbackup.json.alt (direkt löschen würd ich sie erstmal nicht) und dann neustart des Adapters
        SigiMOE
        @amg_666
        Kannst Du mir die Befehle reinkopieren wie ich das machen muss ?
          SigiMOE
          @thomas-braun sagte in [gelöst] Zigbee Adapter nach Update "defekt":
          Von dem Stick die Firmware neu Flashen ? Habe den Stick heute Original ausgepackt. Wie gehe ich da vor ?
          • S SigiMOE
            @sigimoe
            Bevor du die Firmware flashst, erstmal die Einstellungen übereinander bringen.
            Die aktuelle Firmware wäre jedenfalls 20211217
              @sigimoe
              SigiMOE
              schrieb am zuletzt editiert von SigiMOE
              @sigimoe
              Habe nun die PAN ID übereinstimmend in den Einstellungen geändert
              Jetzt scheint es zu laufen :
              Was bedeutet diese WARNUNG ? Bzw. Was muss ich tun ?
              	2022-02-13 08:04:43.529	warn	Extended PAN ID is reversed (expected=bce2ca24004b1200, actual=00124b0024cae2bc)
              • S SigiMOE
                @sigimoe
                @sigimoe
                Die ID nochmal eintragen, diesmal in umgekehrter Reihenfolge.
                  @sigimoe
                  SigiMOE
                  Perfekt , vielen lieben Dank für die Geduld
                  Jetzt sieht es super aus oder ?
                  hier mal der LOG nach Neustart des Adapters :
                  zigbee.0
                  2022-02-13 11:31:53.814	info	Zigbee started
                  zigbee.0
                  2022-02-13 11:31:53.813	info	Currently no devices.
                  zigbee.0
                  2022-02-13 11:31:53.804	info	--> transmitPower : normal
                  zigbee.0
                  2022-02-13 11:31:53.803	info	Unable to disable LED, unsupported function.
                  zigbee.0
                  2022-02-13 11:31:53.792	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                  zigbee.0
                  2022-02-13 11:31:53.312	info	Installed Version: iobroker.zigbee@1.6.14
                  zigbee.0
                  2022-02-13 11:31:52.788	info	Starting Zigbee npm ...
                  zigbee.0
                  2022-02-13 11:31:52.679	info	starting. Version 1.6.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.0, js-controller: 4.0.8
                  zigbee.0
                  2022-02-13 11:31:52.344	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  zigbee.0
                  2022-02-13 11:31:44.937	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  zigbee.0
                  2022-02-13 11:31:44.934	info	terminating
                  zigbee.0
                  2022-02-13 11:31:44.437	info	Zigbee: disabling joining new devices.
                  zigbee.0
                  2022-02-13 11:31:44.433	info	cleaned everything up...
                  zigbee.0
                  2022-02-13 11:31:44.430	info	Got terminate signal TERMINATE_YOURSELF
