  4. Update / Upgrade Fehler
13 Beiträge 6 Kommentatoren 3.3k Aufrufe
  • F Offline
    firstfreak
    Mein ioBroker läuft nun seit Wochen auf einem ESXi Server und das sehr gut, besser als vorher bei Windows
    Nun wollte ich mal ein paar Adapter updaten, aber das funktioniert gar nicht.
    Weder harmony, noch RPC, Rega, iCal nix.
    Weder im Interface noch in SSH, iobroker an oder aus, nicht mit –unsafe-perm
    nix
    Ich brauch dabei mal Hilfe. Vielen Dank
    $ ./iobroker upgrade ical
    npm install iobroker.ical --production --prefix "/opt/iobroker" (System call)
    npm
     WARN
    deprecated node-uuid@1.4.7: use uuid module instead
    npm
    WARN
    optional Skipping failed optional dependency /noble/xpc-connection:npm
     WARN notsup Not compatible with your operating system or architecture: xpc-connection@0.1.4
    npm
     WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/ical/package.json'
    npm
     WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
    npm
    ERR! Linux 4.4.0-64-genericnpm
     ERR! argv
     "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.ical" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.2.6
    npm ERR! npm  v3.5.2
    npm ERR! path /opt/iobroker/node_modules/ical/node_modules/.bin/uuidnpm
     ERR! code EEXIST
    npm
     ERR! Refusing to delete /opt/iobroker/node_modules/ical/node_modules/.bin/uuid: containing path /opt/iobroker/node_modules/ical/node_modules/node-uuid isn't under npm's controlnpm ERR! File exists: /opt/iobroker/node_modules/ical/node_modules/.bin/uuid
    npm
     ERR! Move it away, and try again.
    npm
     ERR! Please include the following file with any support request:
    npm ERR!     /opt/npm-debug.log
    ERROR: host.iobroker Cannot install iobroker.ical: 1
    und im Log:
    iobroker	2017-03-06 03:01:18.871	info	npm
    iobroker	2017-03-06 03:01:18.864	info
    iobroker	2017-03-06 03:01:18.703	info	ERR! Move it away, and try again.
    iobroker	2017-03-06 03:01:18.693	info	npm
    iobroker	2017-03-06 03:01:18.693	info	ERR! Refusing to delete /opt/iobroker/node_modules/ical/node_modules/.bin/uuid: containing path /opt/iobroker/node_modules/ical/node_modules/node-uuid isn't under npm's controlnpm ERR! File exists:
    iobroker	2017-03-06 03:01:18.687	info	npm
    iobroker	2017-03-06 03:01:18.687	info	ERR! code EEXIST
    iobroker	2017-03-06 03:01:18.679	info	npm ERR! path /opt/iobroker/node_modules/ical/node_modules/.bin/uuidnpm
    iobroker	2017-03-06 03:01:18.676	info	npm ERR! npm v3.5.2
    iobroker	2017-03-06 03:01:18.673	info	"/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.ical" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.2.6
    iobroker	2017-03-06 03:01:18.667	info	ERR! argv
    iobroker	2017-03-06 03:01:18.665	info	ERR! Linux 4.4.0-64-genericnpm
    iobroker	2017-03-06 03:01:18.663	info
    iobroker	2017-03-06 03:01:18.659	info	npm
    iobroker	2017-03-06 03:01:18.643	info	WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
    iobroker	2017-03-06 03:01:18.637	info	npm
    iobroker	2017-03-06 03:01:18.633	info	WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/ical/package.json'
    iobroker	2017-03-06 03:01:18.629	info	npm
    iobroker	2017-03-06 03:01:18.624	info	WARN notsup Not compatible with your operating system or architecture: xpc-connection@0.1.4
    iobroker	2017-03-06 03:01:18.614	info	optional Skipping failed optional dependency /noble/xpc-connection:npm
    iobroker	2017-03-06 03:01:18.609	info	WARN
    iobroker	2017-03-06 03:01:18.604	info
    iobroker	2017-03-06 03:01:18.598	info	npm
      Marcolotti
      Guten Morgen,
      als was bist du angemeldet? Hast du es mal mit sudo versucht?
      Gruß Marco
      CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
      • eric2905E Offline
        eric2905E Offline
        eric2905
        Moin,
        noch eine Frage:
        Welches OS hast Du denn für die VM in Einsatz?
        Windows oder Linux (welches)?
        Gruß,
        Eric
        Von unterwegs getippert
        • F Offline
          firstfreak
          Angemeldet bin ich als root.
          Ubuntu 16.04.2 LTS
          Ich habe alles per Hand installiert, neu installiert inkl iobroker. da ging auch noch alles
          • ThisoftT Offline
            ThisoftT Offline
            Thisoft
            > Nun wollte ich mal ein paar Adapter updaten, aber das funktioniert gar nicht. :!: :?: :mrgreen:
            Nix für ungut - will hier auch kein Spam produzieren - konnten mir das nur gerade nich ganz verkneifen "duck und weg"
            • ThisoftT Offline
              ThisoftT Offline
              Thisoft
              So und jetzt der Versuch einer wirklichen Hilfe ;) :
              Ich würde dunkel vermuten dass mit deine npm-Installation was nicht stimmt. Google hat mir z.B. das ausgespuckt
              ` > npm uninstall –save node-uuid
              npm install --save uuid
              The old node-uuid module is deprecated and won't be maintained moving forward. The module is still published in NPM for backward compatibility (with the deprecation notice). If you need the source, clone this repo then git checkout v1.4.7. `
              Wäre vielleicht einen Versuch wert…
              • apollon77A Offline
                Würde ich nicht machen. Diese Warning kommt gerade überall.
                Er sagt doch
                mach das doch mal!
                Bzw wenn DU den Adapter eh neu installierst scheiss das ganze /opt/iobroker/node_modules/ical/ weg.
                Welche node-Version nimmst Du ?
                • F Offline
                  firstfreak
                  @Thisoft:
                  Wäre vielleicht einen Versuch wert… `
                  ERGEBNIS :
                  root@iobroker:~# npm uninstall --save node-uuid
                  npm ERR! Linux 4.4.0-65-generic
                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "uninstall" "--save" "node-uuid"
                  npm ERR! npm  v3.5.2
                  npm ERR! code EMISSINGARG
                  npm ERR! typeerror Error: Missing required argument #3
                  npm ERR! typeerror     at replaceModule (/usr/share/npm/lib/install/deps.js:438:                       3)
                  npm ERR! typeerror     at /usr/share/npm/lib/install/deps.js:234:7
                  npm ERR! typeerror     at Array.forEach (native)
                  npm ERR! typeerror     at exports.removeDeps (/usr/share/npm/lib/install/deps.js                       :230:8)
                  npm ERR! typeerror     at Array. <anonymous>(/usr/share/npm/node_modules/slide/l                       ib/bind-actor.js:15:8)
                  npm ERR! typeerror     at LOOP (/usr/share/npm/node_modules/slide/lib/chain.js:1                       5:14)
                  npm ERR! typeerror     at chain (/usr/share/npm/node_modules/slide/lib/chain.js:                       20:5)
                  npm ERR! typeerror     at Uninstaller.loadAllDepsIntoIdealTree (/usr/share/npm/l                       ib/uninstall.js:72:3)
                  npm ERR! typeerror This is an error with npm itself. Please report this error at                       :
                  npm ERR! typeerror     <http: github.com/npm/issues="">npm ERR! Please include the following file with any support request:
                  npm ERR!     /root/npm-debug.log</http:></anonymous></anonymous>
                  NODE:
                  root@iobroker:~# node -v
                  v4.2.6
                  • ThisoftT Offline
                    ThisoftT Offline
                    Thisoft
                    War ja auch nur von Dr.Google "abgeschrieben"… Bin kein Linux-Kenner...
                    Appollon hatte ja auch schon davon abgeraten.
                    Hast Du auch schon mal versucht das ganze angemeckerte Verzeichnis wegzuschmeißen wie Appollon geraten hatte?
                    • Y Offline
                      Y Offline
                      ykuendig
                      Oder für die nicht Linuxianer (wie mich)
                      sudo rm /opt/iobroker/node_modules/ical/node_modules/.bin/uuid
                      ````oder so
                      Gruss Yves
                      • F Offline
                        firstfreak
                        @ykuendig:
                        ````oder so `
                        Hab ich gemacht, bringt aber nichts.
                        auch die anderen Adapter lassen sich nicht updaten.
                        Ich überlege am Wochenende nochmal alles neu auf zusetzten, ev mit debian, vielleicht ist das besser.
                        Gibt da eine gute Anleitung hier ?
                        • Y Offline
                          Y Offline
                          ykuendig
                          Ich habs ca. nach der hier - in einer xen-server vm gemacht.
                          http://www.iobroker.net/docu/?page_id=5358&lang=de
                          Aber vom Prinzip her ist das Wurst ob virtuell oder physisch.
                          Gruss Yves
                          • F Offline
                            firstfreak
                            @ykuendig:
                            Aber vom Prinzip her ist das Wurst ob virtuell oder physisch. `
                            Vielen Dank, super Anleitung
