  4. Installation unter Debian 11 Bullseye
    6.3k
21 Beiträge 7 Kommentatoren 5.0k Aufrufe 6 Beobachtet
  • H Offline
    heiner1976
    schrieb am zuletzt editiert von heiner1976
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Virtual Box
    Arbeitsspeicher: 2GB
    Festplattenart: SSD
    Betriebssystem: Debian 11 Bullseye
    Node-Version: x.x.x
    Nodejs-Version: x.x.x
    NPM-Version: x.x.x
    Installationsart: Skript
    Image genutzt: ;Nein
    Ich bin gerade dabei meine Installation auf Debian 11 (Bullseye) neu aufzusetzen / umzuziehen.
    Während der Installation von iOBroker kamen folgende Warnungen.
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:58,
                     from ../src/main.cpp:3:
    /root/.cache/node-gyp/14.18.3/include/node/node.h:787:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      787 |       (node::addon_register_func) (regfunc),                          \
    /root/.cache/node-gyp/14.18.3/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
      821 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       42 | NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    Muss ich mir hier Sorgen machen, die Installation lief dennoch durch
        Finalizing installation (4/4)
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.178.65:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    J NT_OlliN 2 Antworten Letzte Antwort
    • H heiner1976
      Festplattenart: SSD
      Node-Version: x.x.x
      NPM-Version: x.x.x
      Autostart enabled!
      Jan1
      @heiner1976
      Sorgen nicht wirklich, aber warum schreibst Du oben Node12, bevor Du überhaupt IOBroker drauf hast?
      Debian beinhaltet standard kein Node und das wird passend bei der IOBroker Installation mit installiert ;)
      • H Offline
        heiner1976
        @jan1
        Danke für die Antwort! Ich hatte die Node Version aus der alten Installation im Kopp. :-( Sorry Du hast recht :-)
        • wendy2702W Offline
          wendy2702W Offline
          wendy2702
          Ist ja noch nicht so alt hier.
          Versuche gerade unter Proxmox 6.4-13 in einem CT mit Bullseye iobroker zu installieren.
          Jetzt schaue ich schon seit ca. 30 minuten auf diese Anzeige:
          mirko@iobroker:~$ curl -sLf https://iobroker.net/install.sh | bash -
          library: loaded
          Library version=2021-12-27
              Welcome to the ioBroker installer!
              Installer version: 2021-12-27
              You might need to enter your password a couple of times.
              Installing prerequisites (1/4)
          Hit:1 http://ftp.debian.org/debian bullseye InRelease
          Hit:2 http://security.debian.org bullseye-security InRelease
          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
          Reading package lists... Done
              Node.js not found. Installing...
          ## Installing the NodeSource Node.js 14.x repo...
          ## Populating apt-get cache...
          + apt-get update
          ## Installing packages required for setup: lsb-release gnupg...
          + apt-get install -y lsb-release gnupg > /dev/null 2>&1
          ## Confirming "bullseye" is supported...
          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/bullseye/Release'
          ## Adding the NodeSource signing key to your keyring...
          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
          ## Creating apt sources list file for the NodeSource Node.js 14.x repo...
          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
          ## Running `apt-get update` for you...
          + apt-get update
          Get:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4586 B]
          Get:5 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B]
          Fetched 5359 B in 1s (5365 B/s)
          ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
          ## You may also need development tools to build native addons:
               sudo apt-get install gcc g++ make
          ## To install the Yarn package manager, run:
               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
               sudo apt-get update && sudo apt-get install yarn
          Installed nodejs
          Node.js Installed successfully!
          Changing npm registry to https://registry.npmjs.org
          Installed acl
          Installed build-essential
          Installed gcc-c++
          Installed libavahi-compat-libdnssd-dev
          Installed libudev-dev
          Installed libpam0g-dev
          Installed git
          Installed unzip
          Installed libcairo2-dev
          Installed libpango1.0-dev
          Installed libjpeg-dev
          Installed libgif-dev
          Installed librsvg2-dev
          Installed net-tools
          Installed python-dev
          Installed cmake
              Creating ioBroker user and directory (2/4)
          User iobroker created
          Created /etc/sudoers.d/iobroker
          Directory /opt/iobroker created
          [#.................] - fetchMetadata: sill pacote range manifest for is-fullwidth-code-point@^1.0.0 fetched in 41ms
          Und nichts passiert.
          • wendy2702W wendy2702
            library: loaded
            + apt-get update
            + apt-get update
            Installed nodejs
            Installed acl
            Installed gcc-c++
            Installed git
            Installed unzip
            Installed net-tools
            Installed cmake
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            @wendy2702 sagte in Installation unter Debian 11 Bullseye:
            fetchMetadata
            Kommt von npm was gerade etwas installieren will und dafür Informationen aus dem Netz lädt. Könnte sein, dass dein Internet gerade etwas hängt.
            • AlCalzoneA AlCalzone
              fetchMetadata
              wendy2702W Offline
              wendy2702W Offline
              wendy2702
              @alcalzone Hm...
              mir ist bei keiner anderen Anwendung ein hänger aufgefallen.
              2 VPN Verbindungen ohne Unterbrechung
              Teams Meeting ohne Unterbrechung
              Live Stream ohne Unterbrechung
              Aber egal, habe es neu gestartet und der zweite Versuch lief durch
                @alcalzone Hm...
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @wendy2702 Vielleicht lags auch an der Gegenstelle... Passiert bei mir manchmal auch abseits von ioBroker.
                • H heiner1976
                  Festplattenart: SSD
                  Node-Version: x.x.x
                  NPM-Version: x.x.x
                  Autostart enabled!
                  NT_OlliN Offline
                  NT_OlliN Offline
                  NT_Olli
                  Hallo @heiner1976 ich habe gerade ähnliches vor wie von Dir oben beschrieben.
                  Ich habe heute eine aktuelle Debian 11 Installation auf einem amd64 System aufgesetzt. Vor dem Versuch ein ioBroker zu installieren habe ich nur den openmediavault und den Logitech MEdia Server 8.2.0 installiert.
                  Halte ich mich an die Anleitung auf https://www.iobroker.net/#de/documentation/install/linux.md bekomme ich neben den von Dir geposteten Warnings auch noch folgende Zeilen:
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 22
                  npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
                  npm ERR! Exit status 22
                  npm ERR!
                  npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  Eine Recherche im web hat ergeben, dass es wohl beim Update des js-controllers dieses Problem geben kann. Leider haben die Hinweise zur Bewältigung kein Erfolg gebracht und der ioBroker startet nicht.
                  root@homeserver:/opt/iobroker# node -v
                  v14.19.0
                  root@homeserver:/opt/iobroker# nodejs -v
                  v14.19.0
                  root@homeserver:/opt/iobroker# npm -v
                  6.14.16
                  Weiß jemand Rat?
                  Vorab vielen Dank und viele Grüße,
                  Olli
                  • NT_OlliN NT_Olli
                    npm ERR! errno 22
                    npm ERR!
                    v14.19.0
                    v14.19.0
                    6.14.16
                    Weiß jemand Rat?
                    Olli
                    @dh2wq sagte in Installation unter Debian 11 Bullseye:
                    Weiß jemand Rat?
                    Ja.
                    Nicht als root rumhampeln wäre der erste Rat.
                    Der zweite: Mehr Output aus der Konsole posten.
                    Der dritte: npm cache löschen
                    • NT_OlliN Offline
                      NT_OlliN Offline
                      NT_Olli
                      Danke für den schnellen Rat,
                      leider hat das rumhampeln per sudo in den scripten das gleiche Ergebnis. Der Vollständigkeit habe ich auch wie geraten die komplette Ausgabe bis auf das abklappern der Quellen gepostet. Der NPM cache wurde vorher auch noch mal geleert.
                      olli@openmediavault:~$ curl -sL https://iobroker.net/install.sh | bash -
                      library: loaded
                      Installed gcc-c++
                      /home/olli/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast betw        een incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node:        :addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>        , void*)’} [-Wcast-function-type]
                        793 |       (node::addon_register_func) (regfunc),                          \
                      /home/olli/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion        of macro ‘NODE_MODULE_X’
                        827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_        usage)
                      npm ERR! errno 22
                      npm ERR!
                      npm ERR!     /home/olli/.npm/_logs/2022-02-04T21_40_48_160Z-debug.log
                      Autostart enabled!
                          Open http://192.168.2.10:8081 in a browser and start configuring!
                      Thomas BraunT AlCalzoneA 2 Antworten Letzte Antwort
                      • NT_OlliN NT_Olli
                        library: loaded
                        Installed gcc-c++
                        npm ERR! errno 22
                        npm ERR!
                        Autostart enabled!
                        @nt_olli
                        Jetzt ist der Hostname anders.
                        NT_OlliN 1 Antwort Letzte Antwort
                          @nt_olli
                          NT_OlliN Offline
                          NT_OlliN Offline
                          NT_Olli
                          Richtig, gleiche Machine, nur eine Änderung aus der GUI des openmediavaults raus und der gewünschte user.
                          • NT_OlliN NT_Olli
                            @nt_olli
                            So ganz verstehe nicht wie das Ding da bei dir aufgesetzt ist.
                            • NT_OlliN NT_Olli
                              library: loaded
                              Installed gcc-c++
                              npm ERR! errno 22
                              npm ERR!
                              Autostart enabled!
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              @nt_olli sagte in Installation unter Debian 11 Bullseye:
                              Steht da ggf. mehr drin?
                                NT_OlliN Offline
                                NT_OlliN Offline
                                NT_Olli
                                Guten Morgen @alcalzone,
                                ja da steht mehr drin. Ich denke der letzte Teil könnte Aufschluss geben:
                                5889 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                5890 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                5891 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
                                5891 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
                                5891 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
                                5891 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: x64
                                5892 verbose stack Error: iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
                                5892 verbose stack Exit status 22
                                5892 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                5892 verbose stack     at EventEmitter.emit (events.js:400:28)
                                5892 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                5892 verbose stack     at ChildProcess.emit (events.js:400:28)
                                5892 verbose stack     at maybeClose (internal/child_process.js:1058:16)
                                5892 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                                5893 verbose pkgid iobroker.js-controller@3.3.22
                                5894 verbose cwd /opt/iobroker
                                5895 verbose Linux 5.10.0-11-amd64
                                5896 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "--production" "--loglevel" "error" "--unsafe-perm"
                                5897 verbose node v14.19.0
                                5898 verbose npm  v6.14.16
                                5899 error code ELIFECYCLE
                                5900 error errno 22
                                5901 error iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
                                5901 error Exit status 22
                                5902 error Failed at the iobroker.js-controller@3.3.22 install script.
                                5902 error This is probably not a problem with npm. There is likely additional logging output above.
                                5903 verbose exit [ 22, true ]
                                Da ich nicht weiß ob in den Ausgaben weiter ober mehr Inhalt steckt die ganze Datei:
                                Schonmal Dank für alle Mhen mir zu helfen. Um die Verwirrung des umsystems zu lösen, kann ich es ggf. nochmal ohne die openmediavault aufsetzen.
                                • NT_OlliN NT_Olli
                                  5900 error errno 22
                                  NT_OlliN Offline
                                  NT_OlliN Offline
                                  NT_Olli
                                  Guten Morgen,
                                  da ich ja noch eine laufende Lösung auf meinem PI 2 habe is es nicht kritisch und ich habe es mit einem neuen sauberen Ubuntu Server 20.04.3 LTS installiert und auch den openmediavault erstmal unten gelassen. Leider kommt es zur genau gleichen Fehlermeldung.
                                  Ich werde es jetzt nochmal in einer VM probieren.
                                  • NT_OlliN NT_Olli
                                    Guten Morgen,
                                    NT_OlliN Offline
                                    NT_OlliN Offline
                                    NT_Olli
                                    da auf den physischen Maschinen als erstes der logitechmediaserver (lms) installiert wurde, habe ich diese Möglichkeit leider übersehen. Tausche ich die Installationsreihenfolge, macht dann der lms beim Starten Probleme.
                                    Die Fehlermeldung ist hier aber für mich verständlicher. Hier finde ich die Information, dass der Port 9000 schon belegt ist.
                                    Daraufhin habe ich im lms den Port auf 9002 geändert und schon geht es.
                                    Ein Test auf der physischen Maschine hat gezeigt, dass sich nun der js-controller installieren lässt.
                                    Wenn möglich, wäre eine Fehlerausgabe in diese Richtung hilfreich.
                                    Viele Grüße,
                                    Olli
                                    • NT_OlliN NT_Olli
                                      Viele Grüße,
                                      Olli
                                      Welche Richtung?
                                      Ich bin mir sicher, dass beim Start (nach der Inst) im log der Hinweis auf den belegten Port steht
                                      so in der Art:
                                      2022-02-06 08:17:27.035  - error: backitup.0 (1445) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                      2022-02-06 08:17:27.235  - error: backitup.0 (1445) States database error: connect ECONNREFUSED 127.0.0.1:9000
                                        Welche Richtung?
                                        so in der Art:
                                        NT_OlliN Offline
                                        NT_OlliN Offline
                                        NT_Olli
                                        schrieb am zuletzt editiert von NT_Olli
                                        ich konnte das setup script zur Installation ja nicht erfolgreich durchführen, da der Port schon belegt war. Da ich mit ps auch kein laufenden iobroker gesehen habe, bin ich davon ausgegangen das ich hier gar nicht in die logs schauen muss.
                                        Meine Debugfähigkeiten haben bei error Failed at the iobroker.js-controller@3.3.22 install script. aufgehört.
                                        Hätte ich hier einen Hinweis in die Richtung belegter Port gefunden, wäre ich vermutlich weiter gekommen. Im Ende ist ja auch alles gelöst. Ich kenne mich auch nur bedingt mit den Details aus und bin über die Unterstützung der Community sehr dankbar.
                                        Viele Grüße
                                        • NT_OlliN NT_Olli
                                          Viele Grüße
                                          @nt_olli Ich verstehe!
                                          Das Installationsskript könnte man mit Sicherheit aufbohren. Aber bis wohin??
                                          Jetzt die Ports, später was noch alles?
                                          Die Installationsroutinen gehen davon aus, dass noch nichts anderes auf dem Server läuft.
                                          Ähnliche Diskussionen gab es auch bereits für andere, ich will mal sagen Custom-Betriebssysteme, wo wür deren Installation einiges anders war, als es bei dem selben nativen OS gewesen wäre.
                                          Im Prinzip gehen wir davon aus, dass wenn jemand es nicht auf einem eigenen System installiert, weiß was er hat und tut.
                                          Du könntest ein Feature Request in Form eines Issues erstellen, damit die Idee nicht verloren geht
