  4. Node-Red
  5. JSON an tr-069 command übergeben
    6.5k
15 Beiträge 3 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • K Offline
    kla960
    ich würde gerne den 5GHz WLAN Channel der FritzBox abfragen und ändern falls dieser nicht den gewünschten Wert hat. Im Moment scheitert es daran, Werte an die FritzBox über den tr-069 Adapter per JSON Command aus Red-Node zu senden. Red-Node übergibt zwar den command, dieser wird aber scheinbar nicht an die FritzBox übermittelt.
    Wenn ich dann manuell in das command Feld gehe und Wert setzen ausführe, bekomme über commandResult das Ergebnis.
    Habe ich da was vergessen?
    So setze ich den Wert:
            "id": "3054ca10.a7b9e6",
            "type": "tab",
            "label": "Flow 1",
            "disabled": false,
            "info": ""
            "id": "955c676a.93fea8",
            "type": "ioBroker out",
            "z": "3054ca10.a7b9e6",
            "name": "Request channel info",
            "topic": "tr-064.1.states.command",
            "ack": "true",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 700,
            "y": 360,
            "wires": []
            "id": "c04328ca.d76ae8",
            "type": "inject",
            "name": "GetChannelInfo",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "{\"service\":\"urn:dslforum-org:service:WLANConfiguration:2\",\"action\":\"GetChannelInfo\",\"params\":{}}",
            "payloadType": "json",
            "x": 280,
            "y": 340,
            "wires": [
                    "bac9031c.48509"
            "id": "bac9031c.48509",
            "type": "json",
            "name": "",
            "property": "payload",
            "action": "str",
            "pretty": true,
            "x": 490,
            "y": 260,
            "wires": [
                    "955c676a.93fea8"
            "id": "85163997.242b48",
            "type": "inject",
            "name": "SetChannel",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "{\"service\":\"urn:dslforum-org:service:WLANConfiguration:2\",\"action\":\"SetChannel\",\"params\":{\"NewChannel\":\"48\"}}",
            "x": 370,
            "y": 420,
            "wires": [
                    "bac9031c.48509"
    F mickymM 2 Antworten Letzte Antwort
    • K kla960
              "type": "tab",
              "label": "Flow 1",
              "disabled": false,
              "info": ""
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 700,
              "y": 360,
              "wires": []
              "type": "inject",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "x": 280,
              "y": 340,
              "wires": [
                      "bac9031c.48509"
              "type": "json",
              "name": "",
              "action": "str",
              "pretty": true,
              "x": 490,
              "y": 260,
              "wires": [
                      "955c676a.93fea8"
              "type": "inject",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "x": 370,
              "y": 420,
              "wires": [
                      "bac9031c.48509"
      frankyboy73
      @kla960 Hi, dein Code lässt sich leider nicht impotieren.
      Schöne Grüße Frank
      • F frankyboy73
        mickymM Offline
        mickymM Offline
        mickym
        @frankyboy73 Fehlt die eckige Klammer am Anfang.
                "ack": "true",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 740,
                "y": 320,
                "wires": []
                "type": "inject",
                "props": [
                        "p": "payload"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "x": 300,
                "y": 200,
                "wires": [
                        "bac9031c.48509"
                "type": "json",
                "name": "",
                "action": "str",
                "pretty": true,
                "x": 490,
                "y": 260,
                "wires": [
                        "955c676a.93fea8"
                "type": "inject",
                "props": [
                        "p": "payload"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "x": 310,
                "y": 300,
                "wires": [
                        "bac9031c.48509"
        • K kla960
                  "type": "tab",
                  "label": "Flow 1",
                  "disabled": false,
                  "info": ""
                  "ack": "true",
                  "stateName": "",
                  "role": "",
                  "payloadType": "",
                  "readonly": "",
                  "stateUnit": "",
                  "stateMin": "",
                  "stateMax": "",
                  "x": 700,
                  "y": 360,
                  "wires": []
                  "type": "inject",
                  "props": [
                          "p": "payload"
                  "repeat": "",
                  "crontab": "",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "",
                  "x": 280,
                  "y": 340,
                  "wires": [
                          "bac9031c.48509"
                  "type": "json",
                  "name": "",
                  "action": "str",
                  "pretty": true,
                  "x": 490,
                  "y": 260,
                  "wires": [
                          "955c676a.93fea8"
                  "type": "inject",
                  "props": [
                          "p": "payload"
                  "repeat": "",
                  "crontab": "",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "",
                  "x": 370,
                  "y": 420,
                  "wires": [
                          "bac9031c.48509"
          mickymM Offline
          mickymM Offline
          mickym
          gelöscht.
          • mickymM mickym
            gelöscht.
            mickymM Offline
            mickymM Offline
            mickym
            Im Prinzip müsste es eigentlich funktionieren, wenn Du statt value - ein command in Deiner iobroker out Node verwendest-
            Inhaltlich habe ich mir das Kommando nicht angeschaut.
            K 1 Antwort Letzte Antwort
            • mickymM mickym
              kla960
              @mickym sagte in JSON an tr-069 command übergeben:
              Habe es wohl hinbekommen. Und ja command wird jetzt verwendet. Der Switch ist noch nicht so schön. Ggf. habt Ihr ja eine bessere Idee😀
              Jetzt wird immer um 5:00 einmal der Kanal geprüft und wenn nicht 48 wieder auf 48 gesetzt.
              Und noch der Code (Hoffentlich ohne Fehler kopiert):
                      "type": "tab",
                      "label": "WLAN 5GHz",
                      "disabled": false,
                      "info": ""
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 960,
                      "y": 360,
                      "wires": []
                      "type": "inject",
                      "props": [
                              "p": "payload"
                      "repeat": "",
                      "crontab": "00 05 * * *",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "x": 290,
                      "y": 340,
                      "wires": [
                              "bac9031c.48509"
                      "type": "json",
                      "name": "",
                      "action": "str",
                      "pretty": true,
                      "x": 490,
                      "y": 360,
                      "wires": [
                              "955c676a.93fea8"
                      "type": "inject",
                      "props": [
                              "p": "payload"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "x": 270,
                      "y": 440,
                      "wires": [
                              "bac9031c.48509"
                      "id": "7e96da1.62c4424",
                      "type": "ioBroker in",
                      "name": "commandResult",
                      "topic": "tr-064.1.states.commandResult",
                      "payloadType": "value",
                      "onlyack": "",
                      "func": "rbe",
                      "gap": "",
                      "fireOnStart": "false",
                      "x": 260,
                      "y": 140,
                      "wires": [
                              "14ef63f9.2cb11c"
                      "id": "14ef63f9.2cb11c",
                      "type": "switch",
                      "name": "",
                      "propertyType": "msg",
                      "rules": [
                              "t": "cont",
                              "v": "\"48\"",
                              "vt": "str"
                              "t": "eq",
                              "v": "{}",
                              "vt": "str"
                              "t": "else"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 3,
                      "x": 450,
                      "y": 140,
                      "wires": [
                              "c6c6dbfb.8e31c8"
                      "id": "c6c6dbfb.8e31c8",
                      "type": "function",
                      "name": "Create JSON",
                      "func": "var data={\"service\": \"urn:dslforum-org:service:WLANConfiguration:2\",\n\"action\": \"SetChannel\",\n\"params\": {\"NewChannel\": \"48\"}};\nnode.log(typeof data);\nmsg.payload=JSON.stringify(data);\nreturn msg;",
                      "outputs": 1,
                      "noerr": 0,
                      "initialize": "",
                      "finalize": "",
                      "libs": [],
                      "x": 670,
                      "y": 260,
                      "wires": [
                              "955c676a.93fea8"
              • K kla960
                        "type": "tab",
                        "disabled": false,
                        "info": ""
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 960,
                        "y": 360,
                        "wires": []
                        "type": "inject",
                        "props": [
                                "p": "payload"
                        "repeat": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "x": 290,
                        "y": 340,
                        "wires": [
                                "bac9031c.48509"
                        "type": "json",
                        "name": "",
                        "action": "str",
                        "pretty": true,
                        "x": 490,
                        "y": 360,
                        "wires": [
                                "955c676a.93fea8"
                        "type": "inject",
                        "props": [
                                "p": "payload"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "x": 270,
                        "y": 440,
                        "wires": [
                                "bac9031c.48509"
                        "onlyack": "",
                        "func": "rbe",
                        "gap": "",
                        "x": 260,
                        "y": 140,
                        "wires": [
                                "14ef63f9.2cb11c"
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "cont",
                                "v": "\"48\"",
                                "vt": "str"
                                "t": "eq",
                                "v": "{}",
                                "vt": "str"
                                "t": "else"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 3,
                        "x": 450,
                        "y": 140,
                        "wires": [
                                "c6c6dbfb.8e31c8"
                        "type": "function",
                        "outputs": 1,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 670,
                        "y": 260,
                        "wires": [
                                "955c676a.93fea8"
                mickymM Offline
                mickymM Offline
                mickym
                @kla960 Ehrlich gesagt verstehe ich nicht - wieso man eine function Node für sowas braucht und eine Switch Node - von den man 2 Ausgänge nicht braucht.
                Wenn der Kanal nicht 48 ist, dann soll doch der Flow nichts machen.
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 1160,
                       "y": 300,
                       "wires": []
                       "type": "inject",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "x": 770,
                       "y": 300,
                       "wires": [
                               "bac9031c.48509"
                       "onlyack": "",
                       "func": "rbe",
                       "gap": "",
                       "x": 200,
                       "y": 240,
                       "wires": [
                               "f72290f1ea35b588"
                       "type": "json",
                       "name": "",
                       "action": "",
                       "pretty": true,
                       "x": 970,
                       "y": 300,
                       "wires": [
                               "955c676a.93fea8"
                       "id": "f72290f1ea35b588",
                       "type": "json",
                       "name": "",
                       "action": "",
                       "pretty": false,
                       "x": 370,
                       "y": 240,
                       "wires": [
                               "2395f29ebcb32c33"
                       "id": "2395f29ebcb32c33",
                       "type": "switch",
                       "name": "Channel nicht 48 ?",
                       "property": "payload.NewChannel",
                       "rules": [
                               "t": "neq",
                               "v": "48",
                               "vt": "str"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 1,
                       "x": 550,
                       "y": 240,
                       "wires": [
                               "e122029bd78ce137"
                       "id": "e122029bd78ce137",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "{\"service\":\"urn:dslforum-org:service:WLANConfiguration:2\",\"action\":\"SetChannel\",\"params\":{\"NewChannel\":\"48\"}}",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 770,
                       "y": 240,
                       "wires": [
                               "bac9031c.48509"
                • mickymM mickym
                         "ack": "false",
                         "stateName": "",
                         "role": "",
                         "payloadType": "",
                         "readonly": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 1160,
                         "y": 300,
                         "wires": []
                         "type": "inject",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "x": 770,
                         "y": 300,
                         "wires": [
                                 "bac9031c.48509"
                         "onlyack": "",
                         "func": "rbe",
                         "gap": "",
                         "x": 200,
                         "y": 240,
                         "wires": [
                                 "f72290f1ea35b588"
                         "type": "json",
                         "name": "",
                         "action": "",
                         "pretty": true,
                         "x": 970,
                         "y": 300,
                         "wires": [
                                 "955c676a.93fea8"
                         "type": "json",
                         "name": "",
                         "action": "",
                         "pretty": false,
                         "x": 370,
                         "y": 240,
                         "wires": [
                                 "2395f29ebcb32c33"
                         "type": "switch",
                         "rules": [
                                 "t": "neq",
                                 "v": "48",
                                 "vt": "str"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 1,
                         "x": 550,
                         "y": 240,
                         "wires": [
                                 "e122029bd78ce137"
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 770,
                         "y": 240,
                         "wires": [
                                 "bac9031c.48509"
                  kla960
                  hast du mal den Code zu dem Bild?
                  mickymM F 2 Antworten Letzte Antwort
                  • K kla960
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @kla960 hängt doch unten dran - Du kannst noch filtern, dass nur die Ergebnisse verarbeitet werden, der NewChannel als Eigenschaft hat.
                    Falls doch nur prüfen willst, dass das commandResult genau das Objekt enthält, was Du sonst zurück bekommst: Also
                    dann kannst Du noch folgende switch Node als Filter vorne dran hängen:
                    hier nochmal der komplette Flow:
                           "z": "54b226bc.0793e8",
                           "ack": "false",
                           "stateName": "",
                           "role": "",
                           "payloadType": "",
                           "readonly": "",
                           "stateUnit": "",
                           "stateMin": "",
                           "stateMax": "",
                           "x": 1280,
                           "y": 3000,
                           "wires": []
                           "type": "inject",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "x": 910,
                           "y": 3000,
                           "wires": [
                                   "bac9031c.48509"
                           "onlyack": "",
                           "func": "rbe",
                           "gap": "",
                           "x": 100,
                           "y": 2940,
                           "wires": [
                                   "f72290f1ea35b588"
                           "type": "json",
                           "name": "",
                           "action": "",
                           "pretty": true,
                           "x": 1090,
                           "y": 3000,
                           "wires": [
                                   "955c676a.93fea8"
                           "type": "json",
                           "name": "",
                           "action": "",
                           "pretty": false,
                           "x": 270,
                           "y": 2940,
                           "wires": [
                                   "4bfc658be9e3e893"
                           "type": "switch",
                           "rules": [
                                   "t": "neq",
                                   "v": "48",
                                   "vt": "str"
                           "checkall": "true",
                           "repair": false,
                           "outputs": 1,
                           "x": 690,
                           "y": 2940,
                           "wires": [
                                   "e122029bd78ce137"
                           "type": "change",
                           "name": "setze Channel 48",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "tot": "json"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 910,
                           "y": 2940,
                           "wires": [
                                   "bac9031c.48509"
                           "id": "4bfc658be9e3e893",
                           "type": "switch",
                           "name": "filter commandResult ",
                           "property": "$exists(payload.NewChannel) and $exists(payload.NewPossibleChannels)\t",
                           "propertyType": "jsonata",
                           "rules": [
                                   "t": "true"
                           "checkall": "true",
                           "repair": false,
                           "outputs": 1,
                           "x": 460,
                           "y": 2940,
                           "wires": [
                                   "2395f29ebcb32c33"
                    • K kla960
                      frankyboy73
                      @kla960 sagte in JSON an tr-069 command übergeben:
                      Klick mal auf "Spoiler" in mickym Post
                      Schöne Grüße Frank
                      • K Offline
                        kla960
                        schrieb am zuletzt editiert von kla960
                        Ja, super danke. NewPossibleChannels muss man aber nicht zusätzlich prüfen. Ansonsten habe ich das jetzt so laufen.
                        • K kla960
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @kla960 trotzdem mal eine blöde Frage: Wenn Du kein Autokanal eingestellt hast, dann bleibt doch der Kanal fix eingestellt. Warum muss man das prüfen und manuell wieder umstellen?
                          • mickymM mickym
                            kla960
                            @mickym Gibt keine blöden Fragen.
                            Ja, das ist bei mir Fix eingetragen. Kein Autokanal. Dennoch stellt sich immer mal wieder der Kannal um. Und sobald ein Kanal ab 52 aufwärts eingestellt ist, funktionieren einige Geräte nicht mehr wie sie sollen.
                            Amazon Echos können kein Multiroom-Audio mehr. FTV Sticks verbinden sich nicht usw.
                            AVM Support sagt: "Ja, es gibt trotz fest eingestelltem Kanal umstände die einen automatischen Wechsel herbeiführen."
                            Also: Gemotze der Familie ertragen, wenn wieder was nicht geht 😧 , oder mit dem iobroker was dagegen tun.
                            • K Offline
                              kla960
                              Den zweiten Switch kann man noch eliminieren, indem man den ersten wie folgt anpasst:
                              $exists(payload.NewChannel) and payload.NewChannel in ["52","56","60","64","100","104","108","112","116","120","124","128","132","136","140"]
                              Wobei ich jetzt die Kanäle von 36 - 48 zulasse.
                              • K kla960
                                mickymM Offline
                                mickymM Offline
                                mickym
                                Ok - das ist ja mal eine gute Info. Das 5 GHz Band hat wahrscheinlich das Problem mit der Radarkollision wahrscheinlich das Problem. Aber wie ich sehe, bist Du ja nun am Feintunen - so dass Du Dir glaub jetzt gut selbst zu helfen weißt.
