  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 738.1k Aufrufe 117 Beobachtet
  • T tombox
    @jojo58 mal den parcel.0.auth ordner löschen
    JoJo58J Online
    JoJo58J Online
    JoJo58
    #1401
    @tombox
    funktioniert leider nicht. Kamen einige Meldungen das ich die Instanz nochmal neu starten soll, dann das ich den Ordner nochmal löschen soll. Hier die Meldungen:
    parcel.0
    	2024-06-23 14:51:47.616	info	Login to Hermes successful
    parcel.0
    	2024-06-23 14:51:47.269	info	Login to Hermes
    parcel.0
    	2024-06-23 14:51:47.268	info	{"Fault":{"faultcode":"Client","faultstring":"An exception has been raised as a result of client data.","detail":{"Errors":{"ErrorDetail":{"Severity":"Authentication","PrimaryErrorCode":{"Code":"250003","Description":"Invalid Access License number"},"Location":{"LocationElementName":"p2:AccessLicenseNumber"}}}}}}
    parcel.0
    	2024-06-23 14:51:47.268	warn	Login to UPS failed
    parcel.0
    	2024-06-23 14:51:46.866	info	Login to UPS
    parcel.0
    	2024-06-23 14:51:46.866	error	Unknown Error: Login to Amazon failed, please login to Amazon and check your credentials
    parcel.0
    	2024-06-23 14:51:45.544	info	Login to Amazon
    parcel.0
    	2024-06-23 14:51:45.464	info	Login to DHL successful
    parcel.0
    	2024-06-23 14:51:43.224	info	Login to DHL
    parcel.0
    	2024-06-23 14:51:43.201	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.parcel, node: v20.15.0, js-controller: 5.0.19
    parcel.0
    	2024-06-23 14:51:37.079	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    parcel.0
    	2024-06-23 14:51:37.078	info	terminating
    parcel.0
    	2024-06-23 14:51:37.077	info	Got terminate signal TERMINATE_YOURSELF
    parcel.0
    	2024-06-23 14:50:17.021	info	Login to Hermes successful
    parcel.0
    	2024-06-23 14:50:16.638	info	Login to Hermes
    parcel.0
    	2024-06-23 14:50:16.638	info	{"Fault":{"faultcode":"Client","faultstring":"An exception has been raised as a result of client data.","detail":{"Errors":{"ErrorDetail":{"Severity":"Authentication","PrimaryErrorCode":{"Code":"250003","Description":"Invalid Access License number"},"Location":{"LocationElementName":"p2:AccessLicenseNumber"}}}}}}
    parcel.0
    	2024-06-23 14:50:16.638	warn	Login to UPS failed
    parcel.0
    	2024-06-23 14:50:15.976	info	Login to UPS
    parcel.0
    	2024-06-23 14:50:15.976	error	Unknown Error: Login to Amazon failed, please login to Amazon and check your credentials
    parcel.0
    	2024-06-23 14:50:14.604	info	Login to Amazon
    parcel.0
    	2024-06-23 14:50:14.556	info	Login to DHL successful
    parcel.0
    	2024-06-23 14:50:12.386	info	Login to DHL
    parcel.0
    	2024-06-23 14:50:12.365	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.parcel, node: v20.15.0, js-controller: 5.0.19
    parcel.0
    	2024-06-23 14:50:07.052	info	terminating
    parcel.0
    	2024-06-23 14:50:06.550	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    parcel.0
    	2024-06-23 14:50:06.550	info	terminating
    parcel.0
    	2024-06-23 14:50:06.549	info	Got terminate signal TERMINATE_YOURSELF
    parcel.0
    	2024-06-23 14:50:05.973	info	Start relogin
    parcel.0
    	2024-06-23 14:50:05.973	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:50:05.972	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:50:04.019	info	Start relogin
    parcel.0
    	2024-06-23 14:50:04.019	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:50:04.018	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:50:01.247	info	Start relogin
    parcel.0
    	2024-06-23 14:50:01.247	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:50:01.246	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:49:59.312	info	Start relogin
    parcel.0
    	2024-06-23 14:49:59.312	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:49:59.312	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:49:57.339	info	Start relogin
    parcel.0
    	2024-06-23 14:49:57.339	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:49:57.338	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:49:55.440	info	Start relogin
    parcel.0
    	2024-06-23 14:49:55.440	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:49:55.439	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:49:53.474	info	Start relogin
    parcel.0
    	2024-06-23 14:49:53.473	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:49:53.473	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:49:51.035	info	Start relogin
    parcel.0
    	2024-06-23 14:49:51.035	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:49:51.035	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:49:49.132	info	Login to Amazon
    parcel.0
    	2024-06-23 14:49:49.018	info	Login to DHL successful
    parcel.0
    	2024-06-23 14:49:47.058	info	Login to DHL
    parcel.0
    	2024-06-23 14:49:47.040	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.parcel, node: v20.15.0, js-controller: 5.0.19
    parcel.0
    	2024-06-23 14:49:04.069	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    parcel.0
    	2024-06-23 14:49:04.069	info	terminating
    parcel.0
    	2024-06-23 14:49:04.068	info	Got terminate signal TERMINATE_YOURSELF
    parcel.0
    	2024-06-23 14:49:03.426	info	Start relogin
    parcel.0
    	2024-06-23 14:49:03.426	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:49:03.426	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:49:01.016	info	Start relogin
    parcel.0
    	2024-06-23 14:49:01.016	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:49:01.016	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:59.033	info	Start relogin
    parcel.0
    	2024-06-23 14:48:59.033	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:59.033	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:57.160	info	Start relogin
    parcel.0
    	2024-06-23 14:48:57.160	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:57.160	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:55.185	info	Start relogin
    parcel.0
    	2024-06-23 14:48:55.185	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:55.185	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:53.332	info	Start relogin
    parcel.0
    	2024-06-23 14:48:53.332	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:53.331	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:50.933	info	Start relogin
    parcel.0
    	2024-06-23 14:48:50.933	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:50.932	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:48.941	info	Start relogin
    parcel.0
    	2024-06-23 14:48:48.941	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:48.941	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:47.072	info	Start relogin
    parcel.0
    	2024-06-23 14:48:47.072	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:47.072	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:45.140	info	Login to Amazon
    parcel.0
    	2024-06-23 14:48:45.094	info	Login to DHL successful
    parcel.0
    	2024-06-23 14:48:42.866	info	Login to DHL
    parcel.0
    	2024-06-23 14:48:42.843	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.parcel, node: v20.15.0, js-controller: 5.0.19
    parcel.0
    	2024-06-23 14:48:37.106	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    parcel.0
    	2024-06-23 14:48:37.106	info	terminating
    parcel.0
    	2024-06-23 14:48:37.105	info	Got terminate signal TERMINATE_YOURSELF
    parcel.0
    	2024-06-23 14:48:36.769	info	Start relogin
    parcel.0
    	2024-06-23 14:48:36.769	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:36.769	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:34.533	info	Start relogin
    parcel.0
    	2024-06-23 14:48:34.533	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:34.533	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:32.588	info	Start relogin
    parcel.0
    	2024-06-23 14:48:32.588	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:32.587	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:30.311	info	Start relogin
    parcel.0
    	2024-06-23 14:48:30.311	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:30.311	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:28.402	info	Start relogin
    parcel.0
    	2024-06-23 14:48:28.402	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:28.402	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:26.434	info	Start relogin
    parcel.0
    	2024-06-23 14:48:26.434	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:26.433	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:24.470	info	Start relogin
    parcel.0
    	2024-06-23 14:48:24.470	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:24.469	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:22.606	info	Start relogin
    parcel.0
    	2024-06-23 14:48:22.606	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:22.606	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:20.094	info	Start relogin
    parcel.0
    	2024-06-23 14:48:20.093	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:20.093	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:18.164	info	Start relogin
    parcel.0
    	2024-06-23 14:48:18.164	info	Amazon cookie are removed. Please restart the adapter to trigger a relogin. If this is not working please manually delete parcel.0.auth.cookie
    parcel.0
    	2024-06-23 14:48:18.163	error	Login to Amazon failed, please login to Amazon manually and check the login
    parcel.0
    	2024-06-23 14:48:16.165	info	Login to Amazon
    parcel.0
    	2024-06-23 14:48:16.116	info	Login to DHL successful
    parcel.0
    	2024-06-23 14:48:14.153	info	Login to DHL
    parcel.0
    	2024-06-23 14:48:14.133	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.parcel, node: v20.15.0, js-controller: 5.0.19
    parcel.0
    	2024-06-23 14:47:45.643	info	terminating
    parcel.0
    	2024-06-23 14:47:45.142	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    parcel.0
    	2024-06-23 14:47:45.142	info	terminating
    parcel.0
    	2024-06-23 14:47:45.141	info	Got terminate signal TERMINATE_YOURSELF
    Habe mich dann über Firefox bei Amazon angemeldet, das klappte. Wenn ich auf meine "Anmeldung & Sicherheit" gehe, wurde mir einmalig eine SMS zugeschickt, danach hätte ich die Einstellungen anpassen können. Konto ist also aktiv und nicht gesperrt.
    Intel NUC i7 64GB 1TB SSD - Proxmox - Raspi 4 8GB 500 GB SSD - Raspi 4 4GB 500GB SSD - Qnap 16TB - CCU3 - Fritz 6591 Cable - Green Cell USV 1500VA
    Sonoff CC2652P - HUE Bridge - Broadlink RM4 pro u. RM3 mini - 5 x Echo - 1 x Samsung STab 8 - 54 x HM und HMIP - 32 x Zigbee - 2 x Shelly 3EM.
    Einfach ein tolles Hobby :-)
    Ro75R 1 Antwort Letzte Antwort
    • JoJo58J JoJo58
      @tombox
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      Ro75R Offline
      Ro75R Offline
      Ro75
      #1402
      @jojo58 du brauchst einen gültigen (in dem Moment) 2FA Code und der muss in den Adapter rein. Bei mir läuft das über eine APP. Da sind alle meine 2FA drin. Aller 30 Sekunden gibt es neue für den jeweiligen Anmeldevorgang.
      Ro75.
      JoJo58J 1 Antwort Letzte Antwort
      • Ro75R Ro75
        Ro75.
        JoJo58J Online
        JoJo58J Online
        JoJo58
        #1403
        @ro75
        Ich habe die Authenticator App wegen Microsoft, habe bei Amazon jetzt wieder die 2FA aktiviert und die App neu verknüpft. Keine Chance, egal ob ich den Token der per SMS kommt nehme, oder einen gültigen aus der App, es funktioniert nicht. Jetzt sieht die Fehlermeldung aber anders aus.
        parcel.0
        	2024-06-23 15:24:48.474	info	Login to Hermes successful
        parcel.0
        	2024-06-23 15:24:48.125	info	Login to Hermes
        parcel.0
        	2024-06-23 15:24:48.124	info	{"Fault":{"faultcode":"Client","faultstring":"An exception has been raised as a result of client data.","detail":{"Errors":{"ErrorDetail":{"Severity":"Authentication","PrimaryErrorCode":{"Code":"250003","Description":"Invalid Access License number"},"Location":{"LocationElementName":"p2:AccessLicenseNumber"}}}}}}
        parcel.0
        	2024-06-23 15:24:48.124	warn	Login to UPS failed
        parcel.0
        	2024-06-23 15:24:47.777	info	Login to UPS
        parcel.0
        	2024-06-23 15:24:47.776	error	MFA: Login to Amazon failed, please login manually to Amazon
        parcel.0
        	2024-06-23 15:24:46.862	info	Found MFA token login
        parcel.0
        	2024-06-23 15:24:45.256	info	Login to Amazon
        parcel.0
        	2024-06-23 15:24:45.211	info	Login to DHL successful
        parcel.0
        	2024-06-23 15:24:43.109	info	Login to DHL
        parcel.0
        	2024-06-23 15:24:43.088	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.parcel, node: v20.15.0, js-controller: 5.0.19
        parcel.0
        	2024-06-23 15:24:38.369	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        parcel.0
        	2024-06-23 15:24:38.368	info	terminating
        parcel.0
        	2024-06-23 15:24:38.368	info	Got terminate signal TERMINATE_YOURSELF
        parcel.0
        	2024-06-23 15:21:15.179	info	Login to Hermes successful
        parcel.0
        	2024-06-23 15:21:14.830	info	Login to Hermes
        parcel.0
        	2024-06-23 15:21:14.829	info	{"Fault":{"faultcode":"Client","faultstring":"An exception has been raised as a result of client data.","detail":{"Errors":{"ErrorDetail":{"Severity":"Authentication","PrimaryErrorCode":{"Code":"250003","Description":"Invalid Access License number"},"Location":{"LocationElementName":"p2:AccessLicenseNumber"}}}}}}
        parcel.0
        	2024-06-23 15:21:14.829	warn	Login to UPS failed
        parcel.0
        	2024-06-23 15:21:14.587	info	Login to UPS
        parcel.0
        	2024-06-23 15:21:14.587	error	MFA: Login to Amazon failed, please login manually to Amazon
        parcel.0
        	2024-06-23 15:21:13.639	info	Found MFA token login
        parcel.0
        	2024-06-23 15:21:12.012	info	Login to Amazon
        parcel.0
        	2024-06-23 15:21:11.967	info	Login to DHL successful
        parcel.0
        	2024-06-23 15:21:09.417	info	Login to DHL
        parcel.0
        	2024-06-23 15:21:09.353	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.parcel, node: v20.15.0, js-controller: 5.0.19
        parcel.0
        	2024-06-23 15:21:04.690	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        parcel.0
        	2024-06-23 15:21:04.690	info	terminating
        parcel.0
        	2024-06-23 15:21:04.689	info	Got terminate signal TERMINATE_YOURSELF
        parcel.0
        	2024-06-23 15:20:42.864	info	Login to Hermes successful
        parcel.0
        	2024-06-23 15:20:42.534	info	Login to Hermes
        parcel.0
        	2024-06-23 15:20:42.533	info	{"Fault":{"faultcode":"Client","faultstring":"An exception has been raised as a result of client data.","detail":{"Errors":{"ErrorDetail":{"Severity":"Authentication","PrimaryErrorCode":{"Code":"250003","Description":"Invalid Access License number"},"Location":{"LocationElementName":"p2:AccessLicenseNumber"}}}}}}
        parcel.0
        	2024-06-23 15:20:42.533	warn	Login to UPS failed
        parcel.0
        	2024-06-23 15:20:41.949	info	Login to UPS
        parcel.0
        	2024-06-23 15:20:41.949	error	MFA: Login to Amazon failed, please login manually to Amazon
        parcel.0
        	2024-06-23 15:20:41.064	info	Found MFA token login
        parcel.0
        	2024-06-23 15:20:39.484	info	Login to Amazon
        parcel.0
        	2024-06-23 15:20:39.434	info	Login to DHL successful
        parcel.0
        	2024-06-23 15:20:37.357	info	Login to DHL
        parcel.0
        	2024-06-23 15:20:37.294	info	starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.parcel, node: v20.15.0, js-controller: 5.0.19
        parcel.0
        	2024-06-23 15:20:32.441	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        Ich höre jetzt mit dem Testen auf, soweit ich weiß ist die Anzahl der Tokens pro Tag begrenzt und ich bin vor ein paar Wochen schon einmal für 24 Stunden gesperrt worden. In der Zeit konnte ich keine Token mehr anfordern.
        • NashraN Offline
          NashraN Offline
          Nashra
          Most Active Forum Testing
          #1404
          Hey, seit einigen Tagen auch bei mir hier keine Anzeige mehr von Amazon Paketen bzw. Lieferungen.
          Nur großes Fehlerprotkoll wie auch hier schon von anderen gepostet.
          Amazon muß leider mal wieder irgendwas geändert haben :-(
          Gruß Ralf
          Mir egal, wer Dein Vater ist! Wenn ich hier angel, wird nicht übers Wasser gelaufen!!
          Thomas BraunT T 2 Antworten Letzte Antwort
          • NashraN Nashra
            #1405
            Ja, da ist wohl was anders.
            2024-06-25 12:14:21.251 - error: parcel.0 (366023) Failed to post with password to https://www.amazon.de/ap/signin
            Die lange Meldung ist html und führt zu:
            • NashraN Nashra
              tombox
              #1406
              @nashra du hast auch mfa? SMS oder App?
              Thomas BraunT NashraN 2 Antworten Letzte Antwort
              • T tombox
                #1407
                @tombox
                Bin zwar nicht @Nashra , aber hier ist MFA vie AuthenticatorApp am Start.
                • T tombox
                  NashraN Offline
                  NashraN Offline
                  Nashra
                  #1408
                  @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                  Nein, ganz normal mit eMail/Passwort
                  Gruß Ralf
                  • Ro75R Offline
                    Ro75R Offline
                    Ro75
                    #1409
                    Nur mal so zur Info. Bin noch mit der 0.2.2 unterwegs. Amazon hat bei mir vor ca. 10 bis 12 Tagen gesponnen (was im 500er Bereich). Im Form hatte sich dazu nichts getan und nach 2 Tagen war dann wieder alles OK.
                    Im Moment läuft der Adapter ohne Probleme. Bestellungen von Amazon werden angezeigt und aktualisiert. Bin mit 2FA unterwegs (ohne geht es ja so wieso nicht).
                    Ro75.
                      @tombox
                      tombox
                      #1410
                      @thomas-braun Kann es mit meinem Account nicht reproduzieren. auch mit MFA und ohne kann es zur zeit nicht fixen
                      • T tombox
                        #1411
                        @tombox Schade. Bringt dir die vollständige (html)-Fehlermeldung was?
                          tombox
                          #1412
                          @thomas-braun Er sagt ja die Webseite gibt es nicht was nicht hilfreich ist
                          • T tombox
                            #1413
                            @tombox Richtig:
                            Tut uns leid: Die Web-Adresse, die du eingegeben hast, gibt es auf unserer Website nicht.
                            2024-06-25 20:58:52.343 - error: parcel.0 (402986) AxiosError: Request failed with status code 404
                              @tombox Richtig:
                              tombox
                              #1414
                              @thomas-braun Die GitHub version hat zusätzliche logs vielleicht sieht man etwas ich kann auch direkt keine änderung im login sehen
                              • T tombox
                                #1415
                                @tombox
                                Die hab ich schon am Wickel:
                                parcel@0.2.7 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#97babf700ab822b2634ad53fbc280f9e24b9dec3)
                                Edit:
                                Jetzt
                                parcel@0.2.7 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#bb1232502ff38f10835635c2926774d940456d8c)
                                • T tombox
                                  #1416
                                  @tombox
                                  2024-06-25 21:33:21.165  - error: parcel.0 (404746) Failed to post with password to https://www.amazon.de/ap/signin
                                  HIER DER HTML-CODE
                                  2024-06-25 21:33:21.174  - error: parcel.0 (404746) AxiosError: Request failed with status code 404
                                    @tombox
                                    HIER DER HTML-CODE
                                    tombox
                                    #1417
                                    @thomas-braun was kommt davor noch an debug log.. bitte e-mail Adresse schwärzen
                                    • T tombox
                                      #1418
                                      @tombox
                                      Email war gar keine drin...
                                      2024-06-25 22:17:52.341  - info: parcel.0 (408802) Login to Amazon
                                      2024-06-25 22:17:53.017  - debug: parcel.0 (408802) Username successfully posted
                                      2024-06-25 22:17:53.018  - debug: parcel.0 (408802) Post form : {"ue_back":"1"}
                                      2024-06-25 22:17:53.018  - debug: parcel.0 (408802) Post with password
                                      2024-06-25 22:17:53.220  - error: parcel.0 (408802) Failed to post with password to https://www.amazon.de/ap/signin
                                      2024-06-25 22:17:53.225  - error: parcel.0 (408802) AxiosError: Request failed with status code 404
                                        @tombox
                                        tombox
                                        schrieb am zuletzt editiert von tombox
                                        #1419
                                        @thomas-braun dann mal auf log level silly stellen und den html code vor
                                        anschauen was da drin steht
                                        • T tombox
                                          #1420
                                          @tombox
                                          Aus dem ganzen html-Wust sticht mir das ins Auge:
                                          Diese Website benötigt JavaScript um korrekt zu funktionieren. Bitte aktivieren Sie Javascript in Ihrem Browser, um fortzufahren.\n    </div></div></div>\n  </noscript>\n\n\n      </div>\n\n      <div class=\"a-section auth-pagelet-mobile-container\">\n        \
                                          n        \n\n\n\n\n\n\n\n\n    \n\n    \n        \n    \n\n\n<div id=\"untrusted-app-sign-in-accept-risk\" class=\"a-box a-alert a-alert-error a-spacing-base\" role=\"alert\"><div class=\"a-box-inner a-alert-container\"><h4 class=\"a-al
                                          ert-heading\">Eine nicht vertrauenswürdige App versucht, auf Ihr Amazon-Konto zuzugreifen.</h4><div class=\"a-alert-content\">\n\n    Durch die Fortsetzen wird der Zugriff auf alle Daten deines Amazon-Kontos gewährt. Um deine Daten und
                                          deine Privatsphäre zu schützen, <b>empfehlen wir dir, diese nicht vertrauenswürdige App nicht weiter zu verwenden, um auf dein Amazon-Konto zuzugreifen</b>.\n</div></div></div>\n\n<div class=\"a-section a-spacing-base\">\n    <form id=\
                                          "untrusted-app-sign-in-continue-form\" method=\"post\" action=\"https://www.amazon.de/ap/signin\">\n
