  4. Javascript Adapter rot
91 Beiträge 4 Kommentatoren 11.6k Aufrufe 3 Beobachtet
  • ChrisPrefectC ChrisPrefect
    @glasfaser sagte in Javascript Adapter rot:
    iob update -i
    pi@ioBrokerVM:/opt/iobroker$ cd /opt/iobroker
    pi@ioBrokerVM:/opt/iobroker$ npm uninstall javascript
    [sudo] Passwort für pi:
    Das hat nicht funktioniert, bitte nochmal probieren.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    up to date in 22.931s
    155 packages are looking for funding
      run `npm fund` for details
    pi@ioBrokerVM:/opt/iobroker$ npm uninstall js-controller
    [..................] / rollbackFailedOptional: verb npm-session 29b8658558937b5f
    up to date in 20.442s
    pi@ioBrokerVM:/opt/iobroker$ iob update -i
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.javascript/io-package.json: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
    Adapter    "admin"         : 5.2.3    , installed 5.2.3
    Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
    Adapter    "backitup"      : 2.2.2    , installed 2.2.3
    Adapter    "cloud"         : 4.1.0    , installed 4.1.0
    Adapter    "deconz"        : 1.3.19   , installed 1.3.19
    Adapter    "discovery"     : 2.7.3    , installed 2.7.5
    Adapter    "email"         : 1.0.10   , installed 1.0.10
    Adapter    "flot"          : 1.10.7   , installed 1.10.7
    Adapter    "geofency"      : 1.0.3    , installed 1.0.3
    Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
    Adapter    "history"       : 1.9.14   , installed 1.10.5
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "influxdb"      : 1.9.5    , installed 2.4.0
    Adapter    "info"          : 1.9.8    , installed 1.9.16
    Adapter    "iot"           : 1.8.24   , installed 1.8.25
    Adapter    "iqontrol"      : 1.8.2    , installed 1.11.0
    Adapter    "jarvis"        : 2.2.1    , installed 3.0.7
    Controller "js-controller" : 3.3.22   , installed 3.3.22
    Adapter    "lifx"          : 0.1.1    , installed 0.1.1
    Adapter    "linkeddevices" : 1.4.3    , installed 1.4.3
    Adapter    "material"      : 1.0.4    , installed 1.1.2
    Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
    Adapter    "mobile"        : 1.0.1    , installed 1.0.1
    Adapter    "modbus"        : 3.4.14   , installed 3.4.17
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.1
    Adapter    "node-red"      : 2.4.1    , installed 2.4.1
    Adapter    "octoprint"     : 2.1.0    , installed 2.1.1
    Adapter    "onvif"         : 0.4.4    , installed 0.4.4
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "proxy"         : 1.2.2    , installed 1.2.2
    Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
    Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
    Adapter    "samsung"       : 0.2.9    , installed 0.2.9
    Adapter    "scenes"        : 2.3.8    , installed 2.3.8
    Adapter    "shelly"        : 4.0.7    , installed 5.0.0
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
    Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.5
    Adapter    "sonoff"        : 2.4.5    , installed 2.4.7
    Adapter    "statistics"    : 1.0.9    , installed 1.0.10
    Adapter    "swiss-weather-api": 1.0.2   , installed 1.0.2
    Adapter    "telegram"      : 1.10.0   , installed 1.10.0
    Adapter    "tesla-motors"  : 0.5.2    , installed 1.0.7
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.15
    Adapter    "unifi"         : 0.5.10   , installed 0.5.10
    Adapter    "vis"           : 1.4.5    , installed 1.4.7
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.9
    Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
    Adapter    "web"           : 3.4.9    , installed 3.4.16
    Adapter    "windows-control": 0.1.5   , installed 0.1.5
    Adapter    "yahka"         : 0.13.1   , installed 0.13.1
    Adapter    "zigbee"        : 1.6.6    , installed 1.6.12
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    #81
    @chrisprefect
    Erlich ......
    nimm ein Backup .... installiere ioBroker neu
    und lass die Finger von root
    HomoranH ChrisPrefectC 2 Antworten Letzte Antwort
      Auf hard ...
      shure?
      ohne -u iobroker -H ?
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      #82
      @homoran sagte in Javascript Adapter rot:
      shure?
      Ja ... wollte sehen was passiert
      • GlasfaserG Glasfaser
        @chrisprefect
        Erlich ......
        #83
        nimm ein Backup
        da sind dann auch deine Skripte drin
          @chrisprefect
          Erlich ......
          ChrisPrefectC Offline
          ChrisPrefect
          #84
          @glasfaser Das Backup das ich habe ist von vorgestern. Das war wohl noch vor dem Update der Admin-Instanz. Aber wenn ich das wieder zurückspiele und wieder update bin ich gleich weit.
          HomoranH GlasfaserG 2 Antworten Letzte Antwort
            #85
            @chrisprefect sagte in Javascript Adapter rot:
            nein!
            Nicht wenn du vorher eine vernünftige Grundinstallation ohne root und ohne Desktop installierst
            ChrisPrefectC 1 Antwort Letzte Antwort
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              #86
              Nein...
              und dann stimmen die Rechte wieder
                nein!
                ChrisPrefect
                #87
                @homoran Das schaffe ich in meinem aktuellen Zustand nicht. Um Debian in der VM mit den Virtualbox-Tools zu installieren brauche ich schon einen Tag. Und dann hoffen, dass das Backitup funktioniert ist zu riskant.
                  Nein...
                  ChrisPrefect
                  #88
                  @glasfaser Ich hatte mich seit dem Backup der VM nicht per Root eingeloggt. Wenn dann wär das vor vielen, vielen Monaten mal gewesen.
                    #89
                    VB kenne ich nicht, bei Proxmox dauert das etwa 1/2 Stunde
                    Das sollte funktionieren.
                    Aber du arbeitest ja mit VMs. Warum machst du nicht erst einmal eine zweite VM parallel neu und installierst da in Ruhe alles
                      ChrisPrefect
                      #90
                      Ich habe jetzt das Backup der VM zurückgespielt und nochmals alles upgedatet. Diesmal hat es funktioniert. Das einzige, was diesmal anders war, ist, dass ich nun zuerst den Javascript-Adapter auf .19 upgedatet habe, dann den jscrontroller/Host auf 3.3.22 und dann noch den Admin-Adapter auf 5.2.3.
                      Seit dem VM-Backup war ich auch nicht als Root eingeloggt... Schon komisch, dass sich ioBroker bei mir so oft irgendwie aufhängt.
                      Solche Ausfälle sind für mich immer extrem stressig, wenn das Smarthome nicht läuft, gerade wenn man nicht fit ist.
                      Merci für die schnelle und ausführliche Hilfe!
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        #91
                        @chrisprefect
                        .... schön das es wieder geht . :)
                        Ein weiteres "rumbastel" wäre auch sinnlos gewesen ... deshalb habe ich auch geschrieben :
                        Erlich ......
