  4. Javascript Adapter rot
    5.5k
91 Beiträge 4 Kommentatoren 11.6k Aufrufe 3 Beobachtet
  • GlasfaserG Glasfaser
    @chrisprefect
    Error deleting adapter javascript from disk:
    Da hast aber ganz schön was .........
    Auf hard ...
    cd /opt/iobroker
    npm uninstall javascript
    npm uninstall js-controller
    Ausgabe
    iob update -i
    #80
    @glasfaser sagte in Javascript Adapter rot:
    Auf hard ...
    shure?
    ohne -u iobroker -H ?
    • ChrisPrefectC ChrisPrefect
      iob update -i
      pi@ioBrokerVM:/opt/iobroker$ cd /opt/iobroker
      pi@ioBrokerVM:/opt/iobroker$ npm uninstall javascript
      [sudo] Passwort für pi:
      Das hat nicht funktioniert, bitte nochmal probieren.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      up to date in 22.931s
      155 packages are looking for funding
        run `npm fund` for details
      pi@ioBrokerVM:/opt/iobroker$ npm uninstall js-controller
      [..................] / rollbackFailedOptional: verb npm-session 29b8658558937b5f
      up to date in 20.442s
      pi@ioBrokerVM:/opt/iobroker$ iob update -i
      Used repository: stable
      hash unchanged, use cached sources
      update done
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.javascript/io-package.json: /opt/iobroker/node_modules/iobroker.javascript/io-package.json: Unexpected end of JSON input
      Adapter    "admin"         : 5.2.3    , installed 5.2.3
      Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
      Adapter    "backitup"      : 2.2.2    , installed 2.2.3
      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
      Adapter    "deconz"        : 1.3.19   , installed 1.3.19
      Adapter    "discovery"     : 2.7.3    , installed 2.7.5
      Adapter    "email"         : 1.0.10   , installed 1.0.10
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "geofency"      : 1.0.3    , installed 1.0.3
      Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
      Adapter    "history"       : 1.9.14   , installed 1.10.5
      Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "influxdb"      : 1.9.5    , installed 2.4.0
      Adapter    "info"          : 1.9.8    , installed 1.9.16
      Adapter    "iot"           : 1.8.24   , installed 1.8.25
      Adapter    "iqontrol"      : 1.8.2    , installed 1.11.0
      Adapter    "jarvis"        : 2.2.1    , installed 3.0.7
      Controller "js-controller" : 3.3.22   , installed 3.3.22
      Adapter    "lifx"          : 0.1.1    , installed 0.1.1
      Adapter    "linkeddevices" : 1.4.3    , installed 1.4.3
      Adapter    "material"      : 1.0.4    , installed 1.1.2
      Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
      Adapter    "modbus"        : 3.4.14   , installed 3.4.17
      Adapter    "mqtt"          : 2.4.0    , installed 2.4.1
      Adapter    "node-red"      : 2.4.1    , installed 2.4.1
      Adapter    "octoprint"     : 2.1.0    , installed 2.1.1
      Adapter    "onvif"         : 0.4.4    , installed 0.4.4
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "proxy"         : 1.2.2    , installed 1.2.2
      Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
      Adapter    "samsung"       : 0.2.9    , installed 0.2.9
      Adapter    "scenes"        : 2.3.8    , installed 2.3.8
      Adapter    "shelly"        : 4.0.7    , installed 5.0.0
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
      Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.5
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.7
      Adapter    "statistics"    : 1.0.9    , installed 1.0.10
      Adapter    "swiss-weather-api": 1.0.2   , installed 1.0.2
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "tesla-motors"  : 0.5.2    , installed 1.0.7
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.15
      Adapter    "unifi"         : 0.5.10   , installed 0.5.10
      Adapter    "vis"           : 1.4.5    , installed 1.4.7
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.9
      Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
      Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
      Adapter    "web"           : 3.4.9    , installed 3.4.16
      Adapter    "windows-control": 0.1.5   , installed 0.1.5
      Adapter    "yahka"         : 0.13.1   , installed 0.13.1
      Adapter    "zigbee"        : 1.6.6    , installed 1.6.12
      GlasfaserG Offline
      GlasfaserG Offline
      #81
      @chrisprefect
      Erlich ......
      nimm ein Backup .... installiere ioBroker neu
      und lass die Finger von root
      HomoranH ChrisPrefectC 2 Antworten Letzte Antwort
        Auf hard ...
        shure?
        GlasfaserG Offline
        GlasfaserG Offline
        #82
        @homoran sagte in Javascript Adapter rot:
        shure?
        Ja ... wollte sehen was passiert
          @chrisprefect
          Erlich ......
          #83
          nimm ein Backup
          da sind dann auch deine Skripte drin
            @chrisprefect
            Erlich ......
            ChrisPrefectC Offline
            ChrisPrefect
            #84
            @glasfaser Das Backup das ich habe ist von vorgestern. Das war wohl noch vor dem Update der Admin-Instanz. Aber wenn ich das wieder zurückspiele und wieder update bin ich gleich weit.
            HomoranH GlasfaserG 2 Antworten Letzte Antwort
              #85
              @chrisprefect sagte in Javascript Adapter rot:
              nein!
              Nicht wenn du vorher eine vernünftige Grundinstallation ohne root und ohne Desktop installierst
              ChrisPrefectC 1 Antwort Letzte Antwort
                GlasfaserG Offline
                GlasfaserG Offline
                #86
                Nein...
                und dann stimmen die Rechte wieder
                  nein!
                  ChrisPrefect
                  #87
                  @homoran Das schaffe ich in meinem aktuellen Zustand nicht. Um Debian in der VM mit den Virtualbox-Tools zu installieren brauche ich schon einen Tag. Und dann hoffen, dass das Backitup funktioniert ist zu riskant.
                    Nein...
                    ChrisPrefect
                    #88
                    @glasfaser Ich hatte mich seit dem Backup der VM nicht per Root eingeloggt. Wenn dann wär das vor vielen, vielen Monaten mal gewesen.
                      #89
                      VB kenne ich nicht, bei Proxmox dauert das etwa 1/2 Stunde
                      Das sollte funktionieren.
                      Aber du arbeitest ja mit VMs. Warum machst du nicht erst einmal eine zweite VM parallel neu und installierst da in Ruhe alles
                        ChrisPrefect
                        #90
                        Ich habe jetzt das Backup der VM zurückgespielt und nochmals alles upgedatet. Diesmal hat es funktioniert. Das einzige, was diesmal anders war, ist, dass ich nun zuerst den Javascript-Adapter auf .19 upgedatet habe, dann den jscrontroller/Host auf 3.3.22 und dann noch den Admin-Adapter auf 5.2.3.
                        Seit dem VM-Backup war ich auch nicht als Root eingeloggt... Schon komisch, dass sich ioBroker bei mir so oft irgendwie aufhängt.
                        Solche Ausfälle sind für mich immer extrem stressig, wenn das Smarthome nicht läuft, gerade wenn man nicht fit ist.
                        Merci für die schnelle und ausführliche Hilfe!
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #91
                          @chrisprefect
                          .... schön das es wieder geht . :)
                          Ein weiteres "rumbastel" wäre auch sinnlos gewesen ... deshalb habe ich auch geschrieben :
                          Erlich ......
