  4. [gelöst] das leidige Thema "Stromausfall"
    6.0k
63 Beiträge 12 Kommentatoren 9.5k Aufrufe 9 Beobachtet
  • R Rushmed
    Ich hab noch ne Frage zu writeFileInterval. Wo genau packe ich das in der iobroker.json hin wenn es noch nicht da ist? Einfach bei Objects und States als neue Zeile mit rein also bspw. Zeile 27 und 53?
      "system": {
        "memoryLimitMB": 0,
        "hostname": "",
        "statisticsInterval": 15000,
        "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
        "checkDiskInterval": 300000,
        "checkDiskIntervalComment": "Interval how often the disk size will be checked",
        "noChmod": false,
        "instanceStartInterval": 2000,
        "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
        "compact": false,
        "compactComment": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in io-package.json",
        "allowShellCommands": false,
        "allowShellCommandsComment": "Allow execution of \"shell\" sendToHost commands"
      "multihostService": {
        "enabled": false,
        "secure": true
      "network": {
        "IPv4": true,
        "IPv6": true,
        "bindAddress": null
      "objects": {
        "type": "file",
        "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
        "host": "127.0.0.1",
        "port": 9001,
        "user": "",
        "pass": "",
        "noFileCache": false,
        "connectTimeout": 2000,
        "options": {
          "auth_pass": null,
          "retry_max_delay": 5000
        "backup": {
          "disabled": false,
          "files": 24,
          "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
          "hours": 48,
          "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
          "period": 120,
          "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
          "path": "",
          "pathComment": "Absolute path to backup directory or empty to backup in data directory"
        "dataDir": "../../iobroker-data/"
      "states": {
        "type": "file",
        "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
        "port": 9000,
        "maxQueue": 1000,
        "user": "",
        "pass": "",
        "options": {
          "auth_pass": null,
        "backup": {
          "disabled": false,
          "files": 24,
          "hours": 48,
          "period": 120,
          "path": "",
      "log": {
        "level": "info",
        "maxDays": 7,
        "noStdout": true,
        "transport": {
          "file1": {
            "type": "file",
            "enabled": true,
            "filename": "log/iobroker",
            "fileext": ".log",
            "maxSize": null,
            "maxFiles": null
          "syslog1": {
            "type": "syslog",
            "enabled": false,
            "host": "localhost",
            "hostComment": "The host running syslogd, defaults to localhost.",
            "portComment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
            "protocol": "udp4",
            "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
            "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
            "facilityComment": "Syslog facility to use (Default: local0).",
            "localhost": "iobroker",
            "localhostComment": "Host to indicate that log messages are coming from (Default: localhost).",
            "sysLogTypeComment": "The type of the syslog protocol to use (Default: BSD).",
            "app_nameComment": "The name of the application (Default: process.title).",
            "eolComment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
      "dataDirComment": "Always relative to iobroker.js-controller/",
    Ich nehme an, dass die noch nicht geschriebenen Werte einfach im Ram bleiben. Welche Intervallzeit ist denn hier empfohlen oder was sollte maximal eingestellt werden.
    Schreibt der ioBroker die Files bei "iobroker stop" unabhängig vom Intervall?
    #41
    @rushmed sagte: Einfach bei Objects und States als neue Zeile mit rein also bspw. Zeile 27 und 53?
    Ja.
    @rushmed sagte in das leidige Thema "Stromausfall":
    Ja.
    R 1 Antwort Letzte Antwort
      Ja.
      Ja.
      Rushmed
      #42
      @paul53 Ok, danke und wie sein die Standardwerte?
      Für die States steht oben 30000 ms und was ist es für die Objects?
      • R Rushmed
        #43
        @rushmed sagte: was ist es für die Objects?
        5000 ms.
          5000 ms.
          Rushmed
          #44
          @paul53 Danke!
          Für mich zum Verständnis, die States enthält die Datenpunkte und doe Objects enthält die Werte, oder?
          • R Rushmed
            @paul53 Danke!
            #45
            @paul53 Danke!
            anders herum
            • R Rushmed
              @paul53 Danke!
              #46
              @rushmed sagte: die States enthält die Datenpunkte und doe Objects enthält die Werte, oder?
              Umgekehrt: States enthält die dynamischen Zustände und Objects enthält die statischen Objekte.
              • R Rushmed
                  "system": {
                    "memoryLimitMB": 0,
                    "hostname": "",
                    "noChmod": false,
                    "compact": false,
                    "enabled": false,
                    "secure": true
                  "network": {
                    "IPv4": true,
                    "IPv6": true,
                    "bindAddress": null
                  "objects": {
                    "type": "file",
                    "port": 9001,
                    "user": "",
                    "pass": "",
                    "options": {
                      "auth_pass": null,
                    "backup": {
                      "disabled": false,
                      "files": 24,
                      "hours": 48,
                      "period": 120,
                      "path": "",
                  "states": {
                    "type": "file",
                    "port": 9000,
                    "maxQueue": 1000,
                    "user": "",
                    "pass": "",
                    "options": {
                      "auth_pass": null,
                    "backup": {
                      "disabled": false,
                      "files": 24,
                      "hours": 48,
                      "period": 120,
                      "path": "",
                  "log": {
                    "level": "info",
                    "maxDays": 7,
                    "noStdout": true,
                    "transport": {
                      "file1": {
                        "type": "file",
                        "enabled": true,
                        "fileext": ".log",
                        "maxSize": null,
                        "maxFiles": null
                      "syslog1": {
                        "type": "syslog",
                        "enabled": false,
                        "protocol": "udp4",
                Rushmed
                #47
                Kann das noch jemand beantworten?
                • R Rushmed
                  #48
                  Noch jemand?
                  @paul53 sagte in das leidige Thema "Stromausfall":
                  kann z.B. die Schreibfrequenz für die states.json vorgegeben werden: "writeFileInterval": 300000 (5 Minuten).
                  Ja.
                  • OliverIOO OliverIO
                    @heimweh
                    Das Risiko der Beschädigung einer Datei oder gar des ganzen System bei Strom weg ist im speziellen bei sd Karten gegeben, da diese im Gegensatz zu ssd Festplatten keine eigenen kondensatoren haben die noch genug Strom haben um zumindest den Cache noch zu schreiben.
                    Da bei sd/ssd immer größere Blocks geschrieben werden, die auch mal größer wie eine Datei sein kann ist, wenn das nicht abgeschlossen werden kann, die Datei oder das ganze Datei System hinüber. Manchmal kann das repariert werden aber nicht immer.
                    Wenn du eine sd Karte gegen eine ssd tauschst dann minimierst du das Risiko noch weiter.
                    Ganz ausschließen kann man das Risiko aber bei keinem Speichermedium. Mit einer usv hat man zumindest aber auch noch genügend Strom um eine ganze applikation und das Betriebssystem ordentlich herunterzufahren.
                    HeimwehH Offline
                    HeimwehH Offline
                    Heimweh
                    #49
                    @oliverio ich habe auch eine SSD im NUC. Das krasse ist - bisher ist in JEDEM Fall passiert das eine der beiden Dateien zerschossen war... Ich bin gerade am recherchieren was für eine USV ich mir anschaffen werde. Am liebsten eine die auch einbindbar ist - um dann zB im Falle eines Stromausfalls das System kontrolliert runterfahren kann. (das würde ja mit den Proxmox Modulen umsetzbar sein)
                    • HeimwehH Heimweh
                      #50
                      @heimweh sagte in das leidige Thema "Stromausfall":
                      Das ist zwar keine Riesen UPS, kostet knapp 100€.
                      ich habe davon 2 Stück eingebunden
                      Für ein ganz paar kleine Rechnerchen hält sie aber auch etwa 1h
                      HeimwehH 1 Antwort Letzte Antwort
                        HeimwehH Offline
                        HeimwehH Offline
                        Heimweh
                        #51
                        @homoran interessant! Vielen Dank! Und ich nehme an mit dem NUT Adapter hast Du die eingebunden? Wie genau heißt das Modell denn? Ich würde maximal den NUC und die Fritzbox ranhängen - dann kann ich mir im Ernstfall auch noch eine Nachricht schicken lassen das der Strom ausgefallen ist
                        • HeimwehH Heimweh
                          #52
                          Aber nur wenn nicht das ganze Dorf inkl. Internet-Infrastruktur ohne Saft ist.
                          HeimwehH HomoranH 2 Antworten Letzte Antwort
                            HeimwehH Offline
                            HeimwehH Offline
                            Heimweh
                            #53
                            @thomas-braun ja das ist klar! Wobei ich neulich gelesen habe das zB Mobilfunk Sender noch ca. 20 Minuten gepuffert sind... Aber wie auch immer - es ging ja mehr darum das mein IObroker Server "überlebt"...
                              #54
                              @thomas-braun sagte in das leidige Thema "Stromausfall":
                              sonst hängt man noch einen Aldi-Stick an den Nuc und schickt ne SMS
                              Back UPS 700
                              habe gerade gesucht, die scheint es nicht mehr zu geben.
                              Ersatz ist wohl die 850er
                              https://www.reichelt.de/back-ups-850va-230v-usb-apc-be850g2-gr-p269971.html
                              Wobei ich da keine Erfahrung habe ob man diese auch an NUT-server einbinden kann
                                Back UPS 700
                                BananaJoeB Online
                                BananaJoeB Online
                                BananaJoe
                                #55
                                @homoran sagte in das leidige Thema "Stromausfall":
                                Back UPS 700
                                Die APC USV-Anlagen haben in der Regel immer alle ein USB-Kabel dabei (sogar die Server USV Geräte bis 5.000 VA).
                                Unter Windows wird das dann nach dem einstecken als Batterie gefunden, also auch ein normaler Desktop-PC hat dann eine Batterieanzeige wie ein Notebook, dementsprechend könnte man Ruhemodus etc. wie beim Notebook einstellen.
                                Man kann aber auch die APC-Software installieren und dort Dinge wie herunterfahren einstellen.
                                Oder per WMI abfragen: https://znil.net/index.php?title=Windows_Batterie_Akku_Status_per_WMI_abfragen
                                QNAP und Synologie-NAS Geräte unterstützen APC USVs auch direkt, einfach USB an dem Gerät anschließen und konfigurieren.
                                Unter Linux wird das zu 100% auch gehen, APC können sie alle.
                                Was man leider nicht so findet wieviel die Dinger verbraten ohne das etwas dran steckt.
                                Nachtrag: USV-Anlagen mit Netzwerkschnittstelle lassen sich immer per SNMP abfragen (behaupte ich mal bis das Gegenteil beweisen wurde)
                                • BananaJoeB BananaJoe
                                  Back UPS 700
                                  #56
                                  @bananajoe sagte in das leidige Thema "Stromausfall":
                                  war bisher so, in der Beschreibung der 850er steht "(nicht enthalten)"
                                  ich weiß nicht wehr sich ein RJ12->USB-Kabel selber basteln kann und will :-(
                                    BananaJoeB Online
                                    BananaJoeB Online
                                    BananaJoe
                                    #57
                                    @homoran neulich hatte ich eines verloren und für 10 Euro in der Bucht nachgekauft
                                    Aber ich behaupte das ist bei Neugeräten immer dabei. Ich meine bei USV-Anlagen steht bei Amazon auch "ohne Batterien" :-)
                                      #58
                                      Aber ich behaupte
                                      ich weiss es :-)
                                      Datenanschluss
                                      Schließen Sie ein RJ45-/USB-Kabel (nicht mitgeliefert) an, um die
                                      Back-UPS an einen Computer zur Installation der Software
                                      anzuschließen. Einzelheiten hierzu finden Sie unter
                                      „PowerChute™ Personal Edition Software“ auf Seite 7.
                                      BananaJoeB E 2 Antworten Letzte Antwort
                                        Aber ich behaupte
                                        ich weiss es :-)
                                        Datenanschluss
                                        BananaJoeB Online
                                        BananaJoeB Online
                                        BananaJoe
                                        #59
                                        @homoran verdammt, da hat wieder einer mit einer Excel-Tabelle errechnet wie die Firma pro Gerät wieder 50 Cent sparen kann ...
                                          Aber ich behaupte
                                          ich weiss es :-)
                                          Datenanschluss
                                          ente34
                                          #60
                                          Im Handbuch steht aber auch:
                                          HINWEIS: Zur Vermeidung von Elektronikschrott und zum Schutz der
                                          Umwelt werden grundsätzlich keine USB-Kabel mehr mitgeliefert. Sie können
                                          das Kabel kostenlos unter https://www.apc.com/usbcable bestellen
