  4. Problem mit Backup Wiederherstellung auf dem Raspi
112 Beiträge 5 Kommentatoren 6.8k Aufrufe 4 Beobachtet
  • G guitardoc
    Das "neue" Backup scheint auch nicht zu funktionieren:
    2021-12-08 12:11:04.517  - info: backitup.0 (3585) cleaned everything up...
    2021-12-08 12:11:04.516  - info: host.raspberrypi received SIGTERM
    2021-12-08 12:11:04.519  - info: admin.0 (3550) terminating http server on port 8081
    2021-12-08 12:11:04.527  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
    2021-12-08 12:11:04.528  - info: host.raspberrypi stopInstance system.adapter.email.0 (force=false, process=false)
    2021-12-08 12:11:04.528  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=false)
    2021-12-08 12:11:04.529  - info: host.raspberrypi stopInstance system.adapter.javascript.1 (force=false, process=false)
    2021-12-08 12:11:04.529  - info: host.raspberrypi stopInstance system.adapter.node-red.0 (force=false, process=false)
    2021-12-08 12:11:04.530  - info: host.raspberrypi stopInstance system.adapter.scenes.0 (force=false, process=false)
    2021-12-08 12:11:04.531  - info: host.raspberrypi stopInstance system.adapter.telegram.0 (force=false, process=false)
    2021-12-08 12:11:04.531  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
    2021-12-08 12:11:04.532  - info: host.raspberrypi stopInstance system.adapter.cloud.0 (force=false, process=false)
    2021-12-08 12:11:04.533  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
    2021-12-08 12:11:04.534  - info: host.raspberrypi stopInstance system.adapter.feiertage.0 (force=false, process=false)
    2021-12-08 12:11:04.534  - info: host.raspberrypi stopInstance system.adapter.homekit-controller.0 (force=false, process=false)
    2021-12-08 12:11:04.535  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=false)
    2021-12-08 12:11:04.535  - info: host.raspberrypi stopInstance system.adapter.shelly.0 (force=false, process=false)
    2021-12-08 12:11:04.535  - info: host.raspberrypi stopInstance system.adapter.shuttercontrol.0 (force=false, process=false)
    2021-12-08 12:11:04.536  - info: host.raspberrypi stopInstance system.adapter.simple-api.0 (force=false, process=false)
    2021-12-08 12:11:04.536  - info: host.raspberrypi stopInstance system.adapter.vis-map.0 (force=false, process=false)
    2021-12-08 12:11:04.536  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
    2021-12-08 12:11:04.537  - info: host.raspberrypi stopInstance system.adapter.vw-connect.0 (force=false, process=false)
    2021-12-08 12:11:04.537  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
    2021-12-08 12:11:04.537  - info: host.raspberrypi stopInstance system.adapter.wiffi-wz.0 (force=false, process=false)
    2021-12-08 12:11:04.538  - info: host.raspberrypi stopInstance system.adapter.yahka.0 (force=false, process=false)
    2021-12-08 12:11:04.559  - info: admin.0 (3550) Got terminate signal TERMINATE_YOURSELF
    2021-12-08 12:11:04.560  - info: backitup.0 (3585) Got terminate signal TERMINATE_YOURSELF
    2021-12-08 12:11:04.563  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
    2021-12-08 12:11:04.563  - info: admin.0 (3550) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-12-08 12:11:04.566  - info: backitup.0 (3585) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-12-08 12:11:04.567  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
    2021-12-08 12:11:05.200  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-12-08 12:11:05.340  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-12-08 12:11:05.344  - info: host.raspberrypi All instances are stopped.
    2021-12-08 12:11:05.429  - info: host.raspberrypi terminated
    2021-12-08 12:13:10.976  - info: host.raspberrypi iobroker.js-controller version 3.3.21 js-controller starting
    2021-12-08 12:13:10.983  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-12-08 12:13:10.984  - info: host.raspberrypi hostname: raspberrypi, node: v14.18.2
    2021-12-08 12:13:10.984  - info: host.raspberrypi ip addresses: 192.168.188.92 fdbd:a2c3:525b:1:f88b:d15e:fe84:a349 fe80::4ef6:367d:5ddc:535f 192.168.188.2 fdbd:a2c3:525b:1:c423:f77c:72ef:35e3 fe80::8b1c:6dce:899f:cad9
    2021-12-08 12:13:11.773  - info: host.raspberrypi connected to Objects and States
    2021-12-08 12:13:11.857  - info: host.raspberrypi added notifications configuration of host
    2021-12-08 12:13:12.680  - info: host.raspberrypi Delete host system.host.raspberrypi
    2021-12-08 12:13:12.776  - info: host.raspberrypi 23 instances found
    2021-12-08 12:13:12.830  - info: host.raspberrypi starting 2 instances
    2021-12-08 12:13:12.952  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 3961
    2021-12-08 12:13:15.443  - info: admin.0 (3961) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.2, js-controller: 3.3.21
    2021-12-08 12:13:15.508  - info: admin.0 (3961) requesting all states
    2021-12-08 12:13:15.513  - info: admin.0 (3961) requesting all objects
    2021-12-08 12:13:16.885  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 3990
    2021-12-08 12:13:17.136  - info: admin.0 (3961) received all objects
    2021-12-08 12:13:17.597  - info: admin.0 (3961) Request actual repository...
    2021-12-08 12:13:17.689  - info: admin.0 (3961) http server listening on port 8081
    2021-12-08 12:13:17.696  - info: admin.0 (3961) Use link "http://localhost:8081" to configure.
    2021-12-08 12:13:18.621  - info: host.raspberrypi Updating repository "Latest" under "http://iobroker.live/repo/sources-dist-latest.json"
    2021-12-08 12:13:20.266  - info: admin.0 (3961) Repository received successfully.
    2021-12-08 12:13:24.129  - info: backitup.0 (3990) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
    2021-12-08 12:13:24.192  - error: backitup.0 (3990) [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
    2021-12-08 12:13:24.193  - error: backitup.0 (3990) [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
    2021-12-08 12:13:24.194  - error: backitup.0 (3990) [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
    2021-12-08 12:13:24.195  - error: backitup.0 (3990) [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
    2021-12-08 12:13:24.196  - error: backitup.0 (3990) [ERROR] [iobroker] [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
    2021-12-08 12:13:24.198  - error: backitup.0 (3990) [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
    2021-12-08 12:13:24.582  - info: backitup.0 (3990) [iobroker] backup was activated at 02:00 every 1 day(s)
    Ich hab mal das Log von dem "neuen" Backup angehangen. Da kommen ein paar Fehler und Infos.
    [DEBUG] [iobroker] Start ioBroker Restore ...
    [DEBUG] [iobroker] iobroker controller daemon is not running
    [DEBUG] [iobroker] host.raspberrypi OK.
    [DEBUG] [iobroker] host.raspberrypi Clear all objects and states...
    [DEBUG] [iobroker] clean 5894 objects...
    [DEBUG] [iobroker] Server Objects 127.0.0.1:47822 Error from InMemDB: Error: Object is marked as non deletable
    [DEBUG] [iobroker] clean 4709 states...
    [DEBUG] [iobroker] host.raspberrypi done.
    [DEBUG] [iobroker] host.raspberrypi Processed 0/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 200/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 400/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 600/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 800/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 1000/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 1200/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 1400/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 1600/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 1800/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 2000/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 2200/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 2400/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 2600/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 2800/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 3000/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 3200/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 3400/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 3600/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 3800/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 4000/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 4200/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 4400/4743 states
    [DEBUG] [iobroker] host.raspberrypi Processed 4600/4743 states
    [DEBUG] [iobroker] 4743 states restored.
    [DEBUG] [iobroker] host.raspberrypi Processed 0/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 200/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 400/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 600/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 800/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 1000/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 1200/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 1400/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 1600/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 1800/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 2000/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 2200/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 2400/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 2600/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 2800/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 3000/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 3200/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 3400/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 3600/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 3800/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 4000/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 4200/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 4400/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 4600/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 4800/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 5000/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 5200/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 5400/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 5600/5897 objects
    [DEBUG] [iobroker] host.raspberrypi Processed 5800/5897 objects
    [DEBUG] [iobroker] 5897 objects restored.
    [DEBUG] [iobroker] host.raspberrypi Upload user file "vis.0/StandortFahrzeug/vis-views.json
    [DEBUG] [iobroker] host.raspberrypi Upload user file "vis.0/main/vis-views.json
    [DEBUG] [iobroker] upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
    [DEBUG] [iobroker] upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    [DEBUG] [iobroker] upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    [DEBUG] [iobroker] upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    [DEBUG] [iobroker] upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    [DEBUG] [iobroker] upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    [DEBUG] [iobroker] upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    [DEBUG] [iobroker] upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    [DEBUG] [iobroker] upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    [DEBUG] [iobroker] upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    [DEBUG] [iobroker] upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    [DEBUG] [iobroker] upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    [DEBUG] [iobroker] upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    [DEBUG] [iobroker] upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    [DEBUG] [iobroker] upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    [DEBUG] [iobroker] upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    [DEBUG] [iobroker] upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    [DEBUG] [iobroker] upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    [DEBUG] [iobroker] upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    [DEBUG] [iobroker] upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    [DEBUG] [iobroker] upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
    [DEBUG] [iobroker] upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
    [DEBUG] [iobroker] upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    [DEBUG] [iobroker] upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    [DEBUG] [iobroker] upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    [DEBUG] [iobroker] upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    [DEBUG] [iobroker] upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    [DEBUG] [iobroker] upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
    [DEBUG] [iobroker] upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    [DEBUG] [iobroker] upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
    [DEBUG] [iobroker] upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
    [DEBUG] [iobroker] upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
    [DEBUG] [iobroker] upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
    [DEBUG] [iobroker] upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
    [DEBUG] [iobroker] upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
    [DEBUG] [iobroker] upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
    [DEBUG] [iobroker] upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    [DEBUG] [iobroker] upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    [DEBUG] [iobroker] upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    [DEBUG] [iobroker] upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    [DEBUG] [iobroker] upload [4] email.admin /opt/iobroker/node_modules/iobroker.email/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [3] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [2] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [1] email.admin /opt/iobroker/node_modules/iobroker.email/admin/email.png email.png image/png
    [DEBUG] [iobroker] upload [0] email.admin /opt/iobroker/node_modules/iobroker.email/admin/blockly.js blockly.js application/javascript
    [DEBUG] [iobroker] upload [4] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [3] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [2] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [1] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/holidays.js holidays.js application/javascript
    [DEBUG] [iobroker] upload [0] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/feiertage.png feiertage.png image/png
    [DEBUG] [iobroker] upload [20] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
    [DEBUG] [iobroker] upload [19] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
    [DEBUG] [iobroker] upload [18] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
    [DEBUG] [iobroker] upload [17] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
    [DEBUG] [iobroker] upload [16] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
    [DEBUG] [iobroker] upload [15] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
    [DEBUG] [iobroker] upload [14] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html.map edit.html.map application/json
    [DEBUG] [iobroker] upload [13] flot /opt/iobroker/node_modules/iobroker.flot/www/edit.html edit.html text/html
    [DEBUG] [iobroker] upload [12] flot /opt/iobroker/node_modules/iobroker.flot/www/css/jquery.colorpicker.css css/jquery.colorpicker.css text/css
    [DEBUG] [iobroker] upload [11] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/ui-colorpicker.png css/images/ui-colorpicker.png image/png
    [DEBUG] [iobroker] upload [10] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/preview-opacity.png css/images/preview-opacity.png image/png
    [DEBUG] [iobroker] upload [9] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map.png css/images/map.png image/png
    [DEBUG] [iobroker] upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-pointer.png css/images/map-pointer.png image/png
    [DEBUG] [iobroker] upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/map-opacity.png css/images/map-opacity.png image/png
    [DEBUG] [iobroker] upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar.png css/images/bar.png image/png
    [DEBUG] [iobroker] upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-pointer.png css/images/bar-pointer.png image/png
    [DEBUG] [iobroker] upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-opacity.png css/images/bar-opacity.png image/png
    [DEBUG] [iobroker] upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/bar-alpha.png css/images/bar-alpha.png image/png
    [DEBUG] [iobroker] upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/map.png css/images/128/map.png image/png
    [DEBUG] [iobroker] upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar.png css/images/128/bar.png image/png
    [DEBUG] [iobroker] upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-alpha.png image/png
    [DEBUG] [iobroker] upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
    [DEBUG] [iobroker] host.raspberrypi Setup "iobroker.flot" adapter
    [DEBUG] [iobroker] upload [10] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/js/runtime-main.f705f273.js static/js/runtime-main.f705f273.js application/javascript
    [DEBUG] [iobroker] upload [9] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/js/main.73ad8aca.chunk.js static/js/main.73ad8aca.chunk.js application/javascript
    [DEBUG] [iobroker] upload [8] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/js/2.e5a95dd3.chunk.js.LICENSE.txt static/js/2.e5a95dd3.chunk.js.LICENSE.txt text/plain
    [DEBUG] [iobroker] upload [7] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/js/2.e5a95dd3.chunk.js static/js/2.e5a95dd3.chunk.js application/javascript
    [DEBUG] [iobroker] upload [6] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    [DEBUG] [iobroker] upload [5] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
    [DEBUG] [iobroker] upload [4] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/manifest.json manifest.json application/json
    [DEBUG] [iobroker] upload [3] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [2] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/homekit-controller.png homekit-controller.png image/png
    [DEBUG] [iobroker] upload [1] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    [DEBUG] [iobroker] upload [0] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/asset-manifest.json asset-manifest.json application/json
    [DEBUG] [iobroker] upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
    [DEBUG] [iobroker] upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
    [DEBUG] [iobroker] upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/xubuntu.png lib/img/logos/xubuntu.png image/png
    [DEBUG] [iobroker] upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/pclinuxos.png lib/img/logos/pclinuxos.png image/png
    [DEBUG] [iobroker] upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/freebsd.png lib/img/logos/freebsd.png image/png
    [DEBUG] [iobroker] upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/usb.png lib/img/icons/usb.png image/png
    [DEBUG] [iobroker] upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/bluetooth.png lib/img/icons/bluetooth.png image/png
    [DEBUG] [iobroker] upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
    [DEBUG] [iobroker] upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/audio.png lib/img/icons/audio.png image/png
    [DEBUG] [iobroker] upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
    [DEBUG] [iobroker] upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
    [DEBUG] [iobroker] upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
    [DEBUG] [iobroker] upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
    [DEBUG] [iobroker] upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
    [DEBUG] [iobroker] upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
    [DEBUG] [iobroker] upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
    [DEBUG] [iobroker] upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
    [DEBUG] [iobroker] upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
    [DEBUG] [iobroker] upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
    [DEBUG] [iobroker] upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
    [DEBUG] [iobroker] upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
    [DEBUG] [iobroker] upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
    [DEBUG] [iobroker] upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
    [DEBUG] [iobroker] upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
    [DEBUG] [iobroker] upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
    [DEBUG] [iobroker] upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
    [DEBUG] [iobroker] upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
    [DEBUG] [iobroker] upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
    [DEBUG] [iobroker] upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/javascript/javascript.js vs/basic-languages/javascript/javascript.js application/javascript
    [DEBUG] [iobroker] upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.fc5df117.chunk.js static/js/main.fc5df117.chunk.js application/javascript
    [DEBUG] [iobroker] upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
    [DEBUG] [iobroker] upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
    [DEBUG] [iobroker] upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
    [DEBUG] [iobroker] upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
    [DEBUG] [iobroker] upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
    [DEBUG] [iobroker] upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
    [DEBUG] [iobroker] upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
    [DEBUG] [iobroker] upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
    [DEBUG] [iobroker] upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
    [DEBUG] [iobroker] upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
    [DEBUG] [iobroker] upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
    [DEBUG] [iobroker] upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
    [DEBUG] [iobroker] upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
    [DEBUG] [iobroker] upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
    [DEBUG] [iobroker] upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
    [DEBUG] [iobroker] upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
    [DEBUG] [iobroker] upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
    [DEBUG] [iobroker] upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
    [DEBUG] [iobroker] upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
    [DEBUG] [iobroker] upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
    [DEBUG] [iobroker] upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
    [DEBUG] [iobroker] upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    [DEBUG] [iobroker] upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
    [DEBUG] [iobroker] upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    [DEBUG] [iobroker] host.raspberrypi Setup "iobroker.javascript" adapter
    [DEBUG] [iobroker] upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    [DEBUG] [iobroker] upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    [DEBUG] [iobroker] upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    [DEBUG] [iobroker] upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    [DEBUG] [iobroker] upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    [DEBUG] [iobroker] upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    [DEBUG] [iobroker] upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
    [DEBUG] [iobroker] upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    [DEBUG] [iobroker] upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
    [DEBUG] [iobroker] upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
    [DEBUG] [iobroker] upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
    [DEBUG] [iobroker] upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
    [DEBUG] [iobroker] upload [17] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/worker-json.js worker-json.js application/javascript
    [DEBUG] [iobroker] upload [16] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/tab.html tab.html text/html
    [DEBUG] [iobroker] upload [15] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/style.css style.css text/css
    [DEBUG] [iobroker] upload [14] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/runtime-main.161dc6ad.js.map static/js/runtime-main.161dc6ad.js.map application/json
    [DEBUG] [iobroker] upload [13] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/runtime-main.161dc6ad.js static/js/runtime-main.161dc6ad.js application/javascript
    [DEBUG] [iobroker] upload [12] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/main.2b32e4c4.chunk.js.map static/js/main.2b32e4c4.chunk.js.map application/json
    [DEBUG] [iobroker] upload [11] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/main.2b32e4c4.chunk.js static/js/main.2b32e4c4.chunk.js application/javascript
    [DEBUG] [iobroker] upload [10] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/2.2afdfa2c.chunk.js.map static/js/2.2afdfa2c.chunk.js.map application/json
    [DEBUG] [iobroker] upload [9] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/2.2afdfa2c.chunk.js.LICENSE.txt static/js/2.2afdfa2c.chunk.js.LICENSE.txt text/plain
    [DEBUG] [iobroker] upload [8] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/js/2.2afdfa2c.chunk.js static/js/2.2afdfa2c.chunk.js application/javascript
    [DEBUG] [iobroker] upload [7] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    [DEBUG] [iobroker] upload [6] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    [DEBUG] [iobroker] upload [5] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
    [DEBUG] [iobroker] upload [4] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
    [DEBUG] [iobroker] upload [3] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/scenes.png scenes.png image/png
    [DEBUG] [iobroker] upload [2] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/manifest.json manifest.json application/json
    [DEBUG] [iobroker] upload [1] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    [DEBUG] [iobroker] upload [0] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/asset-manifest.json asset-manifest.json application/json
    [DEBUG] [iobroker] upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
    [DEBUG] [iobroker] upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
    [DEBUG] [iobroker] upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
    [DEBUG] [iobroker] upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js index_m.js application/javascript
    [DEBUG] [iobroker] upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/info-big.png image/png
    [DEBUG] [iobroker] upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
    [DEBUG] [iobroker] upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
    [DEBUG] [iobroker] upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
    [DEBUG] [iobroker] upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
    [DEBUG] [iobroker] upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
    [DEBUG] [iobroker] upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
    [DEBUG] [iobroker] host.raspberrypi Setup "iobroker.telegram" adapter
    [DEBUG] [iobroker] upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui.html widgets/jqui.html text/html
    [DEBUG] [iobroker] upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBool.png widgets/basic/img/Prev_ValueBool.png image/png
    [DEBUG] [iobroker] upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
    [DEBUG] [iobroker] upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
    [DEBUG] [iobroker] upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
    [DEBUG] [iobroker] upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
    [DEBUG] [iobroker] upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
    [DEBUG] [iobroker] upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
    [DEBUG] [iobroker] upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
    [DEBUG] [iobroker] upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
    [DEBUG] [iobroker] upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
    [DEBUG] [iobroker] upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
    [DEBUG] [iobroker] upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
    [DEBUG] [iobroker] upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
    [DEBUG] [iobroker] upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
    [DEBUG] [iobroker] upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
    [DEBUG] [iobroker] upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
    [DEBUG] [iobroker] upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
    [DEBUG] [iobroker] upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
    [DEBUG] [iobroker] upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
    [DEBUG] [iobroker] upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
    [DEBUG] [iobroker] upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
    [DEBUG] [iobroker] upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
    [DEBUG] [iobroker] upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
    [DEBUG] [iobroker] upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
    [DEBUG] [iobroker] upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
    [DEBUG] [iobroker] upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
    [DEBUG] [iobroker] upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
    [DEBUG] [iobroker] upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
    [DEBUG] [iobroker] upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
    [DEBUG] [iobroker] upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
    [DEBUG] [iobroker] upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
    [DEBUG] [iobroker] upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
    [DEBUG] [iobroker] upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
    [DEBUG] [iobroker] upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
    [DEBUG] [iobroker] INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-map/www" was not found! Nothing was uploaded or deleted.
    [DEBUG] [iobroker] upload [3] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [2] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/vis-map.png vis-map.png image/png
    [DEBUG] [iobroker] upload [1] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [0] vis-map.admin /opt/iobroker/node_modules/iobroker.vis-map/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
    [DEBUG] [iobroker] upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
    [DEBUG] [iobroker] upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
    [DEBUG] [iobroker] upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
    [DEBUG] [iobroker] upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
    [DEBUG] [iobroker] upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
    [DEBUG] [iobroker] upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
    [DEBUG] [iobroker] upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
    [DEBUG] [iobroker] upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
    [DEBUG] [iobroker] upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
    [DEBUG] [iobroker] upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
    [DEBUG] [iobroker] upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
    [DEBUG] [iobroker] upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
    [DEBUG] [iobroker] upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
    [DEBUG] [iobroker] upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
    [DEBUG] [iobroker] upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
    [DEBUG] [iobroker] upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
    [DEBUG] [iobroker] upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
    [DEBUG] [iobroker] upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
    [DEBUG] [iobroker] upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
    [DEBUG] [iobroker] upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
    [DEBUG] [iobroker] upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
    [DEBUG] [iobroker] upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
    [DEBUG] [iobroker] upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
    [DEBUG] [iobroker] upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
    [DEBUG] [iobroker] upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
    [DEBUG] [iobroker] upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
    [DEBUG] [iobroker] upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
    [DEBUG] [iobroker] upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
    [DEBUG] [iobroker] upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
    [DEBUG] [iobroker] upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
    [DEBUG] [iobroker] upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
    [DEBUG] [iobroker] upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
    [DEBUG] [iobroker] upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
    [DEBUG] [iobroker] upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
    [DEBUG] [iobroker] upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
    [DEBUG] [iobroker] upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
    [DEBUG] [iobroker] upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
    [DEBUG] [iobroker] upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
    [DEBUG] [iobroker] upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.6adebaf4.js.map static/js/runtime-main.6adebaf4.js.map application/json
    [DEBUG] [iobroker] upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.6adebaf4.js static/js/runtime-main.6adebaf4.js application/javascript
    [DEBUG] [iobroker] upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.3135e842.chunk.js.map static/js/main.3135e842.chunk.js.map application/json
    [DEBUG] [iobroker] upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.3135e842.chunk.js static/js/main.3135e842.chunk.js application/javascript
    [DEBUG] [iobroker] upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.df85bec8.chunk.js.map static/js/2.df85bec8.chunk.js.map application/json
    [DEBUG] [iobroker] upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.df85bec8.chunk.js.LICENSE.txt static/js/2.df85bec8.chunk.js.LICENSE.txt text/plain
    [DEBUG] [iobroker] upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.df85bec8.chunk.js static/js/2.df85bec8.chunk.js application/javascript
    [DEBUG] [iobroker] upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    [DEBUG] [iobroker] upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    [DEBUG] [iobroker] upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
    [DEBUG] [iobroker] upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
    [DEBUG] [iobroker] upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
    [DEBUG] [iobroker] upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    [DEBUG] [iobroker] upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
    [DEBUG] [iobroker] host.raspberrypi Setup "iobroker.web" adapter
    [DEBUG] [iobroker] upload [2] wiffi-wz.admin /opt/iobroker/node_modules/iobroker.wiffi-wz/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [1] wiffi-wz.admin /opt/iobroker/node_modules/iobroker.wiffi-wz/admin/wiffi-wz.png wiffi-wz.png image/png
    [DEBUG] [iobroker] upload [0] wiffi-wz.admin /opt/iobroker/node_modules/iobroker.wiffi-wz/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
    [DEBUG] [iobroker] upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
    [DEBUG] [iobroker] upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
    [DEBUG] [iobroker] upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
    [DEBUG] [iobroker] upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
    [DEBUG] [iobroker] upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
    [DEBUG] [iobroker] upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
    [DEBUG] [iobroker] upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
    [DEBUG] [iobroker] upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
    [DEBUG] [iobroker] upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
    [DEBUG] [iobroker] upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
    [DEBUG] [iobroker] upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
    [DEBUG] [iobroker] upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
    [DEBUG] [iobroker] upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
    [DEBUG] [iobroker] upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
    [DEBUG] [iobroker] upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
    [DEBUG] [iobroker] upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
    [DEBUG] [iobroker] upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
    [DEBUG] [iobroker] upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
    [DEBUG] [iobroker] upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
    [DEBUG] [iobroker] host.raspberrypi Setup "iobroker.yahka" adapter
    [DEBUG] [iobroker] host.raspberrypi object 0_userdata.0.example_state created
    [DEBUG] [iobroker] System successfully restored!
    [DEBUG] [iobroker] ioBroker Restore completed successfully
    [EXIT] 0 **** Restore completed successfully!! ****
    The log can be closed ...
    Ich versuche mal noch ein anderes Backup...
    #101
    @guitardoc sagte in Problem mit Backup Wiederherstellung auf dem Raspi:
    und jetzt eine Stunde warten!
    iobroker logs --watch zeigt dir, dass jetzt alles erst installiert wird
    G 1 Antwort Letzte Antwort
      guitardoc
      schrieb am zuletzt editiert von guitardoc
      #102
      @homoran Du meinst, die angezeigten Fehler spielen keine Rolle? OK, ich warte mal. Aber iobroker logs --watch läuft eine Weile durch bis yahka (das ist mein letzter Adapter) und dann kommt nichts mehr, da zuckt sich nichts... OK, eine Stunde warten fällt mir schwer, aber ich werde es aushalten... :-)
      Edit: Der Durchlauf bis Yahka war nur beim allerersten Backup, mittlerweile ist schon hier Schluss:
      2021-12-08 12:17:06.540  - info: backitup.0 (3990) cleaned everything up...
      2021-12-08 12:17:06.536  - info: host.raspberrypi received SIGTERM
      2021-12-08 12:17:06.537  - info: admin.0 (3961) terminating http server on port 8081
      2021-12-08 12:17:06.546  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
      2021-12-08 12:17:06.547  - info: host.raspberrypi stopInstance system.adapter.email.0 (force=false, process=false)
      2021-12-08 12:17:06.548  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=false)
      2021-12-08 12:17:06.549  - info: host.raspberrypi stopInstance system.adapter.javascript.1 (force=false, process=false)
      2021-12-08 12:17:06.549  - info: host.raspberrypi stopInstance system.adapter.node-red.0 (force=false, process=false)
      2021-12-08 12:17:06.550  - info: host.raspberrypi stopInstance system.adapter.scenes.0 (force=false, process=false)
      2021-12-08 12:17:06.551  - info: host.raspberrypi stopInstance system.adapter.telegram.0 (force=false, process=false)
      2021-12-08 12:17:06.551  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
      2021-12-08 12:17:06.552  - info: host.raspberrypi stopInstance system.adapter.cloud.0 (force=false, process=false)
      2021-12-08 12:17:06.553  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
      2021-12-08 12:17:06.554  - info: host.raspberrypi stopInstance system.adapter.feiertage.0 (force=false, process=false)
      2021-12-08 12:17:06.554  - info: host.raspberrypi stopInstance system.adapter.homekit-controller.0 (force=false, process=false)
      2021-12-08 12:17:06.555  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=false)
      2021-12-08 12:17:06.555  - info: host.raspberrypi stopInstance system.adapter.shelly.0 (force=false, process=false)
      2021-12-08 12:17:06.555  - info: host.raspberrypi stopInstance system.adapter.shuttercontrol.0 (force=false, process=false)
      2021-12-08 12:17:06.556  - info: host.raspberrypi stopInstance system.adapter.simple-api.0 (force=false, process=false)
      2021-12-08 12:17:06.556  - info: host.raspberrypi stopInstance system.adapter.vis-map.0 (force=false, process=false)
      2021-12-08 12:17:06.556  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
      2021-12-08 12:17:06.557  - info: host.raspberrypi stopInstance system.adapter.vw-connect.0 (force=false, process=false)
      2021-12-08 12:17:06.557  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
      2021-12-08 12:17:06.557  - info: host.raspberrypi stopInstance system.adapter.wiffi-wz.0 (force=false, process=false)
      2021-12-08 12:17:06.558  - info: host.raspberrypi stopInstance system.adapter.yahka.0 (force=false, process=false)
      2021-12-08 12:17:06.597  - info: backitup.0 (3990) Got terminate signal TERMINATE_YOURSELF
      2021-12-08 12:17:06.601  - info: backitup.0 (3990) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-12-08 12:17:06.602  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
      2021-12-08 12:17:06.604  - info: admin.0 (3961) Got terminate signal TERMINATE_YOURSELF
      2021-12-08 12:17:06.608  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
      2021-12-08 12:17:06.608  - info: admin.0 (3961) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-12-08 12:17:07.228  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-12-08 12:17:07.355  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-12-08 12:17:07.357  - info: host.raspberrypi All instances are stopped.
      2021-12-08 12:17:07.407  - info: host.raspberrypi terminated
      2021-12-08 12:19:14.564  - info: host.raspberrypi iobroker.js-controller version 3.3.21 js-controller starting
      2021-12-08 12:19:14.570  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-12-08 12:19:14.571  - info: host.raspberrypi hostname: raspberrypi, node: v14.18.2
      2021-12-08 12:19:14.572  - info: host.raspberrypi ip addresses: 192.168.188.92 fdbd:a2c3:525b:1:f88b:d15e:fe84:a349 fe80::4ef6:367d:5ddc:535f 192.168.188.2 fdbd:a2c3:525b:1:c423:f77c:72ef:35e3 fe80::8b1c:6dce:899f:cad9
      2021-12-08 12:19:15.325  - info: host.raspberrypi connected to Objects and States
      2021-12-08 12:19:15.416  - info: host.raspberrypi added notifications configuration of host
      2021-12-08 12:19:16.245  - info: host.raspberrypi Delete host system.host.raspberrypi
      2021-12-08 12:19:16.335  - info: host.raspberrypi 23 instances found
      2021-12-08 12:19:16.385  - info: host.raspberrypi starting 2 instances
      2021-12-08 12:19:16.498  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 4417
      2021-12-08 12:19:18.957  - info: admin.0 (4417) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.2, js-controller: 3.3.21
      2021-12-08 12:19:19.024  - info: admin.0 (4417) requesting all states
      2021-12-08 12:19:19.025  - info: admin.0 (4417) requesting all objects
      2021-12-08 12:19:20.451  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 4432
      2021-12-08 12:19:20.600  - info: admin.0 (4417) received all objects
      2021-12-08 12:19:21.008  - info: admin.0 (4417) Request actual repository...
      2021-12-08 12:19:21.074  - info: admin.0 (4417) http server listening on port 8081
      2021-12-08 12:19:21.075  - info: admin.0 (4417) Use link "http://localhost:8081" to configure.
      2021-12-08 12:19:22.151  - info: host.raspberrypi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
      2021-12-08 12:19:23.566  - info: admin.0 (4417) Repository received successfully.
      2021-12-08 12:19:27.111  - info: backitup.0 (4432) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
      2021-12-08 12:19:27.182  - error: backitup.0 (4432) [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
      2021-12-08 12:19:27.184  - error: backitup.0 (4432) [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
      2021-12-08 12:19:27.185  - error: backitup.0 (4432) [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
      2021-12-08 12:19:27.186  - error: backitup.0 (4432) [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
      2021-12-08 12:19:27.188  - error: backitup.0 (4432) [ERROR] [iobroker] [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
      2021-12-08 12:19:27.190  - error: backitup.0 (4432) [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
      2021-12-08 12:19:27.598  - info: backitup.0 (4432) [iobroker] backup was activated at 02:00 every 1 day(s)
      • G guitardoc
        #103
        Mein Fehler - scheint komplett durch zu sein
        und was ist jetzt der Status?
          guitardoc
          #104
          @homoran Siehe Post vorher, hab ich gerade editiert...
          Die Adapter sind alle grau, bis auf Admin und Backitup.
          • G guitardoc
            #105
            und wie soll man dann den ursprünglichen "Fehler" finden wenn du dein System schneller änderst als man Antworten auf seine Fragen bekommt?
            Hast du den Hostnamen geändert?
              guitardoc
              #106
              @homoran Haaaaa!!!! Jetzt kommen sie alle wieder!!!!! Ohje, das war eine schwere Geburt!!! Alle Grün und laufen!!!!
              Vielen vielen vielen Dank für die Hilfe!!!! Ohne euch hätte ich das niemals geschafft. Hier bekommt man wirklich noch mit Leidenschaft geholfen. Danke Danke Danke noch mal!!!!!
              • G guitardoc
                #107
                Hast wohl gerade erst den Browser refreshed?
                  guitardoc
                  #108
                  @homoran Nein, den hab ich alle paar Sekunden refresht. Auch die Adapter immer mal neu geladen. Da tat sich nichts. Plötzlich tauchten sie auf. Irgendwas hat da wohl gehangen. Keine Ahnung...
                  Oh Mann jetzt bin ich aber froh...
                  J 1 Antwort Letzte Antwort
                  • G guitardoc
                    Jan1
                    #109
                    @guitardoc
                    Viele Instanzen und nur 2GB RAM, wurde ja gestern schon gesagt, dass das etwas wenig ist ;)
                    • J Jan1
                      @guitardoc
                      guitardoc
                      #110
                      @jan1 Bin mir nicht sicher wieviel GB RAM mein Raspi hat. Ich denke fast dass ich damals 4GB RAM gekauft hab. Kann man das irgendwo ablesen?
                      • G guitardoc
                        Jan1
                        #111
                        @guitardoc
                        Am einfachsten im Info Adapter. Der Restor braucht viel RAM wenn viele Instanzen vorhanden sind.
                        2GB sind da nicht wirklich viel. 4GB sollten locker reichen.
                        • J Jan1
                          @guitardoc
                          guitardoc
                          #112
                          @jan1 ich hab gerade geschaut - RAM im Moment 3,75GB, also hat der Raspi 4GB. Hab ich mich richtig erinnert.
                          Ich habe wirklich keine Idee wieso die Wiederherstellung auf einmal geklappt hat. Vor allem hab ich dann danach auch noch mal das letzte Backup genommen (das was gestern nicht lief) und das ging auch problemlos durch. Fast so als wenn ein Pfropfen in der Leitung gesteckt hat und kaum war der raus flutscht es wieder. Sehr mysteriös…
